- Clicking noise when turning
- can I put a starter from a 5spd VG into an Auto VG?
- Random loss of power? help?
- 254xxx miles and now the car is at its last breath
- Checking A Tokico Insert
- Maxima moved by someone
- Idle Surge - Hesitation
- power lock problem
- Is my automatic transaxle dying?
- auto trunk latch wont pop
- What happend after braking?
- Should I quit now or dig myself deeper?
- 350Z muffler on my VE
- yet another turbo ve
- injectors installation questions
- chrome wheels
- 240 steering wheel
- Pace Setter Exhaust for VE/VG?
- car sputtering
- looking for a good 5-spd for my 89
- Where's Wiking????
- My battery is dead
- rear deck-fiberglass enclosure
- more low end power
- Help! What Should I Do?........
- Fuel Pump Sending Unit
- My buddy's son's VE5 (pic)
- just finished a swap
- Tranny question
- Havent posted in a while... new pics
- Road Tripping to get my 5-Speed!
- control arm bushings???
- Saying hello to another max
- well i had fun today (videos)
- can i replace my windshield by myself??
- delaware valley rust recall help
- Replaced O2 sensor yesterday
- timing chain question. sounds just like the VTC's but louder.
- direct fit mirrors.....
- Some one snatch this VE auto
- Happy b day jeff:-)
- Front Control arm bushings
- 92 se leather trim
- Road Trip!!!
- question about buying a 3rd gen
- fan wiring
- motar mount part 2
- asking a quick favor
- 3rd Gen Rear Sway Bar
- how to tell how many miles you get in a full tank
- 93 VG Auto trans trouble @125,000 miles
- Looking for Spark Plug Info
- how to make the e36s fit flush????
- motor mount wont fit
- (56K beware pics) i'm not a lier
- Digital cluster problem...
- thermostat
- Happy New Year
- my rack and pinion
- Running Rough
- Rear sway bar
- Need maxine to start HELP....
- Big Repair Job on my Max
- 92 max on the road tomorrow!
- Which HIGH FLOW CAT is best for the money?
- Need help with door locks
- inflating tires having to do anything with steering problem?
- Any hope....
- Crankshaft Pulley bolt torque?
- Vq supercharged 3rd gen?
- ignition cylinder is dieing....
- 4th Gen Seats?
- metal portion of powersteering leaking can I replace with rubber??
- KYB GR2....Opinons?
- my swap parts are here
- 4 gen shifter in 3rd gen?????
- Help, mystery fluid leak.
- Failed Emissoins, just passed!
- New Car!!(Pics)
- car sputtering bad... sometimes stalls out.
- Clicking from shifter- now brake lights don't turn on?
- Rev Matching
- Installing under dash lights?
- Turbo question
- Heating Problems/aceleration
- Difficulty: 93 ve manual INTO 91 vg auto
- Car does not start in rainy weather..
- Replacement muffler suggestion- 94 gxe
- need diameter of koni inserts
- clunking from drivers front tire area...
- 93 Max totalled gently last night
- Question about door lock problem
- 5spd is whining
- installing 4 new brembo rotors need help
- How to fix broken lugnut stud
- Surging idle problem, need some advice/confirmation
- crankshaft pulley removal
- HELP alarm trouble!!!!
- locks
- starting problems
- why does exhaust manifold rattle only during acceleration?
- exhaust tips
- Another check this out...
- won't start - afraid timing is off?
- Remote starter on GXE?
- 5peed gone?
- new car possibly???
- acc video of my turbo vg tell me what you think
- Happy Chanukah! to all
- a little shot of my boost gauge
- So what did Santa leave at your house?
- Figure this one out.
- Keyless entry install ! Help!
- What if you get a code 55 and your car still doesn't start?
- K&N Cone Filters
- quick question
- inflating tires
- Check this out!
- Merry christmas 3rd gen group :-)
- push starting a stick shift
- i might be a 3rd genner soon (hopefully)
- best way to clean out k&n cone filter?
- Splash guard
- Transmission oil...Qty
- what are these (HELP!) (pics)
- Any suggestions for seat covers?
- Hitting a really big puddle could short out the alternator....right?
- Radiator fans?????
- Crank Sensor, Cam Sensor
- Lights Flicker, slight vibration
- Conventional Motor Oil to Full Synthetic
- coolant reservoir
- Stock Fog Light Question
- manifold cleaning
- flywheel question.
- cool e 36 brackets
- pcv valve location (VG30E)
- Do you put car parts in the dishwasher?
- locked out of my max.....kinda
- Dash Lights out?
- Power Steering Removal
- 12/21/2005: Never Forget!
- Alarm led hook up to where?
- 5 studs broke off my wheel...
- VTC repair kits
- Car engine sluggish and RPM dropped.
- brake fluid (for clutch)
- Wiring up my trunk...pics
- weird problem help!!!
- Electrical Problem.& Power sterring
- K&N Air Filter
- 5spd swap
- stupid question..
- Strut assembly
- VG tranny to VE swap
- !!!! need help, possible max for sale
- Toyota V8 Oil Filter
- I want a new one now.
- Motor Mounts
- saying goodbye to maxima fam
- Location of Door Locking Relay
- 3rd times a charm - working speedometer!
- y pipe question
- Homemade midpipe pics are up:-)
- What the "Electron bat"? And door relay?
- I need some fast answers concerning wheel fitment...
- somebody hit me wtf
- Bored so I took some pix of the dirty maxima
- Flat black max
- ANything extra to know before changing trans oil for 1st time?
- Thermostat change
- Light output from E36's
- Car sits crooked
- VIDEO of my max accelerating after a Y-pipe install...
- 9007 headlight bulbs on 3rd gen?
- why is my shifter loose.
- 3rd. Gen Coil Packs (New) GD
- There is another Way of Modifying the ECU Come IN
- Intake swap question....
- Stick that turns on lights,brights and blinkers...
- Matt or other manual tranny experts
- Who sells VG UDP?
- Oxygen Sensor
- Alternator...
- Need some help guys
- Gasoline odour in the cab...
- drive belt pulleys
- Finally pulled my blown VE apart today...
- VQ35 Swap Ideas
- 93->90 better parts?
- crappy start.... tps??
- Metal Steering Column
- How to remove 3rd gen rear seats?
- no. 6 goes after warm up
- Blue Clock Mod
- Steering Problem
- How much would it cost the get a brand new 3rd gen?
- Oil leak found, now she's ticking....
- Passenger side transaxle oil seal
- Starting Problem
- air conditioning drain
- Seatbelt Info
- The Power Steering Pump Project
- Digital Climate control
- SOHC Cold-Air Intake?
- Car idle rough
- Need wiper links for 92 MAX SE
- stuff to get
- the holiday spirit
- 89 Max not running!!! Help!!!
- Power Steering Pump
- Q45 caliper+caliper bracket+rotor test fitted
- Anyone 'wrap' their Y-pipe?
- Broken Crossmember.....has this ever happened to you?
- Need some quick advise
- Passenger side CV AXLE
- 92 SE or Fix mine
- Hood Struts mod
- what is it?
- wanna see something funny ?
- another wonderful problem
- slightly confused with max today
- Anyone
- Reverse glow gauges??
- THIRD GEN car model...
- Help! Daily Driver Messed Up
- ShopKey by Snap-on
- wow... long time no see!
- Ticking sounds
- How much is left??????
- Anyone have a MT laying around???
- Found a replacement auto tranny but...
- color code confusion
- After market muffler??????
- Yarh!!! THATS MINE!
- I almost died..well not really but could've (pix inside)
- how to tell if i got a bad wheel bearing
- Inner wheel wells
- Is 4 month old stainless steel muffler supposed to be rusted like that? 56k warning
- when does maf max out?
- Oil filte doesn't fit... has this ever happened to you?
- how to put the rear trans mount bolt (PIC)
- Heater Problem
- Starting Problems
- Stock (OEM) Springs
- Anyone Help me out here?
- tail light conversion
- some help ( quick quetion)
- Simple no-start
- questions abt a jdm transmission
