- anyone need some 18" rims?
- Speaker Box
- Strange noise from rear of car
- Dead power steering.. need help
- Legit ?
- rear center thing
- Chicago Auto Show anyone?
- Stillen side spoiler
- info on what happen to the ve with nissan
- some info I found on nissan engines
- Transmission rebuild going slow-should I quit?
- WTB: Foglights
- I'm going to kill myself....FILESIZE WARNING.
- White Spark Plugs
- Rear speaker deck
- Will a 7 inch lcd fit in a 3rd gen. maxima
- bulbs in dash switches
- What do you buy after a 91 VE?
- cant get my cars pic on..
- Transmission won't separate from engine
- Non stop horn.BEEEEEEEEEEEEEEEP!!!!!!!!
- Power windows
- ABout my fuel injecter experience
- Well, it looks like there's a Catback on my list now..
- VTC Discussion :)
- rough idling
- About to replace front struts...but I can compress them with my hands?? Help
- Original CD BOSE Installation
- More questions on clutch replacement
- How to install a cai in a 94 se?
- walbro fuel pump
- anyone still sell cf hood 3rd gen?
- bad temperture gauge (i think)
- what bulbs should i go with?
- Fuel light wont shut off
- Skyline Body Kit
- Dimensions, please!
- Spraying a y-pipe to prevent rust
- AC Condensor and Water Tank
- Fuel Injector Removal
- Help Diagnose Overheating.
- Maxi died today...ideas?
- any max owners close to jersey do body work?
- ebay y-pipe
- 92 GXE Ordeal - Any advice appreciated
- Changed Gauge Lights...
- Some Jack'off tagged my car
- Brake Pads
- Leaks, Fuel Injector, and more fun stuff!
- kinda O/T, but theres a pic of a 3rd gen in here, so its ok!
- Ran Compression Test...
- Heated Seats Anyone?
- Bleeding the coolant system didn't work!
- sanding headlights/fogs to look new again?
- stillen kit questions...
- broken exhaust tip
- Euro Grill
- airbag light is on
- door lock system doesnt work help
- timing jittering?
- lights = highly overrated
- YAY, my baby is on the road again
- brake+battery warning light
- Carputer in a 3rd gen
- Spoiler help on 3rd gen
- shifting points
- Signing Off
- cv axles
- power question
- Clutch purchase question....
- Repainted the spoiler (pics)
- What size is this bolt?
- 9004 9007?
- Battery Problems
- New info about VG's I just found
- e36 lights
- Yet Another Gauge Problem...
- Might be leaving the Nissan Family
- timing chain tensioner
- Pacesetter header vs. warpspeed Y pipe
- 5-speed swap pics? (Please Read)
- Just Ordered the Wrong Guages...
- windshield wipers quit....wiper motor or relay?
- Question about reseting ECU
- Sunroof Removal
- Wont make any sound
- auto to manual kit ve only
- VTC rebuild question
- "interesting" trunk mod
- Options for front bumper/cap
- VE Variable Intake question
- Master Cylinder Q
- VG Down for the count??
- I'm gong to go broke!!!!
- Pleasantly surprised
- Installing UDP and Water Pump
- VTC repair writeup
- Things to replace when changing clutch?
- Pics of Maroon SE
- $10.99 Eibach ProKits Suspension Springs
- Drum - Roters
- Well, its been real!
- what's the most expensive HU you ever put in a 3rd gen?
- Has anyone removed the ABS from theirs?
- is the vg and the ve tps the same????
- much smoother when in Drive?
- Window installation help
- How Hard are fuel Injectors?
- Engine Condition
- injector sets should consist of.....
- Tax Return= NEW STUFF!!!!
- anyone can do a VIN check for me?
- Is there ABS on 94 Maxima GXE
- 92 Maxima Bose
- having problems with double clutching
- ventilation tubes on E36 lights
- Fuel Pump/Relay question
- How much should I offer
- rear injector sub harness
- How do I get the automatic antenna to work with new head unit?
- Rip in leather seat
- it's been a long time
- Oh gosh, the engine's got a hole in it!
- Which Clutch?
- Slow and sluggish when cold
- Can I fit this into a 3rd gen?.....steering wheel.....
- faulty injector or excessive corrosion?
- i think i need a wheel bearing
- exhaust rusted out
- Need pics of underside and exhaust
- Rpm dipping
- VE Revs alot on acceleration
- Timing Belt Time
- Electrical Problem, looking for ideas
- R33 Tails!!
- Brake Booster Vacuum Hose
- VE doesn't run properly, need help :(
- valve tapping???
- Wiper linkage...broken, need it fast
- door speakers possible size
- door speakers
- VQ30DE in a 3rd gen?
- Slight Crankshaft Wobble
- shift knob thread size
- 3rd Gen 5sp Transmission woes
- How to post a pic of my car?
- What are some effecient and cheap performance mods?
- ABS light
- Clutch Question
- Bringing her back lil by lil
- Swaping Engines.
- jacking up the car
- Picture request: rear suspension
- wet rugs
- Transmission oil drain plug
- Blower motor resistor
- How do I bleed the coolant system on a VE?
- How do I get the lenses off my tail lights?
- yet another belt(maybe timing belt) thread
- Any Meets near TN?
- Heat only comes out of defrost vents
- ac & heater blower fan
- My 3rd gen
- Changing a Master Brake Cyl....
- Which one?....
- G/F just got herself a 3rd Gen!!
- AEed?
- AC not working. Blows warm air.
- Replacing Starter
- Possibly stupid tire Q..
- custom or ??
- Strange Wurring Noise 92 SE Auto
- Rear 91 maxima control arm ***.
- 92 SE or 92 SE lol
- 1 ugly max on Ebay
- nailed a curb (pics)
- lower temp. sensor. do they have it?
- Might be changing brakes yet again
- I've about had enough!!
- Engine reinforcement
- Pics of my Max
- some broken VTC pictures from my new Maxima
- Fluttering sound between 1500-2000 RPM
- foglight bulb burnt out...
- Driver side window will go up from inside and down from outside...
- What are we gonna do when Matt and Jeff get fed up with 3d gens?
- how much is he worth?
- broken axle or broken transmission?
- Welp, she's finally gone. *sniff*
- Y-Pipe question
- BBK finally installed.
- "The Gorealla Grill" Fo' Real...
- Villager: Rattle from the top end
- Coolant temp sensor Question!
- 5sp Man. Tranny locks up when cold...
- 90 max wont start
- My Window won't go up!
- Water Pump
- need help installing new brake lines
- Power Steering Noise?
- Why replace the PCV valve?
- Why I hate the winter...
- Wide Band 02 kit
- My alarm?
- PCV ventilation hose?
- Need A Good Machine Shop In Nj...
- place to buy KYB-GR2 or Tokico struts
- hard to shift in first and third....
- Do you have a 1/4 mile timeslip or time for your 3rd Gen?
- strut spring
- more abs problems
- Ban Snipa
- How much is y~pipe
- Junkyard find
- part # for belts
- Tranny slipping...
- VIN check link
- Georgia
- Fuel Pressure... Idle/Cruizing/Full Throttle
- how to clean the egr valve????
- Clock removal. 91 Maxima
- Another 92 SE 5 Speed. Ideas on Mods??
- Grinding noise at 1300-2000rpm range
- Funny thing is...
- ok..uhm OUCH - friggin hood struts!!!!!
- making the gears smoother with synchromesh fluid
- no idea what this part is
- detonation, help!!!
- stock radio/speaker wire question
- Car will idle fine but when it goes into drive it dies.
- Auto Trans solenoids
- Before swapping...
- Getting some strange wheel wobble
- Over-heating
- do i have a bad injector?
- $2006 rwd 3rd gen
- High idle speed
- took some nightshots (56k not too big 814k))
- Door locks not working
- New Shoes/Car Wash Pics!!
- how do I put a picture in my profile?
- Heater Problems
- camber is a monster!
- How to remove the brake light switch...?
- WHAT IS THIS??and why is there oil in it??
- Clicking noise when turning
- can I put a starter from a 5spd VG into an Auto VG?
- Random loss of power? help?
- 254xxx miles and now the car is at its last breath
- Checking A Tokico Insert
