- Can I Jump Wire an Injector?
- Clutch question?
- Have you Adjusted your Koni Struts?
- Rear caliper and rotor capatability 90 to 94.
- i got owned by a caliper....(see inside for details)
- How many Green/Black/Silver Wires are there?
- Valve?
- abs light
- Tranny woes @ 149k, horror inside...
- How do you hook up Amp-Meter?
- Wat Color Would Look Best On Maxima?
- where can I find polyu bushings for fstb and rear stabilizer
- Fstb???
- Should I keep it?
- Delayed Shifting
- Anybody run the ST Struts on their 3rd gen?
- For all the mn people who wants a ve 5spd.
- FSTB for VE
- What would you do?
- someone EMAILED ME? lost ur email
- how can I tell if its LSD?
- Code 34 and 51
- yellow fogs??
- Rebuilding heads
- who is this
- bose speakers
- Eibach springs with stock struts?
- New in here with some doubts, looking for help!
- Replace auto climate control with manual one
- Intake Manifold Spacer
- Window regulator/power window motor?
- Steering wheel question
- Hey guys, back in town.
- Cam Angle Sensor Testing
- Does anyone have pics of....
- Any1 ever do a VG auto or 5sp to VE5 swap
- New Chrome Gauge Rings (Pics)
- Work in progress: Questions
- bad injector????
- $58 per lifter!?
- Paint/Bodywork prices
- Low Mileage VE, whats it worth?
- San Antonio, TX - Blue TURBO max with Stillen Kits and FMIC. On Nachodoches Rd. Who?
- All The Time Lit Speedo
- pioneer ipod adapter
- busted timing chain
- Digi climate control problems
- Well it's parked now.
- How do you remove the STEERING WHEEL?
- Disaster!!
- WHo here has made their gauges brighter?
- Step 1: Strip car
- Pics Eisenhower Meet 6/17/06
- Positive cable
- Noisy Brakes
- dead ve :(
- se gauges on Ebay
- another one down pic inside
- 149K-Time For JDM Swap
- Back on the road
- Time to say goodbye
- o2 Sensor, will this fit?
- bracket
- Funky noise
- Hmmm....very strange pictures
- Tire Wear
- VG pics
- Stock Waterpump Belt Pics
- Exhaust advice!
- Exhaust Problem: irratic idle, and dies when "hot"?
- Extremely annoying interior sound!!!
- Tip of the week
- Betcha want my goodies...but u can't have them!
- Another dead Maxima
- can't search, 5 speed m/c template
- tach
- Master Cylinder
- Stock Air Intake Pics?
- New MAF
- New wheels :-)
- Help? After-market CD doesn't activate antenna
- New exhaust causing poor gas mileage??
- Looking for Transmission.......
- Please help with body repair options...
- Some new toys...pic!
- glue around transmission fill plug
- Buying a control arm
- Dash Light issue
- bmw exhaust
- that website
- how many quarts of GL-4 gear oil in a 1990?
- Winshield leak
- 06 g35 forged wheels on the the third gen
- Ebay Exhaust System? Will it fit?
- Really Bad Idle Help Please!!!
- How much drop?
- whirring sound
- It's Alive!! (New ECU!)
- Dashboard Lights
- headlight prob
- cheap auto body parts
- please help me save time
- Guess whats wrong with my Maxima?
- Just got the stillen kit what to do before installation?
- Valve cover gaskets
- BRA for the car
- Transmission jerks when putting to drive after changing injectos
- Replaced injectors on VE but still getting shaking/ rough feel
- Maxima Rims
- passenger window switch
- question about buying a 93 with a loan
- Short in tail light
- Replacing rear window..need help
- ve timing check
- Power Steering hose
- Fog lamps question
- Sunroof acting up
- Short Throw Clutch
- iPod interface question...
- Simple Fix for rusted out stock spoiler
- Goodbye to my '89 SE
- door lock handle
- need serious help!
- Phantom Fuel Check Valve
- stupid brake question
- rack question
- i need so feedback .
- Weird issues after injector install?
- Remote keyless entry?
- WATER PUMP TENSIONER? vg30et?
- Injector retaining screws?
- Coolant flow through throttle body?
- Who likes my knob? *PIC*
- Got my Timing Belt replaced By the STEALERSHIP!
- Quick question regarding VE intake manifold removal. *PIC*
- 1992 GXE engine??
- MAF regrounding?
- strut stabilizer to control arm mount
- Some Rare and Hilarious Pics
- o2 sensor upgrade?
- Alternator Prob
- ? some help ? timing ?
- e36 lights
- Is this an alternator problem?
- Opinion Needed
- What kind of seats is this?
- Gabriel Shock absorbers?
- is this worth buying?
- Quick Control Arm Quest.
- Engine a keeper?
- help-Blower won't stop blowing!
- Swapping ECU?
- Possible to switch GXE steering wheel with SE?
- what are the prices for a VE motor?
- Cylinder Heads
- Air conditioning in my 1992 SE
- New Bimmer!
- car shaking a lot
- Broken Dipstick
- Will a 300ZX shifter (A/T) fit in an A/T '89 GXE?
- exshaust question
- Exhaust Manifold and Studs
- what do you guys think? chicago guys i need ur help.
- speaker brackets
- think im buyin my 3rd gen back
- vg head light help
- wtf is up with my lights??
- New mods.
- She did it!!!!
- Camber Adjustment?
- Injector R&R / Intermittent dead cylinder
- starting issue???
- hey Cliff Clavin...
- Plastic housing on E36 HDLights need replacement?
- 3rd Gen caravan for 6/17/06
- Fitting a 300ZX steering wheel?
- Coolant boiling...Fans not coming on...need input
- 300zx shift knob in 3rd gen?
- ECU reset
- input shaft bearing inner ring
- Unorthodox Ruins Motors??
- Maxima VE engine radiator cap pressure????
- Is winter weather a problem for CAI?
- VE Valve Springs
- Tire size too small?
- Rim/Tire Sizes
- Clunk on front driver side
- Wheel painting help?
- Maxima AFM
- Intake advice
- Need Help with Suspension
- Noise From Rear Of Car
- Windshield wipers and other prob
- ABS Wheel Speed Sensor
- remote keyless replacement
- Duplicolor to match Nissan sapphire blue?
- Rough Idle
- Need wisdom from the org...tranny probs
- how to check the sensors...
- look at this pic/ whats wrong with it
- what happens when ks goes bad?
- still learning site.
- curse of the intake manifold gaskets
- I need to change my lower control arm bushings
- Front Bumper Damage
- front valve cover SNAFU !!
- Tranny Mount
- Check Engine Light...
- WIll this really work?
- Torque for knock sensor
- flywheel
- C.l.r.
- Death To The Mass Air !!!!!
- Only 3rd reppin at meet.............
- time to change my plugs
- Help? stuttering/misfire under acceleration/load
- Can The BKR5EIX-11 Be Used In VG30E?
- Camber Kits???
- Hardwiring Indiglow gauges?
- Heater doesnt work
- Door Pods Finished **PICS**
- Front valve cover !!
- piaa led lights
- ABS Code 10 question
- Simple Question
- Axle or bearing issue??
- PCV Inline Filter
- Inner Tie Rod removal
- passenger window issues
- car cuts out
- was ripped off..
- Anyone interested in fabbed vg33e bracket?
- New family member :-)
- Maf?
- ATF in Engine to Carbon Clean?
- outer tie rod ends
- Who outbid me!?
- tps ?
- Suspension problem? Right rear sitting lower
- I Got Hit Today !!!!!
- Saying good bye, another max RIP
- Erratic RPM
- Quick question since search is not working...4th Gen Seats?
- Weird Power Windows Problem
- Speedo Issues
- Oil Pan Screw & Crush Washer
- Code 33
- What's it gonna cost me??
- New SFC design
- caliper probllem
