View Full Version : 5th Generation Maxima (2000-2003)
  1. Roaring noise. Wheel bearings?
  2. bad radio reception
  3. repairing heated seats
  4. power valve question
  5. Fascinating... P0430
  6. Bose System
  7. Navigation question....
  8. re-aim fog lights?
  9. For members with D2...
  10. Volume Cut valve, or New ECU?
  11. P0134 P0135 P0154 P0155 [scanned the service bulletin as PDF for everyone]
  12. 2001 AE bodykit
  13. WE GOT CODES.. Dammit
  14. Replacing the fog lights on my 00 Maxi
  15. posting pictures
  16. 2000 GLE shakes after getting stock with no gas
  17. D2 Coilover Question
  18. $488 for a MAFS installed by nissan!? :ekk:
  19. Starting question
  20. intake
  21. Moisture in Headlight 2001 Anniversary
  22. The Dreaded P1320 trouble code
  23. PIC of my new window spoiler
  24. tell me what i need to do
  25. Does non-professional service void warranty?
  26. Frankencar exhaust and D2s installed
  27. Mevi?
  28. Variable Power Steering
  29. fog light question
  30. power seat question
  31. question about warantee
  32. Need Help in Tuning w/SAFC-II on '02 6 Speed
  33. Engine hesitates upon hard accel, tranny not slipping.
  34. obx b-pipe fit stock exhaust?
  35. Ebrake boot question
  36. 2000 se no floor lights???
  37. eurodezigns h3 6000k???????????
  38. Codes - 1320 and 0302??
  39. Anybody added a heated steering wheel?
  40. Newb With a question
  41. Proximity Sensors
  42. Wheel Alignment Tip
  43. Are all 5th Gen Exhausts the same?
  44. Top Speed
  45. Just Passed Emission Test
  46. 411 on ca to fed spec conversion
  47. Maintenance needs at 35K - Basic Warranty about to expire
  48. 2003 TE Purchase possibly????
  49. Clear corners
  50. Removing sticker/line going across
  51. TS ECU for 5th gen auto
  52. Brembo X drilled/slotted breaking noises?
  53. Possible VIAS Problem
  54. In-Cabin Filter
  55. Top Speed in Gears
  56. Synchros
  57. Electric Shock
  58. Automatic Trans Problems
  59. Audio system or heated leather...
  60. painting bulbs chrome?
  61. H&R or Maxspeed?
  62. what material is our hood?
  63. maxima detailing job.
  64. ses question
  65. Starter Motor, DIY ?
  66. Can this Changer Fit my Glove Box
  67. Hot damn car feels fast
  68. Need Advice on warranty issue or not...
  69. Install CD changer in 01 w/Bose?
  70. Thought on Spark replacement
  71. rear cattman exhaust
  72. Thinking about new shocks...
  73. Has Anyone removed the fog lights with the MT lip?
  74. Any way to substitute precat with regular pipe?
  75. auto grinding sound?
  76. New 5th Gen Exhaust?
  77. newbie question - RPM meter
  78. Muffler valve
  79. is this stupid? HEadlight housings
  80. New to the VQ: Have Mass Air Flow issues. HELP!
  81. Permenant Ink on Engine Cover - Went Postal on Oil Change Place
  82. Aluminum dash pics
  83. anybody know the r+r procedure for bank 2 precat?
  84. Anyone have Yellow Fogs on their Maximas?
  85. SES Light - Front Tube Assembly ?!?! O2 Sensor?!?!
  86. PCV valve pics not showing
  87. 02+ 3.5 videos?
  88. Fuel injection flush, engine flush, throotle body sumthin
  89. Tail light ideas?
  90. Street Scenes Grille
  91. Pics of Projectors
  92. for those with hid fogs
  93. header install question?
  94. took some pics
  95. i think the dealer tryed to kick my....
  96. Just pop the needles off my gauges...?!
  97. Spark Plug Replacement, Mucho Dinero?
  98. Bad oxygen sensors
  99. service engine light
  100. Ringing Headlight Noise
  101. Need direction rear wind noise
  102. vq35 y pipe questions
  103. '02 headlights
  104. couple of questions
  105. lower just the front?
  106. Taillights and LEDs - is it possible
  107. painting the engine cover
  108. wheel alignment?
  109. Auto Valve Body Shipped?
  110. Headlamp housing
  111. How do these cars handle in the Winter?
  112. where to buy NISMO exhaust hangers?
  113. Mechanic Guru's Please Step-Inside. P0100 code
  114. CEL on for half a day. P0135 code, but now the light is off.
  115. Might have a good deal for someone if they can answer this
  116. Found a way to get a new paint job!
  117. 'Speaker Noise' W/ Rear Defrost On...
  118. TCM Needed
  119. Lookoing for a max with Tein H tech drop
  120. Engine Stalling
  121. HID Theft Deterrent Kit form Courtesy Nissan
  122. HID Theft Deterrent Kit form Courtesy Nissan
  123. how to increase better gas mileage
  124. What light bulb numbers for climate control, radio, power windows, and instr cluster?
  125. Looking for custom 2002 Grille....
  126. Power Steering question
  127. 2000 avg. hp # for mods
  128. Anyone know where the trunklight is on 2002???
  129. 01 reverse indiglo gauges
  130. anyone have the custom maxima kit?
  131. ECU reset ??
  132. Things to look for when buying
  133. Replacing my headlight bulbs
  134. Brake pads/rotors, suggestions-recommendations needed...
  135. Custom grille is DONE! (56k = rot in hell)
  136. Changing Fog light bulbs on 00
  137. Difference between SE and GXE muffers?
  138. ebay cold air intake
  139. Completed the drop! See PICS :)
  140. Check out this maxima..
  141. Time for some suspension...
  142. Stock 2002 SE Suspension...
  143. Quite muffler
  144. maf, upgrades?
  145. How to pull engine Codes on 2002 Max
  146. I'm new,so forgive me :)
  147. 01-02 CD changer swap?
  148. AE headlight installation question
  149. Replacing stock Bose HU only...
  150. WHAT IS THE DIFFERENCE OTHER THEN 80 Dollars???
  151. 2002 - Service Engine Soon Light
  152. how to: install TTz calipers
  153. Stillen Y pipe Making Noises?
  154. Exhause Problem
  155. Timing Off.
  156. 2000-2001 maximas with driver side tail light out
  157. Any bad reviews on a nissan maxima
  158. Calipur Bracket Bolts.....So hard to come off
  159. Pics of new paint job!
  160. H4 xtreme white PIAA, weak high beam.
  161. Any such beast?????
  162. 2000 Maxima Headlight Mods
  163. clock doesn't work on 2002 max
  164. Homelink Doesn't Work :-(
  165. Changed main cat still car smells, time for new precat?
  166. best brake pads for my 03 max
  167. Shift_?
  168. Spoiler Light Wiring ?
  169. PO306 code on 2K SE 5spd-need help
  170. hyperground wires for Maxima?
  171. Cobalt Gauges!!!!
  172. Tcm?
  173. New Pics of my 19 inch rims Camra in the trunk!
  174. Do I need a new Catalytic Converter???
  175. JIC owners step in Please
  176. Clear Side Markers?
  177. Just curious what I should pay.
  178. Midnight blue or Black?
  179. Serious Question
  180. Wheel wells and painting lip ???'s
  181. Bose amp wiring diag on 2k
  182. Rewire to work windows without key in ignition?
  183. What break pads and rotors to get.
  184. Front Wheel Well "loose clunk noise" wheel well...advice?
  185. Prime oil pump during oil change?
  186. rimz and suspension
  187. Those who have changed your rotors...
  188. Remote stater on Manual Transmission Pro-Install
  189. Performed 60K tuneup today
  190. afraid my wheels are gonna fall off
  191. Hmm, what to get? 2000 Maxima
  192. Wiring Diagram
  193. AE headlight mod, anyone has them?
  194. Rims can't come off
  195. how much do the 17 INCH ALLOYs weight?
  196. 5th GEN MAX engine light prob
  197. Is It True??
  198. TTZ Calipers
  199. clear HID's? Help please?
  200. Question - STILLEN RACE PIPE 95-01 MAXIMA - MILD STEEL
  201. crystal ball fogs..............anybody have them?
  202. 02-03 Maxima Short Throw Shifter
  203. Question for guys with auto tranny.
  204. e brake light won't go out
  205. New Car Scent !
  206. My max loves cool air!!!
  207. Illuminas for 03 MaX / Part #?
  208. Anybody know if the 3.5 maxima and 3.5 350z engine use different size pullies?
  209. Tokico Blue and Eibach Pro
  210. Throttle plate restrictor mod feedback
  211. Maxima vs. Murano brakes - Murano feels better...
  212. New Personal Best at the Track!!!!!
  213. AC Blower "relay" Problem
  214. oil change
  215. parts for the car
  216. Installed DMS PULLEYS!!!!!!!
  217. Me v. GTP NEW PB 13.93 @ 100.96 mph - Video
  218. Talk me into buying this Maxima
  219. Bad to engine brake when neccessary?
  220. dash kit for aftermarket H/U
  221. brake service prices?
  222. Is Using Emergency Brake Bad to Stop the Car?
  223. Hids more yellow than other maximas.Why?
  224. A question about spring rates for D2 coilovers
  225. Need How-To from STUDMAN for the Viper 791
  226. I'm still around and...oh yeah...SSR's for sale.
  227. Fuel Filter How-To
  228. Anyone with 20mm spacers/ Stock wheels and Lowered?
  229. Clearing HID's with no lens
  230. Help! What's up with the clear coating? Ruined paint.
  231. oil change?
  232. Perf Chip
  233. ECU error code
  234. Newton Meters / How to convert to ft. lbs. of torque?
  235. Check engine light is on
  236. just ordered clear corners
  237. 2003 Maxima Brake Rotors...
  238. Creaking noise from suspension?
  239. cheapest engine mods?
  240. Possibly Blew Master Cylinder
  241. lifter rattle
  242. even tint idea
  243. What is a drop resistor mod?
  244. Easiest way to rolling fenders is to use a baseball bat
  245. Testing coils and MAFS
  246. Steering radius...
  247. Apex'i filter....worth it?????
  248. anyone been hit with Higher insurance?
  249. somethin might be wrong with my engine!! :( Mechs come in.
  250. I'm the newest 5th gen Owner
