- VG Autocrpatic
- New Rear end vs Old.
- Bulb question
- had a wierd offer recently
- Rebuilt Transmission whine
- Anyone have pics of new EURO headlights?
- replacing axle
- car vibrates when in reverse or drive gears
- Weird vibration while accelerating
- Fuel leak
- fuel tank straps
- 3rd gen with bose
- Clutch question
- Question about an Auto Tranny issue
- my e36's
- HaTe my locks!! Need part quotes too.
- Mid-page pics
- Clicking Noise from the dash...........
- Just ran into two problems...
- vg30e and vg30de same auto transmission?? need help a.s.a.p.
- Steering Question
- 1989-1991 SE Trunklid Tailpiece Lettering
- Gauge Clusters
- Speedometer problems
- Spoiler...trunk not popping open
- quick ? about trans seal
- Car don't shift 2-3?
- Need help installing a 95 Bose double din into my 92 Max
- twin turbo 3rd generation. with pics.
- VE Thermostat Gasket
- Just picked up a 3rd gen; have a few questions..
- bumper paint - comes up much darker
- car won't start, clicking like machine gun
- Changing power steering hoses?
- The Max took another hit
- Energy Suspension control arm bushings
- Twisted off both bolts for the foglight....
- LED 194 lights
- fog lamps...how in the hell....
- Orange DONK Maxima
- Need help with a strange vibration issue
- Alternator recharge questionaire!!
- Sold another 3rd gen (pic)
- Car cuts out in the midlle of the road
- For those with lowering springs.
- Exhaust Question
- I have a dilemma...
- head problems not VTC's
- Noticed extra heat...
- A mod that isnt "rice"
- Need Help With Brakes
- Broken Mani bolt or just a rotten Exhaust?
- So im thinking of getting a cheap 3rd gen DD !!READ!! !!HELP!!
- Another accident, pics inside
- HELP....ASAP left headlight not.......
- reverse lights not working
- Sqealing brake caliper
- Infinity j30 intake
- Euro headlight pics...
- Front Engine Oil Seal Leaking
- Todays accomplishments.
- Some E36 and stock Maxima lens pics
- good bye maxima.org
- Sunroof removal at the junkyard (pics)
- Opinions on new clutch choice?
- Third Gen Owners - I made quite a find
- Max rolled into house
- Horn wire on keyless entry install
- Okay....my clutch problem solved?
- (VE) Bad injector or something else?
- wow these got cheap quick!
- need help replacing rear strut
- *MY* custom E36 Install no pics
- Decoding a 3rd gen ecu help
- 1 year, Please read on 9-17-06
- way OT question for the engine/trans freaks
- battery / cv joint questions.
- replacing dashboard/speedometer light
- Just got inpected, emissions question
- 92se 5 speed with a tranny issue!
- VE owners only poll about VTCs
- Hub Dilema
- New E36 vs old E36
- Sagging Intrax?
- Weird sound
- Dysfunc's Turbo'd VG
- Where is the ECU located on an 89 maxima?
- How Long can U Drive In a Leaking CV Boot?
- temp selector for a/c-heater stuck
- painting question
- Steering issue - control arm bushes?
- Orange Sludge in Coolant system
- Axle seal problem
- Hmm. Electrical prob?
- Exedy Stage 1 Clutch Owners
- Problem regarding clock
- CrankShaft?
- desperate need of help for my 93 maxima!!
- turbo VE....video inside
- Oil leacking from lower oil pan
- max idles high after hwy use
- 91 max alarm goes off randomly help!!
- Please Help!! Weird Clutch problem
- possessed max (video)
- OBDI to PC
- VG ENgine miss, diagnosis??
- VE Water Pump biggest PITA
- Observed New Sticker in TN....
- fastest 3rd gen?
- What Cars used the same tranny??
- Koyo Hi- Flow Rad....?
- Rear brake lines
- T/C the VG...
- crank shaft end (front) diameter?
- Master window switch bad?
- painting bumper - Autozone ???
- E36's w/Projectors?
- steering pump
- Driver Side Main Window Switch Repairable?
- Lack of low end power
- I lucked out tonight
- Steering cuts to the right.
- electrical problem?
- Bad fuel injector = wasteful on gas?
- Manual Tranny (original) died @ 549, 010 Miles....
- New Maxima Owner.. Tranny/Engine Help please!
- AC R-134a Retrofit
- Car is hard to start.
- Custom CAI (pics inside)
- Starter wont go
- Radiator fan - constantly full blast
- Were can i get a bigger radiator?
- Center Dask Backlight/illumination
- Black Chamber on Intake?
- Turbo'd 3rd gen RUNS!!!
- Kill switch clarification.....
- brake lines
- Spoiler removal/replacement
- confirm axle seal part #?
- Crank Pulley bent or "unbalanced?"
- how to
- Rest in peace.
- New Rollerz: I got my Crosshairs set on ya Max!
- Smell
- question and opinion on jim wolf product
- Thank God BRAKES!!!
- What do I need to do?
- VTC Grounding Question..
- ALright heres a decision to make Need Input
- fuel issue on Maxima I might purchase
- Shopping list purchased!
- Painted plenum (pic)
- Need help removing Intake Manifold on Max 90
- Anyone Scrapping a VG?
- tranny question
- Left Headlight Assembly Adjustment Broken
- Seatbelt rust.
- Black thing in trunk?
- The cigeratte lighter adaptor is not standard on this car?
- still bad idle
- Need an oil change and new spark plugs
- Rack and Pinion replacement
- Used Fuel Injectors
- Need Lots Of Help!!!! Trunk Not Opening!!!
- Rear defroster repair
- finalllllllllllllllllly the tick is back
- Problems?
- Green or Yellow???
- Buzzing from DRL module
- 3rd gen related thread about MPG
- Rear well rust.
- torque steer
- thank you Nissan finally a easy fix!
- help with automatic tramsnission vg30e
- Lights not turning off
- ABS sensor replacement? Cost/where to get?
- High Mileage 3rd Generation cars
- Coolant leak.................
- a few short ?,idle spd,tps.,test injectors
- ST's Finally Here!!!
- Shifter assembly
- Throttle/Transmission glitching?
- a little control arm question
- Auto tranny not shifting.
- 300zx exhaust stud.
- Clunk Clunk!!!!!!!!!
- Finally got my JDM VE installed........
- Another Video.. but this one made me sad
- Shock Oil (Koni)
- window fell down? Window regulator?
- The 5 speed swap
- My Max totalled! (Pics!!! 56kers beware)
- OEM Throw out bearing. Deffective?
- How much beer fits in a 3rd Gen?
- I'm finally selling my 3rd gen...
- Locking 5Spd Transmission
- security light
- key pad help
- No more MAX
- Fuel Injector Rail
- Bought Another Max!
- 92 sentra se-r
- Fuel Injector Connection
- Shift linkage problem??? Please help
- Modding help
- havent been on in a long time.....
- Timing Belt
- bought used car - plate question
- Checking ABS error code
- Pacesetter headers
- A strange Electrical Problem
- Need help with Remote Start wires!
- Weird sounds from under car
- Engine missing
- Help
- Panel lights
- is the 85 300zx vg30e auto gearbox exactly the same as the 90 nissan maxima vg30e's?
- Installing a Subwoofer
- Is there a difference?
- Opinions needed
- Fuel Pressure Regulator?
- For all!
- Car trouble, need answer ASAP!
- VE power planning?
- Poly Urethane Mounts
- Question about difficulty of swapping
- buying car in Indiana but michigan resident
- question bout vtc not responding when i hit the gas
- Running lean in high rpms
- Cold Air Intake
- Dashboard Light
- Dual Hi/Lo e36 lights.
- lifter tick
- Engine Swap for 92 5spd
- Install kit
- Sponsorship
- Fuel Injector O-ring
- buying car in another state???
- New Headlights (pics) and updated CarDomain
- Zenn Springs
- Clutch Master Cylinder
- 89-94 Euro Crystal Clear Headlights!
- SE vs. GXE Swaybars
- can anyone please tell me what model maxima this is?
- To those that have had new "VE"s installed.......
- Need some friggin help
- Quite the annoyance
- Do GXEs have fog light harnesses? help...
- flywheel compatibility question
- rear wheel bearing help
