View Full Version : 3rd Generation Maxima (1989-1994)
  1. Whats the best tint % for a maxima?
  2. gas leak?
  3. 93 wont start
  4. Adding alarm Blinking red light
  5. Wierd turn signal and headlight problem.
  6. Header question
  7. 357 miles on 1 tank of gas
  8. 3rd Gen feat. in Hemmings Sports & Exotic
  9. cars getting worse fuel economy
  10. VG-VE Speed Sensor
  11. Mechanical rapping
  12. Max running like crap!! Please Help!
  13. Jumpy Speedometer?
  14. Cold weather or worse?
  15. the rust recall epic
  16. Headlights
  17. Transmission problem...?
  18. wheres the guy who went 12.5 in a 3rd gen
  19. 92 SE Gauge Cluster on 92 GXE?
  20. addco sway bar... bolts undoing themselves!
  21. Best place to get injectors and my blower is stuck on!
  22. 5x114.3 lug, can i get a hand
  23. Do not accidently post in the 6th GEN section.....
  24. Quick question
  25. dropped tranny??? somone help
  26. More Pics
  27. Jdm Origin
  28. My $50 max
  29. J30 Brake conversion
  30. Need Help: Axle replacement on 94 GXE Auto
  31. Replacing Driver axle seal
  32. took 18s off rockin some 17s
  33. power steering noise....
  34. ignition coils
  35. car running very poorly, please help
  36. Changing out keypad
  37. wiring diagram for swap
  38. Silly computer Q.
  39. Out of sight, out of mind.
  40. natural to smell antifreeze after spilling some in the bay after hose replacement?
  41. weird speedo problems
  42. Vansskaterfreek's axles don't fit thread:-)
  43. Pics of two of the triplets one year later
  44. 'so is smoke SUPPOSED to be billowing out from under the hood? 0_o'
  45. I really really miss my max...
  46. amount of fluids..
  47. Are these sprints spring or what are they?
  48. Rear Window not working?
  49. Third Gen Insurance ...HELP!
  50. Injector dots
  51. Steering sticking - could it be a bearing?
  52. Cat + b pipe
  53. Gas overflow vent hose repair
  54. replacing water pump on ve
  55. High Idle/Surging
  56. Suggestions For A Pillar Gauge Pod
  57. Tough decision
  58. Valet Key
  59. The following does not work; is it related?
  60. Digital Climate control degree change
  61. A/f ratio gauge
  62. nitrous in max
  63. Sweet headlight trick!
  64. what happens when you are being dumb on a public street
  65. Stupid, Stupid Nobb Question......
  66. About to replace my IACV...
  67. Can we use anything off of a J30?
  68. and the swap saga continues......
  69. high rpm when idle on ve
  70. Another KS question, should be easy
  71. Please Help
  72. 3rd gen in snow and ice
  73. Disabling factory alarm...with broken driver's side lock
  74. Master Cylinder Pic Request
  75. 4th gen seats in a 3rd gen
  76. Testing New Camera, tell me what you guys think..
  77. Aftermarket Alarm Problem
  78. HEEEEEEELP tranny drain pug!!!
  79. On the topic of vacuum lines...
  80. Transmission Fluid
  81. brake help
  82. Code for VE LSD 5sp tranny
  83. best place to buy new VE axles
  84. what to replace when changing a tranny
  85. Carquest offically SUCKS A$$!!!
  86. VE Power Steering Pump
  87. 3rg gear in a vg 5peed
  88. Need help on vacuum lines...
  89. winter
  90. VE Axle Replacement
  91. replaced rear struts, now they go clunk
  92. Platinum Plugs for the VE
  93. Help With distributor rotor
  94. VE to VG HELP!!!
  95. Something's draining the batt. (its not the alt)
  96. 93 Max SE 5 SPD 150K miles needs 4 new struts.
  97. Leaking coolant...but from where?!
  98. Replaced Axles and now....
  99. Stock Tire Recomendations for 92 SE
  100. Brake Pad Recommendations??
  101. New Max Tommorow. Super deal
  102. Need diagram of IACV and Throttle Body vacuum lines
  103. help, noise?
  104. Happy Thanksgiving to all my 3-gen bros.
  105. wheel hub question
  106. ve cai pics are up :-)
  107. VG running rough Help
  108. Confused max:
  109. Oem Number for IACV..DOHC motor/Manual Trans
  110. Free carfax, hurry while it last.
  111. Question about our Stock alarm
  112. VE Electrical expert?
  113. What other Maxima rims fit a 3rd gen?
  114. Over torqued tie rod ends
  115. To anyone who has replaced their IACV on a VE Motor
  116. weird problem
  117. VE Shudders/dies at any speed
  118. VG porn
  119. Woohoo! the rear end is pulled! part Deux
  120. max running rough
  121. Heater and Running problem
  122. Okay Weird VTC Issue....
  123. possible T-belt misalignment?
  124. check out what I'm rolling with (this takes me back :D)
  125. phillips hi visibility bulbs
  126. my power locks dont work
  127. Woohoo! the rear end is pulled!
  128. Goodbye Maxine
  129. window regulator install
  130. Digital re-set?
  131. Many many questions...
  132. Dash LIght Death....
  133. So I buffed/waxed my car for the first time
  134. Trans goes again
  135. VG Maximas, replace your distributor rotor
  136. what years had the egr temp senor
  137. KYB Rear Struts Too Long?
  138. Should I replace the struts on my beater maxima?
  139. hood adjustment
  140. 5-speed update
  141. Fuel Pump Replacement
  142. Rear Center Reflector
  143. As long as I'm there pt1.
  144. Fuel Light
  145. how the HELL do you take out the fuel injector?????
  146. Spark plug wire diagram
  147. 92 gxe worth it????
  148. Digital Dash
  149. INstalling a transmission cooler?
  150. Price estimate
  151. Electronic Speedometer???
  152. Hey 3rd genners... Good DEAL
  153. Fuel Pump Issue/Relay Location
  154. Knock Sensor replace
  155. Damn Axel Bushing!!!!
  156. Best way to DIY allignment
  157. HELP with gas mileage
  158. I found a great deal on struts...
  159. Vibration increased in D/R and brakes applied
  160. Railroad Tracks!!!! =( =( =(
  161. 98 rims on a 90
  162. Headlights for a 3rd gen
  163. engine choices, ideas
  164. For anyone who cares...Pix of my sled are up.
  165. Need new door, couple questions...
  166. Anyone Have a Pic of IACV/EGR valve/PCV valve?
  167. trouble starting when warm?
  168. whine and gas smell- connected?
  169. Anyone have a discount code for CE??
  170. Loss of Power
  171. Big freeking hose w banjo fitting??????
  172. My 92 got hit! ::PICS::
  173. thumping nosie coming from the wheels???
  174. hydroplaning is no fun.....need new bumper skin
  175. Problems with idling?
  176. (PAGING internet auto martor whoever can help)oil leaking on bushing
  177. New Redlinemax Y-Pipe
  178. Manual Experts Please
  179. put car in reverse and shifter didnt stop until it hit the console ;X
  180. VERY annoying scraping noise coming from the rear...
  181. 5-speed conversion
  182. problems with car after letting it sit for a while
  183. Way to get $$ for bad axles?
  184. Body Kits
  185. Is it possible to use VE30de injecotrs in a VG30de?
  186. Front 3 cylinders not working...
  187. Any recommendations for a place to work on a car for those without garages?
  188. Running like crap!!!
  189. Getting Amazing Gas Mileage
  190. my max is working on 5 cyl
  191. Headlight problems
  192. Exhaust, etc....
  193. Speedometer issues!
  194. pics of tvs
  195. steering seams to pull
  196. bad alt?¿
  197. 'Clunk' noise over speed bump.
  198. Tranny still leaking!
  199. 3rd gen paint codes by color and year
  200. My new $1 DD
  201. Do i have a bad mafs?
  202. squeaking
  203. Gotta love the military (and their auto shops)
  204. Problem with Tie Rod End replacement
  205. Engine not happy
  206. Is it okay to buy fuel injectors that have slight damage to the pintle caps?
  207. ve out vq in?
  208. Bleeding Brakes?
  209. Startings Max after sitting
  210. taking 8 hour drive soon......suggestions on what to have in case of anything bad
  211. jetta wheels on a max
  212. * People Have No Respect *
  213. keyless entry
  214. foglamps
  215. A/C Temp. Slider
  216. aftermarket center console
  217. Help with STS install
  218. Terminal Velocity of Sunroof Deflector...
  219. right headlight won't turn on
  220. Another wierd VTC problem
  221. whats a good price to get a 93 blue 5 speed se for
  222. Are there any trip computers out there for our cars?
  223. 5speed grinding in second
  224. Exhaust Manifold
  225. Welders inside please...I had enough engine shake...
  226. Best prices for lowering springs?
  227. Help replacing vent window
  228. My weekend project
  229. New VE A/T - Some questions
  230. no F'in way this is for real
  231. Maximas and EBay?
  232. ayone have info on how to repair bose amps?
  233. cloudy E36 headlights
  234. What sets off the factory alarm?
  235. Rear seat cushion clips
  236. Parallel link bushings...
  237. How difficult is it to replace?
  238. Replacing Knock sensor POLL
  239. Ground for amp
  240. its back running and wow! 16psi
  241. water pump pully (tbelt job)
  242. Troubleshooting sudden gas mileage drop off
  243. CAI K&N Part Number and Place to buy
  244. So my speedometer...
  245. Found the problem
  246. back from Iraq and ready to get pumpin on my max (pics)
  247. Update...
  248. having trouble replacing axles
  249. Stall
  250. To anyone that has purchased an STS lately
