View Full Version : 3rd Generation Maxima (1989-1994)
  1. CV shaft, NEED HELP!
  2. Clutch problem..........
  3. little vaccume hose?
  4. BOSE CD Lens Cleaners Recommended?
  5. Restoring my '92 SE to original glory! Need advice and encouragement!!!
  6. rpm pulses when accelerating
  7. how many quarts for manual transmissions
  8. Distributor Cap dilemma
  9. Koni Special's
  10. Time for front brakes.. which pads are best?
  11. SS Clutch Line
  12. How many 5 speed GXEs are there?
  13. Master switch problem
  14. Does our stock ECU have a PiggyBack mod available?
  15. have I lost some acceleration power?
  16. Hesitation
  17. Accident pics
  18. Udp?? Vg??
  19. Maximized plasTicks
  20. Will 16" ('98 SE) rims/wheels fit on '92 SE??
  21. Are there two Bose Systems?
  22. Very odd starting problem in the rain
  23. auto tranny problems
  24. Warning
  25. stupid problem
  26. New wheels = 2 new problems
  27. k sport coilovers
  28. Attention MrGone
  29. injectors....
  30. Oil leak!!! Ahhh!!
  31. Vavle
  32. spare engine build
  33. my bad
  34. Wheel Studs
  35. IAC...Idle Air Controll
  36. Just tossing my idea to the org for opinions...
  37. Modified CamShaft
  38. track time for a 3rd gen turbo
  39. Max running cold and still idling at 2000 rpm
  40. 300zx Ecu
  41. yet another headlight mod thread
  42. ABS freaks out al the time, what to do?
  43. So prevenitive maintenance screwed me over...
  44. Headlights
  45. powersteering problem.. big time
  46. radiator fans not kicking on
  47. Check Out My New Pics!
  48. If you haven't lately do this tommrow!!!
  49. Help!!! black smoke, rough idle, studdering engine then dead
  50. my long weekend project - Intrax n Tokico installed
  51. Updated Front : LOOK!!!
  52. radiator fuse blew. not the first time
  53. Air conditioning question
  54. Crazy Idea.
  55. replacing seatbelts
  56. My car is not just nice on the outside anymore (interior pics)
  57. tried seatbelt fix, no luck
  58. i wish i had a mechanical problem...
  59. question for those who have installed remtote starter/alarm combo
  60. So my low fuel light doesn't work
  61. g box info
  62. Locks
  63. Installing 12' and amp need help
  64. My ACC fan is stuck on high
  65. noisy brakes please help!!
  66. hail storm.....how do you pop dents on this thing!!!!
  67. antenna adapter
  68. 300z engine question
  69. brakes
  70. 92 GXE vs 04 Mini
  71. Just washed the car, so I thought i'd show some pix
  72. what mod to start
  73. what to do
  74. Rear deck removal?
  75. grounding question...
  76. bad weather, quick alternator question(s)
  77. Tint Pics
  78. speedometer
  79. shifter knob hell
  80. Trailer HItch?
  81. Jumpy Shift- Should I be worried?
  82. throttle body upgrade
  83. Fuel Injector Removal
  84. Starting Problem
  85. anyone have a pic of a 3rd gen w/ a nose mask?
  86. Is this the hose to insulate to get colder air?
  87. my last thread; yer killing me VE
  88. Close to losing my max??? help
  89. VE Questions
  90. spark plug gapping
  91. banjo bolt on P/S pump
  92. recommedations on tint?
  93. Helios 7000k HIDs
  94. Cup holder in center ( between seats)??
  95. What to do first???
  96. 2000 Maxima Wheel
  97. Replaced my Rear Struts...
  98. Great Deal so i bought it, But...
  99. Need timing help
  100. 5 cylinders?!?!
  101. Automatic Seatbelt Question
  102. What would you guys do? Max or T-type?
  103. Chain or Belt
  104. Where To Find Jdm Motors
  105. Marble Madness under the hood?
  106. Plugged cat? (poor mileage...help!)
  107. exhaust studs
  108. getting a SE auto that wont move- sudgetions?
  109. brake light inquiry!
  110. rims pics
  111. LSD in my 92 SE?????
  112. manual tranny filler hole
  113. Wtb - 92 Ve Maf
  114. Rear ended
  115. My baby is dead - again...
  116. exhaust...
  117. seatbelt warning light comes on? O2 sens quest
  118. should I let maaco paint my car?
  119. After an Alternator install question
  120. VE Axles
  121. Need help with wiring of E36 lights
  122. Hey guys!!!! It's the REAL 5 ltr. beater talking........
  123. axle question
  124. Hi Flow Catalytic Converter!!!!!
  125. Question about running engine without oil cap
  126. List of swappable engines?
  127. Power Steering Pump
  128. Removed rear seats to check for rust recall..
  129. Anyone with the euro E36 lights please help!
  130. elecrtical question
  131. Radiator
  132. My baby is back!!
  133. Bulb check relay purpose
  134. Tranny back on, now rattling problems...
  135. is there a "how to" for resistor mod
  136. High Beam switch dosent work!!!
  137. Interior Windshield Haze
  138. problem with sway bar mounts busting
  139. exhaust size.
  140. dyno my turbo 3rd gen not real happy
  141. POST:ONLY if you want a Carbon fiber trunk
  142. VE Exhaust Manifold Outlet Size?
  143. Foggy Fog Light: Does it come apart?
  144. The gas smell
  145. Stock Timing
  146. Is My max totaled?
  147. stock wheel cleaning
  148. Any 3rd Gen drivers in Michigan?
  149. 2 new issues
  150. first rust forming, EEEEEK
  151. rear struts
  152. Odd Headlight issue
  153. My Rott Job
  154. replacing E-brake
  155. Trunk pop wire
  156. Need Help!! My Max Will Not Start!!
  157. idle
  158. ac condensor/dryer
  159. transmission question
  160. Easy window tint removal
  161. I love the smell of fresh paint
  162. spark plug info needed
  163. Repair Information!!!!!!!!!!!!!!!!!!!!!!
  164. Replacing injectors....any tips
  165. Grey Leather?
  166. Brake pedal goes to the floor after rebleeding. What does that mean?
  167. Removing Cat Back
  168. rb25det swap
  169. projectors Suck..(update)
  170. Bad strut or worn bushing??
  171. possible leaking injector, what to look for?
  172. starter is maybe going?
  173. I need to drive up hill
  174. Sprint Suspension Spring kit.
  175. CF Trunk Lid
  176. alternator function question
  177. eibach drop in the back??
  178. Possibly ridiculous question...
  179. rear stb
  180. Exhaust piping size
  181. New 1/4 mile record for the fastest NA VE Auto!
  182. Help with exhaust system please.
  183. Turbo Question
  184. eBay UDP
  185. will this steering wheel fit?
  186. Front wheel bearings
  187. Price on leather seats
  188. tensioner wheel/pulley
  189. wsp y pipe with pacesetter headers
  190. removing pass axle
  191. ignition coil boots???
  192. Grease inside axle boots
  193. re-route pcv line to intake
  194. bmw headlights
  195. Want quietest exhaust system for WSP Y
  196. Removing rear studs, how much to drop engine?
  197. car wont wont stay running
  198. 2k to blow, what to buy for the max??
  199. FSTB instal - holy cow!!!!
  200. Corner lights melting?
  201. How much does JWT advance the timing?
  202. new brake calipers
  203. VG UDP Installed.
  204. results...
  205. Rust/Rott
  206. Tranny Cooler question
  207. Another 3rd gen question
  208. 1990 Aztec red paint code
  209. shift solenoids on a VE
  210. Heads
  211. dark spot on splash guard below fuel vapor canister
  212. one more max!
  213. axel install
  214. Best shocks/struts for blue sprint 2" dropped springs?
  215. ks wiring harness replacement
  216. What is this plug for?
  217. Need your write ups/opinions please
  218. WSP VG CAI Installed! pics
  219. FuberGlass Subs
  220. 3 maximas
  221. Wing?????
  222. Does anyone have a write up on a install of lowering springs
  223. Water pump estimate
  224. Help!!! Car cuts off!!
  225. Dash Light went out...
  226. auto tran fluid check, cold or hot?
  227. Y-Pipe-Question
  228. anyway to get ahold of more than just touch up paint.....
  229. Help with power door locks
  230. parking brake / rear caliper issue
  231. A Sad Goodbye
  232. Window electronic problems
  233. to test KS while motor operation....
  234. 370cc injectors
  235. leaks everywhere
  236. Trying To Quiet My Car
  237. overfill hose
  238. Replacing my Hood
  239. 4DSC decals
  240. few new pics of my car; questions about our stock wheels
  241. brake squeal
  242. VG30 Spark Plug Question
  243. A.S.C.D. cancel switch?
  244. Confused
  245. Red Maxima
  246. Tach Signal Wire (Remote Start)
  247. warpspeed question
  248. Coolant problem!!???!!
  249. Driveshaft
  250. Just tested my ignition coil packs....
