View Full Version : 3rd Generation Maxima (1989-1994)
  1. sunroof seals
  2. how much your max means to you
  3. AHH! Dash Lights wont work!!
  4. CV Axles again?
  5. HELP!!! 3rd gen keeps dying!
  6. vg motor swap problems
  7. Changing the Distributor
  8. Stereo keeps turning off
  9. Headlight Relay
  10. Bose Headunits different sizes?
  11. 3rd gen Bose, did it change?
  12. 3rd gen?
  13. check engine light...on one second then off
  14. Matt's Stage II LTB
  15. VE + n2o + DRs + track
  16. Pulling VG motor..
  17. Pulling the Engine
  18. power steering question
  19. Transmission problems
  20. Update: Turbo back in with upgrades and Euro Projectors
  21. Help!!!
  22. heater core
  23. Help Needed. Losing water etc.
  24. seatbelt
  25. Bangs into gear out of park
  26. dripping from under dash, passenger side
  27. What is Thermal Transmitter -
  28. Check Engine - code 32 HELP!!!!
  29. What Tools Are Needed For Brakes?
  30. fule pressure regulater hose
  31. Once again.... now engine dies at higher rpms?
  32. James - 1, Rust - 0
  33. Polling for opinions on exhaust change
  34. anyone have coilovers on their car
  35. Maxus SFC sale
  36. Trunk Light - Alarm
  37. no power again but its not knock sensor this time
  38. 300ZX manifolds
  39. vacuum line on top of plenum ve auto
  40. please help. gauge face problem.
  41. BOSE problem - 93 SE
  42. How can I fix small rust spots?
  43. Ripped steering rack boot, now what?
  44. Soo..I changed my timing belt today....
  45. Welding Gland nut?
  46. Painting my plastic pieces in the interior, what should I do next?
  47. How to change brake shoes?
  48. Homemade FSTB
  49. I hate Pot-holes!
  50. help::temperature gauge inside is going out
  51. smoother idle with A/C on??
  52. Pre maxus subframe deal
  53. 94 Gxe...program Keypad On Door Handle
  54. 1157 Blinker Mod WriteUp
  55. SE wheel weight
  56. heat?
  57. o/d light dont work anymore
  58. getting new rims/tires question -no pics-
  59. Alternator VE/VG
  60. 1157 Blinker Mod
  61. Which Tranny Fluid To Use
  62. VE Vacuum Lines
  63. Turning radius
  64. Rear deforster barely works
  65. VE Oil gallies
  66. Control Arm bushing
  67. Big Brake Kit
  68. minor accident, need repairs?
  69. Rsf50a tranny rebuild
  70. Help with rims please
  71. These are my symptoms.Thinking alt.
  72. Side exit exhaust
  73. VG Phenolic Spacer - DEPOSIT DUE!!
  74. FSTBs any difference?
  75. Speedometer Sensor Install on VG
  76. front window replacement
  77. what would cause a.....
  78. rear lower main bearing help
  79. so i can finally see
  80. bulb info
  81. Where to find those AWESOME chrome gauge/dash rings?
  82. Coolant issues
  83. VG Cold Air Intake Interest Thread
  84. Rear parallel link bushings
  85. 'True Clear' Corners Project
  86. Questions about CAI
  87. new turbo setup
  88. Headliner sag
  89. The sweetest 3rd gen I've ever seen!!
  90. VG30E interals
  91. Car's idle dips below 500rpm when A/C is on
  92. My New 02GLE !!
  93. Source for extended wheel studs... ~2.25in or 55mm
  94. Does not start / pin out
  95. hook up points for engine removal
  96. SE Suspension on GXE...
  97. Do I have Eibach springs?
  98. 19x8.5 wheels
  99. Bose Radio Issue...
  100. Subframe Removal
  101. Check out this awsome grill
  102. Difference between addco and ST
  103. Rear drum brakes
  104. Best Joke ever
  105. Stillen kit
  106. Clearing Lesnses???
  107. Installed Fstb....
  108. When VTC goes bad....
  109. P/s high press hose
  110. my repair scheme
  111. Autozone Repair Guides
  112. The Great 3rd Gen Picture Thread/READ RULES BEFORE POSTING!
  113. high idle speed...? WTF.....
  114. Fresh wash & wax shoots with zymol
  115. Part number...
  116. Just watched a 3rd Gen get "pimped" on MTV
  117. Anyone Had Luck Cleaning Bad Injectors?
  118. 9007 bulb upgrade**With Pics**
  119. Front Right Tire
  120. Anyone VIP a 3rd gen?
  121. Most annoying "engine-in-car" job?
  122. ive never seen a gold vg 5 sp.
  123. Motor Mounts.....is it time?
  124. Auto Sunroof Re-Wire?
  125. New eBay cold air intake for the VE
  126. Question about valve cover screws
  127. Instrument Panel Dimmer?!
  128. Need Rim Help!!!!!!!!!!!!!!!!!!
  129. Headlight bulbs
  130. e36 headlight wiring
  131. Jim Wolftech
  132. any gaskets and tips?
  133. Fuel Pressure Regulator
  134. strange hissing sound on passenger side
  135. Front Suspension For My 94 Gxe
  136. tranny removal
  137. 3000k in E55 Output Pics! (no 56k)(4 mtcookson)
  138. Maf Sensor Question Kinda Weird??
  139. A 2 door maxima? SE-R 3rd gen?
  140. Infinity FX45 projector retrofit
  141. when my 3 rd gen get out the body shop
  142. engine tranny change
  143. when if ever shold the timing chain be swaped
  144. Angle eyes...what would you do?
  145. Headlight wire harness
  146. rear window removal help
  147. fan speed.....on or off? what's wrong
  148. Crashed my Max =(
  149. Keyless entry Problems!
  150. from the general discussion forum..
  151. Super loose part on VG, need help
  152. VG rear main oil seal
  153. Carbon deposits in combustion chamber
  154. Cleaned up the Engine a Bit Today
  155. Who's Running Unorthodox Pulley Quick ?
  156. No Arranca En Frio, In Spanish...
  157. Loss of odometer/mph signal
  158. A/C removal
  159. for those who completed the 5spd swap.
  160. for those vg guys with injector issues.
  161. Alternator bearings
  162. Quick question anyone can answer
  163. FSTB question
  164. Changing Camber and Caster without aftermarket bolts
  165. quick helpe removing o2 sensor
  166. Resolved : Fuel pump followup.
  167. Need a new shift knob
  168. Does Not Start In Cold Help Me!!!!!
  169. Camber Kits with Intrax Springs
  170. Too much color?
  171. exhaust stud aftermath
  172. throttle affecting temp gauge
  173. RARE JDM, EDM "stuff"
  174. Paint Questions
  175. bbk
  176. Engine swap ????
  177. stupid question removing intake manifold vg
  178. just got my girlfriend a new max
  179. whats wrong with my car?
  180. Where in the world is the mobil filter?!
  181. Transmission go Bye-Bye
  182. HEADLIGHT teaser
  183. Question about e36 headlights
  184. Considering a 93 GXE - what to look for?
  185. VE on spray...
  186. Engine Trouble
  187. WANTED: Anyone selling 3rd gen stillen lip???
  188. Curb Weight of '07 Sentra vs. 3rd Gen
  189. Anyone have a pic of 3rd gen in satin black?
  190. Rear Poly Bushing Separated
  191. Automatic Variable Intake Manifold Swap
  192. exhaust pipe, SE/VG
  193. Which is a better Idea?
  194. Engine / Transmission Spec Questions
  195. Loss of ShiftLock?
  196. what type of car alarms do you all have?
  197. Yellow Foglight Capsules
  198. Emission System Trouble Light
  199. thinking of buying a 3rd gen
  200. How to remove a sunroof
  201. Lucas Oils
  202. Who Still Has Their Original 4DSC Sticker?
  203. Rough idle
  204. Moonroof question-
  205. Who still has their original window sticker?
  206. Temperature Sending Unit
  207. Muffler
  208. anyone rolled there fenders?
  209. Will my maxima every need a valve adjustment VG
  210. No High beams ! Need Help
  211. Who has a Stillen FSTB on their 1993-1994 VG?
  212. Stripped bolt head
  213. HELP!! VE5spd
  214. Whistling sound
  215. turbo 3rd gens
  216. 05 350Z rims and tires on a 3rd Gen?
  217. bad lifters?
  218. Zomg I Love Ve5!!!
  219. Transmission gear ratios
  220. WTB: bose deck, I read the sticky, no flame please
  221. Possible to replace axles myself ?
  222. Not exactly the RR "The Spirit of Ecstasy"
  223. VE auto speed sensor repair
  224. ve to vq swap
  225. so i bought another max!!!!
  226. Time is Ticking Away =0 !
  227. RSB mod..:-)
  228. Video
  229. Negative camber. What could cause it?
  230. A little theoretical, but...
  231. Hey guys I need some help with timing
  232. SE vs GXE road noise question
  233. Posting pics
  234. Replacing rack and pinion...what additional parts do I need?
  235. fuel pump problems
  236. Wiring Problems
  237. Possible defective fuel filter?
  238. Starting issue.
  239. brake line part #........
  240. Theres something about...that makes me...
  241. New wheel setup
  242. Got a G-Tech Pro for the weekend, need 1/4 mile tips!
  243. Will A pathfinder VG30E work in my Max??
  244. Are my injectors good or not?
  245. Torque converter install help!
  246. Why Pay Money For Something Im Not Getting???
  247. ELECTRIC SUPERCHARGER:thoughts opinions
  248. Why I like my 3rd Gen
  249. Cruise Control
  250. Slow air conditioning leak
