- rear winshield deflector/spoiler
- Any Tips on How To Separate Intake Manifold VG
- Ignition Upgrade for VG
- 92 SE 5spd
- Rocker Shaft Bolts - Position Important (Photo)
- front bumper mask suggestions
- Suspension problem, or axle problem... advice needed
- Will 1995-1999 Bose/Clarion HU work with 92-94 Bose system?
- STS mods ???
- rack bushing replacement
- Help Car Won't Start
- Removing yoke from striking rod
- Window.... tabs?
- Easy Mirror Mod
- Gaskets...Mounts...Manifold...
- What Gaskets do i need when i replace my rear injectors?
- CarFax Help......
- Torque converter lockup
- getting another VeeGee tomorrow (plus another addition to teh family)
- Bad Injector or Bad Coil Pack?
- Parking Lights Out Again !!!
- Starting up after long time
- Muffler question
- 92 SE: Recent Purchase trouble shoot
- 1991 gxe trans not shifting to 3-4 and no speedometer
- Why is this bolt here??
- Anyone Know if This Camshaft Will Fit
- Is there much of a market for used Engine parts?
- New Strange Problem(s) going on now?....
- Heads up on JWT ecu's
- I don't Know How You Guys Removed that RH VG Drive Axle
- pacesetter headers w y pipe or wsp y pipe?...
- What are some good spark plugs?
- suspension overhaul!!! (pics)
- fog light advice/recommendations needed
- corner lights wiring question
- Just got a Magnaflow... But it sounds like CRAP! Need Help
- Should I Purchase? 92 GXE or maybe SE
- slight hesitation when accelerating?
- 2 SCREWS ON TOP OF EACH FUEL INJECTOR?
- Good project car? 92 SE Auto
- Wheel bearing replacement
- EGR VALVE BOLT SIZE??
- wheelwell clunking
- THERMOSTAT QUESTIONS??
- just wandering
- Just wondering if this was possible
- Stress fractures in transmission bell housing
- MAF?? or other things?
- STILLEN BODY KIT "how to?"...
- Flat Tappet Cam
- power steering fluid vs transmission fluid
- Acceleration power loss
- temp gauge
- 5spd swap from 89 SE to 91 GXE
- Valve Stem Seal
- VG Injector Pintle cap's....need it?
- digital conversion
- where to get a 3rd gen carbon hood?
- Disabling "key release"
- selling the vg30 5speed
- 1990 A/C Evap
- Unlock trunk to start car?
- rack and pinion?
- changing VG30E exhaust manifolds question
- Flushing The cooling system!
- Foggy windows, moisture problem?
- Driving my VE again..
- digital dash swap question
- still having cruise control issues - help
- Won't Turn Over.... Video Attached
- Reading High temp..but why?
- FRONT SWAY BAR QUESTION???
- Does this rear main seal need replacing?
- Anyone Have a Makeshift Way to Remove Crankshaft Pulley?
- cusom made headers
- Question about MAF adapter
- engine mysteriously dying while shifting gears.....
- Thinking about selling, what should I ask
- Failed emissions.....Thoughts?
- Back on the road - 3rd gen VE5
- seperate vtc's with a clamp+sockets!
- Slow start, i already searched
- Shift Lock/Brake Fuse burning out
- need help fast
- For The Don's & Don's To Be
- question about reserve radiator tank
- UNUSUAL SParK KNOCKING FROM ENGINE
- 6inch speakers in the Front doors??
- Changing Fuel Injectors????
- D.I.Y. HAI questions
- driving without alternator adjustment bolt
- mah new cah!
- odd chaffing/clicking noise for a few mins when the car's cold (with video)
- My car was jacked, I need an AM alarm
- Aftermaarket Radio Stopped working?
- where to buy e36 headlights?
- new battery terminal and wires
- oem fog lamp glass
- New [Bigger] Ride
- Failed Emissions Test
- My new tune up + MPG reading
- Longer exhaust tip effective in quieting WSP+magnaflow exhaust
- My transmission acting funny
- Got everything worked out (tuning) now how would I get more power?
- Hose Barb Terminating Fuel Lines
- Transmissions done for probably, what should i pay for a new one?
- Power to my power windows?
- CEL: Code 51 Replace Injectors
- Some more/better pics of my "new" VE
- Vent.....I hate VG Injector's..............
- spoiler options/advice
- cruise control issues, help
- No Fuel Pump Fuse...what the...
- vg30de head studs???
- Injector Changing Tip!
- changed the fuel filter today
- bose 6 disk changer upgrade
- REAR WINDOW PROBLEMS!!!!
- O2 bung
- Finally Getting Around to Re-routing my intake infront of the battery..
- How much R12 does the ac system hold?
- overheating
- 1990 VG30E installed... Finally!
- Tracking Down Misfire issues...
- ABS "chatter" on take-off?
- What color are my injectors? and what is that cap called that screws down on top?
- Pulled upper plenum and found some oil
- Removing stuck spark plugs
- SPARK PLUG WIRES??
- Trunk Bike Rack
- STRUT TOWER BAR QUESTIONS????
- Can one go into detail on how to install a subwoofer?
- new set of wheels on the beater!
- might buy a 3rd gen..need some advice
- Blower Fan Motor Replacement?...
- second gen 5spd swap into vg auto
- Auto trans fluid
- Oil Drain Pan Screws
- rediculous brake light issue
- Would You Feel Confident Dressing Your Head Gasket?
- Removing Back seats
- Wheels fitment question, using spacers?
- Pictures of the day
- 1989 VG engine - Higher Octane Gas Requirement?
- Changing transmission seals/gaskets?
- Options for Bose speaker replacement?
- Sunroof
- power steering pump
- Broken ground strap on exhaust hanger bolt
- Where is the transmission ground?
- in-cabin water leak from rain
- venom programer chip
- In desperate need of HELP! Clunking sound coming from rear right strut area!
- high idle low idle?????
- fog light opinions
- So just how rare was the GXE auto climate control?
- '02 rims fit a '94 max?
- Cheapest Online Retailer(s) For VG Re-Ring/Overhaul Kits
- What kind of mileage do you get?
- SE vs GXE sway bar??
- VIBRATION AT HIGHWAY SPEEDS FROM THE DRIVER SIDE OF CAR!
- Would Bad injectors cause the engine to miss while driving???
- Replacing valve cover gaskets (VG)
- VG Cylinder Head Bolts Reusable?
- 92 maxima SE white smoke coming out exhaust
- Carjacked!
- Power Steering Pump Questions
- 92 VE 5spd
- Ignition Coil Replacement for VG
- Throttle Body Bypass Kit
- Replacing Bose h/u
- Question regarding BBK Swaps
- So I bought another VG auto
- Where is the speedo sensor?
- Anybody ever actually "fix" their alarm?
- Watch out for flying coolers on the highways :(
- How to tell SE trim?
- 92GXE pulling to side while driving.
- Need favour from VE guys
- Once The Rear Slide Pin is Seized - Is Torque Member Junk?
- A/C Question
- Alignment problem or something else?
- my max updates
- Danger Gas+Spark=Fire (Funny Injector Changing Story)
- About to rebuild vg auto any advice on this kit or anything?
- VG Auto Tranny Issues....
- Caliper, Rotor and Pad
- VG Header/Ypipe
- How Did You Separate the Inner Tie Rod Joints?
- Replacing my brake and fuel lines questions
- dremel made me do it
- How advanced to you all run your timing?..
- Injector 2 & 6
- Injector Plastic Tip....Do I need it?
- Stubborn starts
- This car is a real PIMA !!!!
- egr removal
- speedometer going crazy
- Rims
- Need Power Steering Pump
- 4th gen Pacesetter STS fit the 3rd Gen
- fixing rear defrost strips
- Injector CC problem
- 91 Maxima's in the shop.
- my 92 maxima has a miss
- Troubling no Start Issue
- Does Y-Pipe have pre-cats?
- Spark Plug Look...Hmm
- rack and pinion steering leaking???!!
- Manually Firing an Injector???
- Temp/Perm Fix for Failed Regulator
- Sputtering at Startup to WarmUp...Hmmm.
- 1990 GXE Sun Roof Seal?...
- 91 Maxima. Starting Question...Security System causing this?
- 1991 Maxima Driver side tail light cover
- 1992 Maxima GXE Rear Brake Conversion
- Something I Was Wondering About?
- installed fog lights = low battery
- OK.Before I Call My Local Nissan Stealership
- Intermittent upper end rap when below 50 degrees
- Wheres my pcv valve located
- So I bought another '92 VE 5 speed
- 89-94 NM Diagnostics...
- Should I VG 5spd vs VE Auto...which to buy..:)
- How are you guys???
- need ignition help ASAP
- Fog Lights
- Greeny's Gone :sadwavey:
- Bose Scosche adapter
- bought a 92 max today...
- Help me clear out the confusion..
- Selling the max...
- Power Window Diagnosis Please
- Question about rear big brakes
- E-Brake not disengaging?
- clutch ?
- I pulled a Matt93SE...
- Hesitation after power washing
- overheating
- Brake light switch question
- Car Vibration
- exhaust manifold gasket and/or intake manifold gasket
- End of transmission.
- Car will not start
- Where is the vg auto trans filter?
- tranny shiftin issues...
- Should This Be connected To Something??
- No power to the ECU/No Spark
- Wheel & Tires what will fit?
