View Full Version : 3rd Generation Maxima (1989-1994)
  1. Car Won't Start!
  2. buzzing noise
  3. gunk in my cai
  4. knock sensor resistor
  5. maxima of golf
  6. Ex Manifold studs - manifold
  7. Brake bleeding order confusion
  8. just installed digital dash on 92 se 5sp
  9. Block heater
  10. problems with door locks...
  11. who said they got replacement bose amps 4 free?
  12. testing harness
  13. Trunk not opening
  14. Y pipe.
  15. Idle problem with ve
  16. auto > manual swap
  17. Hi-Beam issue
  18. Problems starting engine
  19. Need help, diagnosing random engine cut off
  20. car acting very strange today(long)
  21. Check engine
  22. Dead water temp. gauge... how do I change it?
  23. tranny help!!!!
  24. Angel Eyes
  25. Upgrades
  26. Charging issue
  27. best way to polish valve covers?
  28. How many of you have replaced you cats?
  29. Are JDM VE engines proven to be a tad more powerful than the american VE?
  30. Changing Fuel Injector...Experts..
  31. LED turn signal update
  32. Tail Light
  33. Grinding Under feet?
  34. New crank arm sensor...how much should this be?
  35. Clutch engagement
  36. found a site with a bunch of parts
  37. Head Unit for 2002 SE
  38. Lights
  39. 91 GXE for Sale -- AS IS
  40. 205/R15 Specs
  41. complete asthetic restoration (need parts)
  42. A few pics of me goofing off at the track...
  43. Guage Cluster Malfunction - Any Ideas?
  44. 200k - too many miles?
  45. Foglight Kits?
  46. AE Pedals & Shift Knob
  47. Question about alarms =) (and HI)
  48. O2 sensor problems
  49. need help with the rust recall (long)
  50. sunroof shade?
  51. installed heads-up display
  52. hi flow cats
  53. How to remove right axle?
  54. sohc vg30 turbo off a 84-89 300zx turbo on a gxe sohc?
  55. My VE's gone!!!!
  56. Turbo Maxima Project
  57. Id10t light
  58. interested in having another choice in the exhaust world?
  59. timing chain or belt?
  60. Help!!!! Vg?
  61. good find at Junkyard
  62. vent problems....is this common?
  63. Exhaust woe's
  64. If not lines on fuel rails, where is smell coming from?
  65. Daytime Running Lights
  66. Projectors not Projecting. . .GRRRR. . .
  67. One headlight
  68. Digital Climate display gone out
  69. High theft!!
  70. Steering Whell Vibration - Part 2
  71. Yzza1?
  72. just wanted to say
  73. HELP!! VE- Great when its cool, weird when hot
  74. Hey MODERATOR since i cant post to my last thread
  75. Sold the max free left over parts post in the for sale
  76. hoses/tubing
  77. aftermarket speakers
  78. Are these symptoms of my alternator going bad??
  79. Climate Controls are Dead
  80. Help with rear window mechanism
  81. picture of painted rims.
  82. stillen body kit
  83. strange problem...no spark
  84. How to pull Check Engine Light codes?
  85. Tranny Whines in 1st & 2nd??? (5spd)
  86. Anodized or Chrome Rims?
  87. Help ID electronic box under dash
  88. Matt's Project of the Week
  89. 2002 SE...price good??
  90. help: dead injector? newbie question
  91. what are the ohms on bose speaker?
  92. Hate being at stock height!!!!
  93. F/R brake replacement tips
  94. Bose Front Passenger Speaker Craclking. Need help
  95. LooKing for the maxima piece in middle of trunk.
  96. bleed coolant system.
  97. door codes
  98. 90VG -> 93VG Experts Only
  99. Where to connect chain to lift the engine
  100. possible cf hood for 3rd gen...with enough interest
  101. Oil Thread
  102. Ticking coming from engine after car is turned off
  103. What is this new noise?
  104. Electrical Gremlins
  105. Dash light troubles
  106. Aluminum Dash Kit Pics?
  107. Terrible day with clutch
  108. what site can i go to buy spring and struts 91 max
  109. Strut Brace - cheap vs. expensive
  110. car sways from side to side during heavy acceleration.......bad axle?
  111. Interior color question
  112. Basic performance mods?
  113. NGK O2 sensor
  114. tranny issue
  115. Installed my Australian front sway bar today
  116. Internal Engine question
  117. need help asap on brake pads!
  118. Plug gap
  119. got an 89 SE today.. some probelms
  120. Heater blower problem
  121. Speed Sensor Question on 91 Maxima SE
  122. Fog light. How to fix it?
  123. Rear Defroster
  124. found my '91
  125. trouble starting car this morning
  126. Is the Nissan's Security System reliable?
  127. shocks struts 90 max
  128. Vibration on steering wheel
  129. Fuel economy/range
  130. pulled ecu codes
  131. seats, heated seats stock?
  132. QTEC Cuttout Exhaust?
  133. The hisotry of my 3rd gen maxima
  134. H&R Springs for 3rd gen????
  135. My '92 SE (VE Engine)
  136. exhaust
  137. Heater Core
  138. 1989 color codes
  139. Headlight out, not the bulb.
  140. I'm so gay, I sex myself!
  141. Car keeps getting kicked out of gear
  142. bad morning
  143. Engine Cont Fuse Keeps Blowing
  144. buying stuff
  145. glow gauges
  146. rear defroster
  147. ECU - CONSULT question
  148. fixing broken speaker
  149. Sunroof one-touch switch
  150. No Brake Lights
  151. stalling and high pitch sound
  152. A few Noob Troubleshooting Questions...
  153. Max FINALLY Back on Road...a few annoyances...
  154. Smog test results.
  155. I'm going to be selling my JWT ECU pretty soon........
  156. factory alarm question
  157. couple of new pics
  158. Tranny removal
  159. aftermarket rims max
  160. Do I need to change my WP on my JDM?
  161. Location of Door Lock Switch
  162. Digital Dash Repair
  163. Good news/Bad news
  164. Hesitation then sputtering then stalling out
  165. smoked tailights
  166. What type of liquid gasket to use?
  167. OEM anti-theft system
  168. Driver Seat Belt Stuck [Please Help]
  169. sunroof doesnt open
  170. Sunroof auto relay
  171. Transmission requires "Double-Clutching" when downshifting
  172. Heater Controls
  173. Electrical Prob
  174. Finally fixed my injector problem.
  175. fuse identification
  176. ASP pulley installed!!
  177. 99/98 Infiniti I30 or Maxima SE-Auto
  178. Power Windows not working
  179. front end poping noise
  180. strut tower brace
  181. z32 wheel question
  182. 20 questions.
  183. loud click under hood after changing timing belt
  184. 18" Wheels
  185. Help removing my control arm.
  186. Biggest pain in the ***
  187. My engine fell.
  188. tranny codes??
  189. Camber kits.
  190. Exhaust For The 92 GXE
  191. Front End Problems and Alignment
  192. cheapest place to buy ball joints?
  193. Problem 2
  194. Problems
  195. New Spark Plugs, new noises
  196. 8mm Spark Plug wires
  197. Updated Cardomain and new Stillen Front Lip pix inside!!
  198. question on oil pressure
  199. Pics of the triplets
  200. Leather seats....
  201. Skid Plates
  202. rebuild tranny place?
  203. throttle position sensor...
  204. vibration when air turns on
  205. auto >> manual
  206. My day at the junkyard...
  207. Where to buy seat covers?
  208. Front Wheel Studs and Lug Nuts
  209. Weight of Alloy Rims Setup
  210. Advanced Timing check
  211. Heater problems, maybe faulty thermostat? Please help.
  212. driver side molding
  213. Turn Signal 1156>1157 Conversion
  214. Erebuni body kit
  215. gauging interest: VE and VG Stainless Steel clutch lines!
  216. no power to the washer pump.
  217. brake click
  218. 3" CAI anyone have them?
  219. Hazard Switch! The Bane Of My Existence.
  220. What do mods do to MPG?
  221. Stalling issues
  222. Question about pulling engine - 92 SE 5-spd
  223. replaced the thermostat, waterpump..car still overheats!
  224. Dash lights / chime out. Fuses ok. Where to look?
  225. just got a rebuilt on my tranny
  226. clicking noise...
  227. gauging interest auto trim shifter
  228. Bose: Error code hhhhh and won't play CDs
  229. other names for interlocking differential?
  230. Race Pipe?
  231. Indiglo Reverse Gauges?
  232. Carbon Fiber Hood?
  233. Door & Dash Panels?
  234. '01 Aniversery SE Rims
  235. "rebuilding" se wheels....
  236. VG Headers That Bad?.....You Decide
  237. Need some help to change my timing belt
  238. Interior Control
  239. Sluggish Maxima requires assistance please
  240. Tps?
  241. starting trouble...
  242. leaking?
  243. Deep stumble at low Rpms
  244. engine light on and started up rough, help!
  245. Piaa Fog?driving Lights
  246. painting advice
  247. that lump in our trunk
  248. Pointers
  249. Will "Infiniti M30 Oil Filter" fit in Max?
  250. Odd sound coming from clutch area
