- valve train
- major major issues
- The max broke down today
- Cars Jacking point Bent?
- Need Head!!!
- Repair progress
- Replacement bulb type?
- Fluttering sound coming from engine - video
- Just did the LED swap
- VG30DETT swap
- Do the 91's come with cup holders?
- would this cause weird steering?
- High Speed Traveling
- I love to get high on raw gas fumes in my cabin. Anyone else?
- My first trip to a drag strip (video)
- Maxima Is Mine
- Short Shifter?
- What could this be?
- No one cares but I'm back
- How many 3rd gens is yours made of?
- changing battery
- exam this morning missed because car wouldn't start
- Corner/Turning Lamps
- Some electronics questions....stereo, alarm, lights, 5speed swap.
- righthand camshaft seal?
- 3rd/4th gen flywheel the same?
- ECM Trouble Codes
- cold start??
- catalytic converter ?
- working on shift_fast again today... half of it almost worked
- OoOooOOo!!... a pic thread!!!1! :-)
- Blinking Air Bag Light
- Exhaust Question
- HG repair attempt! - need advice!
- Dash Bulbs
- Blinking cruise light?
- WarpSpeed Y Pipe
- starter failure
- Heated Seats
- Instant power cut-off - and the fix
- Bleeding coolant
- 99 altenator bolt on to 92 VE?
- New Headlights
- WTF? v. broken ss brake lines?
- Engine stand bolts
- What's This Connector For?
- 2 Sexy Maximas
- Car Missing Slightly
- Headlight problem
- i'M aLL wIrEd uP!!11!!!!1!!
- OMG
- bought a twin cam motor and tranny
- Is this a tranny problem?
- Warning about the poly control arm bushings...
- 90 se having mild seizures
- small issue with headlights and interior lights...
- Glowing Gauges
- need input (no pun intended)
- Big(ger) Brake Swap
- [holy] sliding control arms [batman]
- New Car
- Ball Joints
- y pipe ?
- drop resistor before and after video
- Power Locks
- Cattman Y-pipe
- Very Sad pic found on ebay :(
- Fluttering sound on acceleration
- Replaced Fuel Pump...
- Adjusted Timing/Lost lots of power
- big work day tomorrow
- Uhh WTF window switch...
- Clogged Injector/Misfire/Injectors Click Fine....
- Bath time for the Maxima!!
- blown fuses
- 3rd Gen Lost Archives (eye candy)
- trying to understand VG EGR variations
- Auto Climate Control
- Transmission
- Blown Head Gasket?
- another speaker thread
- Speakers for front doors.
- Keyswitch?
- power valve sticky?
- New TPS possibly bad?
- New Springs
- Weak E-Brake/Back Brakes(might not work)
- stock upper intake with T/B
- full set of seatbealts
- E36's and Amber Euro corners. w/ pics
- headlight housing discrepancies
- Leaky sunroof
- Tachometer works on and off?
- Digital AC Screen
- Major Headlight Issue!!!!!!!!!!!!!!!!!!!!!
- Wires hanging down on driver side?
- VE30DE in an s12...old project, bringing out new ideas...
- SOLD. But.
- another cv axle saga....
- CV Axle Emergency (Help!)
- Cigarette Lighter
- to all the jewish 3rd genners have an easy fast
- fixing coding issues.......
- Just got hit
- Made a sharp turn and....
- Cold Engine Dies When Put in Gear?
- possible bad engine/tranny swap
- power window problem
- SS Brake Line
- Window
- timing chain tensioners and VTC springs
- Tire question
- Z31 Turbo engine swap? '94 GXE
- BATTERY OR ALTERNATOR???
- headers vs exhaust manifold
- couple exhaust questions, plz
- ABS breaking braking.
- 91 gxe ps hp hose.....
- Catalytic Converter?
- really dumb headlight problem help plz
- A little help for those doing a 5 spd swap...Part numbers and Diagrams
- dont know if this is a transmission problem
- Electrical Ideas
- Yay. New Wheels.
- Keyless Entry with remote on OEM?
- crazy sway
- Weird Headlight... (I wouldn't say problem?)
- rear disc swap, plz
- Jumping beans
- audio wiring diagram plz
- heater not working
- Drop springs
- Wiper problem
- Rear jiggling
- Who is the Aaron92se of the VG world?
- Firewall engine motor mount
- what's your mpg reading?
- New Strut Bar
- were gurgling feeling.
- Bleeding ABS brakes/installing Actuator
- Need help trouble shooting!
- Electrical Problem
- Intake outtake
- Need suggestions for stereo replacement
- need help identifying this part.
- 89 Max ABS Pump Over Ride
- control arm fiasco
- pics of clutch line cooler mounting location?
- identify a plug??
- Got my muffler
- Radio wiring diagram
- Steering
- The bumpers metal part.
- Rear Speakers/Wires
- Automatic sunroof
- Help! Leaky Sunroof in Florida Storms!
- Pimp My Ride Stole My front end!
- Smokey third gen.
- gauging interest: 3rd gen A/T tiptronic system
- A/T power switch
- how to remove valveboby from auto trans?
- Just did a transmission drain and refill
- fog lights
- NEED HELP NOW/Door lock circuit on my table.
- HELP!!! Transmission swap clutch pedal wiring question... auto 2 5spd
- Power Door Lock Timer
- Rear brake pad
- How to tell if power antenna is Working
- Brake Leak/Rear Brakes
- Mass air flow sensors
- discrepancies in VG oil capacity
- Opinion- Buy '92 SE5 as parts car or fix-n-drive?
- Coilovers
- this is what happens when i get carried away
- low idle, hard to start cold, wants to stall.
- a little more right direction on e36
- Factory Head Unit Options?
- just checking on e36 conversion
- Cooling Fans
- Should I.........
- body parts- GXE to SE
- Digital Fuel Sensor
- pulse spark plugs?
- Poly want a maxima? :-)
- knock sensor help
- pics of wash day. (repost)
- Maxima misfiring?
- Gas tank leaking?
- Dash light comes on when brake is pressed
- whats needed for 5spd swap
- I can smell petrol when i drive
- Yay, New Car. (Kinda?)
- the trunk
- crank pulley damage? replace?
- Is my throwout bearing on the way out?
- maxima or UFO?
- relocated coolant overflow tank.
- Performance and MPG affected by ECU tinkering
- Why is my stereo so quiet?
- mouse in the engine!!!
- weird
- 44psi
- cleaning iacv, do i need to buy a gasket first?
- 1992 SE Auto yep i got another maxi
- Cai
- air bag component location?
- Electrical buzz from tranny
- Automatic in a VG SE
- Depo e36 euro + tsx projector retro!
- Installing Fog Lights
- I found out how to make the clock white
- Accel problem
- Power Steering leak: advice from old people
- Need help with a problem
- CV Axle Problems
- Side mirror replacement question
- got a small exhaust leak/crack.. can't find it
- Finally got em and installed em! pics inside
- Have you ever noticed.....
- Simple question, or observation..
- vg30et swap
- oil change problem, maybe
- Sometimes transmission lets me shift quickly but other times I have to force it...
- Transmission flush
- Rear Exhaust Manifold studs
- cv joint info
- jwt cams
- Inexpensive Parts
- Storm damage
- Weird Request for those with E36 lights.
- This morning
- Pinging
- so finally....some body work (pics)
- Has any one lost there key?
- jwt ecu
- Bose died...
- 2 Pics of my 94 GXE with 19's
- Interior pics of my $500 Maxima 56k warn
- what is maximum overbore of the VE block
- fighting with the max
- for a VE DOHC injectors question
- What a load of Cr@p
- It's magic :-)
- How to install This Spoiler
- installed stock winger-ma-thing
- Install help....blehmco parallel links
- A lil day of boredom. [pics]
- VE or VG
- VE Died on Hwy, Fuel pump cover to blame
- put 19's on my max but rubbing an issue now
