View Full Version : 3rd Generation Maxima (1989-1994)
  1. Optima Battery Model
  2. TPS Sensor fix
  3. Bolt holding the rotor
  4. Oil here, Oil there, Oil Oil Everywhere!
  5. 1993 Maxima GXE can't get to normal operating temperature when cold! Please help!
  6. Testing injectors
  7. Need speed sensor help
  8. morides4chefs
  9. Alternator Belt Tensioner Busted! :(
  10. IYO rims for 3rd Gen...
  11. Seafoam in crankcase and oilchange
  12. Where is the speed sensor on 91 max SE auto?
  13. Differences between VG and VE?
  14. even more problems
  15. Smoked Lights with Tinted Film
  16. Exhaust leak
  17. Testing injectors/sensors
  18. P-brake & Battery lights- Alternator?
  19. replacing bumper
  20. Strange random motor tick - what the hell is it?
  21. Welcome to you new home in Chicago
  22. Question about Tire pressure
  23. Vg auto to Ve5 speed swap
  24. rack and pinion
  25. Apparently cold temperature fixes things !
  26. 3rd genners thinking of selling, trading, junking - come in
  27. Adjusting timing - Distributor bolt
  28. vibrations while in Drive / Accelerating
  29. Flex pipe and catalitic converts PITA
  30. Alternator Question
  31. illegal or legal? [GA]
  32. VG Distributor Noisy?
  33. Wiper system kicks the bucket
  34. Has anyone used the Nissan Factory Service Manual CD-ROM?
  35. Timing check in plano, tx
  36. Looks like a good project car... EBAY
  37. 3.3l Ve
  38. VG Oil Filter??
  39. speed sensor
  40. opinions on getting MOTORVAC done.
  41. Crankshaft VG questions.
  42. What kind of Y-Pipe to get???
  43. Wires through the firewall??
  44. Engine fire?!?
  45. damn gap win regulator *help*
  46. Rebuilt power steering pump and no worky! Help!
  47. Sticky valves
  48. is fsm fuel pres. release procedure bad for car?
  49. unplug ant-pwr to keep from breaking in cold
  50. Oil Issue
  51. Distributor
  52. What should I do with my Max?
  53. oil filter bracket VE
  54. are these the funky vg injectors?
  55. Humming noise inside the cabin on idle....
  56. How to Read Timings?
  57. pcv valve elbow/hose
  58. 92 max not running right IE:bad miss
  59. Someone might want this?
  60. NRG steering wheel hub...will it fit??
  61. In the middle of knock sensor job...need advice
  62. VG auto trans to engine bolts
  63. Looking for pics of 89+ VG ECU
  64. Pop charger, cai, or stock
  65. Motor mount blues
  66. Idle adjustment procedure for '93 vg30 SOHC
  67. rear suspension
  68. question about Q45 T/B
  69. sold the max:(
  70. Fuel Pump recommendation
  71. Electrical problems...no start
  72. ABS problem
  73. Weird engine miss - vg
  74. power windows stopped working
  75. Max still has electrical issue
  76. oxygen sensor socket
  77. i think i finnally fixed it
  78. Torqe Specs - vg upper intake manifold
  79. A little 3rd gen 'Extra'...
  80. Sweet Smelling Exhaust? Oil Leak too?!?!
  81. any1 else has water in the radio?
  82. Can't seem to figure this one out... need advice
  83. Funny how things work out (warning... big picture)
  84. Suede interior write up...install tomorrow pics today
  85. Aftermarket Radio
  86. How can I fix this... (See Pic)
  87. changing oil pan gasket/directions
  88. 3rd gens rendered in 3d
  89. brake bleeding procedures?
  90. Need help on engine mounts R&R
  91. E36 curve/contour vs stock
  92. bad idel and take off still help fast!!!please
  93. Help! Can't shift into Park.
  94. Best Performance Upgrade
  95. So I was on ebay and found some interesting lil toys...
  96. 92max, car shakes betwen 0-40mph's, what do i do?
  97. Need help, car just die...
  98. Radiator Hose?
  99. Here's a new body kit v.awsm66
  100. Stage 1 of VG auto swap. question about a part
  101. Best place to buy a Fidanza Flywheel?
  102. 'pulsation' feeling.new exhaust
  103. Is this normal in the cold?
  104. Rip
  105. Car broken into... NEED 2 FRONT WINDOWS
  106. 3rd Gen Reunion - Tons of issues (damn the mother-in-law)
  107. Rear Disc Conversion (Pics Inside)
  108. 3rd Gen Auto Transmission: Whats your story?
  109. Brake problem again!
  110. help installing power steering hoses?
  111. torque number for ST front stabilizer bar
  112. crap! help help I cut my brake line
  113. Need gasket on my trannsmission RS5F50A
  114. Still Wrenching on the Brakes..
  115. vg30de ticking?
  116. how to refill a craftsman hydraulic jack?
  117. Random Pics of Max and New Fogs
  118. The Fidanza Flywheel I ordered that I never Got
  119. Spoiler on GXE
  120. HELP! Rear brake shoes stuck
  121. Want to do 5-speed swap but found VE Auto on CraigsList for CHEAP
  122. i think my clutch is on the way out
  123. Burnout Vid
  124. rear brake caliper rebuilt
  125. Power Steering Rack and Pinion
  126. expansion valve
  127. need some help on installing the (R) lower arm control
  128. Merry Xmas Eve+TY
  129. Bad front struts - what to replace with
  130. Any off the shelf 140A or larger alternators for the VG?
  131. EPROM chip worth the money?
  132. ECU (OBD I) consult cables...would this work??
  133. Hood Project!
  134. need a post for a vg auto to vg 5spd swap
  135. Timing: Distributor 12mm bolt not tighening
  136. Got a Z. Expressing Gratitude and Bidding Farewell...
  137. new wheels
  138. My Maxx is on its way!
  139. Throttle Body Bypass...
  140. Great news
  141. facelift possibility?
  142. Took a Drive Today...
  143. swapin steering wheel
  144. Will 18x9 with a +40mm offset Fit?
  145. Stupid y-pipe
  146. 2-Piston Brake Upgrade
  147. Lighting on Climate Control
  148. Who's dash digital clock still works?
  149. Coolant Temp Sensor
  150. Best year 89-94?
  151. No Power, Brake pedal to the floor?
  152. crank angle sensor
  153. Interior Lights
  154. Correct me if im wrong or miss something.
  155. Speed-O-Meter/VSS
  156. A/T Mistery, Please Help me!
  157. Anybody wearing Kumho Solus KH16 on their Max?
  158. Maximum offset..
  159. Trunk Lid Take 2 (Wrx tail) + bonus
  160. ecu codes
  161. VG Exhaust Upgrade
  162. hard to start rough idle/ check eng lite
  163. Have a charged battery but now it wont turnover
  164. Will new headers work...
  165. VSS wire info...
  166. installing transmission /killself
  167. Got some wheels from a org member on here, tell me what you think...
  168. Passed inspection...
  169. Hard cold starts?
  170. pics of my macco paint job after 1 month....
  171. maybe my egr?
  172. Original Wheels
  173. Painted Grille
  174. Interior roof removal
  175. MAX broken into, pics
  176. 5 speed manuel gearbox overhaul
  177. New exhaust and missing low end torque
  178. After New CV axle & injector Max is Back up!
  179. 92 auto tranny problem
  180. Trading in the Max :(
  181. Order of Clutches/Steels?
  182. Odometer, Shocks and TailLights
  183. now that the cold weather rolled in....
  184. Dual Stage Muffler
  185. Fuel Injectors?
  186. 92 auto tranny - revolution sensor
  187. Got bored ended up with retrofit.
  188. Stock b-pipe diameter
  189. RSB question
  190. Stalling when the motor is cold
  191. 17" chrome infiniti's? what you all think
  192. Sub direction/enclosures.
  193. I want to post a picture,but I don't know how? Step in here :-)
  194. Vg Manual transmission number
  195. Last word on Konis?
  196. Transmission out need help!
  197. metal fuel and brake lines help!!!
  198. Heat, No Heat
  199. Getting All Exhaust studs replaced but
  200. Timing Chain vs. Belt
  201. Headlight Bracket ?
  202. uh, HELP please..
  203. Vibration in reverse - any idea?
  204. Removing Transmission
  205. Auto tranny check plase help me!
  206. Well, I sold my max today and picked up this...
  207. Speaker Sizes?
  208. What 14" wheels fit?
  209. Common ABS leak?
  210. 3rd gen repair issues.
  211. 3rd gen repair issues.
  212. Best price for Fuel Injectors!
  213. Maxima Down=CTS-V UP!!!
  214. Thoughts on Tokico HP Spring and Strut kit.
  215. What's Your Most Anal-Retentive Automotive Quirk?
  216. Parking lot light fell on my car!
  217. No Longer!
  218. whoah, what a difference.
  219. In-Cabin Lighting upgrades
  220. Engine Whine VG
  221. 95-98 240sx Steering Wheel in 3rd Gen
  222. VE Brake Rotor/Pad selection
  223. firewall water leak
  224. Stop with the multiple threads that cover the same subject!
  225. Power Black Leather
  226. sunroof drain exit point?
  227. can a timming belt affect peformance?
  228. Digital cluster and HUD
  229. oxygen sensor?
  230. Question on installing the Digital Dash in a 93 GXE
  231. Front Strut Bar?
  232. Can you interchange parts from a 93 Altima to a 90 Maxima?
  233. Help ! No fuel
  234. Nice VE-5 on ebay
  235. People who have rebuilt 93-94 Auto Trans? Chim in
  236. 3rd Gen may be the best Max Ever!
  237. How to remove governor from your Maxima...
  238. Euro headlight pics...INSTALLED!
  239. CV Axle assembly
  240. AT refill VG
  241. someone has some suede..............
  242. pot hole bent my rims!!!
  243. Bench Bleed Master cylinder
  244. Speaker PODS
  245. Finally pic of my max w/clear euro headlights
  246. new twist on a common problem....exhaust manifold
  247. 1993 Maxima.. Took Tranny Apart Questions?
  248. New Battery
  249. shudder when in reverse.
  250. question
