- Rough shifts between 2nd and 3rd gear, is it my tranny?
- We Need These Cool Signal Mirrors!!!
- Help on new car.
- Need help. I stripped a screw
- My dvd player headunit install with tek-niq!!!
- how do i post pics in threads cuz i wanna show pics of headunit install
- Need help with Code PO172 and PO175
- shakey car
- Budget y-pipe dyno
- Timing belt, chain belt or both?
- Pics of my new Hid's
- sts best one for my 2k se
- Need some Tech help
- Is this true or is the dealer lieing???????
- Bose System Problem Comment (im aware of problem and tsb)
- Traction Control
- can't wait till monday
- silver dot on new ignition coils?
- Z32 brakes on 03 max..
- Daytime running lights stopped working
- Anyone get a CEL after underdrive crank pulley install?
- P1320 pulled...sh*t
- Bad power seat switch???
- finally found a max
- fuel filter making noise
- Projector Headlight MDX retrofit..Writeup!!!!
- What are the best all around wiper blades?
- Is this a good dollar amount???
- 2k max GLE Ignition Coil problem?
- Lots of new pictures of my car
- P0139 +P1147 = Heated O2 Sensor bad?
- 5.0 & 5.5 gen oem suspension swap ???
- MY 2K2 ...thoughts...
- See My Pics on My Sig...
- Just bought mine for my birthday
- Shift Knob replacement?
- Need opinions on next Project car
- I need a rear muffler section for a 2002
- Stuck (frozen) windows
- Tought time starting
- Really DUMB LED and filament heat question!
- Just got back from dealer regarding P0420....
- i am about to look at MAF sensor...any tips
- Will SES light ever turn off???
- help this prob is driving me nuts
- Are xtec 6000k d2r's a lot dimmer than stock d2r's??
- Throttle Body Info Needed
- What does System lean and bank 1 mean??
- SES Light On...
- 3 wire or 4 wire 02 sensor.
- Black Factory Wheels?
- Rattling noise in blower
- Spring..what do you think of these
- any ideas?
- Haven't started my car in 2 months, need help!
- Intake.. Stillen or Jim Wolf
- Body kit question for 2k3 owners
- which optima battery fits 02 max?
- Non-Bose Stereo Question
- 2k and 2k1 seats
- Jet V-Force Module
- how much to paint?
- Whats wrong with my car!!!
- Help with headlight covers
- Ignition Coils 2000 max HELP!
- HLSD rules
- Both foglights cracked again
- Cruise control problem??
- Gas Mileage Question
- Help! Need a brighter reverse light
- are my brakes/calipers sticking?
- VQ35DE Question For Anyone Who Knows...
- cool backlights?
- Keep or Take Off VentVisors?
- hp/torque comparsion: maxima and 300zx
- Does the VIAS issue apply to 5.5 Gens as well?
- Oil pressure gauges
- WHEELS & SUSP. INSTALLED..1 PIC 4 NOW
- who has the best prices on piaa h3 bulbs?
- keep pulling po420
- What pulley????
- Energy Suspension Bushings
- good deal just one problem, help!
- High Beam replacements?
- 2000 Big Problem?
- Got the TSB done to take care of P0420, now it gives P0430?????
- What kind of bulbs to use for auto shifter light?
- Anyone with photoshop?
- Best clutch on a 5th gen
- Those with FIAMM air horns, PLEASE HELP!
- Please Post Pics of 5.5Gen tails on 5th Gen (Silver)
- 2002 Maxima -- Clicking
- Do I have a belt going?
- Installing dde's question
- How to change front corners
- ddes for 2001
- Need a group deal on Illumina Struts??
- xenon super white Xe install
- Which piaa h3 lights are the closest to our hid headlights?
- 60k mile tuneup...best plugs? wires? what do I need? Checked stickys already
- Auxiliary Fan Motor Problem - Not Sure
- motostorm UDP
- What do you think
- Finally Lowered...Settled...Updated...*PICS*
- headlamp covers
- Belt # for UR Pulley???Help
- Tranny Slipping?
- Harsh start ups
- P0420 and O2 simulator soln
- rsb or pulley???
- Gotta love a new MAFS!
- Help - Sudden Significant Gas Mileage Drop
- Potential 01 Maxima owner
- Strange sound when cold!
- lowering
- suspension between 00-01 and 02-03
- Any differences between 02 and 03?
- adding projectors to stock housings
- Idle Air Problems - P0505
- Can't get my calipers off, got any suggestions?
- Just Completed Hyperground....thoughts
- Has anyone ever had to get a transponder key made?
- STERLING MIST Maxima's with Bodykit, Rims, Lowered
- Blown IAC, ECU, battery and ABS sensor.
- Guess what i found today?
- Altima quicker?
- From FLA to NYC! Here's a picture!
- front strut bar install??
- Egr
- Clutch Line
- How to translate VIN #
- The Best Air Intaike??
- Has anyone AE'd their 02 tail lights?
- Vibration
- Doing my front brakes.... NEED HELP!
- Wiring for Seat Heaters on my '00 SE
- Pulleys
- Security Codes On Head Unit???
- O2 simulator
- Y-pipe failure
- Mechanics, please step in...
- Clicking in back brakes?
- 2k owners with headers step in
- Max in super street
- Will 5th gen 17's run w/300zx brake conversion
- The Great Radar Detector Thread
- No more Gen I MAFS, NIssan is using Gen II now.
- HID question
- Anybody have this exhaust setup?
- Where to get 2001 front lip CHEAP!!!!!1
- BMW and Mercedes OEM Parts + Free Shipping !
- high flow cat
- Brake Work
- Could someone please run a carfax for me?
- Question about Bose HU, No, not about speakers cutting out...
- SES code *P0171*
- Autoluminaion LED owners, STEP IN!
- what tools for coil/spark plug change?
- Resonator?
- Fuel and Oil Pressure Gauges
- people who are lowered step inside
- Tein H Tech 2k3 Max
- Location List???
- Paradox Touch Up Kit
- Glove Compartment
- O2 sensor
- Hi there !
- pictures of window visors please
- where is my ECM?
- Manual Radiator Fan?
- a little help. quick
- side marker bulb question.
- Which size HID Bulbs?
- how do you rate your max in the snow?
- Apex'i Exhaust...?
- Finally lowered...*PICS*
- orange bulbs for front side markers
- parking lights????
- HELP! Bad gas mileage & KYB humming noise
- New Wheel Question
- need help, car is making a wierd noise from the front right vents/fan, any ideas?
- new y-pipe = no headers?
- Spark Plug Question
- Squeaking Noise/front Driver Side Wheel
- Deflectors?
- Wierd happening today
- MDX projector retrofit - pics!!!
- 02 HID's without highbeam
- obd port - Where is it?
- Data Dots
- Alignment after drop
- MT Lip installed *PICS*
- Another CAT Conv brand question.
- Clear Bra pics anyone?
- P0011?
- Anyone using a bored out throttle body?
- Where is my IAT sensor plug??
- Internals of 5th gen MAFS in 2k2 MAFS, possible or no?
- Some 2002 Questions
- Signs of a bad MAFS?
- 2K Subwoofer not working.....
- Thinking about upgrading...
- New HIDs
- Problem with remote trunk release????
- P0140 Oxygen sensor problem
- FYI-Online Parts Discount.
- Hid Bulbs for 2k2 maxima
- Engine Dress up/Sound deadening
- cat back... any good? asap
- Spoiler L.e.d.
- Question for those who swapped headlights to the 5.5 gen
- Price for AE lights
- How Can I Detect A Defective MAF?
- 02 6 disk changer problem, any answers?
- Headers?
- Shift_brakes!!!!
- how do you know when timing is going?
- Request: Pictures of 300zx wheels on 5th gen
- Picking up my 2002 SE tommorow pics!!
- Info about Limited Slip Differentials and more
- Best tint for Sterling Mist...
- filter box cracked during MAF install
- P1320??
- Exhaust Question....
- light bulbs
- fstb installation
- 2001 SE Alternator and Belts
- cattman vs budget ypipe
- transmission
- I need more power
- help...noise from suspension!!!
- Pictures from ECES 2005 Car Show
- rear window spoiler...
- HELP!!! Maxima totalled...
- WTF is wrong?? Please Help!!
- Vacuum ported fuel pressure regulator???
- Problem
- Programming Homelink to work with apartment entrance
- 2002 SE maxima auto stock 1/4
- Tranny Flush with Pics
- Projectors or AE?
- is there any way to have our computer read out different data
- Tire Rotation
- Child Safety lock problem
- All red 2k2-2k3 tails
- who knows how to program garage door buttons?
- Rear Anti-Sway Bar
- B-pipe with all other exhaust OEM...
- Leather seat covers, will they fit?
- Video clip of my exhaust
