View Full Version : 3rd Generation Maxima (1989-1994)
  1. Bose Stereo Trouble
  2. Xenon?
  3. Defrost?
  4. BOSE specs
  5. Door lock/car starting problem again
  6. Newbie has Questions
  7. intermitant dying.. any ideas?
  8. Alternator=Bad I found out the hard way
  9. How hard is it to change the water pump and timing belt?
  10. VE Maxima vs. Taurus SHO
  11. Optima Red Tops
  12. not regulator, not guide... ?
  13. Headlight gremlins 2
  14. seat belt warranty repair on a 1991?
  15. power seatbelt
  16. ES Motor and Tranny Mounts for 92-94 SE.
  17. no more rub
  18. Bored project #1 & 2
  19. strut suspension problem
  20. Newbie Timing Belt Question
  21. Fuel Warning Lamp Issue
  22. VIN# issues...my car from Canada?? -->
  23. How big is fuel tank?
  24. Thanks to all who helped
  25. Before I Buy.
  26. Cutting shifter...
  27. got 2 problems
  28. Headlight gremlins
  29. Radio Display out............fixable?
  30. headlight gremlins
  31. Resetting the ECU after exhaust install
  32. Super blinking turn signal
  33. Remove the rear bumper
  34. Y pipe
  35. After market HU and Speakers: Do you have to rewire?
  36. e36 lights
  37. Years for tail lights
  38. SAFC-II VE wiring
  39. Stillen kit knock off?
  40. wheel alignment after struct change
  41. paint
  42. Everything works (pretty much)
  43. Wheel bearing replacement
  44. Warpspeed, probably the worst purchase I ever made (long)
  45. Clutch Issues
  46. Wrecked max, now what?
  47. Tranny/Clutch Problem?
  48. high fan speed problem
  49. E36 Light Advice
  50. Bose Sysetm?
  51. anyone got picture ??
  52. its gone..
  53. dyno'd the POS today... with and without VTCs.. (56k warning)
  54. Axle ? (pics)
  55. 92 max SE timing belt??
  56. Lights on my HVAC unit don't work right.
  57. ball joint
  58. help on power lock
  59. upgrade guides
  60. can someone help me..
  61. car won't start, any ideas?
  62. Just installed my VG grounding kit
  63. Temp Sensor Problem?
  64. Just a lil update on the g35 muffler.
  65. possible leaking injector
  66. Can a 96 Bose system fit for a 91 Bose System?
  67. Which Site or Stores sell LED Bubls?
  68. possible rear strut prob?
  69. Fuel Injector Specs - Maxima SE
  70. Inner glo not working PLEASE HELP
  71. Vacuum Line Dilemma
  72. Tinted tailights
  73. Mickey Thompson ET street tires on MAXIMA
  74. cv help
  75. O/D controls movement?
  76. Again, I'm Sad......
  77. 92 SE 5-Speed Impressions
  78. Sunroof install Help Please! Not look easy
  79. E36 lights
  80. What the flip is up with my car??
  81. Inconsistant acceleration
  82. cf trunks??? R U in...
  83. Weird Electrical Problem
  84. Any One Interested in a group deal on a fiber images CF hood get in here
  85. Anyone use LED's in their corner lights?
  86. Plus Size Advice
  87. shaved trunk
  88. Please help! Car won't start!
  89. Maxima engine swap
  90. Knock sensor bad
  91. electric problem, fuse?
  92. Need Help
  93. Headlights Died
  94. my back hurts
  95. painted some interior pieces
  96. Cryo2 CO2 kits
  97. Just put down on a 92 Max SE 5-Speed
  98. Glove box light
  99. Car Died when Driving And now it won't start... HELP!!!
  100. heater/blower
  101. dirty to clean, before and after engine bay
  102. KYB GR2 Struts on a 3rd gen
  103. Strut bar
  104. Windshield Wipers
  105. speedsensor
  106. Is This a Good Deal
  107. friends soft brakes + my squeeky brakes
  108. I know its not a Max, but..
  109. Toyota filter p/n 90915-YZZA2 on a VG?
  110. idle a little rough, chugging, steering vibrate at low speed
  111. Here's your daewoo, your car's unsafe to drive.
  112. Good alternator Source
  113. LED light on Speedometer Cluster
  114. New Head Unit
  115. Dual exhaust 92se
  116. Car Wont Start!
  117. Please Help, I'm Sad
  118. Manual Fan Control Lever Sticks
  119. Brake Lights Spazzing
  120. bumper replacement
  121. VG30e
  122. Broken Stud Help. Yes, I read the stickies.
  123. I finally ordered a muffler
  124. How do I reset my keyless entry number
  125. Sporadic starting problems?
  126. would love 2 get my 92 se running
  127. My Maxima still isn't running perfectly (but pretty well)
  128. tranny
  129. Octane ratings and altitude...I am stuck
  130. 1990 Auto trans-need expert advise
  131. Steering wheel from a 96 maxima
  132. flywheel and clutch for dohc
  133. Prolong engine treatment & other additives?
  134. VTC--Temporary Solution
  135. The softest screws I've ever seen
  136. Fan not working
  137. Got my full Warpspeed exhaust, i think...
  138. heated mirror install
  139. Recall by Nissan - R5002-
  140. HELP, This makes no sense
  141. Purchasing a '94 SE....a few issues I need addressed
  142. Re-Installing a trunk switch
  143. Front End Vibration???
  144. 93 gle leather seats
  145. Transmission leaking, common causes?
  146. A/T Power switch lights
  147. Have you had the same experience yet?
  148. Heat with gauge pointing to "C"?
  149. high speed, engine died!!
  150. Pulsing Lights
  151. Microvision TV
  152. How to test Knock Sensor?
  153. Hood Supports - Best place to get?
  154. lowering springs?
  155. juice box??
  156. Steering Wheel Compatability (Airbag/Non-Airbag)
  157. Mustang Wheel help
  158. Customization Questions
  159. water pump leaking
  160. $24.95 for ebay grounding wire kit? worth it?
  161. HELP PLZZZZZZZZ!!! Head Gasket Blown??
  162. How Nissan V6 Coolant flows?
  163. 3gen tranny?
  164. Ebay Performance ECU?
  165. Nissan Body Kit
  166. max wouldn't start pt2.
  167. Ground Wire Kits
  168. 3rd Gen LED Turn Signal Mirror Shells (Gauging interest)
  169. Reprogramming the Keypad, Please Help?
  170. What the???
  171. 9004 and HID
  172. Pics of my custom grille
  173. Need instructions...
  174. Rear seat removal
  175. Plz plzz help me Heating guage
  176. how many models of the 89-94 where made
  177. Bucking around 2000 rmp
  178. Evaporative Vac Solenoid read on ecu
  179. help with antenna.....again
  180. TB gasket leak?
  181. 1992 Maxima SE wheel question
  182. looking for a decent rebuildable block
  183. Cruise control
  184. performance
  185. Recalls and Technical Service Bulletins for 1992 Maxima
  186. help with guages
  187. 93 SE shorting out on start-up?
  188. i bought new struts but when i ordered they send me cartriges
  189. 1990 SE Cruise Control
  190. door keypad on an se
  191. Is This True (VTC-related)
  192. Rough idle?
  193. black leather, woot
  194. Running Wires
  195. Engine/Auto Trans Mount Replacement
  196. heater question
  197. whats the difference between struts and shocks
  198. VG30DE Turbo for $50???
  199. power locks
  200. What suspension comes on 1990 gxe?
  201. Factory service manual on cd?
  202. Tips On Car Audio Anyone?
  203. keyless entry
  204. Have to hold down the unlock to take the car out of park...& ques on ball joints?
  205. Well I met the Candi man
  206. How many......
  207. lucas oil?
  208. conversion e36 lights
  209. Which axles for 93gxe?
  210. Nissan 3000 trim
  211. ve injectors
  212. suggestions for a mod anyone????
  213. Light in trunk
  214. nissan cedric engine
  215. 1990 Nissan Maxima(GXE) Cold Air Intake???
  216. Talked w/ a Nissan Tech today (VTC related)
  217. Bose radio parts
  218. Rear strut bar!!!!!!!!!!
  219. Nice Deal On A Max On Ebay Check It Out
  220. what's the best brand of timing belt for a VG30E?
  221. pls help, the sequel
  222. Head-unit/deck issues and question
  223. 92 maxima 160k miles smoke from exhaust
  224. 92 maxima pulls right after alignment
  225. What do the injector color codes mean?
  226. Starting and running problems again!!
  227. 93-up injectors in a 90?
  228. What u used to stop rear deck rattle?
  229. shift knob
  230. steering wheel
  231. oil pressure light just came on
  232. Driveaxles
  233. Window Tinting
  234. really quick guys........
  235. Mystery plug
  236. Magazine Articles/Review ft. 3rd Gen
  237. Hood
  238. gauge pod
  239. Wierd electrical problem
  240. Digital HVAC Controls
  241. Warpspeed b-pipe ?
  242. diameter of the stock sway bars....
  243. angel eyes
  244. Testing a speed sensor
  245. 92 SE questions?
  246. VG ticking? studdering issues
  247. Gap between bumper and headlamps
  248. im back
  249. Buyer Advice Needed
  250. Can someone show me a pic of the TCU?
