View Full Version : 3rd Generation Maxima (1989-1994)
  1. Got my max fixed, yay
  2. why didn't anyone tell me! ve and vg rear brakes arent the same.
  3. Power steering Squeal
  4. alternator
  5. Oh dang. Wheel/suspension noise. Squeaks and groans.
  6. Top speed limiter? and oil leakage
  7. Rims
  8. compression
  9. 93 GXE Timing Belt
  10. Will your 2005 Tax Return go towards your Max?
  11. maxima language
  12. 91 max ..will not start distributor ?????????
  13. How do VG Maximas sounds with performance exhausts?
  14. electric question should i add a fuse?
  15. Wobbly Rotor...i think
  16. Steering wheel
  17. Strange happenings....
  18. knock sensor question
  19. Installed my 350Z dead pedal to match my AE pedals
  20. relay question for radiator fans
  21. Doors unloks by emself and weird smell in vents
  22. Tranny leak.........
  23. Pacesetter Headers Compatible w/ WSP Y-pipe?
  24. Speed sensor..
  25. NOLOGY Plug Wires?
  26. Power Windows
  27. 5th gen swap in a 3rd gen? What's needed to be done?
  28. Car won't heat at idle?
  29. Harsh Shifting please help
  30. KYB GR2 strut life
  31. i really messed up my maxima...
  32. Temperature going crazy....
  33. Value Clicking Noise
  34. Suspension drop pictures and advice
  35. Climate Control Removal...
  36. Which motor do i have?
  37. Question about seats
  38. Finally got the pics
  39. engine seizes and quits
  40. Clunking Into drive still
  41. Cv Joint
  42. Underdrive pulleys(where, how much, how?)?
  43. 3rd 4th and 5th gen seats
  44. help with 5speed
  45. Car is now always running like it's cold??
  46. Max Smoking Badly -BLACK
  47. Tranny Curiosity
  48. Check out this!
  49. 3rd gen vs 4th gen
  50. Keep and mod my VG or go for a VQ35?
  51. Easy way to shine up your engine
  52. Frozen Rear Suspension?
  53. how much
  54. Performance upgrades
  55. Speaker modifications
  56. weird
  57. considering purchasing a new hu and speakers....
  58. does any one else get this many miles on a tank?
  59. Autotragic finally died
  60. Car not heating up...
  61. Installing Injectors.
  62. weird problem with the max
  63. Door Sills???
  64. bolt extraction
  65. HELP! Best place to find a starter?
  66. Rear defroster button stuck
  67. Story of how you ended up with your 3rd gen
  68. Performance Loss, Any Suggestions...
  69. Tomarrow I start on fixing the broken exhaust studs, any tips.
  70. seatbelt chime
  71. Fuel Injectors Recall or service bulletin for '89
  72. 4th gen engine swap???
  73. 9007 vs. 9004 pics
  74. Need Some Vacuum Hoses
  75. mutated with rust
  76. new suspension
  77. Need electronic starter system diagram
  78. Exhaust
  79. where is it coming from...?!?
  80. ACC wanna-be ON
  81. Auto Shop
  82. What could this be??
  83. Maxima worth buying???
  84. ez outs, good or bad?
  85. Vibration issue solved
  86. no 2nd, OD or reverse?
  87. Eibach Pro Kit
  88. What color is my oxygen sensor wire on my ecu?
  89. big problem...
  90. keyless entry failure
  91. new to the board.
  92. quick fog bulb replacement..
  93. clunking noise
  94. What does a Knock senser code 34 mean?
  95. doors misaligned?
  96. power antenna
  97. transmission change
  98. Best way to lower my car?
  99. exhaust leak identification
  100. What to do about a cup holder?
  101. Audio problem
  102. My car smokes, any help?
  103. gas mileage
  104. What clutch to get?
  105. 5 speed transmission question
  106. PS Pressure host replacement
  107. Windshield wipers dont work! please help
  108. I'm A Total Fricken Retard/idiot
  109. Anyone on 19's?
  110. STS turbocharger
  111. Keypad Door Locking
  112. Has anyone used Maaco?
  113. Do I have a GXE or SE?
  114. 92GXE with antifreeze leak
  115. 1993 Maxima SE spd, is it worth it?
  116. Is it worth buying??
  117. good deal?
  118. cold air intake
  119. Couple Blemco things installed (pics), not much more to go!
  120. '91 Maxima won't move at all
  121. Roo Bars
  122. Grinding noise from rear.. Need to re-use strut fluid when installing new Struts??
  123. Urethane parts, how many?
  124. Best Aftermarket Suspension/ Custom Coilovers?
  125. Drive axel seating
  126. custom intake manifold idea
  127. my car needs an exorcism. "electrical"
  128. 4th gen head unit??
  129. when replacing rear main seal?
  130. clutch pedal goes to the floor!!
  131. Limited Slip Differential???
  132. Rear defroster not defrosting.........
  133. interesting fuel rail findings
  134. vaccume hose size and speed bleeder size
  135. shock/strut question
  136. help plz, problem after the snow
  137. It's So Hard to Say Goodbye...
  138. fat *** electrical problem, need help fast
  139. Fuel Pressure Riser?
  140. Help, can't reattach ball joint
  141. Model 3rd gen?
  142. 5 speed swap COMPLETE.. BUT!
  143. No Heat!
  144. pics of broken cross member
  145. what are the sizes of speakers in a 92 se?
  146. Door won't unlock with key in cold weather
  147. Power Window Problem
  148. can't lock rear door...
  149. Can I Use 215/50/15 Tires On My 93 GXE
  150. My VG Tranny Doesnt Shift Out of 3rd Gear Sometimes
  151. Any Suggestions For this???
  152. starting trouble
  153. Snowed-In 3rd gens sign in!
  154. Which tires to get for our stock rims?
  155. will not start.. HELP!
  156. Door keypad is failing...options??
  157. Im Back!
  158. Transmission Compatibility
  159. Interference Engine?
  160. Feasibility
  161. Bypassing bose?
  162. What do you think??
  163. Fuel Rail Fuel Lines
  164. Who needed VIN info?
  165. anyone have pics of brown leather interior?
  166. Battery Drain When Off
  167. Any one else in the north east?
  168. My new max [modding continues]
  169. anyone else ever encounter this with the rear calipers?
  170. Sorry VGers
  171. alternator question
  172. oil pressure light, friction sound on startup
  173. installing cv joint
  174. i made a solid shifter mount
  175. The old gas leak
  176. Coolant a little frothy
  177. 91 Nissan maxima MAF HELP
  178. du-oh! rear struts
  179. Just starting to fix
  180. Engine cold start problem
  181. compatibility between accessories
  182. Got a new Maxima...problems popping out like crazy...
  183. Toughhhh problem
  184. carpet wet inside car
  185. shift lock not releasing
  186. remote start manual
  187. factory tint...
  188. bad thermostat?
  189. Changing a timing belt....
  190. Custom MAF Adapter
  191. Thanks to super fishy administrator
  192. Master cylinder going..??
  193. No heat on 93 GXE
  194. DRRRive Moving on.
  195. How do we remove the ecu?
  196. Thinkin of getting Nissan to install a sunroof
  197. Projecter e36 headlights!!!
  198. I Need An Opinion On This
  199. 91 maxima exhaust problems
  200. Pics Of My 93 GXE Max Wat You Think?
  201. oem alarm system bypass
  202. fuse box
  203. Thermostat
  204. Pics Of My Pistons
  205. Injectors Question
  206. anyone w/ CARFAX....need vin # checked please
  207. Clutch Master Cylinder
  208. sun roof son of a |31tch
  209. So I finaly installed radio right
  210. High mounted brake light melting
  211. Got Clutch?
  212. The Bendix Blues, Starter Problems
  213. Spark Plug Fuzed - Help!!!
  214. Need help with strange sound
  215. maxima meet in ontario,ca
  216. 92 LR Caliper for GXE
  217. Disc Brake Swap on GXE Completed
  218. stuck odometer
  219. caught doing "about 90"
  220. chrome door sills
  221. Keyless entry seems to be out / Anti-Theft- 89 Maxima
  222. Brake Question
  223. car modification confusion
  224. engine swap..
  225. After market body panels
  226. Key in Door
  227. HVAC Control Swap?
  228. relay location help
  229. What will give me the power I had when I first got the car
  230. Price expected for P & P job
  231. how to fix a damn BOSE head unit....?
  232. Weird Noise at Start-Up
  233. 3rd gen stuff to sell?
  234. 1990 Maxima SE Alternator
  235. Valve cover gasket
  236. Torque specs...
  237. need some help fixing my friend's car...tech guys help me out.
  238. Ebay Air filters
  239. Top Speed Adventure
  240. How do I reset keyless entry on my 94 gxe?
  241. Pulled my CV joint apart....
  242. Body work
  243. Who owns 3 maximas...I do
  244. 1994 interior grey colour
  245. 92 vs 94 seat cloth design
  246. light problem
  247. Armorall on Plastic...
  248. Maxima Reliability?
  249. not looking good
  250. spongy brakes.....think it's the master cylinder
