- Low RPM idle.
- PPL with autostart . step in PLease.
- Lights dim when idling
- terrible gas mileage combined with my tranny weirdness
- auto---manual swap quick question
- Cheaper Alternative to AE door sills
- Refine the quality of your 5th gen...
- Speed Control Volume on Type A Radio?
- ABS and unusual brake noise
- Plug change with NIssan coupon
- Check out this max on Ebay
- Mass Air Flow
- Installing Sirius Satellite Antenna Recommendations/Help
- stock brakes
- where do u guys buy your in-cabin filter?
- D2 Coilovers???
- Re: Front Strut Tower Braces
- car is driving like ****..
- Any good and cheap/decent paint/body shops in NY?
- Question about 02' suspension.
- Knocking on 01 Se
- Oh man, Redline MT-90 rocks.....
- 01 cf trunk??
- Rear wheel bearing replacement question?
- Brake pads and rotors
- double clutching?
- Smelling gas / oil / exhaust in the cabin?
- Code 1320 fixed by dealership for $50
- Intermitent tail lights
- CD player issue
- Sunroof Problem!
- replacing shift knob
- PR CAI vs BERK/FRANKENCAR
- Check Engine light just came on.
- subwoofer tube or box??
- Any issues with 19'' wheels on maxima?
- coilover question
- rotors 2002 se problems
- Question on tweeters
- Intake Breather Hose?
- resale value
- Has anyone bought or installed these??
- bulb sizes
- Clearing the headlights
- pics of cai
- Illumina or Koni ?
- whats the word on the cryo2 kits?
- ECU in California - 2000 SE
- '02 Leaking Valve Cover?
- grill mesh
- Help. Steering Stops Creak?
- Dimensions of 5th Gen Hood
- Buying an 02 SE should I purchase extended warranty?
- will this work/look right
- any 5th gen running 225/55/17 tires with drop?
- frankencar exhaust
- P0456 Very Small Evap Leak
- Headlight Moisture 2001 Anniversary
- To the owner of the silver 5.5gen SE with angeleyes in LOUISVILLE, KY....
- need help with fog lights
- burger logos
- Loud Noises when turning the wheel all the way in each direction...
- valve body
- 2K1 Tranny swap
- Which wire is GROUND on 12-pin CD changer harness?
- Please help, LED question...
- Front lips and rear lips for a 00 max
- Bose Subwoofer question....
- Cold weather starter noise!
- Brembo stock number...
- MAF Part # For 01 (Need Someone 2 Confirm)
- Window motors slowing down
- DVD/Navigation System
- Finally got them dark tails...
- Lowering Springs W/ Stock Shocks
- What's the correct part # for spark plugs?
- need new muffler. suggestions please!
- vq35det?
- called NISSAN for BOSE system... and guess what?
- To anyone with a Berk Intake
- Jerry Rome All Season Floor Mat Help!!!
- intake quickie sorry for another one
- GLE rims, 18"
- 2.5 or 2.25 inch stock cat?
- tb off a pathfinder
- 02-03's...who has the JWT flywheel?
- polarg bulbs
- TRYED to clean throttle body , help please
- Nissan Calipers..
- Could This Be A The Tranny?????
- Hood Vibration
- cut stock coil
- Beware before going to the track
- anyone with a P0140 CEL?
- Rear bumper
- is it worth the 6speed?
- PCV Filter
- Stock Intake Whistle??
- Minimum brake disc thickness?
- New issue of Super Street recommends the 5th gen
- Any idea of rough start in the morning?
- My Maxima Engine is shot after 57k miles
- 03 SE Suspension Tweaks
- Intake manifold whistling since CAI install
- Eyelids for 2K
- Please read...
- Show me pictures of your aftermarket HU install!!!
- HELP - maxima losing power
- FYI - new hyperground setup for VQ35
- Replacement Python Remote
- Starter causing a rattle at startup?
- 02-03 diff?
- Need some advice
- Nissan Stereo Aux Adapter
- Driver side power window wont roll up.
- Blown maf before or after adding aftermarket intake?
- Highbeams work, but lowbeams don't..
- whats the best catback and cat to get, where?
- Steeing Wheel Audio controls on early 5th gen...
- Updated pics of custom grille (Two hi-res shots)
- Cracked orange marker lamp, suggestions?
- 03 Max vs 04 Mazda S
- how to tell need replace belts
- 2000 Maxima with timing chain or timing belt?
- LED install...
- Better to Rent or Drive my car
- Cold Weather Gas Mileage
- Mid-pipe only on 3.5L?
- How to on painting OEM grill...
- my cali spec car
- Projector Headlights from Custom Enterprise
- Anyone know how to reset the airbag light on an 02?
- Just realized something serious/bad
- rear brake help needed....
- heated seat Switch light bulbs
- Where's the best place for alignment
- Where to get Maxx Tuning front lip?
- ABS on the blink....please help!!!
- 02 HID Headlight Aiming
- My Max told me........
- What does the BOOST SENSOR do?
- Brake Question
- 02 Maxima Brake parts.....
- problem with my car...
- Just felt like sharing (purchased PIAA GTX)
- Crazy sound when i make a u-turn
- another intake thread
- Best Brake Pads? - (Daily Driver)
- Rusty fuel filler door hinge
- Tunning Question
- Repairing my 2k3 Max, what mods do you recommend over stock?
- Jetta Vs Maxima?
- Where to buy lower-grille? (Diamond cut)
- '02-'03 Max most stolen car...
- 03 dash problem
- Windshield replacement ???s
- Average Life of a 03 SE?
- Need Some Advice, please. Pricing question..
- WEIRD tranmissions behavior just now
- Wanna new grill
- Cool sound, but what?
- Just got the 5th Gen
- best aftermarket brakes w/o goin big?
- help, no power after 5k rpm, strange exhaust sound
- G-style02max Pics Smaller
- brake and battery light
- G-style02max Pics
- Driving too fast, nailed the brakes, TCS light, ABS light and SLIP light turned on.
- Spark plug change out
- speed govener
- Clearance light install
- Projector Headlamps Question
- Anybody have Illuminas & H&R springs & getting noise FROM rear?
- Suspension Help
- Crutchfield Faceplate Kit
- SES light Pulled P0174 code
- abnormal shifting of auto TSB...DENIED...
- pics of CF hood
- why is my back lower than my front
- new owner of 2k se
- car parts.....
- Navigation systems in 2k-2k1?
- Intake Anyone???
- 2k2 high beams
- 2002 manual fluid change
- computer chips
- Looking At A 2003 SE
- Whistling noise from timing chain area
- puting reverse indiglo on...
- HELP! Car is shaking. Engine light is flashing
- Which on is 'Bank 1"????
- ?? about brakes
- I've Decided Tein H-tech and GR2
- anyone know where i can get one of these?
- Cattman Or Frankencar???
- Interior smells like sulfur esp when heat is on. HELP!
- Where is the fuse for traction control?
- Cattman Exhausts???
- Digital Climate Control on a SE?
- Idle air volume learning procedure
- www.Nissan-techinfo.com
- DaveB saves the day again (Spare tire trunk cover alternative)
- Problem with the interior lights
- 02-03 Auto Tranny Reliability ?
- Weird shifting and car stalling - help!
- p1456
- Thinking of a getting remote start
- Who has cut a coil on their Eibachs?
- gimpy cd player
- Best Roadside Assistance Plan
- SES Light just came on - what to check?
- High cost of keys
- Cattman exhaust
- 5th Gen audio guys help!
- N00b question
- 00-03 Front Fender?
- G35 rotor question
- Headliner removal...anyone done it?
- Maf and Throttle Body
- synthetic vs. dino oil
- WSP Y-Pipe, 2.5" B-Pipe w/o Resonator w/ stock muffler, NOT the sound I wanted HELP!!
- Searched For Info
- Should I switch to high mileage oil?
- 6speed or bike
- Bulbs Keep Burning Out?!?!?
- painting engine cover
- 2K SE- want factory grd. effects
- Need Spare Key
- Sell my Place Racing CAI or not POLL
- Hotshot header owners step inside
- '02 Frame or Subframe problems
- Changing pass. side brake light
- Magnaflow resonator Q
- Do all '02s have 60k mile powertrain warranty?
- Cleaned T/b WOW, RPms.
- '02 Buzzing/Humming noise from pass front
- Cheapo XM radio install ideas
- What is this....
- Pathfinder Throttle Body?
- In Cabin Microfilter
- Installed Tranny cooler!!!!
- 02-03 Short Throw Shifter
- Will This Be Your Last Maxima?
- Gauge Bulbs
- How much Torque on Lug Nuts?
- Ever had this happen to you?
- hi guys, quick question about switching gears between 3 and 4
- RSB Install time
- Radio, Clock, and Horn doesn't work........ Blown Fuse?
