View Full Version : 3rd Generation Maxima (1989-1994)
  1. O2 Check Engine Light Issues.
  2. Looks like Im back :)
  3. Cefiro Question
  4. Bose Radio
  5. Hey all, thought I'd stop by and say hi!
  6. general info on Bose amps
  7. i need help removing driveshafts?
  8. cloudy headlights
  9. How does cruise control work?
  10. RPM drops to 200~400 at the light
  11. Shifting Problem...
  12. Check out my 200$ maxima se
  13. flush mounted bimmer lights, pics inside
  14. BRAKES?? Need Help
  15. Lost all pressure in my clutch
  16. On the pipe....
  17. Found some pictures(Now I need to find my car.)
  18. Strange sound coming from dash? Any thoughts?
  19. Front end noise, Ball Joint or CV?
  20. anyone heard from awsm66?
  21. Warpspeed Y-Pipe
  22. Speed sensors for different years
  23. How Far - with one gallon?
  24. radiator resavoir
  25. Hmm, MAF issues? '92 Maxi
  26. Possible or waste of time (lighting Q)
  27. Help with GXE alarm and trunk sensor.
  28. i need a new clutch
  29. Brake Job
  30. ACC Question
  31. Just Some Pics of Max
  32. CF hood?
  33. Rear wheel arches
  34. pathfinder bose hu question
  35. Adjusting rear discbrake help
  36. heater core
  37. Wiring problems?
  38. how can i tell if timeing belt snaped????
  39. Brembro blanks and increased performance...
  40. Help a friend, help a friend
  41. Rear drum seezed up...Help!
  42. low idle still
  43. Philadelphia dyno day
  44. Tempature gauge rises while idling
  45. E-brake
  46. Our 3rd gens are Famous!!!
  47. Hummmm an exhaust option???
  48. Cooling Issues
  49. Dropzone Lowering Springs
  50. flex band
  51. Did some work today.....
  52. replacing manifold studs today
  53. Struts 1990 maxima
  54. my car wont idle anymore?????????
  55. how to increase your fuel economy
  56. hinge pins
  57. Need help diagnosing problems
  58. Hey Yourself, saw you today
  59. VG Timing
  60. Good place to get fuel injector
  61. Intake Manifold Bolt Question
  62. transmission fluid qustion
  63. Anyone else donating to a NO victims fund?
  64. Well this might be the end folks
  65. anyone with a junker want to try this?
  66. Weird Hesitation Problem???
  67. Umm...Big Problem!?!?
  68. Brakes making loud moan when stopping
  69. Brake Job
  70. Do you get better mileage with better gas or is just good for the car?
  71. Green vs. Yellow Marking for 93, 94 Injectors
  72. Somthing Wrong
  73. fallen windows glass
  74. Putting a VG into a VE...part 2
  75. Great Day With My Max
  76. Gas
  77. How do you install a tranny cooler in the max?
  78. Heat / AC issue
  79. Sea Foam Question! Help
  80. maxima nightmare...literally
  81. 300ZX calipers
  82. tranny shifting weird
  83. Any Swap Mechanics in or around Southern MA?
  84. PITA oil leak
  85. Help! Lost Key AT locked
  86. lower controle arms
  87. going rate?
  88. SE Stock headlights
  89. changing foglight bulbs help
  90. so i turned my max into a drift machine...
  91. pulling the tranny today
  92. Transmission Rebuild VS Used
  93. .org stickers?
  94. FSTB worth it?
  95. nissan's prices
  96. Decent Price?
  97. road rage
  98. need to paint bumper
  99. Thoes dang yellow lights on the chevy's
  100. Problems started last week
  101. 93 with 84k - $5,950
  102. intakes?
  103. What is the sealing factor in the AC parts?
  104. To all that have done the TB bypass.......
  105. Clutch
  106. any break in period for new clutch?
  107. Two Quick Questions
  108. c foam
  109. orger's in katrina's path...
  110. Odd Hesitation
  111. VGDET heads for a VG30E?
  112. hesitation....help
  113. Exhaust on a budget
  114. Flushing cooling system
  115. starting/power issue
  116. Replaced front wheel bearings-saved $400
  117. help removing permanet bird dropping stains...
  118. PVC valves and cussin'
  119. M.I.A.xima
  120. Quiet "chatter" in 5spd transmission under stress
  121. door hinges
  122. oil sump
  123. How many gallons per gallon?
  124. Question about antenna drain
  125. Stuck on the side of the road HELP!
  126. Injen CAI for 3rd Gen only $5000 !!!
  127. VG30 Timing Belt Replacement
  128. Oil Leak that Opec would hate!
  129. headers???
  130. wsp vs. greddy from the cat back
  131. People That Bought Tokico Struts
  132. WHat Mod To Buy
  133. Should I replace the starter
  134. Need source for radio mounting bracket, etc.
  135. Rear parrell link bushing kit. Worth it?
  136. i need a 1992 fsm
  137. 247.4bhp?
  138. got the timing belt done....
  139. lots of problems lots of money
  140. What do you guys think? (pictures included, 56k welcome)
  141. Cars missing, stumped!
  142. lost power
  143. So I thought I got a steal CONTINUED....
  144. Looking at 3rd gen
  145. How to set VE30DE timing??
  146. problems with slave cylinder after installing new clutch
  147. wipers only work in one speed
  148. Can anyone put up a picture for Speed Sensor?
  149. E36 lights help PLEASE!!!
  150. Best way to remove old Gasket...kinda urgent!
  151. iacv location?
  152. Putting a VG into a VE...a few questions
  153. Fuse and brake light problem
  154. Just replace the o2 sensor and KS?
  155. break grinding
  156. Found Some Rust(pics)
  157. heater hose or core broken?
  158. Tach is possessed!!!
  159. Horn Not working
  160. Brake Question
  161. What a bummer
  162. Question on Steering Linkage
  163. VTC's and oil type
  164. Stiff Brakes!! What do I do??
  165. Motor Oil
  166. ve trans mated to vg, a few problems
  167. What to use for winter wheels
  168. Just thought i would share!!!!
  169. Weird starting problem
  170. Otto Bar.. Me likey likey!!
  171. Looking for someone/shop to fix the broken manifold stud on 93 GXE
  172. weird tread ware on my 91 Max
  173. Wiper Help V.2
  174. need help on removing wax on door moldings and stock spoiler
  175. strut tower deterioration
  176. Might buy a 93 that threw a connecting rod
  177. Soo i have been busy with the grill pictures and others
  178. Fog lamps
  179. Aftermarket gauge users.
  180. who sold their se?
  181. Just got my OTTO bar in,, any advice??
  182. VG intake
  183. Hesitation & surging - then CEL came on
  184. stupid *** sunroof
  185. repair woes
  186. ECU dying?
  187. what's wrong with cardomain?
  188. Hella Supertones installed - See how
  189. Advice on buying 93 SE
  190. Why does this so not look like mine??
  191. All windows quit-resolved!
  192. Need help with Rack and Pinion R & R on my 90 Max
  193. need the FSM
  194. Engine rebuild
  195. tranmission problem
  196. Door Lock Actuators (89 SE)
  197. plug cleaning
  198. My VE(many pics - beware 56k)
  199. If you are scared your heater core will die and leave you stranded, please read -->
  200. weird el. problem. Wiking may be.....
  201. Shifting at high RPM
  202. Water Pump Replacement Instructions??
  203. professional service stress
  204. shaking and high whine
  205. luk clutch
  206. spoiler
  207. HELP! VTC problem!!!
  208. I'm about to give up on Warpspeed
  209. Problem with Wipers
  210. cooling fan problem!!
  211. Parts Source - Manifold Studs?
  212. getting new clutch
  213. Racing Chip
  214. Replaced the injectors, do I have a bigger problem?
  215. Ignition Coil soaked in oil!
  216. very weird problem
  217. Flippin window!
  218. a/c recharge question
  219. All windows quit
  220. Anyone with wiring diagrams?
  221. has anyone else tried this on ve intake
  222. Electrical problem with my new VE
  223. My parts car tried to kill me!!
  224. plz don't say this is a stupid question...but...
  225. My upholstery saga continues ...
  226. So I THOUGHT I got a steal....
  227. Dead MAF... quck question...
  228. Door Locks
  229. Parts Gurus, HELP!!!!
  230. Where to get O2 sensor?
  231. Lighter Flywheel for Auto?
  232. Rainy day weird electric droplets
  233. Rims
  234. Maxima Commercials
  235. underdrive pulley
  236. Air box Vs Cone filter
  237. Cheap suspension mod?
  238. NEW PICS Check out the car
  239. 1st Axle Replacement - Front driver's side
  240. Ahhhhhhhhhh...........A/C!!!
  241. whats it worth?
  242. Some updated pics
  243. HELP- 5 spd tranny problem! shifting out of gear while driving.
  244. Those with HIDs help me out
  245. How much for parting?
  246. Crap again! Now my driver's side window won't go back up
  247. Ignition coils in a certain order?
  248. Electronics, one more try
  249. Need your opinions....SE or GXE Wheels
  250. Must be a record
