View Full Version : 3rd Generation Maxima (1989-1994)
  1. Extreme Rattling HELP.
  2. JWT ECU and gas problems
  3. Head up display
  4. pacesetter headers update
  5. break-in for new cars
  6. What front axles do I need???
  7. fixed gas smell in car, but now a new problem starting. i love problems
  8. Arrgh I'm stuck (i Think)
  9. grounded vtc car sucks
  10. Replacing injector. Have couple questions.
  11. I blew something...
  12. What is this? Light Bar?
  13. dash, tail, parking lights not working.
  14. overdrive problems
  15. moisture in head lights
  16. valve cover gaskets
  17. Fuel filter replacement
  18. Speaker question
  19. Quick questin...
  20. How do you remove the plastic on the B pillar?
  21. Will 2k wheels fit
  22. A/C Heat Blowing Vents
  23. I'm getting code 51 and 32 at the same time
  24. Need ideas for Fixing a 90' Maxima SE
  25. Finally pic vg turbo
  26. '91 Sunroof Leak; Where to find replacement seal?
  27. AC/lighter Power Outlet Doesn't WOrk
  28. VG Tranny Question
  29. Getting an extra VE!
  30. just bought 4th gen seats
  31. Car is finally done....
  32. guage lights please look!!!
  33. The Mind Boggles...
  34. 93 SE for sale?
  35. gxe brake upgrades
  36. Motor Mounts
  37. 3RD & 4TH GEN COMPATIBILITY
  38. Help a Gross Polluter
  39. big *** spoiler
  40. I "winterized" my Max today
  41. Sweet sounding advice.
  42. VE30DE doesn't start (HELP!!!)
  43. Wiper Refills to replace Bosch's
  44. Power Window Help "PLEASE"
  45. crank pulley trouble!
  46. Sorry
  47. Eibach Pro-Alignment Kit
  48. 93 DOHC 3.0litre, timing issue
  49. VG30de perofrmance
  50. Bedding rear brakes?
  51. Ve30de Turbo
  52. I am looking for a good mechanic in Minnesota...
  53. Have to replace the brakes + Rotors - what to get?
  54. engine rebuild questions
  55. 95-96 Bose HU
  56. Need Help With New Speakers
  57. intake manifold question
  58. Abs....
  59. resetting computeri
  60. 1989 Maxima Heater Core
  61. Squirelly steering
  62. Bolt pattern?
  63. AT gone bust... =(
  64. speaker grills
  65. Tranny flush?????
  66. I just bought a Maxima!
  67. New wheels for the winter
  68. Brake light mean more then parking brake?
  69. GXE to SE exhaust
  70. Brighter back up lights?
  71. Bulb holder and cover needed.
  72. ECU Error 51 on a 93
  73. Leaking Brake Fluid in Cold Weather
  74. Clutch Pedal Sinks to the floor?
  75. Head Bolt Question......
  76. lower control arm bushing
  77. ATTN: Dynoed VE'ers
  78. Is 13.27 MPG normal??
  79. odometer
  80. Where's the ECU?
  81. HELP...Wheel Bearings on 3rd gen....
  82. REVERSE GLOW GAUGES Help!!
  83. power distribution in pedal for the ve?
  84. VG Tranny
  85. VG intake
  86. vg- jim wolf upgraded!
  87. ve30de
  88. Try some rezlube
  89. No dash lights
  90. Amp and spearker combo
  91. My Idle is not SMOOTH
  92. Help My Gay Nuts!!!!
  93. how to get amp wire through firewall
  94. popping noise when i turn or hit bumps
  95. What intake for my VE?
  96. Timing Belt Change Parts
  97. Crazy Headlights
  98. Fuel Usage
  99. subwoofer problems
  100. Car doesn't start
  101. VE engine question
  102. Seat Belt Computer Fix Question
  103. HL Switch
  104. heater problem
  105. how do i get to the speed sensor?
  106. Drivers Seat Questions
  107. 90 Maxima Front suspension noise
  108. Pulling door apart
  109. Polished Trans
  110. sqeaking and sqealing
  111. Getting a Maxima - '93
  112. My Max (video)
  113. How to do Timing...
  114. Post pics of your sister
  115. '92 SE - VTC a big deal?
  116. Performace from grounding?
  117. Lower Control Arm Bushing
  118. Underdrive Pulley HELP
  119. Idle Problems....
  120. Rack and pinion question
  121. ECU Codes
  122. 93 GXE White Face Guages
  123. custom exhaust
  124. ***Help: problem w/ '91 maxima clutch pedal***
  125. Installing remote start in 5-SPD
  126. Power Steering Drip?
  127. Tranny Question.
  128. 92 Maxima Project - Update
  129. moved up to the 5th Gen
  130. what kind of intake
  131. I Know its not a max(ABS kind of long)
  132. Battery Starting Problems 90'
  133. Did our Maxima's come with Traction Control?
  134. Rack and pinion replacement.
  135. Fuses
  136. door code reset
  137. Where to buy REVERSE GLOW GAUGES
  138. Tach stays at about 700rpm hmmmm?
  139. opinions on a 90SE
  140. Steam Cleaning Engine & Chassis
  141. Vg30e
  142. Leds in the vent control....
  143. Can not remove the drive shaft, HELP!!!
  144. The never ending dominoe effect Kinda long
  145. ABS light on
  146. Post pics of you system.
  147. Buying First Maxima, I could use some advise
  148. I broke my car again
  149. My lug is nutty. . .
  150. auto tranny problems
  151. Help diagnose starter issue
  152. Need help!!!
  153. tire wear issues
  154. 91 digital instrument cluster
  155. vibrating sound from loud exhaust
  156. 370cc injectors
  157. Good Paint Touch Up???
  158. Noisy Braking
  159. help runnin 4gauge wire from trunk to front
  160. Thermostat
  161. Draining coolant from block--need help!
  162. VTC sprocket trouble. HELP!!!
  163. Strut repalcement question?
  164. seisures on idle
  165. Help! distributer
  166. Car is overheating...Help!!!!
  167. Running Rich.
  168. power steering hose repl
  169. no heat no rear defrost
  170. ??? bout pop charger or CAI!
  171. Recurring sound from the drivetrain...
  172. WHat the heck is this (peice in dashboard area)
  173. "Skipped" timing belt??
  174. Paintscratch.com
  175. cap n rotor rattlin???
  176. digital dash black in cold
  177. Question
  178. hey, you lighting experts
  179. Pics of all my maxipads v.7000
  180. Is my beloved 89 passing?
  181. Update on troubleshooting!!
  182. RSB Questions
  183. speaker grills
  184. High or Low Compression?
  185. Brightest 9004 Bulbs?
  186. Help!! (Installing Remote Starter)
  187. water in my ride!!
  188. Strange 'ticking' from passenger side??
  189. Long time question - clear corners?
  190. Can You Help (taillights)
  191. Fidanza and ACT Torque specs
  192. Post Pics of Your Engine Bay
  193. Maxima stuff in canada?
  194. Is This A Fake Or Does It Really Work_
  195. question on fuel...
  196. Temperature Problems
  197. Must be a rare color?
  198. Head Gasket Replacement Update
  199. the wierdest thing
  200. Need Help Urgently!!! Please!!
  201. removing engine
  202. Ok to use Aftermarket Regulators?
  203. vg compression after boost and running rich
  204. Rpm Hole
  205. Vet Tesing :high Hydrocarbon
  206. corner light indicators stopped working
  207. Timing Belt replacement on SOHC MAX 93 -- Need some help
  208. Post Pics of your rims
  209. Door/ignition locks
  210. battery light in dash dimmly lit......guessing it's the alternator
  211. broken hose
  212. 91 Maxima 4DSC dosent start. Please help.
  213. hood release not working?
  214. Anyone ever seen this Max before
  215. different question about door locks
  216. here's a good ghost
  217. Thermostat!!!!
  218. door inserts
  219. tranny swap? anyone got a write up?
  220. How to shut off diagnostic mode?
  221. Can a 3rd gen VG owner...
  222. Alternator.....
  223. Headlights don't work
  224. good idea or bad idea?
  225. Problem with prestige alarm
  226. Stalling when in Reverse?
  227. injecters from the 93 patherfinder
  228. Found a dealership w/Mobil 1 oil filter cheap!
  229. How many of you have your timing advanced?
  230. lets see your e36s!
  231. Should I Partout-or Sell for 1100
  232. Scratching Noise: Front Driver SIde Wheel
  233. How to test fuel injector
  234. Good Muffler Tips
  235. Trunk Opens with Heavy Bass
  236. Grinding noise from front when turning
  237. Power Locks don work !!!!!
  238. Have a few questions......please help
  239. Short in Horn - need help
  240. another junk yard find
  241. caster
  242. Pics of a ASP Pulley with Sleeve installed
  243. SE Foglights
  244. Is my alternator bad/dying/dead?
  245. Water Pump Prob
  246. suspension
  247. Pacesetter Headers?
  248. G Tech 15.28 with a 3500lb max
  249. Having troubles with starting..
  250. It's Back!
