View Full Version : 3rd Generation Maxima (1989-1994)
  1. Quite the annoyance
  2. Do GXEs have fog light harnesses? help...
  3. flywheel compatibility question
  4. rear wheel bearing help
  5. Clutch replacement options
  6. tranny rebuild cost
  7. Car shuts off please help
  8. 3rd Gen Production Numbers
  9. Front end project log.
  10. Help me a bit...
  11. Where to find? Wings West spoiler
  12. Just wanted to show you how im coming along
  13. control arm replacement
  14. Rear speakers not working?
  15. Break In
  16. CarFax reports
  17. FSB how much of a diff?
  18. I may sound silly but bear with me. Power loss or what?
  19. Teh 300k club: sign in..:-)
  20. Engine acts likes it's flooding?
  21. Serious Clutch Problem (again)
  22. Need Opinion.. Keep It Or Sell It?
  23. LED spoiler brake light question...help
  24. Anyone with JWT ECU?
  25. bought another one
  26. Chrome trim -> Black trim on 92SE
  27. 3rd Gen Respect!
  28. Is it worth it?
  29. My Maxima = teh suck
  30. Idle Problem, ive searched. cant find anything
  31. NA vs Turbo
  32. Photoshop Anybody???
  33. Tips/ Instructions for removing back seat
  34. $200.00 for a COMPLETE VTC's rebuild??
  35. Need a front exhaust manifold...
  36. Whirring at certain rpm range = engine mounts?
  37. need help with courtesy nissan nismo studs
  38. VG Factory fitted alarm - intermittent sound
  39. Bright side corner lights?
  40. Erattic Idle
  41. fast help please!!!!
  42. 92SE Perform.Rebuild & Airshifter
  43. Rear fenders rusted through - to fix or not to fix?
  44. you could say it was time to change the axle
  45. Is an CAI Or RAM worth it on 3rd gen SE?
  46. Big wheel stud problem
  47. Trunk lift springs
  48. Running With No Cat = CEL???
  49. Rear window ALL the way down
  50. Need to replace windshield wiper motor on 93 GXE
  51. So i got bored with tail lights...
  52. Hub Question
  53. Well, she's finally gone......my first love :(
  54. Where to get Y-Pipe in Vancouver
  55. Aftermarket Control Arms wont bolt up!! **pics
  56. Air wrench monkeys! Argh!
  57. R-12 substitute?
  58. Trim Levels, what makes an SE VE GXE ect?
  59. Car A/C smell
  60. Race. respond quickly please.
  61. My car was stollen
  62. disabling VTC?
  63. Distributor removal?
  64. FOG Light Rust
  65. Tranny: Problem never heard before, please advise!
  66. alt problems
  67. Paint Job
  68. I think its time to sell...
  69. VE Dipstick Question
  70. Side Mirrors?
  71. Washer fell in spark plug hole.
  72. sounds like I have a BOV!
  73. Fuel injector wiring
  74. front valve cover/head noise
  75. Spindle differences
  76. What can I say..ebay link
  77. steering wheel suckage
  78. found this on ebay.
  79. Failed Fuel Injectors
  80. Whining Noise from Front
  81. Sign of tranny going out?
  82. Need more power.
  83. 3rd gen Villager/Quest owners (ecu where)
  84. Just bought another Maxima
  85. Engine Coolant (antifreeze) Leak
  86. Clean injector plug terminals
  87. Heater core, where is it on these cars?
  88. My cure for hesitation
  89. new tires worth while selling maxima?
  90. Leaky ABS unit
  91. quick question about intake manifold
  92. AC controls stuck on heat!!!
  93. Wierd rattle. NEED HELP BAD!!!
  94. Replacing Control Arms and Minor Rust issue..pic*
  95. How much money is invested in your 3rd gen Max?
  96. One-piece BMW Halos and clear corners...pics update!
  97. Clear headlight film to protect wades???
  98. engine dress up kit???? anyone seen this??
  99. Edmunds TMV: Our car is worth...
  100. Drove with parking brake on
  101. Strange
  102. VG30E(T) Adjustable Cam Gears
  103. Too Hot to Work on Car!!!
  104. Stupid VE Dipstick Thread
  105. Those with aftermarket clutches! Enter.
  106. Replacing Control Arms and ST Sway Bars
  107. Fitting the 93/94 srs airbag wheel onto a 91 max?
  108. belt size for ASP udp?
  109. Do these chips really work?
  110. digi/anal gauges
  111. She's down....................................loooowwww :-)
  112. Sunroof shade problems. Help!
  113. Y-pipe problem
  114. VE cluster in my VG
  115. Justa warning to all of us: radiator hoses hazard!
  116. Valve cover gasket sealant
  117. Dust Cap?
  118. Todays photoshoot (56k beware)
  119. Air Bag Challenge...
  120. Sign of bad alternator??
  121. Help...92 maxi, Power lock problem
  122. Where are the VG sensors
  123. I know I dont post much but...
  124. turn signal indicator bulbs
  125. Some project pics (rust!) 56k no way!
  126. Axle Problem...
  127. Repost : heater/ac lights are dim at night-time
  128. rear suspension tower brace
  129. Acetone-duct tape residue removal
  130. Advice on possible purchase VE5
  131. Exhaust Studs Finally Replaced
  132. Foglight Question....
  133. Brake Master Cylinder Swap
  134. Auto Transmission fluid flush on a 93 GXE.
  135. Stiilen
  136. Spark Plugs G-Power
  137. Great New sources for Maxima Info...i think??
  138. cooler thermostat
  139. Bad dont know what happened yet!
  140. only running on 5 cyl
  141. oil pan replacement
  142. Made one window regulator out of two
  143. more exhaust bolt repair ???
  144. TB sensor question.
  145. Check engine and oil light lit up on dash, followed by a dead battery..in that order
  146. Fan Belt
  147. help, 92gxe to 89se
  148. So.....can anyone here in SoCal help me out?
  149. I Finally Did It. Installed e36 lights.
  150. Hard shift; worth fixing?
  151. How to get a new key cut for 92 SE?
  152. Injector additives
  153. found feature on accident
  154. New wheels for my '90 SE
  155. cabin air filter???
  156. Rear brakes - does piston need to be turned back in?
  157. Dashboard lights out
  158. Has anyone insalled a Quaif Differential on a 3rd gen?
  159. Factory alarm
  160. quick question here...
  161. That K&N really worth it?
  162. gauge needles stopped working....
  163. lopey idle
  164. VG TB water rerouting.
  165. Cleaned out engine bay
  166. #$&%@ foiled by the dealer parts guy - wrong seal
  167. Strange power locks issue
  168. Some pics of a recent project I have been working on (56k beware)
  169. Broken Pintle Cap
  170. Corner Light Rewire Keeps Blowing Fuse???
  171. Questions. And Answers that work.
  172. sway bar bushings
  173. It's finally here!!!!
  174. It's dead.....
  175. Just found this on my PC
  176. Crankshaft Position Sensor (VE) & VTCs
  177. How to get fuel injectors out of rail?
  178. i must say
  179. Help something bad
  180. Climate Control LED
  181. R12 vs r134 systems
  182. New front axles and now a vibration
  183. Door Panels
  184. 2 Quick Questions
  185. 1st Thread
  186. Wtf Was He Thinking!
  187. While I got my trany out, what should I look at?
  188. An Easy One !
  189. 240sx wheels...
  190. radiator?
  191. Sunroof vs no sunroof
  192. Antenna Prob.
  193. Making plans for VTC and Clutch install need help (long)
  194. Injector Stuck!?
  195. AC Compressor
  196. 93 maxima
  197. '94 DOHC in a '93?
  198. How to remove screws in fuel injector caps?
  199. Wont start and have run out of ideas
  200. Starter and maybe tranny problems???
  201. E36 light pictures?
  202. automatic a/c control
  203. LSD Problem?
  204. Blown Injectors (on both Maximas at the same time)
  205. Driver side door wiring question (trunk)
  206. VE5 tranny on a VG auto
  207. Car Cleanliness
  208. Window problem.
  209. OEM Spoiler Install
  210. bought a pair of lights Need Someones Help
  211. Bit The Dust!
  212. quick q
  213. 1993 Maxima Runs rough
  214. quick tranny question
  215. Replace Springs with Struts or no?
  216. Bad o2 sensor?
  217. WTF? Enkei RS6 + SMALL pothole at 25MPH
  218. Minor(?) rust..how to handle? (pic)
  219. Say hello to my aussie max
  220. My maxima gave me a pleasant surprise today.
  221. Replaced knock sensor and injector, now wat?
  222. Steering Wheel Removal?
  223. What's New
  224. Has anybody done this?
  225. Installed VE tails...looks "different"
  226. Best Aftermarket Speakers For Stock Bose???
  227. 3rd gen leather care?
  228. the million miles mark
  229. A/T additives?
  230. NE1 ship a Stillen Lip? How much? Folded?
  231. leaking ABS actuator.....
  232. Msd ignition, loud horn
  233. from 3rd Gen Maxima to BMW 3 series
  234. I replaced my window regulators!
  235. glad the inspector found this problem! (pics inside)
  236. failed state inspecition and not very happy...
  237. How to clean out hvac air ducts inside the cabin
  238. Short throw shifter
  239. Symptoms of bad springs?
  240. need a steering rack or rebuilt kit
  241. fuel injector test?
  242. Can Anyone help???
  243. Replacing VE water pump
  244. Chasing Down an Electrical Issue
  245. Help! Oil Light only on U turn.
  246. window problem
  247. Hi i need help
  248. sticking throttle body
  249. Strange buzzing from new exhaust
  250. Can I Jump Wire an Injector?
