View Full Version : 3rd Generation Maxima (1989-1994)
  1. So my muffler rotted off and i put on a...
  2. Your Steering Wheel
  3. udp for ve
  4. Place Racing CAI
  5. How does it sound when you plug the resonator?
  6. removing a crankshaft pulley...
  7. My 92se's speedo is dead
  8. ve intake help
  9. NEED HELP ASAP: got air in the brake lines when changing master cylinder
  10. 94 se running like crap
  11. Gas Leak Question
  12. 4thGen multli-link beam in a 3rdGen: Nissan produced video
  13. My tires are killing me...
  14. Distributor
  15. Interior Body panels
  16. The time has come.....
  17. struts n stuff
  18. rough idle in gear
  19. rough idle in gear
  20. Should the AC Lines be Frosty?
  21. Need new injection system
  22. blinking red battery light
  23. Control Arm changed overnight
  24. the correct PCV valve......
  25. what if I dont have paypal how do I donate
  26. brake pads
  27. ground strap for exhaust??
  28. accord intake for 3rd gen?
  29. FSM for 92 SE
  30. Broken sunroof :(
  31. vin check?thanks either way
  32. y-pipe flex sect.can plug cat. convt.
  33. New Hinges YAY
  34. trunk mechanism stuck
  35. Correct Torque Value On Rear Caliper Pin Bolt?
  36. replace outer tie rod ends?
  37. average ve numbers
  38. limited slip check same for a/t?
  39. VG30E intake question...
  40. Stripped manifold stud
  41. Low oil pressure
  42. Max not starting
  43. Gauge cluster
  44. Product Q's
  45. Engine Rebuild?
  46. auto tranny
  47. wtf
  48. Maxima Of the Month...
  49. this is a bit confusing
  50. this is a bit confusing
  51. What is a resonator?
  52. Tire sizes
  53. Rear Swaybar?
  54. Junking my '93 max as a parts car
  55. Transmission, Rebuild or not
  56. stupid question
  57. Questions About Summmer Mods.....
  58. Dashboard light problem sorry about asking again
  59. Power Vavle Not Working???
  60. Best way to change pintle caps on injectors.
  61. should I paint my calipers???
  62. This is for (InternetAutoMart)
  63. Broke 94 Maxima Key, Need master Key Code
  64. Squeeky New Brakes
  65. Steering Rack Boots?
  66. Car won't start...clicking sound
  67. 200sx fogs on 3rd gen? question...
  68. Engine Control Fuse keeps blowing...
  69. VE cluster on a VG
  70. timing belt ripped
  71. want to change headlights to bmw's
  72. knock sensor erorr code
  73. Brake question...
  74. Somewhat OT - Max to the rescue!
  75. Braking and Cluster light
  76. Exhaust question
  77. Mobil regular engine oil
  78. And the fun shall begin
  79. manual trans not shifting into any gears
  80. daytime running lights 4 Canada
  81. What In The Name Of Motherf****
  82. E36 325I parts
  83. VIN check please?
  84. electric powered max
  85. Maxima vids
  86. Low end torque gone?
  87. Intake question...
  88. 4th gen FOGS on 3rd gen...
  89. Who all has sunroof wind deflectors?
  90. need to wash engine to find oil leek
  91. Door panel question
  92. Argh! Just Missed the Deal of the Century!
  93. PCV vavle
  94. PCV vavle,.....
  95. Nismo Exhaust Hangers
  96. Strange Leak
  97. 4DSC and Canada
  98. engine missing
  99. Stupid Disc Brakes!
  100. Maxima Strut replacement
  101. Maxima A/C
  102. Door Attach Thingies
  103. Idle Hesitation Update
  104. maxima 94 won't start the first time
  105. stall, start, CEL... code 55
  106. Different MAF sensors?
  107. What a weekend...
  108. Best clutch fluid?
  109. Possible end of maxima
  110. Wow, my Max ran in ditch!
  111. Changing a Front Door
  112. Belts
  113. rear brake conversion
  114. New Toyota Oil Filter YZZF1
  115. hey anyone have motorized seatbelts?
  116. need help replacing brake lines under car...
  117. New to the .org & got a question
  118. Weekend projects and stuff
  119. some more info On the vg30
  120. ABS Control Unit
  121. can ya'll help me out.
  122. for the VE fanboys...ok anyone:)
  123. Problem with hesitation/vibration
  124. Starting Issue and smoke from engine bay.
  125. car runs like crap after it warms up - need advice
  126. Hose from Transmission
  127. 5spd ve tranny problem
  128. Non VLSD VE Auto trans???
  129. VG30E Pop Charger
  130. What is this part?
  131. Heater core/vent assembly R&R
  132. timing belt broke
  133. Headlight Not Working Properly
  134. Rear suspension connecting rod issues
  135. hmmm...idea....ricey of course....
  136. Quick Rear Suspension Q
  137. good basic struts?
  138. the mag mod
  139. Where can i find?
  140. factory springs.
  141. Need Help with Fuel Injectors
  142. Hard Jerk from Tranny
  143. Replacing Power Window Module
  144. g35 rims??
  145. Cruise Control Won't work
  146. Anyone use Polarg M4s in their SE guage clusters
  147. help with a VIN check?
  148. replace head gaskets vs entire engine.
  149. Speed sensor or guage cluster
  150. ways to remove crankshaft pulley w/o impact gun
  151. Clutch problem
  152. Gauging interest in 91 max
  153. stock ve time vs stock vq time
  154. Flywheel Issue(I think)
  155. Airbag system recall stuff
  156. VG intake manifold
  157. Flip Flop Trunk Question.....?
  158. Time to say goodbye to the 3rd Gen :sadwavey:
  159. Amazing event today.
  160. Stuck Odometer/Tripometer
  161. Rust repair panel source?
  162. horrible sputtering
  163. Quest engine interference?
  164. Strange shudder when slowing down and speeding up under 55mph
  165. Mystery of O2 Sensors Revealed!!
  166. Difference between VQ, VE, VG
  167. Green Dot Fuel Injector
  168. VE vs VQ (plus a pic to get you to look)
  169. Can someone help me .
  170. Warpspeed Y-pipe Leaking
  171. A/C Comp. not turning on!!!
  172. AMP bypass
  173. Cam Shaft Seals
  174. really bad news for the maxima
  175. Rear Disc Conversion
  176. Cooling System
  177. Radiator fans not working?
  178. How to check if ECU is bad
  179. bbk
  180. MAF or Knock sensor?
  181. adding aftermarket siren
  182. Passenger side Axle/ball joint issue maybe related to ST sway
  183. Just asking?
  184. omg VTC ticking GONE!!!!!!!!!!
  185. Head room?
  186. Dashboard light problem
  187. Drag
  188. .ORG and Maxima New Guy
  189. once you go black, you go back
  190. GXE gauges with SE Gauges write up
  191. K&N Air Intake Install Write-up
  192. digital dash
  193. wierd problem....
  194. Installing new Rotor, and brakes
  195. Gas Odor
  196. A good place to buy struts
  197. ABS Error message
  198. New pis, comments welcome
  199. Question about rust
  200. Vans Skater Freak Parking Lot Madness Video
  201. Exhaust Manifold
  202. Arg!!! Cracked Rear Manifold!
  203. vg30et
  204. Broken Emergency Brake
  205. Window Motors
  206. Changed rear struts, wheel cylinders..
  207. New K&N Air Filter Installed! (photo)
  208. Jack Hammer Vibration/Sound Front Passenger
  209. Need Bolt
  210. How is the ride?
  211. e36 headlight ( sware it's last on this topic for me )
  212. FS: 93 max
  213. Radiator, AC, Heat Question; Overheating
  214. Insurance accident question
  215. BMW Headlight List (L00K)
  216. replacing struts
  217. STB question
  218. sputtering question
  219. brake master cylinder leaking between it and the booster, gasket maybe?
  220. will place racing CAI for VE work with VG?
  221. Steering Wheel coming apart
  222. Adjusting font tires?
  223. Popping noise from front right wheel well
  224. Digital dash not workin when cold...
  225. Happy Easter!
  226. oil on plugs
  227. strange noise w BOSE...help
  228. Rear brake and caliper q's
  229. Idle situation
  230. Replacing Water Pump?
  231. got bored so decided to take some night time pics
  232. switching gauge cluster 125 >> 145
  233. LCA Bushing how to
  234. Digital speed sensor?
  235. Battery Leaking Power
  236. What kind of oil / filter?
  237. ecu self diagnostic
  238. Front Panel Lights...
  239. Fluttering sound between 1500-2000 RPM (manifold studs?)
  240. What kind of tranny fluid
  241. Timing belt question
  242. leaking oil and coolant O.O
  243. Newbie here.......
  244. Ipod
  245. The mysterious box!
  246. Crankshaft pulley
  247. cassette player
  248. Wierd Windows HELP!!!! 90 GXE
  249. Finally!! power locks again
  250. 5 sp Tranny conversion: Component verification
