- i LOVE my vg (broken timing belt)...
- Mounting 7 in Microvision
- Instant RPM rise
- Brake pedal for conversion
- Took some pics after i used a clay bar...
- where to find bushings
- HELP! Where to lift VG engine??
- Well crap. I can't get the driver's door open.
- New Grill, New Pictures
- Rotor button
- VG on hold, let's talk cams
- low fuel warning indicator question
- Clunking noises while driving
- Got my new 3rd Gen!!
- i need your opinions please!!!
- Steering Rack Replacement
- for those of you with 5spd trans
- ITT I search for you :o
- Sudden bad gas mileage?
- 92SE A/T shift kit
- VE30DE Header flanges
- Blank factory keys
- Axle Replacement
- Stock Rim question
- Body work
- Can you guys help me with this error #32
- It's gotta be the switch right???
- what are VTCs?
- help with addco sway
- Car Domain site thought
- New clutch ideas
- Window switch just broke-help!
- Engine won't start
- Can I change out the key locks???
- Ordered from Warpspeed?????
- Lock doesn't go all the way up.
- Where can i get a JDM engine?
- Check engine + Oil lights lit with removed key
- $1,094 = what I paid to fix....
- Transmission Problem: Auto slipped out of gear
- window problem
- Finally the suspension is on! Freshly washed pics.
- recent fix
- need help!!!
- Advice on install and performance tracking...
- 92 VE which one is the IACV
- What are the wires going to the battey?
- another temp gauge prob.-long
- Where is the Speed Sensor located?
- Clutch time again, need a fianl solutiuon.
- The ticking time bomb just went off....
- Replace Transmission or Not?
- mods, please dont erase.
- gas smell
- Driving the un-modded car
- After alignment problems...
- What is the trans code of the VG trans
- some advice
- The Car stalled when braking too hard
- Stubborn Exhaust Manifold Stud...pic
- exhaust leak fix, it really works!
- broken speedometer
- ECU PINs
- help-locks stopped working agine!
- performance headers/y pipe
- clickity clack from engine
- Rear suspension and blehmco upgrade finally done!!!!
- new intake and some questions
- Door Problems
- Shift selector removal?
- which gauge panel?
- weight reduction
- is this normal?
- Engine Restore
- Long Never ending problem. Any input would help
- Turbonator? anyone heard of? Does it work?
- Clay bar
- What' wrong with my brakes?
- posting pictures
- 3rd gen Seattle Meet: Saturday, Aug 6th
- Rust...
- Skyline Tails
- oil press gauge install
- those with HUDs, problems
- Removing Spray Paint
- exhaust wrap
- Does anyone remember....
- just a question
- TSB for rear Seatbealt Retractors
- Strange Power Window Problem
- Who has brake rotor/pad pricing like Automax?
- reman fuel inject
- Small questions on changing ATF?
- grant steering wheel
- Tranny Repair, need advice/opinion
- Power Antennae Not Extending Fully
- Fresh Paint Pics
- noise from front of car
- Cleaning Tinted windows....
- Is this a record or something?
- ebrake light stays on
- bleeding brakes/ss brake line install
- HELP!!!! theft wiring
- Need Help: Part num. or name for this hose?
- injectors and premium fuel
- Odometer stopped working!
- new alternator whines, why??
- help with temp gauge
- Tail light covers (Dual circles)
- Fuel Injector replacement questions
- hole in firewall
- Alternator leak current; how much?
- any1 try pathfinder navi in 3rd gen?
- window reg ques
- Windshield replacement ...
- power steering again
- Made my clock always fully illuminated
- fellow 3rd gens with 15" subs...
- More on Magnaflow...
- East Coasters - Poss. Large Hail
- Datalogging/OBDI Palm Question
- rims
- Power trunk release nonfunctional...
- Rims
- Parts Source?
- offset Q's
- vaccum canister?
- need measurements of exhaust cut-out in rear lip of stillen kit.
- Support bearing bracket
- need some suggestions
- noise from drivers side front wheel
- jdm ve swap completed but few problems
- Front pass seat arm rests, are there?
- Anyone have Fidanze Flywheel?
- another e36 convert thread
- How many max's do you have?
- Some help please (plexiglass related)
- Thinking about getting a 3rd Gen!!!
- Parting Away With My Max!!!
- power steering rack boot
- 3rd gen Wrenching Tricks of the Trade
- new brake pads porterfield's?
- Driver's side headlight is out
- Can you identify this Tranny?
- gauge cluster swap (GXE vs. SE)
- monza catback?
- Replaced both LCA with poly, did the PS hose
- noise
- Warpspeed not making 3rd gen exhaust???
- Possibly selling the Maxima...
- anyone ever try this on a 3rd gen? pics inside
- kinda sorta maxima related
- CV boot ???
- shift boots
- superchargered maximas
- Motor mounts interchangable?
- What exactly does the surge tank do?
- 2 questions
- Window regulator and motor question.
- ASCD wiring
- Shifter popping out of gear
- need help from the maxima enthusiats
- oil pressure guage
- Something is seriously wrong with my steering
- Autozones return policy on tools for changing 91 SE rball joint?
- power antenna
- Changed trans oil today
- Because so many of you want an A/F meter
- Does anyone know where ot get a very low mileage motor for a 91 4dsc auto
- Power steering lag
- Power door lock, alarm, remote
- Changing ball joints questions?
- inspection woes
- Tranny Change: For the Criminally Insane?
- Remove the center rear trunk pice...or not?
- Fsm
- General Injector Questions
- Almost everything is ok!
- Turbo Manifold options?
- Speedo not working
- seafoam
- HELP!!!! feels like wheel is going to fall off!!! (VE auto)
- been a while, just updating everyone...
- Anyone have sticking rear doors?
- Fuel injector pintle caps?
- Underhood Heat
- Suspension swap oddity?
- Exhaust manifold warpage?
- Exhaust stud hardware
- Power steering fluid leak????
- weird sounds
- How Many Amps Is Stock Alternator
- 1Grand to play with, what to buy???
- cefiro front end swap
- hole in the cat
- What is the condenser made of?
- Air Condition goodies update for u
- A/C question
- Brake Problems.
- finally updated my cardio site
- maxima clock
- I did a Jeff92se :)
- Been getting an odd noise from the front
- Big 3 Upgrade
- rpm's and acceleration.
- I pulled a Matt today
- new job = updated ride
- It's been forever
- omg look at the rims
- opinions on suspension
- high idle
- rear strut removal problemo
- trade in the works
- Quick question, potentially got scammed
- Do I really need to buy a 4th slave cylinder?
- Exhaust studs +++
- Attn Fidanza users......
- new tires
- Tire Pressure
- so sick of my crappy gas mileage
- Wiper Problem
- Ball joint OEM part no
- My road trip...
- Jacobs Pro-Street Ultral Team. Any Benifit?
- How much to get a decent paint job done?
- Removing Right Halfshaft - Need Help!
- Needs front end naked pics.
- Need some serious help pliz
- how fast would you go in your 3rd gen
- Keyless Entry install....worth the hassle?
- Visiting NJ/NY
- manual transmission mount
- I've had mine for 2 years
- Exhaust Studs - A Thanks
- Max Broke Down(Very Weird) - Please Help
- O2 Sensor difference
- Need Opinions...
- What Lowering Springs
- Outside Temperature Sensor
- Im I insane or....
- all lights dim, erratic idle, dead battery....help!
- Fuel injector diagnosis and replacement
- Door Panel question
- Bye Bye 1st gear
- Oil Leaking Problem
- Manual Transaxle Grind
- problem with belts maybe
- One Touch Sunroof Control?
- You ever had a "one of" problem that no one else seem to have problems with
- MAF Adaptor
