- OXYGEN SENSOR????
- 3rd gen floormats??
- Turn fuse blowing when ignition turned off
- Window will go down but not up?
- HOW DO U UNPLUG THE FUEL INJECTORS TO CHECK THEM??
- Not a good end...
- Question for Stereo Experts
- MT Transmission Gears ?? 91 vs 96
- 3rd gen maxima VQ swap V. craigslist ad questions
- Ignition timing?
- Custom Seat ideas
- 2 Electrical Questions
- What do you guys think?? 3rd gen for sale I want to look at
- new cluster odometer dies again?
- REMANUFACTURED FUEL INJECTORS????
- Best Way to Seal a Small Radiator Crack?
- Photo of GXE Tranny If Anyones Curious
- Best Power Band Plan
- shifter issue
- 4th Gen engine in a 3rd Gen. maxima?
- RE4F02A Torque Converter Install - Phasta Write Up
- VG Auto dies when put into gear.
- Fog Lights - re-wiring HELP !!!
- Theres something wrong with my 93 maxima. HELP!
- Where is all the oil going.
- Misfire issue
- AE Door Sills in a 3rd Gen & new shift boots
- locks not working
- Need help with fuel system / ECU issue
- Black interior
- need opinions
- Transmission concern......
- Bad EGR valve or Bad Fuel Injectors???
- Remaning a Starter
- Tan seatbelts FTL
- VE HEADS
- How Do I Fix an Error Code 51
- Jiggle Sound Gone
- Rough Low Idle Speed????
- help unclogging moonroop drainage pipe
- Replacing A/C Components Myself
- new PS hose, new groan/whine
- can these be used on a VG maxima?
- Driver's window one-touch down fix
- So, what are the odds my JDM VE has new VTC's?
- My Alarm Goes off Unexpectedly Usually At Night
- Any Tips For Driving In The Driver Side Front Axle/AT Oil Seal?
- injector no resistance
- New "Used" motor is in - Same old Problems :(
- Air conditioning! Is it on or off?
- Throttle body cleaning procedure links are dead!
- Power Steering Pump Replacement -- degree of DIY difficulty? Please chime in.
- 1993 Nissan Maxima 3.0L SOHC low voltage problem 11.5-11.6V w/ VIDEO
- Who has had to replace their ASCD relay fuse?
- Something I never experienced
- Lost thread on Wing / Spoiler repair
- Sputtering/hesitation related to worn VTC Sprocket/Springs?
- Need timing belt replace! Lisle IL.
- Thank you and Goodbye...
- Rear strut removal questions....
- Would this cause a starting issue?
- Getting ready to pull motor - want to resolve last minute issues
- Search Function Settings
- 3rd gen turbo build
- Interior trim (roof) removal?
- Finally after a yr, some pics of my Maxima
- Rear Strut Piston Rod Nut
- Would like some insight
- OK New Injector In & This is What Happened
- need opinions
- wind noise on highway...strange
- Any1 ever installed U O Underdrive Pulley?
- Can The Leakdown Test for VG30E Work With Upper Plenum Off?
- VE and VG manifolds
- OH OH
- Driving without power steering/breaks
- BTDC How To Be Exact
- How do you drain the fuel tank?
- is this injector too damaged to use? pic
- i think im sure now!!!!!
- battery starting to go bad?
- GXE KEYLESS ENTRY TOUCH PAD PROBLEM!
- Any Ideas How To Remove The Tiny Injector Screws?
- Fouling on Bottom of Dead Injector
- Michael's (AWSM66) latest Maxima work pics
- HELP!!!!!!!!!!!!!!!!!
- motor mount bushing
- Strut help please?
- So, I was bored AGAIN...
- Welp....I riced it out...
- Photos of 93 J30 Maxima Suspension Parts
- Can I Inspect The Rear Caliper Without Bleeding?
- Disabled fuel pump - still getting fuel?
- so confused... injector colors
- PIcs of G35 rims?
- crack wire insulation repair
- I hit a deer
- No VE ignition timing "sight"?
- Anybody replaced front windshield?
- Broke timming belt I think What kind of damage is done
- Cleaning
- problems after engine wash
- Do I Remove the Oil Seal From the OEM Gland Nut for Rear Strut?
- Look what i FINALLY test fitted...
- misfire from h3ll part 2(videos)
- misfire from h3ll like poof poof poof!!!!!!!!!
- Spot the mod V Greeny2
- VIDEO: My Electric Exhaust Cutout First Run
- the problems keep rolling in
- tick noise while rolling
- RUSTY Coolent??
- I need soem advise for a better 1/4mile run
- Interior sunroof cover alternatives?
- my 92 got a bit owned
- Timing: Me vs FSM
- Is this a common oil leak?
- coilovers Finally?
- What to check to fix exhaust smell after injector replacement?
- color not matching
- E-Brake Issues
- Good quality fuel injectors
- Don't Know How You Guys Got Those Clips Off
- Has anyone Ever looked into This
- ignition help
- Grounding VTC
- Can ABS Be Dangerous?
- auto shift knobs
- Battery keeps dying, why!?
- After years of searching...
- car dying while running
- Who to setting timing
- Trunk?????????
- Revolution sensor error
- Dash Lights Intermittent
- MAXUS 09 WHO'S GOING??
- slow cranking
- Location of scanner connector
- Aftermarket Gauge Face Installation Write-Up
- So, I Need Your Opinion...(Power Windows)
- Want Smoked Headlight Covers For Your 3rd Gen?
- new axle, new control arm. Now vibration under fast acceleration
- Putting on White Face gauge and i think i broke someting. HELP!!!!!
- Multiple ECU Codes?
- maxima wrecked :(
- How do you deal with people with no insurance
- recomended brake pads?
- Runs Rough Only During Rain Or Snow
- High Temp Paint didn't Do Crap for My VG Muffler Assy
- Suspension Questions
- Paint
- Passing Smog
- Correct 1993 VG Injector Green or Yellow Dot
- Battery area rust
- 3rd Generation Rear Struts??
- Lucky to be alive
- turd gen teh pwnzor!!!
- installing axle...
- Using Speed Bleeders
- Knocking sound
- ED Kombat Body Kit
- What is causing this squeeling noise? [in the engine]
- having trouble getting tie rod to steering knuckle ball joint off
- Can this '91 be saved?? (pics)
- My 94 maxima Videos coming soon
- Clicking under e-brake?
- two different ve30de motors, i have both lots of pics
- CEL Again! Codes 34 & 51 Help!
- power steering hose leaking
- How exactly does out security passcode system work?
- Tires Studs
- Spot the mod
- HELP! Installed Pathfinder/ VG30ET injectors - not starting!
- Best way to pull the block and tranny?
- anyone in seattle area looking for ve 5spd?
- Keep blowing engine control fuse.
- Battery Connectors / Fuseable Link
- Adding a little Down Under style...
- Fuel Tank Vent hose
- Ball Joint... Stuck
- Installing Driver Side CV Axle
- Adding new switches
- (Aftermarket) Alarms and keypads
- Breath In and Breath Out!!!!
- Play in Front Axles - Jiggling Sound Down Low
- wiring diagram on a radio for a 91 maxima
- Need brake help!
- Fuse looks good; what the - is wrong with my radio?
- Auto hesitant to shift into second..
- California Spec ECU?
- Maxima VE vs T-BIRD SC
- tire size
- VG Rear Brake Conversion
- Rear caliper problem
- TACH Erratic
- odometer
- Bose question, please help
- Blown head gasket
- Moving on...
- Two audio questions
- stock 1992 ve highschool kid build thread..follow me from the start, (pictures)
- 1994 VG Check Engine Light On
- my GXE plus some questions
- Intake/Throttle Body
- battery problems, again.
- my car pulls to one side and nobody knows why
- Besides AMSOIL, tranny fluid
- Headlights
- junk yard sensor connectors. how do i pull out wires, pics
- Thinking about paintING my car...
- Junk Yard Trip
- TORQUE CONVERTOR/ tranny REMOVAL
- speedometer not working properly
- your input on your interior color
- Door question
- bolt pattern
- Replacing injector
- Rear sawy bar help!!
- Well I think im gonna sell my ride... anyone interested in my headlights?
- Would you buy these? (2 '92 maximas)
- speaker amp?
- The Great 3rd Gen Video Thread
- engine misfire moves from one cylinder to the next wtf
- ASP VG crankshaft pulley how to?
- Loud whistle after injector replacement?
- Iacv-AAC Valve Gasket question.
- How the hucking fell do you actually pull the injector out of the rail?
- GI: NWP VG Phenolic Spacer Group Buy
- Polyurethane Control Arm Bushings
- Fuel Level Guage Malfunction
- Stalling and rough running while idling or at low speed
- Could 5 of my 6 injectors be bad?
- (Another) Turbo 3rd Gen
- MANUAL SWAP IS DONE!!!!!
- The Maxima Has A Little Brother...
- VG30 Rebuild.
- Swapping brake lights
- Starter fuse
- replacing an injector any tips
- Air-Bag light constant on
- Teh VE hawtness has been revived!
- changed radiator, air not so hot when freezing out
- Injectors OEM or Remanufactured?
- Engine Misfire
- Injector problems??
- Replacing fuel injectors
- keys keys keys
- goodridge ss lines
- Progressively cranking slower
- Overdrive. re-evaluating?
- Headlight Retrofit Help
