View Full Version : 3rd Generation Maxima (1989-1994)
  1. Stock Windshield Washers Have Low Pressure/Aim Low
  2. HID's
  3. Ground kit help
  4. How to realign steering wheel with wheels?
  5. another worthless thread
  6. Wiper not smooth
  7. Spark Plug Information
  8. 6th gen engine/tranny fitment
  9. Looking For A Stillen Body Kit
  10. automotive problem of the century
  11. Is SE and 5-speed indicated in VIN?
  12. My buttons...they be broke... :)
  13. New muffler
  14. 3rd Gen Grounding Kit?
  15. Fuel pump problem?? maybe
  16. Various intake Q's....
  17. anyone have warpspeed catback
  18. need help for a friend
  19. will synthetic oil smoke?
  20. MAF wire question
  21. Rear end droning
  22. Black Out Headlights And Tailights
  23. JWT ECU on a 91 SE 5spd
  24. Starting VG build, any sage advice?
  25. exhaust help
  26. Eurolite Headlights
  27. z31 engine question????
  28. coilover setup
  29. If you think you're having fuel injector problems.
  30. 5 speed swap first problem...
  31. Cobra Rims
  32. Mustang Wheels
  33. Brake pads and rotor replacement
  34. Trouble with window...
  35. Cat Back
  36. Possible problem with distributor?
  37. anti roll bar
  38. front suspension clunking
  39. clay bar loves my car *PICS*
  40. Update: starting problem
  41. Some 3rd gen autocross pics...
  42. put engine in. crank, no start
  43. What consists of a full tuneup
  44. Power Steering Pump
  45. For BadHonda Injector issues.
  46. valve cover seal washers
  47. Hookup power leather seats?
  48. Let us say goodbye... (56k=go drive a 4th gen)
  49. Input Shaft Bearings
  50. Maxima maintnence episode V: SE wing strikes back
  51. Maxima Maintnence episode III : revenge of the stalling VE.....
  52. buying another car/carfax request
  53. Seized rear brake: caliper or e-brake?
  54. Clogged Injector Leaks on Mornings
  55. Speaker/headlight Problem
  56. bose amp wires
  57. stock exhaust
  58. running 16.0s :(
  59. Condenser replacement
  60. Do they make Angel Eyes for 3rd Gens?
  61. Doing timing belt, what parts do I need?
  62. anyone know if these ar 16 or 17s
  63. gear shifter very loose all of a sudden
  64. fog light ques
  65. 3rd gen floormats? Does anyone sell them new?
  66. This car is hot
  67. New maxima owner, with light problem
  68. Couple O2 Questions
  69. My 94 Maxima is sluggish and shaking at 45 MPH and 1500 RPM
  70. Intake for a '90
  71. "tune up" Am I missing anything??
  72. Learned the hard way
  73. bleeded air still no heats
  74. What to do?
  75. window wont go up
  76. exhaust flex section
  77. lost power door locks after disconnecting 3rd brake light?
  78. help with trunk lid
  79. '04 engine/tranny..what will it take?
  80. tach signal wire ve
  81. simple temperature gauge prob
  82. it's my bday, any ideas for car
  83. Radio Question
  84. Which spark plugs to get?
  85. Parting out 93' max
  86. Rust
  87. Custom "leather" for 3d Gen - home-made ;)
  88. Potential VE Purchase - Please Help
  89. Flare in Automatic trans
  90. New Intake
  91. VTC parts?
  92. Size of Axle Locknut
  93. Anyone had luck with FSTBs from eBay?
  94. Wiki for 3rd (all) Maxima repair/maintenance/tune/upgrade?
  95. Let's talk about lights.
  96. car sounds like a lawnmore
  97. Tail light question.
  98. Door Seals?
  99. Opinions on Brake Lines
  100. What are your car plans for the summer
  101. front door speaker mounts?
  102. For those of you with 97-99 SE wheels..
  103. Well... I found my brake fluid leak...
  104. Help me hotwire my car....
  105. I Changed the Cylinder Head Temp Sensor And......
  106. Help, VE 194 Gauge Bulbs! (Upgrade)
  107. Front Seal
  108. Speedometer stopped working
  109. Putting VQ engine in 92 SE??
  110. Stuck in DC? Help!
  111. help with shaking car
  112. grounding question
  113. this works really well...
  114. engine dimension question
  115. When extremely hot, Car dies at stop and no performance
  116. high idle.....rough change of gears
  117. 2 years of work... some pics
  118. Please criticize my work......be gentle
  119. car shutters while driving
  120. funny thing happened today...
  121. need expert help, well almost....
  122. quick vtc question
  123. article on easy HP
  124. 92 VE alternator - 2 entirely diff. models???
  125. Seat Belt Not working
  126. Sticker Shock...does this seem right?
  127. Found Classic 3rd Gen Mag Commercial
  128. i need to replace my pads and rotors
  129. Cleaning coil packs
  130. smoke
  131. Nitrous?
  132. brake/fuel line rust CHECK IT
  133. wtf!!!! everything dimming!
  134. replacing injectors
  135. E-Brake Tightening
  136. best muffler for a VG?
  137. Spark plug freakin' blew out!
  138. Engine Ideas
  139. IACV stock position
  140. Was bored.
  141. P/S pressure hose and pump???
  142. fuel line question...
  143. Sounds like somebody besides me needs a vacation!
  144. And here's another
  145. Nice looking VE 5spd on eBay
  146. a new kind of door lock issue - i think
  147. I stand corrected
  148. I need a favor!
  149. move carpet for power wire
  150. Is this a sign that my starter is about to fail?
  151. installing water temp gauge
  152. How can you find where broken vaccuum lines go?
  153. Power Steering Hose Replacement
  154. Coil Packs
  155. battery light stays on
  156. Taking out injector
  157. axel
  158. anyone who has the blehmco ground kit
  159. changing cluster from a VG into a VE...
  160. Need info on 4th gen seat compatible with 3rd gen.
  161. Replace KS or use Resistor?
  162. Clutch Replacement
  163. slight hesitation at first then normal. what to look for?
  164. Air very low coming from vents....
  165. Knocking after flex section repair
  166. Weird sound
  167. Daytime driving lights or headlight buzzer?
  168. keypad fix pictures
  169. Rev Limiter
  170. Fog lights not working ?
  171. Help - strut plates loose, can't do alignment
  172. E36 with lids ... what do you think of this look?
  173. is this good???
  174. A/C Not Workin
  175. silver lining
  176. Powder Coat Parts
  177. Engine Bucking, Stalling, Jumping Tach
  178. bose radio with sony cd player
  179. tint
  180. engine misfire
  181. Dash Panel Lights Out!
  182. Another AC Question
  183. Wheel Alignment Problem
  184. FS: $500 for my 93 SE 5-sp...parts or project
  185. hot when idleing
  186. Part Needs???
  187. its been fun....
  188. airbag light
  189. E85 fuel....yes or no?
  190. E36
  191. Replace piston rings w/out removing engine??
  192. Bose CD/Cassette/Radio quits working !!!
  193. mtbe in drinking water
  194. e-10 being used in different states
  195. KYB VS Gabriel
  196. Some problems..
  197. really need advice:
  198. Steering Rack & Pinion
  199. a/c problems
  200. new tint pics
  201. possible blown head gasket
  202. What do you guys think?
  203. Pics of MY boring day..
  204. High Pitch Noise in Rear
  205. Performance Susp .....
  206. Detonation sensor?
  207. Spokane area?
  208. exhaust noises
  209. idle woes
  210. Toyota filter Q
  211. How Do I know If My Max Had Recall(95V244000) Done?
  212. Did I Wreck my Tranny?
  213. Anyone do a JDM Engine swap on 92 SE?
  214. VG30E Weird (high) idle problem - take two.
  215. 7000 red line Vg
  216. fixed keyless entry. for now
  217. leaking power steering fluid
  218. Gas w/ ethanol - bad for injectors???
  219. Air bag replacement
  220. squeaky brakes
  221. New car.
  222. 89 Maxima RIP... worth parting out?
  223. Help...Need Ideas!
  224. Intake
  225. Ol Faithfuul?! Radiator.....
  226. Window Problem
  227. bad idling when i turn on a/c
  228. Problems starting.. sometimes?
  229. quick simple fog light question for yall
  230. High Pressure Power Steering Hose
  231. RELAY BOX - AC Problem Found
  232. Power Door Lock stops working on 93 GXE
  233. Pics from my boring day
  234. Changin Ac belt
  235. what type of bulbs are in your clr corners??
  236. Cleaning GXE Rims
  237. idea for site introduction...thoughts?
  238. Body parts - where 2 find ...
  239. Need Lighting Suggestions
  240. Maybe a new rust Recall victim
  241. Ractiv muffler sound clip link
  242. I think my guages might be going or something has anyone heard of this.
  243. my buddy just bought a 94
  244. brake sensitivity
  245. Any pictures of a white 3rd gen with black/graphite powdercoated SE wheels?
  246. Front Suspension
  247. Are the 1993-94 Maxima SE Twin Cam faster than...
  248. new foglights
  249. what size...
  250. wiring diagram anyone?
