View Full Version : 3rd Generation Maxima (1989-1994)
  1. Goofy problem - climate control display gone dark
  2. Just installed Clutch masters stage 1 and fidanza
  3. radiator help
  4. Homemade Short/Short Throw Shifter
  5. Opinions wanted... G35 coupe Muffler
  6. question about heating
  7. ATTN: ALL MEMBERS - I SUCK AT TEH MODDING
  8. Which oil filter to use for oil change?
  9. VE performance problem.....
  10. 93 se VS. 95Acura legend
  11. Fuel Gage is reading 1/4 less than it should!!?? HELP!
  12. Why can I move my rear pass wheel in and out>?
  13. Tire Size Question
  14. quick length question!
  15. Wind shield wiper water tank leaking
  16. Rear Drum converstion?????
  17. Ideas to get exhaust off?
  18. How much capacity of antifreeze for 92 gxe maxima? Urgent as working on it now..
  19. Busse Woods, IL All Nissan meeting, anyone going?
  20. I cant find my computer?
  21. VG to VE (VTC fix)
  22. New toy M3 mirrors
  23. Lexus GS/IS series licsense plate lights.....future mod maybe?
  24. calendar pics
  25. How do you stop clear coat peeling?!!
  26. bumper is painted (pics inside before/after)
  27. temp went to High and smoke
  28. Real quick rear brake ???
  29. car is stalling on idle or driving
  30. ebay CAI, MAFS problem?
  31. Look what i found
  32. need some advice painting bumper
  33. Estimate for repairs, ouch.
  34. Are Dynomax mufflers any good?
  35. gold package on 3rd gen
  36. Wiper Piviot Point
  37. Thought it was plugs, boy was I wrong!!!
  38. Bbbbbaby - it's cold inside!
  39. boneyard goodies
  40. headlight help pleeeeeeeeease
  41. Euro/JDM or foreign maxima pic thread anyone have any pics. I do
  42. Valve rattling in a vg question. also gas grade question too.
  43. the mailman brought me some goodies
  44. '93 Max Versus '93 Camaro z28
  45. People with 5spoke rims sign in
  46. Cant install FSTB on right side tower..hose blockin way
  47. Rear Main Seal Automatic Transmission
  48. A question on painting...
  49. Input shaft bearing
  50. Me wantz a WAI
  51. Manifold Stud Question - Y-pipe
  52. hard to shift gears in my manual, why?
  53. In the garage on laptop trying to fix wipers, please help
  54. vg headers? who makes them? ANy one have them, any word good or bad?
  55. Max not starting AGAIN!
  56. Weird problem with car windows!!
  57. Knocking is gone
  58. 91 max wont go over 75mph
  59. Sputtering and vibrations
  60. '96 power, heated seats in my '89
  61. Fuel rail?
  62. Who's maxima is this on this board (its black) look inside
  63. Is my starter going or has my alarm gone haywire??
  64. Very Emotional Day for me.
  65. shift linkage help
  66. Replacing fuel pump
  67. Charging System Prob?
  68. Passanger Side Grinding when breaking
  69. help with y-pipe studs
  70. Heater Not working?
  71. VG Air Box Question !!
  72. Is it safe to clean injectors with CarbCleaner?
  73. Relay?¿
  74. Prices for a VE
  75. Need a cat....not the meowing kind
  76. Best sounding muffler ever #199
  77. Wierd clutch
  78. where on earth is this hose connected to
  79. Green Dot vs. Yellow dot injectors for 1993 and 1994 VG30E
  80. Half Shaft Part number for VE
  81. Front right wheel wobbling need help
  82. what size tires for 18'' wheels
  83. need help with my BOSE
  84. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!
  85. non driven VG running rough
  86. toyota filter #
  87. rear strut cartridge
  88. weird heater problem
  89. volk wheels?
  90. Best sot to run Power cable
  91. Gas Smell Is Gone....... BUT.....
  92. Bose Whining
  93. Update! (pics)
  94. hard to start when it rains (odd)
  95. short throw shifter
  96. looking for thoughts on how to spice up interior (classy that is)
  97. JWT ECU and Knock Sensor thread split
  98. VE30DE build details
  99. Power Steering pressure hose replacement
  100. Engine/ Tranny Mounts
  101. Pics!
  102. doing some surgery soon
  103. Exhaust Manifold Studs.....anywhere to gettem other than dealer?
  104. Front bumper cover removal
  105. Somethings broken here
  106. Best clear corners, recommendatons?
  107. FSTB Question
  108. spare mirror?
  109. help with ignition.
  110. Stop Lamp failure, please help
  111. Quick help needed in cd player installation
  112. How can I be sure my Max is being cooled properly?
  113. manual tranny fluid change
  114. Stereo HELP!!!
  115. No, really, I do have a catback...somewhere...
  116. **3rd gen owners, put yourself on the map**
  117. New Rims *pics*
  118. Need swap help info
  119. No blinkers....what happened? step in...
  120. What is whining in my max? Help!
  121. Car is acting wierd
  122. A Q about Painting
  123. 600$ 154000 mile loaded 3rd gen maxima is it worth it !!help!!
  124. cracked/broken injector plugs
  125. Making More Light
  126. hard to start problem
  127. UH OH! What Have I Done Now?
  128. My 92' GXE Pics
  129. SS clutch line for VG stick
  130. Where to get studs???
  131. My car's still on the lift!!
  132. How much to shave off VG heads to get 10:1 Compression?
  133. jdm vg30et install
  134. still having troubles with ve
  135. steering rack replacement check list
  136. advice on tradeing from vg to a ve max
  137. if speed is wrong what about RPMs?
  138. Are there any aftmkt spoilers that fit the stock holes?
  139. Battery trouble?
  140. Intake idea...CAI
  141. Finally took pics of the max
  142. Lighting Problem (Headlights and Foglights)
  143. Car got broken into....
  144. Max and 5 speed swap are almost done!
  145. 1st and 2nd gear, toast.....
  146. ABS leak
  147. therealgoon9, happy birthday :)
  148. Max doesnt start????
  149. PCV location (1993).
  150. Are wheel bearings a big problem on our cars?
  151. Some help trouble shooting steering problem
  152. weird sound...
  153. Totalled the max. Bye, maybe...
  154. Trans Problem
  155. Bad radiator..or bigger problem?
  156. Cant seem to pin point vibration........
  157. starting problem
  158. Clock and Stereo wont turn off
  159. Oil Leek??
  160. reverse glow gauges
  161. How do you hold the crank pulley still to loosten the bolt?
  162. The winterizing thread...:-)
  163. 10" or 12" Sub
  164. Low pressure hoses r12 and r134
  165. legal legal legal
  166. Getting new Half Shafts.
  167. just did a carfax
  168. thought you guys would like this *pics*
  169. Hit a Median...........
  170. Knock Sensor
  171. High Idle Help Please!
  172. Carbon fiber hood vs stock hood
  173. Headlight problem
  174. ...and I knew I was in trouble when my exhaust passed me...
  175. tuning fork effect...belts?
  176. Gas smell from the tank cover
  177. To those who have done the 5-speed swap...
  178. Probe GT Wheels
  179. Power Steering normal or acting up?
  180. Input on 3 Gen as a beater
  181. Have a broke valve. What else can I do to the heads while they're off?
  182. Power Locks.
  183. Fstb
  184. New Battery, All Lites On, ....No Start!!!!!
  185. sway bar end links
  186. Replacing t-belt Saturday
  187. Waiting for "I-Bent-My-Key-Day"
  188. Vin Check Please
  189. Changing exhaust manifold gasket.....advice?
  190. Tracks to the right...
  191. Powering aftermarket accessories sort of long
  192. heater core continued.....
  193. Exhaust Leak on Y Pipe
  194. need a carfax ran
  195. Lowered Alignment
  196. in the matter of master & slave cylinders
  197. By Popular Demand!!! PICS!!!!
  198. cold/heat slider problem
  199. What do you do after all the bolt-ons?
  200. replacing passenger side axle
  201. Does high grade fuel & advanced timing need colder plugs?
  202. ATF level
  203. Performance increase question....I know you're tired of these...
  204. replaceing lower balljoints
  205. Trunk lid
  206. is this bad??? *pics*
  207. Discovered Something Leakin Need Help (PICS!)
  208. another man's problems
  209. The Stillen Front Lip, and Fog Lights
  210. ode to a manual trans
  211. fridays genocide
  212. power seat problem
  213. Puff of smoke and exhaust smell in the morning
  214. part request, heater control unit
  215. Need stock exhaust:
  216. VTC Clack!!!!
  217. Worried about smoke
  218. Mustang wheels on a Max?
  219. Exhaust Manifold Leak.....What to do?
  220. wierd shutter while driving
  221. plates between tranny and engine
  222. Move on to 6th Gen Maxima
  223. Rubbing Problem
  224. need help installing car alarm
  225. starting problems
  226. More pics from my crashed max
  227. "fill-in car"
  228. shock problem
  229. Did tranny honey help your automatic?
  230. Rear KYB struts fluid
  231. wanted : dyno sheet.
  232. intermitent power problem...VE
  233. Trouble With Auto Shop!!!need Help Pliz!
  234. Maxima bit the dust at the right time
  235. temperature problem
  236. Hoisting a complete VE on a pallet.
  237. IS WARSPEED Y-pipe SAME for VE and VG?
  238. not sure If I had the compresssion stroke or not what would happen
  239. Video of my ex-89 SE accelerating....
  240. GL-4 gear oil [where to get it?]
  241. No Red valve covers here, MrGone :)
  242. quick psi air pressure question
  243. custom fenders?
  244. Let's meet this Friday-Minneapolis,MN
  245. How do you make a home made CAI?
  246. Which is ebay CAI for VG+where to get o2 sensor?
  247. do i need my Power Steering cooler
  248. 89 questions
  249. Rollin'!!
  250. What Kind of engine
