- Shakey + pull to the left at high speed.
- recommended tire pressure for our cars?
- Idle fluctuates between 50-55 mph with throttle closed
- How long till it will die?
- Grounding Kit
- Technical IACV Question
- Parts just falling off
- Cruise control, 5spd swap rewire troubleshooting help
- New Interior (kind of)
- Is this how it ends?
- new engine
- Overheating; I think I know what it is.
- The great 3rd gen mileage thread :-)
- Temp Gauge Twitched & Stopped Working
- Front left axle replacement?
- Completely rebuilt RE4F02A for under $900
- do all 3rd gens have body colored mouldings on the doors?
- Wierd gas/check engine light problem
- Someone's bound to know this Bose answer
- Turd gen in the drain
- CV Joint boot torn...bad vibration in front end
- headlight question
- other engines in 3rd gen
- how bad is this tie rod?
- How bad is this bushing?
- small cold engine quirk
- Electrical Gurus: Got a nice little problem here!
- Attn, ColumbianMax, others that know how to get COLD ac
- Antennas
- So I got a new problem...
- test pipes
- Grinding/Grating noise from front tire after putting axel in
- Question for auto climate control owners
- HOT Engine
- Org for 94 SE front struts/shocks
- Finally installed a tranny cooler today.
- belt squeel maybe AC?
- Does your A/C work on your 3rd gen? How cold is it?
- 94 SE just died - part it out or just junk it? ???
- What a load of Cr@p
- Regional Meet (Nov.) Poll in S.E. Forum
- Finally Its in!!
- Search function dead, knock sensor Q
- Inner tie rod: How do you know if it's bad?
- dead cylinder
- Can R134 frigerant go into a 3gen gxe?
- maximum tuning is going to offer bulletproof auto transmisions
- Iac???
- stillen body kit
- quick q...
- suspension
- clack really, really loud---how long before BOOM!?
- Rear tails
- Rattly Sunroof Shade
- What spark plugs are in your Max
- Incorrect MPH readings after changing gauges?
- Adding foglights
- questions about car alarms and wiring them up?
- Alignment Issues....
- rear pivot arm?
- brake light
- Question....just got a 94 SE Auto VTC ticking...
- trick for repairing valve cover gasket leak
- Fan Speed 4 doesn't work. 1,2,3, are fine. Blower Motor Resistor?
- dead coil harness or something
- Lightweight wheels...
- You may want to check your car too
- paint job
- battery and E-brake light
- the life of a max maybe at end
- rim question
- FINALLY! The Max is back home...
- Ve30de Ecu
- The Ultimate n00b Question
- Trunk Idea
- VE30DE ECU Chip?
- ATF Fluid
- Home Depot Grill
- engine question
- Your feedback on springs.
- Cylinders 1 and 6 not working
- A max with a difference (or three)
- Transmission wont shift outta car after rebuild
- need AT Shifter bushing help
- 90 se, engine control fuse constantly blowing
- master cylinder w/ABS
- The P/N Thread
- got bored.
- Headlight problem
- Now "Stop" means "STOP"!!
- for those with 18's
- Tranny Shifting
- Strange front suspension noises
- slight issue
- problem with my gxe tear*
- Hid
- What is your gas mileage?
- Where the $%#* is my coolant going!?!?
- Warpspeed Ypipe hanger Q.
- Electrical Problem after Fixing AC
- Starter kit and Distributor cap and rotor
- Just Recieved VG Phenolic Spacers!
- never gotten so much love in one night
- Long Time Since I have been here
- Manual Conversion
- paint
- Need help with fuel filter
- tranny noise 93 ve 5spd
- Parting Out!! 1989 Nissan Maxima GXE
- clicking when i turn
- Goodbye fellow Maxima enthusiats.
- M buddies maxima is actin weird possible head gasket??
- They finally make coilovers for 3rd gens.....or did you already know that?
- CODE 15 Help!
- crap....my flux capacitor....no seriously.
- leak problem
- WTB GXE driver side taillight
- 1992 Maxima wont start backfiring HELP
- window problem
- Engine problem, help please.
- Went to Junkyard Today
- Serious question
- se or gxe grille? (view picture)
- TiMiNg BeLt
- Injector Insulator Leak
- Unorthodox Racing Pulley
- new struts, new noise
- 3rd gen runs, shifts, won't move.
- #4 cylinder dead, I need an electrical genius.:banghead:
- clarion wiring diagram- Active
- Different Bose Question
- VG knock sensor
- Best test for vacuum leak?
- VTC noise? or lifters? or timing chain?
- electric chalenge or dumb problem
- 19's
- Rust in rear wheel well = Useless seatbelt
- Quick Question
- Digital dash conversion
- fuel pump relay
- Plastic Cover
- new project with reflector plate
- Engine Oil
- 2 problems, with sensors
- VG to VE transmission
- Engine rough chuging when cold
- Plastic rivet part # & foam tape ?'s
- Blue LED's
- 3rd Gen Owner Age Groups
- engine stalling
- New big undertaking....R34 tails lights on my Maxima. Wish me luck......
- Brake and battery indicator lights on dash on.
- New symptom after Oil on Plug.
- I think MrGone needs to rejoin the club...
- Converting to power front seats...
- no ground clearance
- Good news, and injectors news?
- fuel injector leak
- Big problems!Maybe ECU?
- HIR bulbs, anyone have them?
- vacuum lines
- finally back up and running
- starting problem
- q45 retrofits??
- GD on Matt's LTB's
- engine still stalls everynow and then
- auto tranny shift lock thingy broken
- cruise control doesn't work, need rewire post
- strange morning startup
- What's she worth?
- instrument cluster swap
- after injector install
- before putting in new injectors
- rpm and clock
- RPM Issue...
- New Front Speakers
- Thinking of converting to SE gauge cluster, had a few questions...
- Speedo is not working.
- How is everyone?
- 1990SE : For those I never got back to....
- First Road Trip
- where is the trunk light switch
- Installed!!
- brakes
- Two Questions? Keyless entry & Grill.
- Interesting problem
- Size of rear rotors for BBK
- Fun With Starters
- koni struts...
- sluggish after long drives...
- My front right KYB-GR2 strut is dead after hitting a pothole
- Oil in #6 spark plug
- 2 leaks... which is the most important to fix
- black smoke from exhaust
- anyone know how to reach MyGreenMax94
- New Parts!!!
- Leaking something...
- Key Pad
- Car eating batteries
- Valve Cover Gasket-do I HAVE to change it?
- Need help and thoughts about overheating problem
- Power Sunroof into a non-sunroof car
- Question/tranny
- Splitting the manual transmission
- CAr Will Not Start After Injector Replacement
- Car has Slight Chugging Issue
- seat
- Help with vaccum hose part2
- passenger side window regulator/rail
- Help with a vacuum hose!!
- a/c R-12 conversion to R-134
- need pics of chrome intake mans and valve covers
- Apexi NEO on a VE
- Big Decision! Transmission questions
- Starting Problem
- Any Computer Chips Or Mods That Work
- sounds
- door locks lock after let go unlock....
- rear hub/bearing
- door pillars
- Use of gasket maker for fuel injector replacement...
- Condensor bolts
- wondering why their are not more ve's out there/turbo
- will car run with plenum off?
- I hate electroincs.
- trannys
- V-Manage from Greddy or Trust
- Taillight problem
- Bad injector? just great.....
- Clear Blinkers!!
- Control Arms
- cefiro body kit...fitment issues?
- engine conversion help?
- Left Headlight
- Steering Bushing
- injector orings
- Cleaning Injectors (Out of Car)
- My max
- Eliminating the VTC
- Pic of 3rd Gen keyless remote....
- How many miles daily...
- bored, made a vid
- Throttle Enigma
- I just bought some e36 and a upgraded to h7 harness
- ATTN: All 3rd gens NOT at Maxus
- Exhaust
- Control arm Bushings
- Grills
- connectors/tranny
