View Full Version : 3rd Generation Maxima (1989-1994)
  1. Moving on...well sorta!!!!!!
  2. Wow! These cars can take quite a hit...
  3. A few pics
  4. Air Ride
  5. Speedo is not working
  6. Anyone Know a Good Place to Buy Lowering Springs
  7. stiff passenger side doorlock
  8. Best tires for 97-99 SE rims on 3rd gen
  9. led taillight bulbs...anyone got em??
  10. Speedo not Acurate
  11. Need Good Shop In ATL to take Max
  12. pulling motor question
  13. Is this the dreded window reg????
  14. yet another turbo vg
  15. 92 se 5spd, needs timing chain, good idea?
  16. intake adapter
  17. Urethane and Delrin Suspension Bushings: Experiences?
  18. what tires can i install
  19. alternator belt
  20. Intake For a VG?
  21. Pic of my Maxima/Bose garage stereo
  22. help me spend $$$
  23. Car seats and carpet
  24. 5th Gen Muffler
  25. lights and corners out of place
  26. Injector Prices
  27. window regulator silicone spray antenna
  28. Got it started with a screwdriver and brought it home (before & after pics too) -->
  29. Happy Birthday to MrGone and Subs!
  30. It's time to put the old girl down
  31. ac/heat instrument panel
  32. Maxima Wrecked
  33. power steering makes my engine....
  34. Cold starts with white smoke and stalling behavior...
  35. Help!! :(
  36. Stolen Car Update: Found, but totally trashed. Please give me some advice....
  37. Sunroof Closing?
  38. Struts
  39. Pics of my crappy car
  40. Replace Bose Tape HU with Bose CD HU?
  41. oversteer a normal problem?
  42. What Alternator?
  43. cams for the vg30
  44. Installed E36's on Friday...The Max gets stolen on Thursday. -->
  45. Failed emissions test
  46. 3rd gen engine swap
  47. Tranny time!!!
  48. Changed T-belt - now running rough...
  49. Carbon Fiber Everything
  50. anyone replace their fuel lines?
  51. Will VTCs from VQ30DE work in VE30DE??
  52. can i fit 19x8
  53. Bored vg30?
  54. knock sens bypass question
  55. Fusible Link Wire ??? - VGE
  56. stillen body kit
  57. 1990 se 5spd
  58. AC Compressor and Clutch
  59. keyless entry replacement writeup?
  60. help me break into my car
  61. Spark plugs?
  62. Hole in radiator
  63. Can anyone rebuild VTCs??
  64. 92 se reliability?
  65. Which wire to tap for Valentine 1 hardwire
  66. maxima.org
  67. Anyone have a dyno chart of a VG 5 spd?
  68. HUD questions
  69. need help with search for Snap-On Shop Key #5
  70. White Rims
  71. 1991 5spd....
  72. Higher RPM's
  73. Sunroof Loose?
  74. Battery?
  75. Finished my intake
  76. Power steering fluid leaking
  77. I may have screwed the pooch this time?!?!
  78. Quick!! -what voltage?
  79. Wierd electrical gremlin/problem
  80. clutch question
  81. Update
  82. Hazard light button 1991 SE
  83. Interesting
  84. 5sp swap reverse lights
  85. Robbed...
  86. Fuel Pump Removal Question......
  87. Best Place for Maxima Used or Rebuilt Engines
  88. vent problem
  89. Factory made pheno spacers??????????
  90. Power Mirrors Switch---Light?
  91. intermittant stalling
  92. need some problem solving help. thanks!
  93. addco rsb install q's
  94. Best way to disable Factory Anti Theft
  95. Magnaflow Cat Install Question
  96. CAI for VE...
  97. New Application for E36's!
  98. speedo works up intill 22mph
  99. changed the injectors in my 93, ran great for 10 min, but....
  100. Venom 400 PCM
  101. Ignition Wire Set... any comments?
  102. fixing antenna...few questions
  103. back tires are very slightly rubbing on strut..
  104. D2 coilovers
  105. Good Deal??żż
  106. Engine temp unusually hot
  107. Washed engine - chugging & idling high now
  108. Axle Question
  109. Car loses its balls after its warm
  110. Where's the best place to get a new MAF sensor?
  111. A Question for thoes that have the E36's
  112. testing my ks w/ dmm questions
  113. Remus Muffler
  114. strut stabilizer bars
  115. Rusty Rotor(pics)
  116. Urgent ABS + Brake Bleeing HELP
  117. black marks on your pearl maxima?
  118. Was Corduroy interior a stock option?
  119. fog light help...
  120. opinions from those you have kyb gr2's installed
  121. odometer issue
  122. Anybody here in Socal wanna help me install my E36's when I get them?
  123. climate control
  124. Bringing it back to life....
  125. Finally, new rims (pics inside)
  126. Coolant Temp Sensor
  127. Wheel bearing problems?
  128. Stripped crossmember thread
  129. clear corners
  130. replacing brake lines...
  131. Remote Mounted Turbo
  132. Any luck repairing cigarette burns in Cloth like this?
  133. my ac vents =D
  134. Problem after drilling broken Exhaust Studs.
  135. Injector question
  136. Battery Drain
  137. Need help buying a car
  138. emblems
  139. eyelids or no eyelids
  140. idle air speed problems
  141. Exhaust System shot...a few questions
  142. BIGGER fenders
  143. Random prob wit Door Locks....
  144. another ebay gimmick...
  145. SC or Turbo for VG
  146. black or white?
  147. Trade of the Century
  148. Urgent! Tranny Prob.
  149. another ebay gimmick?.....
  150. blow off valve
  151. HO alt
  152. fuel injectors question
  153. valve cover gasket replace 92 se dohc
  154. Car wont start
  155. found a heads up in a 240
  156. Are the guys that have the S-AFC controller, following some sort of tune.........
  157. shifter acting up
  158. vg30dett cams?
  159. Vacuum leak?
  160. Coil Pack Experiment
  161. Antenna question
  162. Smoking Car..Oil Problem?
  163. exhaust muffler
  164. Front Strut Semi-Nightmare
  165. Direct fit cat?
  166. pathfider head
  167. Some F*** Broke into my car (kind of long)
  168. Rotary maxima?
  169. Better than OEM Disks, but not BBK??
  170. knock sensor on a 91 vg30
  171. Questions for those that have done front BBK
  172. Radio Install
  173. Bose CD err
  174. Different Maximas have Different Side Mirrrors?
  175. Shift Selector won't shift out of Park
  176. Quick question...
  177. Freeking Abs!!!!!
  178. repair manuals
  179. ECU Toaster Shield
  180. short shifter
  181. e36 conversion
  182. carbon fiber door pillars
  183. Water Leak
  184. Follow-up on "The Injector Killer" Vol. 16, Pt. 4, Ch. 3
  185. My Motor Mounts SUCK!
  186. Found some wheels
  187. bad vibrations
  188. confused...
  189. Sounds like marbles in my engine...
  190. JWT pop charger instructions & other queries
  191. Studdering Auto
  192. clutch
  193. Anyone Have pics Murano Weels on a Max
  194. Farewell to all (sort of)...time to move on
  195. headlight issues
  196. ebay question
  197. hey what does the up/down switch on the A/C panel do?
  198. clunky bumpy
  199. Offset question
  200. tranny question
  201. Aiming headlights
  202. try to seal my trunk
  203. Automatic Climate Control question
  204. CV Boot replacement
  205. Head Light-wire Confusion
  206. Possible Blown Fuse?
  207. Non-newbie question about where to find an exhaust system...
  208. sway bar link and exhaust size questions (pics)
  209. Replaced your own VTCs?
  210. painting calipers.....
  211. how to remove airbag steering wheel?
  212. Bolt broke off on me...
  213. sunroof
  214. My first window regulator
  215. any movie clips out there?
  216. Auto Window must be pressed x 3
  217. Opening trunk with key sets off alarm
  218. Odometer reading wrong
  219. Bracing the Crankshaft
  220. 300zx ECU
  221. How many engine/tranmission mounts do we have.
  222. tranmission swap question
  223. installed new vtcs have a few ?s
  224. a few problems
  225. remove spoiler
  226. Wings West pics anyone?
  227. A few new mods looking for them low low 13,s
  228. let see your safc
  229. coil pack cracks
  230. Interior pics please
  231. abs problem
  232. alternator decision
  233. fender removal
  234. OEM windshield wiper blade size
  235. Speedometer Issues - '90 SE 5spd.
  236. Sale over at Nopi
  237. Totaled out my 1993 Se
  238. It's official!!!!!!!!! Amsoil GL-4 comming back
  239. Road Trip!!!
  240. Went to the track today....
  241. so i replaced my belts...
  242. Does the JWT ECU need to be programmed?
  243. Pics
  244. Waxed my Baby Yesterday
  245. VG 5-spd - going into 3rd is a pain
  246. skyline motor = VE?
  247. thinking about stripping/selling the max :(
  248. more problems...
  249. Trouble shooting my new max...
  250. VQ question since my original post was deleted from the VQ section........
