- new carpet or clean with a steam cleaner
- Need To Get a Lightened Underdrive Crank Pulley
- problem with eagle rods
- 1994 GXE vs SE Question
- 91 SE Spoiler
- Rubber Trim Pieces
- Electrical problem
- Energy Suspension Parallel Link Bushings
- driver's side headlight?
- My Maxima swirls to left when accelerating very fast.
- brake fuse keeps blowing
- does it matter?
- Engine idling at 2000 RPM......
- new member- Who can we smoke?
- Price Of My Maxima?
- Yet another upgrade for my BlueVe5spDream, Rims
- Going spoiler-less kinda sucks...
- Too Leave or Not 2 Leave???
- Looking for black seats
- Faster Engine cooling
- Cruise Control Help
- KS troubles..........and I mean trouble!
- break pads for 94 maxima gxe
- 3rd gen gauge pods still availabE?
- VE engine rebuild
- radio / power antennae question...
- Replaced radiator hoses
- how to change rear side marker light?
- From bad to worse
- Vacuum lines
- 91 maxima worth fixing up?
- Random things stoped working
- tail light question
- 89 SE running poorly, fuel tank under pressure?
- VE 5spd motor into VE auto car. misses under load
- '93 Bose vs. aftermarket Sony CD Player
- Rust Recall, what should I do?
- Question about color lower side and bumpers of Maximas 89-94
- Place Cold Air Intake Installation Help
- '93 with BOSE system... Just so everybody knows...
- Suspension Techniques...
- VTC rebuild??
- its been a minute...but im back
- VERY VERY bad day
- inexpensive, simple grounding kit :O
- Why do brake lines have to break?
- Internet wheels part two with pics
- Wheel Hub to Axle Problems
- HELP!HELP! ('92)Tape won't eject & Draining battery
- Spedo on a 1989 SE
- Rear brake caliper...
- VTC Ticking only when car is warm?
- Vinyl Repair kits
- Vibrating at speed
- Wood Grain
- Manual Transmission- what the hell happened?
- Power Window Problem...
- Aftermarket Bumpers
- stock bose amp bypass writeup please
- Need HO Alternator
- Auto tranny fluid question
- Timing Belt question
- fog lights, need help
- car shakes in drive when still
- heater blows cold air
- How soon should you wax after a paint job?
- Does anyone know the Engine Oil Capacity on an 89 Maxima?
- Electrical Issues
- performance specs
- Will R34 Skyline wheels fit?
- Throttle Position Sensor (TPS)
- Looking for an install template for a SOHC CAI...
- Oxygen sensor help
- About Lumens and Halogen
- bump stops and dust boots
- paint stripper safe for stillen kit
- car puttering in low rpm in drive
- Exhaust manifold stud theory
- custom headlight covers/ wade covers/ flush mounted.
- 90 Max...Looks like it's seen its last day
- Can I run the engine on just water w/o coolant?
- Thinking about selling 93 SE
- cefiro lights?? H I D's to use?
- Whaaaaaaaaaaaaaaaaat?
- WTB - Left Front Drivers Seat
- Life After the 3rd gen........
- Is this it?
- quick exhaust manifold ?
- LSD question
- Fog light covers for 3rd gen lights
- 93 Car Audio Help
- writeups for engine pull?
- Knock Sensor questions...
- Are 3rd gens 9004s or 9007s?
- where is the darn iacv
- Car doesn't seem to make power until about 3k RPMs, any ideas?
- Pitching and rolling help please
- Is this real or is it a scam for money?
- Sparkplugs... PFR5C-11 vs BKR5EGP
- air filter box
- General Mantenance Q's (Spark Plugs, O2 sensor, fuel filter)
- Alarm System ( again )
- Help Please?Cylinder Head Temp sensor???
- Ma
- door panel?
- SPEC Clutches
- where to get stage 2 clutch
- what clutch will fit?
- bose power problems possible short???
- vacum line?
- What ya think?
- gas milleage improvment?
- unlock button on the driver side problem
- Superbright reverse lights
- Removing Manual Climate Control
- Wheels and lugnuts
- Security Alarm Light...
- Exhaust manifold problem
- Questions about engine parts swaps
- Need parts!
- Today I got lucky...in an unlucky sorta way
- Jdm Vg
- need help or opinions...
- HELP! fidanza flywheel clutch cover the bolts
- Stranded at School (Electrical)
- amp question
- ABS Braking system
- $300 Vq30de?
- quick question on repainting -
- Electrical Problems - Wiring Gods Needed
- Exhaust
- Recommendations for seat covers?
- leather seats, need help
- Where to buy alternator / fuel pump
- Struts/Shocks & Springs
- VG30E Cams?
- Gas Stablizer/Booster Suggestion?
- Went to replace spark plugs... uh oh!
- BMW Lights
- The end of my Maxima
- Question for those with sunroofs
- My next project...
- clutch problem
- When replacing radiator hoses/thermostat?
- super bad gas mileage
- Catalytic Converter w/Air Tube
- knock sensor and harness replacement
- Another Interesting Fuel Problem on the Injectors
- Oil leaking on my 93 SE Maxima
- Stock Tire Size?
- door locks?window won't roll down?
- I got a VE5spd! I got a VE5spd!
- Got my new ride
- bumper removal
- changing lights
- Fstb
- innerglow
- Intrax springs: any performance value?
- New speakers, Sony CDX-F5700 CD Player
- I lost my foglights
- Air Conditioner Direction Output
- Power Window Switches
- Manual Climate Control Lights
- VTC noise in 93 maxima
- Sound system HELP!
- take a look at this...
- I need help big time.....
- Performance Chips
- Turn Signal Bulb
- Aha! Finally figured it out!
- anyone wanna take bets on my tranny problem?
- what is it, why is it running
- Still Wanted: Engine Parts Pics
- Hood shakin
- Quick temp question
- Headlight issue
- inside light problems
- Spring cuts
- timing belt and other replacements
- i figured you jdm vultures may want to jump on this
- Just bought an SE instrument cluster, How do I swap the odometers?
- fin flywheel and exedy stage 1 install
- anyone live in Quebec ?
- Stock Amplifier
- 5th Gen Muffler
- Timing Light.......
- Loud noise from rear side???
- If I spent $1000 in engine mods...(GXE)
- door trim can YOU get them off
- Engine Stalling Really Bad. Help !!!!!!!!
- sunroof
- Any reason to be picky about a battery?
- How To Change A Fuel Pump?
- Fuses
- Rubbing
- wtf this must be to good to be true
- Help with transmission removal
- Help With BLOSE Replacement
- smell
- A/T Switch Green Orange and Light Green?
- Window button lights?
- i am new and need major sound system help!
- oil pan seals....
- Ok......so lemme get this straight......
- Engine missing
- Speedo, ODO and CC dont work
- G35 Coupe rims on a '90 3rd gen?
- pictures of my maxi! no 56k!
- injector recall
- Internet wheels and tires
- Will it fit?
- 350z wheels on 3rd Gen??
- Underbody light kits
- STS Problems
- Worst locks ever
- Sparco Torino seats installed, plus fixed my sticking out muffler. PICS! 56k death.
- Intake
- RF high beam doesn't work?
- what is this
- Changed Your Struts? Rack?
- wanna blaze
- engine whine - VE
- Keyless entry
- A lake in my trunk
- should i buy these?
- Is $440 right for timing belt + water pump?
- ecu toast!!
- Tranny Problem?
- Auto transmission needs rebuild.
- Was this a good deal and................
- Security System
- rice burner?
- Do I need a better alternator?
- Strut Mounts & Boots??
- Is this Crank Pulley OK?
- Turbocharging VG
- where i can find the refilled oil for the rear cartriges
- Headlight switch
- Finally got pics of my new ride
- Its a sad day for the Max
- To Techron or not?
- Sea foam made my car sooo sluggish ???
- Question about engine swap
- Saying goodbye
- Keyless entry
- finally got her back together
- car won't start please help
- Brakes Pads
- tires looking funny
- coil overs for a third gen
