View Full Version : 3rd Generation Maxima (1989-1994)
  1. Overheated....coolant leak....won't start...----->
  2. Yay another problem..
  3. Broken sway bar bracket?
  4. Does the VE really like intake(HAI or CAI)?
  5. just picked up a 90 SE
  6. Plastic Fog Light Lens Protectors?
  7. Vibrating When Braking
  8. What to do with old starter?
  9. Clunk
  10. Just donated and WOW I can search!!!
  11. relocate stereo 2" forward?
  12. Best prices for OEM
  13. Valve cover gaskets done last night BUT...SOL
  14. MP3 Player Cradle
  15. Turbo'd 3rd Gen
  16. what is wrong here?
  17. The dreaded recall....
  18. Anyone have ZENN Springs on their max....
  19. Maybe my EGR valve?
  20. Why are brakes still soft after bleeding?
  21. need deep tone muffler..
  22. Oh.... snap my master cylinder is leaking very bad
  23. $ distributor cap & rotor
  24. Got The Max Back From Paint Shop Tell Me What U Think(Pic 56k beware)
  25. Just received/installed new tires today
  26. How does VLSD work?
  27. Alternator output 15v and over, HELP!!
  28. brakes on a 3rd gen
  29. Pics of Clean and Sweet Engine Bays?
  30. Anyone here live in North Central Florida?
  31. Carbon fiber hoods?
  32. Another bose question
  33. 3rd generation coilovers?
  34. Seatbelt Question
  35. Exedy Clutch= OEM???
  36. Anybody with black interior pieces?
  37. Forced Cold Air Intake?!
  38. JDM Intake FTL
  39. Need pictures of dash at night!
  40. Yet Another Door Lock Problem
  41. Master Cylinder ran dry-how do I bleed?
  42. Idle air control valve?
  43. Exhaust too loud?
  44. worthwhile upgrade? Or just a gas guzzling waste of money
  45. Speakers acting weird...
  46. Turn signal/headlight switch stalk
  47. Any experience with axles from Raxles.com?
  48. So I hit a deer....
  49. what happened to this forum?? ive been gone a few months.
  50. Supercharger
  51. Bose Buzz
  52. Vg question
  53. Powder Coated my rear break calipers
  54. Synthetic oil? (non-maxima question)
  55. broken bolt in the main pin
  56. Power Steering Question
  57. Weird Relay Happenings
  58. 3rd Gen Wiper Arm Replacement
  59. 1993 Black VE for sale $500?
  60. Gas Consumption Revisited!
  61. Fuel pump gone ? Cause its not worth fixing
  62. Do I need to go from BKR6 to BKR7 if I advance 15°?
  63. 28,875 original kilometers on a '92!
  64. Suspension Possibilities
  65. Headlights burning out! Time for swap?
  66. VE33 or VE34?
  67. The best ride w/ lowered height
  68. VQ35 3rd Gen?
  69. Questions
  70. Cleaning injector conections
  71. just a maxima
  72. Idle Sputtering
  73. Trans: electrical problems next day
  74. Black or Beige
  75. Need new leather seats
  76. Changed brake pads, now soft brakes!?
  77. Possible to measure rear injectors without taking manifold off?
  78. new body kit? or remake?
  79. installed ADDCO RSB
  80. Sticky rear caliper piston-rebuild easy?
  81. Sonar Suspension Removal?
  82. Shift Light Requirements?
  83. Bet you've never seen or heard this!
  84. low mileage transmission or rebuild?
  85. Advice on BBK for 3rd gens
  86. 6 cylinders vs 4 cylinders
  87. accident in parking lot
  88. Car Parts,
  89. In what order do you bleed the brakes?
  90. WTB: 3rd gen stock springs WTT: aftermarket springs for stock springs
  91. Seat belt chimes
  92. Leaking tires
  93. Help PLZ! Turbo questions
  94. I broke my 3rd-4th gear shift fork....
  95. Back from Trip, Met Some .Orgers
  96. Stock headlamp Q..
  97. '93 SE/AT Brakes, Clacking & Manifold
  98. heat!
  99. Trans shifting
  100. What's this hanging from the dash??
  101. strong wind
  102. Suspension/Steering overhaul question
  103. Motor Mounts. where?
  104. H.i.d.s On The A 3rd Gen Yea Or Nay
  105. Humming noise from rear
  106. Is this a good buy
  107. fuel master?
  108. 5spd and Neutral Safety Switch
  109. Brake Help!!!!!
  110. thumpin noise
  111. Hard start on humid day
  112. Help on DIY brake job?
  113. My baby is gone.
  114. Ready to KILL someone
  115. installing gauges
  116. those who have the infiniti basslink installed, couple of questions...
  117. Maxima's OEM Anti Theft Alarm
  118. gret news!!!!!
  119. Headlights Opinions
  120. Fate of 89blackse, Advice please.
  121. What are you driving this winter...
  122. power lock actuator pinout
  123. Faulty Gas Gauge!?!?!
  124. Turn Signal relay question
  125. exhaust
  126. GREAT Source for 13" Rotors
  127. first string of problems from the 3rd gen are here
  128. 88-94 body style changes?
  129. Starting is becoming a chore :(
  130. a strange bogging/vibration noise, muffler related?
  131. why can't all forums be this helpful?
  132. lost endlink bolt
  133. Bad alignmnet after CV boot replacement?
  134. Engine temp sensor
  135. Exhaust
  136. Anyone install 9007 bulbs in their headlights?
  137. climate control backlights - 3/4 of them just died
  138. 3rd Gen whoops up on 3 5th gens and an I30 at autocross
  139. Lights are scaring me
  140. Do I have limited slip?
  141. Slight studder....
  142. p/s problem
  143. Mass Airflow Sensor Source
  144. possibly changing out all 6 injectors
  145. selling whole or piecing out
  146. Problems with headlight chime
  147. burnt smell coming through the vent..
  148. Any Idea Why Fans and Coolaint.....
  149. 3rd Gen weird noise, need advice.
  150. tranny went
  151. Is it a bad idea?
  152. A.A.C valve on the VG
  153. New headunit wont turn on :(
  154. Milky looking oil
  155. all right, who is a quiter?
  156. could it be the VSS?
  157. How Many Have A 3rd Gen With All Options...
  158. vtc? refresher please
  159. Tighten the steering
  160. I HATE my engine!!
  161. How hard to replace CV joint?
  162. Timing belt gone?
  163. This Is Interesting.....
  164. When Pimp my Ride gets hold of a 3rd Gen...
  165. Heater Valve
  166. Rotting front end
  167. fog light re-wire help
  168. Painted Interior Trim !?!
  169. Bose Fix
  170. Addco RSB hardware
  171. Sticky: Engine running rough?
  172. motor problem
  173. Body Kits
  174. HELP! Max shut off..No Spark..
  175. need CV axles
  176. #4
  177. Swapped struts today...
  178. LED Spoiler Brake Light
  179. Got hit by a F150
  180. Maxima's Gas consumption
  181. brake problem please help!!!!
  182. Bose/Car electrical problem?
  183. Front door speaker(Bose replacement)
  184. Possible HP mod for our VE's?
  185. well... might be getting another max.....
  186. Bar's leak working ?
  187. Plug Wire Question
  188. 1993 Maxima SE
  189. Tokico Suspension Kit
  190. Do I fix the body?
  191. Wierd engine thing...
  192. 94 Nissan Maxima Shocks
  193. Crossmember Carnage
  194. Ebay FSTB
  195. Head Unit Decission help please.
  196. Bouncing RPM while going down hill
  197. Dancing Speedo
  198. 3rd gen vg manifold set up
  199. Rough engine -- all conditions
  200. If alloted $10 G's, what would the best idea?
  201. Need help transmission fluid pan crack
  202. Looking For Parts Needed For 5 Speed Swap on VG
  203. Starting car with timing belt cover removed
  204. Working on the 3rd gen
  205. budget CH0
  206. Cigarette Lighter Ring Light Removal
  207. Another axle going out.
  208. Just got Waxed Pics!!!
  209. Brakelight wiring diagram
  210. Noisy belts?
  211. Technical question
  212. car problems help!
  213. Euro headlight pics wanted...
  214. Tail Light/ Blinker Mod
  215. No acceleration. Looking at 3rd gen for an in-law
  216. SE Rear Brake proportioning
  217. Rear Brakes
  218. HIN show
  219. Since everyone looks for stock fog's
  220. turbo question for anyone that done it
  221. Coolant Leaking
  222. Ve Rwd?
  223. Before you change the temp, make sure you....
  224. Rear sprockets not lining up after VTC rebuild
  225. weird noise, oil leak & exhaust
  226. occasionally shaking
  227. knock sensor?
  228. stupid mistakes lead to big problems...
  229. starter question
  230. Electrical problem...help
  231. look at my plugs...(pics)
  232. VB cleaning or else?
  233. brakes
  234. ball joints and front motor mount
  235. sunroof shade stuck
  236. windows and seatbelts not working
  237. 3rd gen seats fit in a 95?
  238. VG30E PICS to identify hose routes, please.
  239. Battery problem
  240. Opinion
  241. weird putting...
  242. I smell gas....
  243. parting out 91 Max GXE
  244. What tells the seatbelt to retract?
  245. As life of our beloved 3d gens coming to an end...
  246. Temp Gauge Not Working
  247. Bose tape deck - unichannel?
  248. Anyone Ever See This Car Before?
  249. Hot/Cold Slider Control Sticking
  250. Does anyone know the EGR pipe nut size?
