View Full Version : 3rd Generation Maxima (1989-1994)
  1. ST sway bars, opinions?
  2. anyone in CT with a tig welder?
  3. quick question
  4. I think I need a new engine..
  5. Does this make sense?
  6. max wont crank
  7. Engine swap to be started...
  8. My new "toys"
  9. will the vg max injectiors fit the vg pathfinder
  10. Will my 4th gen FSTB fit on my 3rd gen?
  11. think this wing will fit smoothly?
  12. non-abs brake pedal pulse(s) @ low speed
  13. Code 12. Can't go over 2500RPM
  14. Power steering pump hose identification
  15. replaced fuel injecter. but now...
  16. Max shocks the crap out of me
  17. Bright and dim dash.
  18. Motor Mounts available for polyurathane rehab
  19. what can be salvage from a 300zx for the max?
  20. one dollar max!!
  21. question about 5 speed trans
  22. What stereos you guys use?
  23. Insurance is going to total it...
  24. VE Motor Mounts - Where to buy?
  25. Good price on front brake rotors
  26. Need Help. Need to get an alternator ASAP
  27. Engine wont crank -- Is my starter dead???
  28. Putting the Injecter into the rail.
  29. Lowerd maxima + running over brick at 45mph = UH OH!
  30. replaced stock intake....hard starting problem
  31. Can someone help!!!
  32. question about TPS
  33. Missing ve issue solved :-)
  34. Brake problems, help needed.
  35. Accel 300+ ignition wires, good or junk?
  36. Pacesetter STS update on Heat problems
  37. FSTB question
  38. wrapping the vg out to 7000rpms
  39. Anyone Elses Streering Really Loose Feel?
  40. Upgrading Ground Wires
  41. Before and after.
  42. Speed sensor
  43. 93' GXE Auto Climate Control light (On/Off) problem
  44. 92 GXE - Drivability Issue
  45. Flex pipe leakage
  46. custom built fuel rail
  47. want to find someone to paint my maxima
  48. Want to setup E36's for me
  49. Back on the Road
  50. Trunk-cabin access question, help
  51. Door Lock Poltergiest
  52. what to do with tax return money?
  53. lowering my max
  54. Clutch stuck to floor!!!!!
  55. Running only on 5 cylinders!!??
  56. Should I go with a bigger Rim?
  57. HELP...none of my injectors is working...VG
  58. Will grounding the VTCs hurt performance?
  59. Climate control?
  60. Polished Engine Parts
  61. need help with transmission
  62. spotted a nice 92 VE5
  63. VE underpowered until 3K, and ideas?
  64. Maxima.org Decals?
  65. lsd of the ve tranny
  66. Alarm help please?
  67. Whats Going on !!!
  68. VTC clack?
  69. My two weeks saga continues...venting out...
  70. More interesting VG info
  71. Windshiled Wipers??
  72. Speedometer Acting up
  73. Suspension Time
  74. car trouble, belt squeaking
  75. Replaced the tranny yesterday...
  76. Replace outer cv boot
  77. is it worth it
  78. For Those With STS
  79. I broke this thing...What is it?
  80. What size speakers in font?
  81. How to Support Engine While Removing Oil Pan?
  82. RIP Transmission
  83. Timing Belt Update
  84. VG Timing belt question? Anyone have COLOR Pictures? Or any helpful pictures?
  85. pippity *POP* *BANG* *POP POP*
  86. Cold temp outside = engine turning over for a minute. Fixable?
  87. 3rd Gen VG H/O Alternator?
  88. vg wont go over 20mph
  89. Removing porcelain from broken spark plug
  90. Hood hits wiper arms
  91. Found one of the leaks!
  92. AC and RPMs
  93. 4th Gen RSTB???
  94. Sony Xplode Vs Kenwood KFC's?
  95. Please take a look at this 90 for cheap and offer your opinions or carfax
  96. Best SS Brake Lines for 3rd gen?
  97. Cold RPM Hesitation
  98. Running on 5......
  99. Electrical question, trunk room light...help
  100. fixin to order eibach springs, need another new set of struts?
  101. Tranny problem
  102. MAF Adapter
  103. question about making bmw headlights flush
  104. Gettin ready for paint
  105. NEW LIP FOR THE MAX!!! OMG LOOK?!?! *PIC* someone explain
  106. 3rd Generation DIY
  107. Ghetto Search
  108. What gas do you use?
  109. what vg30 is this?
  110. Traction bars for 4th. What about us?
  111. Tbelt question
  112. Y? Pipe
  113. Valve cover vs. Form a Gasket
  114. Fuel problem
  115. Stock Springs.... i need your 2 arm and one leg!
  116. Best way to clean injector contacts?
  117. Inner tie-rod end replacement
  118. trunk centerpeice
  119. And that's all she wrote.
  120. o2 sensor troubles
  121. how long does a vg30e last
  122. Is the Tokico Intrax setup really that bad?
  123. engine shields
  124. Valvebody upgrade and torque converter
  125. how hard is it to replace rear window
  126. Anyone know....???
  127. Tried starting car and fuse popped
  128. Side view mirror defrosters?
  129. Starting issues
  130. blown struts
  131. Avg Joe - factory front suspension fading - Best Course of Action?
  132. Any thoughts? Check Engine On, but no ECU blinks
  133. Jerking steering wheel.
  134. to those complaining about lack of VE5s
  135. lsd, vlsd, who has it who dont. Do i?
  136. problem with clutch or clutch pedal
  137. H.I.D.s
  138. Exhaust problem
  139. e36 headlights
  140. no more max, nx time?
  141. Getting my new max tomorrow (Sunday
  142. 95-99 maxima conversion or R32 front conversion. Anyone tried it?
  143. Bad wheel bearing?
  144. Well I finaly got my max today.. and I think I need a new tranny :(
  145. VG problem
  146. Do They Make A Ve All Aluminum Radiator?
  147. Fuel pump
  148. how to shave the door handle lines.....
  149. Intake's the name of the game
  150. Intake manifold swap on VG? Pathfinder Manifold???
  151. bumper assembly
  152. Upper hose split at the engine
  153. Strange VE Problem
  154. Odometer Question
  155. distributer cap
  156. Replacement glass for OEM foglights? who has them
  157. Black housing Headlights? DIY? Pics inside of a members car...
  158. Camber kit question on installation.. quick question
  159. Rack Boot Replacement
  160. cv axle questions.
  161. Remote Starter/Keyless Entry
  162. The plan: Turbo VG
  163. ebay gas saver thing, real?
  164. 4th gen SUNVISORS in a 3rd gen...help
  165. Quick question
  166. Advice on shocks/struts.
  167. Warpspeed muffler rusted out...
  168. Wade covers or GTS brand?
  169. car's runing "rough" and rich..all injectors work...damn
  170. prep work?
  171. Shift knob threads
  172. why you never follow drunk people
  173. 91 se rear maxima section
  174. smoked corners
  175. New to me VE
  176. Auto ECU vs. 5-spd ECU?
  177. need help changing gxe to all black interior
  178. water pump
  179. Rear defross amp draw
  180. Felony
  181. Turbo questions
  182. Power of Asbestos
  183. powerstearing problem
  184. another auto tranny bit the dust....
  185. exhaust and oil pan.
  186. Those with FSMs
  187. Sprint XS Shocks
  188. Anyone know about laws for smoked corner lenses?
  189. Speedometer question
  190. fiberglassed door panels to fit 8in. woofers...
  191. VG 5sp Tranny rebuild Q:
  192. Any advice on changing transmission oil?
  193. pros and cons of grounding VTC's
  194. Tach Going Crazy
  195. Cigarette lighter port wire
  196. Honestly, is it pointless to put any money into a GXE?
  197. tires rubbing so what do i get for my 18's
  198. FSTB avaliable for a VE?
  199. Another Body Kit Question
  200. Lucky 7.......
  201. Well the Max can stop now.
  202. for all the north east max owners
  203. Attn anyone who knows or has BODYKITS
  204. How do you check for blown head gasket?
  205. Gas mileage poll
  206. Injector problem
  207. Those going to performance nissan meet
  208. Window Problem
  209. Anyone here from MO
  210. tune up...
  211. struts
  212. Does anyone have
  213. Won't shift or is stuck in gear
  214. Fan wont turn on, code 13, CTS already replaced...
  215. BOSE audio system problems
  216. car makes a ticking noise. is it the vtc's?
  217. Steering wheel will not lock in place
  218. Selling max, buying max
  219. well i got into another accident (pics)
  220. why cant I search?
  221. idle speed high?
  222. How to adjust idle speed with ECU ?
  223. ecu compatibility?
  224. New CF Door Sills
  225. Speed Sensor EXACT location....pls heeeeeeelp
  226. What is this? pic
  227. Does it ever end ???
  228. Power Valve Control Solenoid Vacuum
  229. iPod Dash Mount
  230. Belts squeaking
  231. 3 days off work...hah
  232. Exterior Door Handle Removal
  233. Any special tools needed?
  234. rear brake conversion
  235. new problem to battery+brake light
  236. ipod and maxima
  237. Kyb Gr2
  238. More and more problems...
  239. Another one gone
  240. Rate your struts...
  241. took some evening/night pictures
  242. Fogs on the GXE?
  243. Center Lug Cover
  244. Ohhh I can't wait till Friday.
  245. Airbag lights
  246. CAI. Open or closed filter?
  247. Headlight harness's hate me.
  248. Hard to Mount Headlights?
  249. Tranny (pics!)
  250. 93 door hinge how-to
