View Full Version : 3rd Generation Maxima (1989-1994)
  1. Tach Signal Wire (Remote Start)
  2. warpspeed question
  3. Coolant problem!!???!!
  4. Driveshaft
  5. Just tested my ignition coil packs....
  6. For cleaning the MAF, carb cleaner?
  7. What would cause an )2 sensor to fail?
  8. Need Help Motor mounts!! Never thought it will so had!!!
  9. front end rehab........is this what I should do?
  10. Clutch Replacement Horrors
  11. will these tires fit??
  12. This Grounding Kit Any Good?
  13. VE thermostat temp
  14. 1/4 watt or 1/2watt resitor for KS?
  15. REBUILT Trans Problems
  16. bought new leather foam wear question
  17. Crank seal question.
  18. How much could I get for my 3rd gen?
  19. oil problems???
  20. Fire Wall Help
  21. Squeaking noise when driving on "un-even" roads
  22. big 3 (dont kill me)
  23. VE engine swap
  24. Remote start....alarm going off??!?!
  25. Engine Help!!!
  26. transmission help!!!
  27. Come look at my "new" Corbeau Seats
  28. Remote Start
  29. 5 spd tranny shifts hard....
  30. Will i notice not having 2 antennas?
  31. Temp gauge maxed...help!
  32. I A A idle air valve....
  33. what the ??? whats wrong with trans
  34. got new pic w/body kit and rims back on
  35. 91 gxe factory amp.. non bose
  36. spark plug q's
  37. planning on a 2,500 mile trip
  38. Floor Mats
  39. A/C with Digital Air conditioner
  40. Behind glovebox water .
  41. Cheap mods + Low budget = low power
  42. 1995-1999 maxima engine and trans?????
  43. Leaking front & rear seals
  44. aftermarket Cam kit
  45. Turn Signal Hell
  46. Smoke!
  47. supercharger
  48. transmission advice
  49. How To Go Turbo With A Vg?
  50. (Stupid?) question
  51. Whats the Diameter of the fuel return hose?
  52. strut and mount replacement
  53. Need some help!!!!
  54. BBK will this work?
  55. Digital to Analog Dash Conversion
  56. Ignition upgrades?
  57. how to get antenna out?
  58. Just Did Tune Up And....................
  59. having a bad day? this will cheer you up --> VE5spd + laughs
  60. door hinges...getting worse
  61. Bomex kit for 3gen max?
  62. Disappearing coolant
  63. Can someone help me with this????
  64. timing belt
  65. rock through window = broken window
  66. Help!!!! Disobedient passenger window........
  67. Screwed up. Turn signals aren't working...
  68. Fuse???
  69. Chassis Greasing
  70. Has anyone seen results with an SAFC-II module?
  71. Tweeter location
  72. Starting Issue
  73. Decisions, Decisions... VG vs. VE
  74. VTC's worse now
  75. bouncing car, frustrating!!
  76. AC relay clicking?
  77. remote keyless entry
  78. KS replaced ($550 later) and loving every moment of it.
  79. just got the alternator replaced and ......
  80. Engine temps are high....HELP
  81. frightening timing belt price..
  82. Possibly the greatest idea ever..
  83. intalling E36 lights
  84. Tranny Problems?
  85. Short shifter
  86. Rpm's going crazy!!!
  87. How nasty is a halfshaft replacement?
  88. Gauges...
  89. sudden drop in gas mileage
  90. body kit installation
  91. Power wire on the '93 Max
  92. ATF for a 93 maxima.could it be trans problem?
  93. Installed cheap 4th gen STS today
  94. Who Has 18x8's?
  95. injectors
  96. Are these lights for a 3rd gen
  97. Transmission issues
  98. to those with a flywheel
  99. How to Lighten up
  100. Rough Idle and Noises
  101. Stock wheels...
  102. Major Engine Failure - KS related !!
  103. Started Cefiro Conversion
  104. I upgraded :hs: *pics*
  105. location of vacuum hoses?
  106. dash lights
  107. some new pics with my car all together
  108. y-pipe question
  109. How much boost to add??
  110. 94 SE for my 92 GXE Maybe
  111. Sloooww starting
  112. How to pull the engine?
  113. Question: Pullling A VG
  114. Found out why my maxima handles like crap!
  115. Check Out My New SE JDM Gauges
  116. Odd engine vibration
  117. Sunroof Problems - HELP
  118. Replaced the exhaust studs on my rear manifold over the weekend *very very very long*
  119. Why doesnt the starter work ...
  120. WSP CAI Template= Craig_B's Template?
  121. stock TC rims on my new max
  122. Quick Cutting Question
  123. Bose capacitor replacement
  124. Cruise Control - DEATH Trap!
  125. Brake light gremlin?
  126. Pics of the new 18's
  127. its been quite fun... but, i'm moving on
  128. 600 miles on 1 tank of gas
  129. low rpm hesitation
  130. Lower control arm loosen, what else will be broken?
  131. y-pipe install
  132. CAI Install Question Place Racing/Cattman
  133. Long trip in the Max.
  134. Tranny filter???
  135. Rattling Noise after installing tranny cooler
  136. Bad Steering when road is wet.
  137. Radiator or headgasket??
  138. How do I remove a 240sx steering wheel?
  139. Can we get a 5 speed swap sticky?
  140. Need some light!
  141. STEREO HELP, ive done all my reading and still have some problems!
  142. tranny noise
  143. hey guys question about gas milage going to crap
  144. Few ideas, questions.
  145. Catalytic Converter on its way out??
  146. buzzing noise in speakers
  147. question about sunroof glass
  148. omg, waterfall in my car!!
  149. Changing the passenger Motor mount
  150. had a very productive day on sat. v.lotsa picsas
  151. Noisy Timing Belt-VG Engine
  152. 3rd Gen Modification Information
  153. Gauging interest on Fiberglass Fenders
  154. Lowering springs
  155. Just some new pics
  156. Its Clutch time again
  157. ideas?
  158. who has underdrive lighten pulley
  159. pics
  160. couple problems....
  161. Corbeau Seats
  162. Leather Seats
  163. roof racks
  164. paint on rear bumper
  165. mud guards?
  166. My max is finally done! :)
  167. front speakers
  168. Throttle Body
  169. Spark Plugs
  170. Intake manifold cleaning
  171. parts counter at dealership a little dumb, need some help.
  172. 3rd gen body kit
  173. Need some help with search/ gauging interest
  174. Good junk yard in western PA?
  175. Help!!! My max left my stranded at my Finacee's parents house...
  176. You have to pay to get quality parts, Stillen STS
  177. Review Intrax wrapped around Tokicos, Post only your review on this setup!
  178. Heater issues
  179. Dealers,Gotta Love'em!(Kinda Long)
  180. 30mpg
  181. Fuel Frustrations update
  182. 90 max door glass fits a 94gxe?
  183. Where is this thing?????
  184. Figured my brake problem has a vacuum root cause - what?
  185. ATTN: n00bs with <15 posts
  186. whats the deal w/ the D2 Coilovers?
  187. ebay clear corners..
  188. E36s W/Angel Eyes?
  189. driving me crazey
  190. horsepower/torque
  191. How it cost to put manuel transmission on 3rd gen automatic?
  192. Matt's pics of the Week...
  193. Untill I fix my speedometer...
  194. Exhaust Manifolds/studs
  195. well its not finished but figured I would show an update pic
  196. Headlight strobe lights
  197. 02 sensor q's
  198. omg i have 3 3rd gens!
  199. Is this bad?
  200. need feedback on alpine SPR-69LP rear speakers...
  201. Grounds For A Beatdown
  202. What Do You Guys Think.
  203. VLSD question
  204. removing the hood
  205. Removing "door ding" guards on a 91
  206. How bad is my tranny ??
  207. paint code?
  208. Help!!Keyless entry tone!!Driving me crazy
  209. Anyone Attempted this Trunk Mod?
  210. A/C Compressor
  211. motion to change crazy4maxima's user name to grave digger
  212. Loud continuos Beep sound!!!!!Help!!
  213. Alternator going?????Need help
  214. QUICK! Oil Change gone horribly wrong....How do I remove my foglight?
  215. car will not start
  216. Can't install new antenna mast - Help
  217. insurance policies.....
  218. Interesting thread about coil packs
  219. Tail-lights
  220. Trunk Popper idea...
  221. Cold Air Intake?
  222. tokico shocks
  223. gas smell and its not the filler tube
  224. MAXIMA recalls (ALL?)
  225. MAXIMA SE 3.0 V6 24v M REG 1994 FOR SALE
  226. 02' xterra intake manifold on VG30E?
  227. ECU- I can't find this thing.
  228. are all trunk latches interchangeable?
  229. Tranny compatibilty??
  230. need help on 90 max upgrades
  231. Rust Removal: Help Needed
  232. What Is Fair?
  233. car won't start, ideas?
  234. Need help identifying part.....
  235. Clear Coat Qs
  236. Need a junkyard in Phoenix, AZ area
  237. Rosen R6500 post....
  238. finished HU/speaker installation
  239. Aftermarket Body kits??
  240. wiring diagram
  241. FYI- incase any CO guys didnt know...CO meet
  242. Getting trunk lid open....
  243. remote start clutch relay
  244. sold my 90 gxe question about a j30 fan and fan clutch
  245. maxima.org sticker! I NEED IT!
  246. fog lights
  247. Fuel Economy Frustrations
  248. Has any kept their Bose and been happy?
  249. Do you have Koni red's?
  250. Got a Taurus cup holder. Doesn't fit :(
