View Full Version : 3rd Generation Maxima (1989-1994)
  1. Overdrive. re-evaluating?
  2. Headlight Retrofit Help
  3. Build Thread: turd gen...
  4. Need help on LED
  5. Help! hard running
  6. Noise at Brake pedal release
  7. VE auto driver axle, help which one fits my car...
  8. Misfiring
  9. Engine Temperatures?
  10. Project: AWD MAXIMA
  11. VE Injector rail O-ring size?
  12. Clicking noise behing the dash
  13. Places to mount amps in the trunk?
  14. Modifying Rear seats to fold.
  15. Where can I find a alternator that will "last?"
  16. Testing auto trans. line pressure
  17. Power Windows and Windshield washer not working
  18. rough idle when cold hard start
  19. axle mount, auto>manual, is it needed?
  20. Photoshop 3rd GEN...
  21. VE Starter Problem
  22. handbrake down...
  23. '93 SE auto trans. bolt up to a '90 gxe?
  24. Runs great! until... ('90GXE auto tranny help)
  25. timing cover
  26. coolant leak near pulleys
  27. ve intake plenum off...safe to clean?
  28. low-end misfire
  29. Led tail suggestions
  30. You know what I just realized?
  31. Interesting issue
  32. help me choose color for 3rd gen...
  33. Trunk swap with pics and questions
  34. Brakes!
  35. Brake & Battery light are both on.
  36. pilot bearing and my 1992 transmission input shaft?
  37. Don't know if anyone saw this
  38. Exhaust Systems...
  39. Pic of a rear trunk spoiler...
  40. Best spot to drill a hole in the firewall?
  41. another 3rd gen pet peeve
  42. Question
  43. Trouble Replacing Light
  44. Whats your Max's weight? And how can we reduce it.
  45. How 'Bout a Contest?
  46. brand new vtc from dealer, anyone use before?
  47. loose or broken wipers
  48. front strut ?
  49. intake manifold gasket ?
  50. perfect wheel fit?
  51. Single gauge pillar pod that fits?
  52. omg my wheels!!!
  53. oil pan gasket, one piece or multi piece?
  54. My Summer Project Just Fell Into My Lap
  55. Rear Radius Rod Bracket (Closer to Front)
  56. which one of you is this?
  57. The Maxima has a new playmate
  58. 4th gen fuel rails
  59. Garage + Newb = Pwnd
  60. Mods for a 92 DOHC Max
  61. Shift lock override? is there one?
  62. S13 Bodykit
  63. So where does this plug go?
  64. chrome or tuner rims?
  65. My baby wont go into 1st or 2nd gear
  66. Alternator question for 92 Maxima SE Auto
  67. Whatever happened to LED tails?
  68. DOHC Engine costs or help on current engine
  69. Should I Paint My Dash?
  70. Things I learned today
  71. fuel injection hose ok for tranny to radiator?
  72. Turbo VG Video
  73. engine mounts at>m
  74. Is This Mechanic Blowing Hot Air About Rear VG Caliper
  75. Burning Plastic Smell?
  76. VQ 5-spd trans compatible w/ 3rd gen?
  77. The Smells...
  78. weird electrical problem
  79. What is this gasket for?
  80. Similar Radio Mounting Brackets?
  81. Opinion on aftermarket speaker grills?
  82. Looking for a 3rd gen UDP.
  83. VG Coil Springs
  84. NEEDED - 5MT Transmission diagram
  85. 4th Gen injectors on 3rd gen Max
  86. Repairing Hail Dents w/ Ice
  87. Why no hot air?
  88. Bose Amp By-Pass
  89. New Maxima, what should i look for?
  90. GXE Trans Failure! ideas as to why?
  91. stain removal
  92. Rear wheel bearings exist?
  93. Wierd Hesitation this morning
  94. Maxima is getting a lot of needed TLC
  95. Different Steering Wheel?
  96. Radiator blew like Old Faithful! Want to avoid installing garbage. Help
  97. 750hp+ VG30E
  98. Boy do I feel stupid...how do you remove exhaust tip?
  99. Can i have Blue Speedo Meter?
  100. Cold Cranking Amps?
  101. Intermittent High Idle Problem
  102. trunk light
  103. Clutch replacement... IDK
  104. Need lil info
  105. Back Firing From The Intake?
  106. someone post a pic of their stock intake box velocity stack?
  107. MP3 iPod connection
  108. i smell gas but dont see it
  109. Rear Passenger Suspension Dropped Tonight - Repairs
  110. Easily remove Comfort Control?
  111. Heater hose routing?
  112. OEM brake lines or universal brake lines
  113. How'd He Manage This?
  114. Phenolic Intake Spacer Kit! Is it worth it?
  115. Moving to sinthetic oil
  116. clutch issues.
  117. more from carbibles
  118. Venom Injectors ??
  119. Oil Flushing ( Sludge Removal )
  120. Seat belt light coming on while driving?
  121. oil pressure question
  122. Look what followed me home.... (bandwagon thread)
  123. come to light and car dies, but will restart....
  124. Maxima musings
  125. Installed HU, no sound?
  126. 4DSC Decals are back in stock!
  127. Third Generation Maxima Needed for Winter 2009 issue!
  128. Hello Everyone
  129. Greeny's VE "Retired" 1-08-09 "The Green Mile":-(
  130. possibly buying black 93 ve 5spd
  131. IM and head porting question. has anyone done this?
  132. tranny on its way out?
  133. A Rat Ate On My Plug Wires
  134. Should I buy another one?
  135. ideas for lincense plate?
  136. Intake manifold cleaning and chasing the elusive hot engine "ping"
  137. #2,4,6 cylinders not working...engine swap....desperation
  138. Battery/Alternator/Charging problem
  139. Wow our headlights do suck....
  140. How many 3rd gens have been on the track?
  141. Addco rsb instructions
  142. Starting Car causes power loss?
  143. recall
  144. fuel leak
  145. need more hp and torq
  146. what is the best way to install UDP
  147. Are the Metal Type Upper & Lower Plenum Gaskets Re-Usable?
  148. Having trouble getting 91 GXE to get power
  149. corner lights/blinkers not working
  150. Trip reset busted help.
  151. Window Regulators
  152. speed sensor or cluster
  153. Reducing wheel hop
  154. Front windsheild frozen. (inside)
  155. Front Parking Light How to?
  156. urgent: Eibach alignment specs vs stock?
  157. porting exhaust manifolds
  158. no heat
  159. Clutch won't relase.
  160. Can the VG Cylinder Head Gasket be Accessed Like So:
  161. Horn stopped? and brotherly war question.
  162. OBX Headers
  163. Heater Core
  164. Problem with suspension
  165. Looking for VE UDP
  166. Round Tooth or Square Tooth Sprockets - 2 Varations of Timing Belt for VG?
  167. Max pulls to the right. Help!!!!
  168. External Tranny filter (good idea?)
  169. power fold mirrors
  170. rear bumper
  171. Max dead on the side of the road, any thoughts?
  172. cooling system
  173. Time to change the timing belt
  174. exhaust manifolds
  175. safe to use chains on lowered max?
  176. WYNN's V.I.C
  177. Please help uneven mixture between front and rear banks
  178. Equal Length Y-Pipe (w/vid)
  179. Trunk wont open HELP!!!
  180. Heating problems
  181. Just need 1 more for spacer kit
  182. Wiper troubles
  183. installing keypads?
  184. Hate those VG30E valve cover fasteners?
  185. Painted Upper Intake Manifold
  186. Timing Tensioner
  187. Third Gen headlight retro
  188. I'm saying good bye to my Max.
  189. foglight rewire
  190. just bought body kit
  191. Winter Here new turbo projects take off...
  192. engine help
  193. Wheel/tire fitment question
  194. Idle worsens...
  195. Oooops :-(
  196. ebay strut bars
  197. HTP Billet 3rd Gen MAF Adapter
  198. Fuel Pump malfunction??
  199. ASP Racing Crank Pulley
  200. ****_____Lights Issue_____****
  201. Crankshaft pulley TURNED
  202. Killer Maxima!
  203. Car Clacks like an old Diesel Mercedes
  204. VTC's went as i was driving.
  205. AC tensioner pulley help
  206. HELP! Mechanic maybe screwing me, tokico struts
  207. 92 VE Stalling out while driving??
  208. Heater Core
  209. VG30E Intake almost ready to Howl!
  210. VG38R?
  211. Odd Noise After Timing Belt Job
  212. grounding kit
  213. Problem wire in harness
  214. Writeup: 5.5gen (A33B) front BBK for your 3rd Gen
  215. Visual Mods: add your opinion
  216. Raising the compression ratio on VE?.
  217. 'retarded llama' sound from brake mcyl
  218. Happy Turkey Day!
  219. Aussie maxima..se or gxe?
  220. Will a windshield fit in the back?
  221. is it my window motor or regulator?
  222. 1992 FSM??
  223. Caped and Pearl's Speed-O-Meter thread...
  224. Is it Possible to Replace the Metal in Wheel Wells?
  225. Bad caliper or wheel bearing?
  226. For Those Who Have Installed Aftermarket Swaybars
  227. Stock housing projectors
  228. 3rd Gen w/a GTR Motor
  229. VE30 engine swap
  230. Feedback on my lowred GXE
  231. 94 motor into an 89
  232. Anyone live near Binghamton, NY?
  233. Question regarding VG30E
  234. Need to replace crankshaft pulley
  235. axle and dust boot ?
  236. transmission leaking BAD!!
  237. Chip?
  238. Vacuum lines and power valve
  239. will an '87 engine fit on a 3rd gen?
  240. Motor Swap Underway, Any Advice?????
  241. Max was hit - need advice
  242. Where to buy the fidanza flywheel for the low
  243. Fasten seat belts light
  244. Is it Safe to Completely Remove the AC Condenser
  245. Floor mode doesn't work right on a/c
  246. my old 91 maxima is sick
  247. Clicking / Putting / smoke from engine bay while accelerating and clunk when braking
  248. tranny mount
  249. want to rid of my ABS
  250. the electrics!
