- Not sure maybe MAF?
- RPM's drop at speed/Bad idle
- check this out. a pretty nice deal!
- Check it Out! (56k beware)
- New VE engine coming.....w00t
- cost of a break job?
- O/D on auto tranny - when (and if) to turn it off?
- Gunna Rice it out.
- Bose Woes
- Alternator??Charging Problem
- Tranny Leaking...Grrrrr
- Anybody in the Seattle WA area race a black max
- code 33
- another oil leak......any help?
- what the heck is this?
- Ordering new bulbs anynone prefer diff brands?
- sun roof leaking?
- bye bye to maxima, hello to 240sx
- control arm bushings
- Hmm Nissan/Infiniti wheel version # 3245687736
- Honest Shop for Colorado
- Grounded vtcs but they still tick.
- 89 max
- Maxima and itss overall integrity
- window problem
- Rewire of overhead map lights
- Thumper Antilock Brakes
- How hard is it to remove the air intake?
- It's ALIVE!!!
- ok another gas consumption question
- Cleaning the IAC on a 94 Auto
- Problem with Swap!
- is it the starter?
- 35,000 miles on a bent rod..
- Fuel Injectors for a 1994 Auto
- Transmission Swap Question
- A/C & Ash Tray swap?
- oil question
- Rough Idle/Hesitates off line
- Bad Mass Airflow Meter
- Disaster!
- I keep wasting my 90 SE motor mounts?
- would flushing the coolant keep heat warmer while idling?
- Custom 4dsc Sticker interest Thread
- warpspeed complete 2 1/2 exhaust - worth it??
- Aww, isnt it cute?
- can someone carfax this for me?
- Pictures on your posts
- Vibrating Gas Pedal.
- ecu upgrade question
- Manual transmission questions.
- transmission fluid
- lost my valve cover thread.......here's a question
- might be committing the unforgivable sin....
- finally changing my sprakplugs
- Can Seafoam damage the engine?
- General Lee meets 3rd gen Maxima
- changing tranny fluid in my 5 speed
- Grounding VTCs quick question!?
- jsut a shot of the old 3rd gen
- air conditioning a/c compressor noise
- Burning smell from engine compartment
- door handle!
- slight vibration at 55 mph after putting on wheels
- Struck gold walking to lunch...
- Experts-Difference between VE and VG alternator?
- A CONFEDERATE Maxima?
- toyota oil filter 90915-yzzf2
- Brake Upgrade Options
- All Motor VE Auto goes 13.79 @ 100.3mph!!!
- please take me seriously on this question..
- VTCs ???
- just cause I'm bored
- Pioneer DEH-7700mp Install
- got bored sooo made a vid of my car
- rear deck fabrication idea..
- G/fs car is up and running :)
- new recall- PRO-A MOTORS light
- updated pics of project j30 more comming soon
- Rough running 89
- looking for a FSTB for my dohc
- lifter vs. VTC
- Throttle Sensor, Switch Adjustment
- bose hu
- Rear Strut Help
- best lowering springs???
- AE Pedals
- Need Stereo advice
- Idea
- Wheel Lock problem/question...help
- Surging/ Fluxuating idle !!!
- Problem Removing E-Brake (Drum)
- Steering Wheel
- Wheel Alignment - DIY?
- Someone Stole My Car!!!
- well, ****...yet another swap coming up next week...
- maxima recall
- speaker ques
- New Max, needs help...
- Tranny - what to do?
- well a 3rd gen is in the works for me!!!!
- ahhh bad day:-( now distributer is clicking
- Which side of the h7 bulb is the positive.
- replacing antenna mast....
- CV Boot Removal
- Starting problem...
- 5 speed swap question
- Thermostat
- grill problems
- 5-Speed Swap Update
- Tranny Mounts
- Water bubbling sound sometimes when I accelerate.
- are these JDM tyte, y0?
- Need help on wiring the power seat
- shaving the center trunk thingy
- Quick question about 4th gen SE rims on a 3rd gen
- parting out the car????
- Interesting findings re. green-dot injectors...
- anyone uses the NGK G-Power?
- IACV/AAC Valve Cleaning
- Anyone here still running on an original auto tranny on their 1989?
- Transmission Question
- temp gauge + maybe odo problem.
- need some z31 mod info
- What does this plug into...VG engine
- my new Maxima
- HAI Setup
- bolt on so tight...suggestion for substance to loosen it up
- cutting off tailpipes
- cleaning MAF Sensor...for vg30e
- Speedometer question
- A new thud? How exciting!
- Can I tap into a wire and make the car stall when attempted to be started?
- H.I.D.s
- Weird Door lock and window thing
- replacing wheel studs.....quick question
- OK need some technical info
- Anyone in CT help with e36 lights?
- Removing Resonator=More Grunt?
- Part Numbers
- blackmax
- Broken Glass
- Ahh what is it?
- How Many Miles You all racked up?
- Timing on SE
- VE Stumbling issues....have tested about everything!
- what is this plug???
- Wheel Bearings driving me crazy
- another tranny bites the dust....
- Maxima Gauges
- Who Said A 3rd Gen Is Not An Exotic?
- JDM Motor swap and reliability.....Wise investment???
- Digital door keypad - how to reset?
- VE vs VG and...
- Break question
- is the ve and the vg 5 spd. trasm. the same?
- Mounting the Clutch Pedal
- uh oh, broken sway bar bushings and mounts. where to buy?
- Got my Zt-2 wideband and timming belt pops!
- darkened reverse light on VE tail lights
- VG30E Overheating Problem... Waterpump Issue?
- shaving the 3rd gen trunk. Is there a guide? Any tips, what all do i need.
- Weird tranny problem
- please!please!please! alarm help!
- alternator or the battery...?
- VTC write up
- changed my oil today and......
- surfing threw web found this photo. you decided
- Craziest 3rd Gen EVER {VIDEO}
- UK Corners
- y pipe is on now! What bout my exaust. mandrel bend vs pressure bend catback
- Need source for parts.... Caliper bracket
- Windshield wipers and armrest!
- should we ban backNblackj30, or put up with his trash.
- steering tranny question
- Maxima Tail Lights
- Clock resets
- since weekend battles isnt working...
- will infiniti q45 seats fit???
- Help with fixing a few things(wheel bearing,motor mounts,thermostat)
- ok dont laugh!!!
- Max on Wrecked Exotics
- valve covers.....suggestions on fixing them
- Last Post for me.
- Engine Control fuse blows..one of the few problems
- Gauge pod for maxima? The side pillar kind. What fits?
- castrol gtx or high mileage
- Tranny Removal
- Wiring Question!
- Sold the Maxima
- VTC and Tranny Shot - what to do
- My new REAL Jdm Fog lights, with pics, PLease give me your 2 cents!
- kind of struck in reverse ???
- Stuck in 1st when cold!!
- sick of clutches
- mass airflow sensor
- how do i fix a leak coming from my winshield washer fluid?
- body damage
- Recent Pictures (56K killer)
- QUestion on Shifter in general.
- clutch question. Wich one to go with choices inside
- How long to fix exhaust?
- anyone run 5mm spacers?
- My day
- lightning the stock flywheel? possible
- Okay to use e36 headlight with broken tabs?
- Might be leaving Max community (pic)
- VQ possible to replace the VG?
- This Beautiful Weather
- Redlinemax = Scammers!?!?!?
- Car is doing some things.
- Badman Returns
- has anyone put hid lights on stock lamps?
- Im ordering y pipe from Redlinemax. How quick is there shipping? Good people?
- Fender Drainage problem
- Y-Pipe Repair?
- question about performance y-pipes
- Looking for stereo din gauge panel.
- Cartoonish Maxima..
- Tranny goes buh-bye...
- Test drove a 99 se-L 5 speed....
- did an 8 hour axle job today.
- Bad Old and New Door Hinge (56K Killer)
- Filling Mounts with Urethrane
- *KABLAM* bye VE :(
- using 91 octane in my car
- whats the first sign a bose system diein???
- What battery terminals do you guys use?
- Tach Problem Now
- Help...Major Oil Leak!
- dang punks!!!
- my ve 5 spd. trans. got jam again!
- just thought id share this (go ahead and laugh at this)
- Don't make me do this again
- VG Plenum 1/2 inch gasket?
- So how do i make my antenna stay down for good.
- Anyone have any ideas?
- Front Sway Bar Links Question
- weird CEL problem
- How Much did you pay to change the VG Timing Belt?
- rim question
- Spent on Starter Issue... Any Suggestions?
- Are you biased towards 3rd Gens?
- product review: strong arm hood lift supports
- no power after warm up...I'm out of ideas...VG
- No start;Have fuel, maybe timing?
- jwt tuned ecu +turbo and Downpipe
- Seafoam question
- Trans help
- I think some of you third gen guys should see this..
