View Full Version : 5th Generation Maxima (2000-2003)
  1. Can I remove the painted part of the side mirror?
  2. Air intake
  3. Front Strut/Shock recommendations
  4. billet grille help
  5. passenger side motor mount
  6. Strange clicking noise from brake pedal
  7. Hi my fellow Nissan owners
  8. CEL codes and my mechanic
  9. Replaced IACV and ECM is fine "2000" I30
  10. hid kit/ halo question
  11. ABS light on but no codes
  12. Again.. Yellow FOGS
  13. Mmmmmm, MT-85 :)
  14. Adjustable Rear Links Will Be Available Soon!
  15. Power Steering Hose to Rack
  16. How can i report members on the org?
  17. Front license bracket?
  18. Who is the Weirdest G-Hustler Regular
  19. Radiator Issues
  20. TCM problem?
  21. Cracked GPS screen
  22. What is the best 2000 5spd. Rebuild kit?
  23. new exhaust
  24. 2K3 Maxima Tuning...need opinions!
  25. Need some Brake Pads!
  26. cleaned TB + relearn + success + failure?
  27. cat back with magnaflow?
  28. random question
  29. New Member Saying Whats up!
  30. What's wrong with my headlights?
  31. Just a simple question about my climate control...
  32. 2003 Maxima audio upgrade
  33. 6 spd swap into 5.5
  34. NEED A EXPERT HERE!!!!!!
  35. 2000 MAXIMA TRANSMISSION FLUID
  36. 2000 Maxima Motor Mounts.....
  37. 2000 Max 5 spd. Tranny Issues
  38. 2000 Maxima Won't Shift Out Of 1st Gear Sometimes (Auto Trans)
  39. Question
  40. Oil issue...please help
  41. A/C delete on 5th gen?
  42. anybody try the B&M knock off or Ralco RZ short shifters?
  43. Transmission or MAF?
  44. Is there any difference on body trim between 2000 and 2003.
  45. Spark Plug Question?
  46. Berk!!!! where are youuuu!!!
  47. HELP! Car runs like it has no power and is LOUD
  48. Jack stands driving me nuts
  49. yellow fogs
  50. Hybrid Tail Lights?
  51. Replacing drive belt - pls confirm
  52. APPS Question
  53. Mishimoto Radiator with 12" Blue slim fans
  54. anyone else have a 2000 SE with NO sunroof?
  55. Why cruise control, WHY? (cruise top speed)
  56. Ball Joint and Tie Rod Kit For 2002-2003 Maxima
  57. New 5th Gen owner needs help....
  58. does anyone have a blown up diagraim of the 3.5L engine
  59. Buying a 2000 Maxima, but has P1320 code
  60. Radiator Question
  61. Can anyone tell me what wrong?
  62. What's with the lousy oil dipstick measurement?
  63. Radiator Support rusted out
  64. Tired of these vibrations!
  65. New Owner of a 5.5 Maxima
  66. Can we ban phatboi to open the ghustle thread plea
  67. I don't have the fastest 5.5, but come for me anyways
  68. Alternator Wire Harness Connector?
  69. Proud new owner of a 5th gen
  70. 5.5 Gen - Random (electrical) Power Cutout
  71. help me!
  72. Transmission axle seals.
  73. IACV Help
  74. another tcm question
  75. 2001 Max stops shifting or jumps out of gear help!
  76. Jumped battery and screwed up...
  77. Idle Surge @ 1500 - 2000 RPM (01 VQ30)
  78. Can I get away w/o the IAVL procedure on a 2k?
  79. Lug Nut Torque Specs
  80. Intake info
  81. Quick question on ES LCA bushing install
  82. Can't get the 2002 Maxima auto trans valve body to reseat
  83. Codes P1490 and P0446...Searched like mad, still no idea
  84. Engine knocking
  85. head units for 2000 maxima
  86. Fuel Tap - Wet N2O - 5th Gen DEK
  87. 2000 maxmia need help please
  88. What to look for when buying a used auto trans
  89. Strut mount question
  90. anyone have these wheels on their i35/i30?
  91. Tuning
  92. new grill
  93. Just a quick question about my tranny
  94. Buying a replacement IACV, do I buy the entire valve assembly?
  95. Where to begin?...Audio?
  96. Is the tube supposed to be connected to something?
  97. 2001 SE Starting Problem
  98. 2002 infiniti i35 timing chain noise?
  99. Engine struggles when driving slow, and stalls when in park?
  100. Looking to replace my windshield wipers...what do I get?
  101. Intake Valve Timing Control Cover ???
  102. Loud tappet type noise upon start-up
  103. Inner CV axle installation
  104. Shifter Knob Moving Around While Driving Normal??
  105. Catalytic converter or 02 sensor?
  106. Question about Factory Installed Anti-theft/auto start.
  107. Car has been running crappy, intake breather issue?
  108. New 5th Gen. Quick Question.
  109. spacer question
  110. Spirited driving: Which gear do you use?
  111. idler pulley replacement
  112. For people running Headers or Gutted Precats.
  113. Distraction= oil starvation and engine damage
  114. 300ZX Caliper Adapters
  115. Back after a long time down.
  116. Best Tires for a 2000 SE? R17s
  117. Steering Wheel Question
  118. 2000 Maxima Odometer issue
  119. Alternator question, 110amp vs 125amp, 02
  120. How do I find the vacuum hose thats connected to the air control valve?
  121. How many 02 sensor
  122. need help with tranny
  123. 2001 Maxima CD/FM Display not working. Help ?
  124. Help-Cling cling metal sound when turning
  125. Help Windows not working!
  126. Does ECU Reprogram Include Idle Air Relearn?
  127. Car died while driving, but mechanic say's everything is fine
  128. What in the world would cause this?
  129. need help got a code p1165
  130. Be Careful who you trust working on your car!!
  131. Warpspeed v Cattman
  132. 2000 check engine light on
  133. Aftermarket radiator hose fitment problem?
  134. automatic seat doesn't move back 02 AT
  135. p0112 & p0127 After Changing Air Filter
  136. Intermittent Rough Running
  137. Throttle Lag
  138. Transmition slip 4sp
  139. Anyone try Ebay Engine mounts/Shocks ?
  140. Replace Axle or CV Joints??
  141. Rear door won't unlock/open
  142. This can't be good can it?
  143. Juke rims on a '02 Maxima SE?
  144. 6mt Shifter cable issues
  145. Changing a wheel bearing?
  146. Power differences
  147. Y-Pipe/Exhaust Question
  148. Need new catalytic converter
  149. Need some SES Light advice please
  150. 2000 GLE trans in 2002 SE
  151. Stillen lip
  152. P0505 - High Idle When Warm
  153. 2001 - Collant overflow tank boiling gurling. Overheat.
  154. Car driving extremely sluggish and boggy after a oil cooler gasket replacement
  155. My DIY mirror signals and puddle lights
  156. Will a 4th Gen exhaust fit 5th gen?
  157. What is this bolted to the motor?
  158. Manual conversion ideas
  159. Car starts, but dies right after 2k2 AT
  160. Intense sulfer odor when redlining motor.
  161. Wheel noises: CV Joint or Bearing?
  162. Gauging interest in VQ30/VQ35 long tube headers..
  163. Rattles from back brakes...I assume
  164. Finally doing Upper Oil Pan Gasket: Need help
  165. Any performance loss AFTER oil cooler gasket change ?
  166. Best power mod I've ever discovered!
  167. Figured out what was wrong with my AC
  168. Vq35 ticking
  169. Would this work???
  170. need to fix b pipe flange what size adapter?
  171. Where to buy mods in Adelaide?
  172. Buzzing noise when pressing gas pedal
  173. 2000 passenger side motor mount
  174. XXR 527 18x9.75 ~~~ too aggressive?!
  175. OBX R EXHAUST 2002 MAX
  176. Replacing front struts
  177. Starting/Sunroof woes
  178. Parking light on the rear
  179. Suggestions on a B-Pipe?
  180. Idler pulley tension effecting alternator?
  181. HELP! Tracks to the left under acceleration
  182. quick question about purchasing a y-pipe
  183. considering to buy a 5.5 gen, IS oil burning as bad as they say?
  184. Need more guidance on removing the EGR tube
  185. Throttle Body sizes
  186. O2 wire help!
  187. 2001 maxima resonator pipe broke at back flange
  188. 16 inch tire on 17 inch rims cause shaking?
  189. Spark plugs? 6240 or 4469?
  190. Engine need replacement
  191. Tranny going or salvageable?
  192. P0505 Code
  193. Confused??? Making a SRI
  194. 2000 Maxima SE (MT) 173K Miles VIAS Problem
  195. Parking Brake won't tighten any more
  196. Lot's of CEL Codes - Any ideas what the problem is?
  197. Cattman 3" + RSB
  198. Rattling-timing chain?
  199. 2003 Maxima GE stereo speakers cut out
  200. DISCOUNT CODE for V-Led
  201. *Need help - Replacing front struts... WHAT ELSE SHOULD i REPLACE WHILE i'M IN THERE?
  202. Tire size and steering repsonse...?
  203. Broken lug bolt studs:
  204. headers??
  205. after mkt subs 2 a stock clarion headunit?
  206. Gas question
  207. engine mounts
  208. Rear sway bar
  209. Motor brakdown
  210. tuning maxima step by step instructions?
  211. DSS Axle broke yesterday (pics)
  212. Spacers fitted=stitches
  213. 5 spoke or 7+
  214. Leaking Trunk Resulted in Bath Tub-effect in Spare Tire Well [Pic]
  215. subs
  216. leaky trans
  217. Opinions Needed Please
  218. Bogging under load (New MAFS, IM Gaskets...) Help!
  219. Code PO335 CPS and P0725 help.
  220. Frequent alignments?
  221. Hood struts
  222. Question about MAF/IACV/ECU in 2000 Manual Transmission
  223. Some Tire Advice
  224. I need some advise please
  225. Clutch Replacement- Help
  226. Back home now.. What to do with the maxima?
  227. I Pissed off my Max (kicking codes)
  228. location of Output speed sensor circuit in Maxima 2000 model
  229. grinding sound from engine
  230. What oxygen sensor is best for my 2000?
  231. FINALLY! The Plug and Play Haltech for Maximas! Serious tuning , all info inside!
  232. Issue after cleaning upper intake manifold
  233. Cleaning the connector contact
  234. MAF question...
  235. Mysterious popping noise
  236. A/C Issues, as Acceleration. Related or Coincidence?
  237. hmm just day dreaming here
  238. intake manifold
  239. Aftermarket rear spoiler
  240. Pre Cut tint ? anyone tried it ?
  241. 2002 Maxima VIAS box location???
  242. PowerSport slotted rotors: Brakelabs
  243. Overheating. Relatively Urgent!
  244. Removing secondary bank 2 O2 sensor on a 2003
  245. Manual Trans Drain Plug part #
  246. radio, clock, and park light
  247. help diagnose my fuel problem
  248. State Tint Law Summary Table
  249. Bad/clogged fuel injector symptoms?
  250. SAFC 2 AFR and larger exhaust
