- Remote Start ???
- Which one is Umnitza 6000k Kit You be the judge
- Need Fast Response
- Metal shavings in my transmission - help
- ordered MAF sensor
- Steering problem
- Replace headlight bulbs 2000 max
- Serious Issues with Budget Exhaust (long)
- Struts with Factory Springs?
- fuel injection cleaning
- Can you break loose in 2nd? (6-spd & 19's + Opinionators)
- MAF help
- Paint/Install Kit PRICE! GOOD DEAL?
- hid headlights
- JIC FLAT2 settings?
- Whats a good Strut bar?
- Top Speed?
- Newbie here, questions about some probs.
- Regrets On Dropping?
- heated seats schematic
- Bad MAF. mostly cured pinging and hard shifts
- Ecu?..5geners Step Inside.?
- Venom 400..Will it work
- Anyone Use Touchup Paint Pens?
- factory springs
- ? about heated seats
- Maxima and Infiniti I30 part numbers??
- FSTB how do they work?
- Anniversary Edition Items?
- were my coils replaced?
- I think I've decided on my springs/struts
- Can I convert to climate control?
- squealling, squeaking brakes no judder
- Cabin Filter
- H&R Wheel Spacers Coming In!!!
- Coils and BAD MPG
- Awnser me this......
- Clicking sound from left front
- New rear pads - is this sound normal?
- 4 th windshield on my 2k1 max wtf...
- suggestions need on shocks/struts
- Drivebelts...hmmm
- Smoked taillights?
- help!!!!!!!!!!!
- clicking after shut off???
- advice i am getting MAF sensor
- I guess I need brakes? If so, which pads?
- Finally pictures before and after repairs on 03 SE
- Possible MAF Problem: Manual Tranny!
- I dont race , but need good handling, what strut/spring combo i need?
- Denso Iridium spark plugs overkill?
- strut question?
- How to get MAF?
- Maxima sound clips
- Stolen HIDs
- INJEN = Pingining Sound?
- 00-01 SE's have dark taillights?
- Data Dots...WTF
- Clear coners removal
- times on the 1/4 mile?
- G35 Rims....on!
- Dip stick trick
- Is this a MAF problem ???
- gr-2 or illuminas
- Blown Springs / Alignment Problem
- 2000 Nissan Maxima Putters
- Lightning audio Maxima pictured in Modified Mag
- At a loss on the 2k Max (misfire)
- any one have the alex pepper odb-ii scan tool?
- Interior fan noise
- crank sensor?
- 2001 AE Y pipe, Federal Spec / California Spec???
- 2000 maxima throttle hesitation
- Cruise control issue?
- optima red to
- H.I.D bulb question
- Want quicker throttle response 5.5 owners , do this...
- Blue light vs. Purple light in Umnitza X-Tec kits?..pic comparison
- My Transmission, R.I.P...
- sway bar question.....
- Steering wheel shaking, please help.
- Technosquare ECU for a 2000?
- O2 Sensor Question.
- Filters and intake.
- Unidentified object in engine bay
- ECU upgrade.
- where to jack up car?
- What needs replacing to make suspension quiet again?
- Another Brake Problem...help Immediately Please!!
- Keyless Remote Instructions...Help
- Weird Y-Pipe Sound...Need Some Help!
- ok i know no one wants to show these but
- SES lIGHT!
- Who's interested in blue radio/door lighting?
- XD Rotors?
- strut bar and sway bar....
- Import Tuner Bash Cancelled!
- Show me your engine.
- stillen battery hold down
- optima red top vs factory battery
- Odometer/Speedometer Cluster Lights... Out!
- e-brake cable removal from rear caliper help again!!
- pros and cons for dropping max with eibach or any springs
- HID Question!!!!
- Chiltons Equivalent?
- Heated Mirror question
- 2002 maxima
- 5.5 gen...any of you have this yet?
- Weird sound with clutch in
- Upgrade help
- Ses ?
- found my favorite exhaust setup!
- Which mod to do first?
- "How Many Miles do you Mod?"
- Cheapest source for iridium plugs?
- Brake replacement problem...HELP!!!!
- Hesitation Problem
- Front brakes...Push or turn caliper piston in?
- Valet Key Stolen
- Engine just shuts oFF!
- has anyone changed rear break piston dust seals?
- Passing Lights question
- Injen filter sucks what are you guys using as a replacement?
- HID lamps for a 2000 maxima
- 6spd owners, how is the 1-2 shift like?
- Spark Plug Miss?
- People with sterling mist painted tail lights...
- 350Z rims in the year, rub or no? (17x8 -- 33 offset)
- Important Reminder...
- Adaptive Auto transmission on 5.5 gen?
- Suspension Question??
- kyb gr-2's and maxspeed springs?
- Light/wiper switch swap 2k1->2k3
- Any interest in a Custom Gill
- Anyone have problems with...(y-pipe)
- Pics of my ride with new Z rims
- Follow up on Daiyama Coilovers
- Installed Injen Intake Today
- D2R Retrofit. Glare or no?
- cylinder misfire
- Sucking water into the engine!?!? Cold air injen users step in.
- I think I broke my car tonight :(
- Maintenance...
- Accident... Damn
- What is the duration/miles on the Factory waranty?
- Question about lowering
- Anyone modify doors?
- Sunroof Problems
- Removing cheapy plastic
- Ebay headers + y-pipe
- anyone still need their factory intake?
- automatics
- How long will it take for my coils to finally go out?
- ARGH ....Tire Decision time....please help
- Dash Clock Removal
- Any information on how G35 gets 298 HP
- 2.5" vs 2.25" cat back exhaust
- MAf # 22680-CA000
- Wheel Bearing on 03
- Swaping main Guages
- surface rust
- Stock 5.0 gen headers...
- Engine Stalling on start up
- Fog Light????
- motor mount question
- Owners of the ViS CF hood
- switching hid bulbs to 8000k??
- fog lamps for evo5 front
- What is the difference between jic a1 and a2?
- Exhaust Gaskets
- Anyone have their oil light flicker quickly when they start up?
- help! oil pressure light!
- BlehmCo kit Pics
- insurance not replacing my headlight and bumper with OEM?!
- Opinons..
- help..2000 i30t Xenons problem..
- Looking for a Junkyard
- o/d light
- HEADLIGHTS acting funny
- Repeat problem with delayed shifting
- A new MAF sensor fixed everything- slugish,pinging and shifting - all gone
- Dealer lied to me about warranty ?!?!?
- yet another MAF question
- How About This Strut Bar?????
- need help
- I hate JIC Magic
- Maxima color codes?
- VIS R-34 Conversion body kit??
- Trans problem?
- Rear brake caliper installation - any gotcha's I should be aware of?
- Fog light installation - instructions link not working
- This cracks me up......Re:Nissan Service
- does any one have any 2000 interior pics
- CANADA Dealers overpricing MAF's on purpose?
- Where to buy chrome guage rings
- Steering Column Issue Requires Airbag Removal
- Pic Post finally!
- How can I tell if a 5th Gen has LSD?
- which way should the slotted rotors face???
- Home made AE headlights.
- First front brake job... problems! Arrggghhh
- motor mounts for 2001 Auto
- Anyone have problems with front tokico hp struts?
- Some more new pics ladies
- exedy clutch
- Looking for part # for a K&N filter that fits a PR CAI
- HID in 2001 headlight case?
- Staying with the BLACK theme....
- weathertech window guards
- ae pedals. where?????
- Goin to the body shop...
- how far can i go?
- +20 HP Speed Chip found in ebay
- what's the sensor in front of air filter????
- New Gauges On 03 Max
- how is your car in the snow
- anything else other than niteshades?
- Brake accessories?
- Accelerator stop
- rear turn signals
- Anyone have Philips Blue Vision Bulbs?
- any classic STILLEN KIT PICS???
- Anzousa.com projectors for 02 max??
- hid foglight/headlight q's
- need clutch recommendation
- If you have any kind of BBK (inc Blehmco) step in...
- 2k2/3 6 speeders, step in please!
- Coil part #????? 2000-2001
- Front End crash rating on a 2000?
- For those of you who've had the VB Mod for over a year
- Is this a good price?
- 5th Gen with Murano 18's?
- Long term advice needed!
- Towing Capacity
- Does any company make a good dash mat for the Max?
- Are there any links for adding a dimming mirror to a 2K?
- Question for 5th Gen Maxima owners
- yellow fog lights??
- Best Wiper Nozzle Light, where are you?
- Courtesy Max Grounding kit a33 3.5
- FIRST LOOK! SSR/SFR Turbo Kit for 5th Gen
- Just Repainted Bumpers with Pics lQQk
- Does anyone know what kind of adhesive Nissan uses...
- Re-routing high-beam signal to fog lights?
- HID's....kind a new look?
- LED switch over
- Driver Side seat died
- Where are the brake bleed screws on 2K?
- Which is the 4th cylinder
