View Full Version : 5th Generation Maxima (2000-2003)
  1. Sigh.. Chain Tensioner bad?
  2. RPM Switch for VI Activation?
  3. power seat stuck..............
  4. Upgrading Suspension - Which Mounts?
  5. ABS Sensor for 2001 Maxima SE rear left
  6. 01 Auto Climate Control not blowing cold air
  7. Possible Clutch issue?
  8. 6th Gen Front Brakes?
  9. Ceramic Coating & Cattman Headers
  10. How do you clean an injen CAI filter?
  11. Anti-freeze on floor board, and hesitation when cold
  12. headlight flickers
  13. Fog light/Fuses
  14. problem with Locks and Keyless
  15. Knowing the Model Year is only a starting point
  16. transmission slip?
  17. Custom 3" Exhaust
  18. Front/Rear bumper removal
  19. Transmission connectors mounting plates
  20. I NEED HELP!!!!
  21. 03 Maxima front suspension noise
  22. Steering wheel controls
  23. CF Hood - which one do you guys like?
  24. Lowering Car
  25. Pressing bearings
  26. OBDII/DLC Connector Terminal L? (For ABS check)
  27. question on aftermarket springs.. ?
  28. 2002 GLE and 1999 SE: wheels interchangeable?
  29. How-To: Maybe a solution to CD skipping
  30. What is the black plastic box under the trunk? driver side?
  31. Ceramic Coating Exhaust and Rust?
  32. what my hs y pipe looks like after 3 years in ny..
  33. HKS rear section
  34. Mixing synthetic 5w-30and 10-30 ?
  35. My car hesitates at full throttle!!
  36. Underdrive pulleys
  37. 6000k?
  38. Couple of Problems today
  39. what MP3 adaptors will work with the stereo in my 2K3 Max?
  40. Dim Angel Eyes?
  41. LOUD NOISE COMING FROM REAR DOOR WHEN I UNLOCK
  42. How to pull ABS codes?
  43. Hood Vibration 2001 Max
  44. Location of all O2 sensors?
  45. Replacing LOW SIDE A/C hose
  46. Replacing radiator, what do you use to plug the transmission cooler lines?
  47. 03 GLE Price Question
  48. Reliability...
  49. LED's from V-LEDS....
  50. Spray Tint
  51. New ecu, fried in seconds....
  52. Polishing the 5.5 gen intake manifold
  53. IACV gasket part number?
  54. HID Ballast Mounting
  55. Valve cover install
  56. Ball Joints
  57. Transmission?
  58. 04 sunroof visor work on a 02
  59. 5.5 Gen Rear Lug Stud Removal and Replacement?
  60. Black lips and side skirts
  61. y pipe and headers from 3.5
  62. I'm looking for an old Friend white AE 2001 max
  63. 02-03 Testpipe Installed
  64. Need to replace passenger rear door actuator
  65. Stillen Classic Lip vs MaxxTuning Lip
  66. p1147 02 + stealership
  67. trouble with remote program
  68. Taking Full Advantage of a SSIM?
  69. Questions..
  70. Rear Main Seal?
  71. 1990 Flywheel on a 2001 SE?
  72. CENTER CAPS FOR G35 Rims
  73. Cold Start stalls...
  74. creaking noise from?
  75. Timing Chain Dealership Experience
  76. It was the wheel bearing and hub
  77. Car wants to stall when starting.
  78. Max Factor "rides" magazine?
  79. STS for 2000-2001
  80. spring rubbers to stiffen your spring rate
  81. Where in our keys is it safe to drill a hole?
  82. Brake Upgrade Recommendations - 2002 5.5 Gen
  83. So i entered my first auto-x
  84. Did my susp. this weekend....but
  85. Chinese rotor question (repost)
  86. Is this causing the noise Im hearing in the transmission? Help
  87. Brake Pad ?
  88. Quick question about axle removal
  89. Sunroof Tilt Seal
  90. Clear Head/Tail Light Covers
  91. One headlight won't turn on, lamp and fuse are fine
  92. Installed my COSMO CAI, today
  93. Replacing Radiator Fan, noticed this?
  94. How long does an oil filter last?
  95. Megan OE RS for Canadians!
  96. ES Shifter bushings
  97. Suspension Shopping List?
  98. New TCM To Fix Hard Shifting?
  99. Real weak FM signal.
  100. Poll: What tuning devices is everyone out there using?
  101. POLL: Headers vs. Stock Manifolds - Weight Savings?
  102. First CEL? What to do.
  103. windshield trim question
  104. Titanium Edition interior trim
  105. Where is the 2K2 Front Bumper Swap Instructions??
  106. How do you take off front and back side markers?
  107. replaced ABS speed sensor now Cruise control don't work
  108. Who has re-packed their bearings and is it DIY worthy?
  109. What other years did the auto LSD tranny come in?
  110. Cattman 3" catback
  111. wtb/.. center wheel cap
  112. Where are the 2K1 to 2K2 Bumper Replacement Instructions?
  113. headlight depot HID's vs OEM
  114. 00 Max Failed emissions (CO)
  115. 4th gen progress RSB?
  116. Brembo Brakes
  117. Nismo black ball shift knob, will it fit?
  118. BAD COIL
  119. Rear speaker stoped working, any ideas?
  120. BATTERY DIED NOW LOCKS & REAR DEFROST.............
  121. Rear brake job... help
  122. Bosch Generic or OEM O2 Sensor?
  123. Clutch Bleeding question
  124. Intermittent code 1320 experienced
  125. bottom radiator support bracket
  126. Can u/have u changed frt sway bar?
  127. Annoying catalytic converter.
  128. Codes P0440 & P0420
  129. ONLY GRINDING INTO 3RD. NEED YOUR OPINION PLEASE!!
  130. weird noise from front left...
  131. Cattman Headers, Fastcat, Catback Full Exhaust Only
  132. 5th Gens "Dropped" Thread
  133. Wheel clearance question!
  134. wanna go lower!!
  135. maybe a maf prob?
  136. Blemco, Z32 Calliper Upgrade BBK
  137. Adding TCS, a few Q's
  138. My LED mod for tail lights
  139. Where should I buy good headlights?
  140. Tire Shopping
  141. Rear Bumper Grommet?
  142. NISMO 380RS Gas Pedal
  143. Lost...questions on VQ35 6 Speed Swap on a 2000 5th gen
  144. wheel spacers
  145. grill-tech
  146. vfiber kombat nose
  147. tint the inner taillight
  148. tranny issue...i think
  149. Driving Without Axle-Back (Muffler)
  150. Odd knock or pop on the passenger side
  151. Installed Illuminas, Eibach and Progress RSB. Sub frames next
  152. performance ignition set?
  153. Bose and wiring harness?
  154. Headlight Bulb?
  155. running lean and rich at the same time?
  156. 5.5 Gen Navi?
  157. Reverse, pop, then sounds like the tire is flat but....
  158. Rumbling sound from heater
  159. Bad strut /strut mount at only 56k miles???
  160. Using Toyota oil filter for Maxima?
  161. Just resurfaced the brakes
  162. Auto Tranny issues
  163. led size?
  164. Bose Radio not working after disconnecting battery? Not a fuse problem
  165. removing the c/v axles help
  166. Im out an HID fog light,.. buy another 3000k or buy(2) 5000k to match the headlights
  167. HID'S
  168. show me ya grill!!!!!
  169. 3Bspec foglight install question
  170. cleaning intake manifolds
  171. Ultimate Tune-Up
  172. maxima bose sub/ g35 question
  173. Odd Starting Issue (MT)
  174. How the F*** did i screw up installing clear side marker lights lol
  175. this sound sucks... help
  176. Ever seen an in-cabin filter with 200,000 miles on it?
  177. idle problems in gear (thump/kick/chunk) 03 AT
  178. Starting Problem
  179. 03 MAXIMA VSS WIRE LOCATION
  180. 2k2-2k3 retrofit turn signal wiring
  181. Whats more worth it?
  182. Noisy Console Shift Interlock on 2K3 Automatic
  183. New Maxima, new problems!
  184. Q45 calipers over stock 5.5gen rotors
  185. Ball joint install
  186. Location of Paint code on our cars??
  187. Hotshot headers installed
  188. LM4519 - Unibody Jack Stand Adapter
  189. 2002 Maxima 17inch SE rims on '02 Altima
  190. speedo reading off
  191. Complicated window switch problem, Experts help please!
  192. 5.5 gen fog lamp replacement
  193. Locking Differential?
  194. SE-S or SE-L?
  195. Door Clips
  196. Shopping around for clutches
  197. walling trunk
  198. Gas tank fill-up ?
  199. looking for led conversion pics!
  200. All Maximas 4DSC's?
  201. Dose anyone have this key?
  202. 00-01 getting a 3.5l?
  203. subframe bushings?
  204. New Owner, odd issue
  205. squeaky sound on turning need help
  206. Removing tint from tails
  207. Wheel bearing problem?
  208. New roof spoiler
  209. 5.5 gen camber ?
  210. Clear Door Lenses??
  211. anyone running faskbrakes 12.6" 4 piston caliper kit?
  212. Rear clear makers
  213. Brake Pedal Pressure Issue
  214. 5th Gen Aftermarket Headunit and Other ICE Pictures
  215. 5th Gen Bodykits, Lighting, Exterior Modifications Pictures
  216. NEW STICKIES in Progress - Need Your Help
  217. Thump sound coming from rear of 00 max
  218. turning and makes a metal on metal noise
  219. 5th Gen How-To/DIY
  220. 5th Gen General Information, Maintenance, and Common Issues
  221. 5th Gen Modifications
  222. TSBs, Owners Manuals, Recalls, Repair Information, Part #s, etc
  223. Rpms high on parkway?
  224. Ticking/tapping noise
  225. best intake for the 5.5
  226. ahhh I miss my maxima
  227. Front and Rear side markers
  228. Wiring 5.5 headlights
  229. Swapped Motor Problems?????
  230. satisfied gransport 6 pads
  231. WTF is this stuff on my oil dipstick?
  232. P0139 and P1147...
  233. 00MaxSE project2 headunit installed (pics)
  234. Coming to a hard decesion...
  235. 02 to 03 Trade? Opinions?
  236. Miles required after SES Codes Cleared
  237. Turn signals issue
  238. Header Install, Rusty Header Stud Issues
  239. 5.5 Gen OEM Navigation Install?
  240. Front marker wiring got stripped off during a fender bender ... what parts do I need?
  241. What do you think of warpspeed's ypipe good or bad?
  242. So new headlights.. Just not fitting
  243. P0302
  244. this may be the audio wiring diagram?
  245. help! vavle cover replacement while putting on NWP spacers?
  246. what are the two sensors that are fan switch
  247. Spacers and Vias installation/deletion today!
  248. kinda dumb question about my 00?
  249. maxima mirrors
  250. Aftermarket replacement parts?
