- Trade my ES engine mounts for your OEM ones
- Hit some deers, poor baby
- suspension help
- Weird problem
- Replaced Fuel Filter, Car Won't Start!
- WWANT TO CHANGE FROM AUTO TO 6SPD
- JDM oil cooler leak
- Debadge
- WTF???
- what exhaust should i get?
- Interior Removal
- Bump steer...how to get rid of it?
- HEADLIGHT MOD: BLACK OR CHROME HOUSING
- plzz dont say cats again !! ??? help
- Rear Brake Job: Comments and Questions
- changing battery cables?
- Cruise control problem
- HID HILOs Problem
- 00 SE weird acceleration?!?!
- One, just one splash guard needed
- thinking about healight mods (clear, paint, LED)
- Clutch pedal In = noise at idle?
- Fuel Door spring
- Flashing Check engine light
- VAIS Fix
- Installed HKS axle back and am very pleased but...
- Extra Keys how much
- Auto trans/MAF problem when cold?
- have you flushed the power steering fluid
- Slave Cylinder Install
- O/D LIGHT FLASHING NORMAL??
- 01 ECU question
- engine codes
- Dealership replacement parts...Strut mounts vs. strut bearings???
- Rear window spoiler install
- Replacing Strut mounts without...
- Can I combine Tein H tech with Tokico Blues or KYB GR2?
- LEDs in gauges
- Will these muffler fit?
- anyone used this before??? nissan bose radio replacement converter
- need some help / advice on interior lighting...
- shift knob
- KEEP LOSING THE SOME COIL HELP!!!!
- transmission failed today..just got rebuilt
- Just purchased ASA IS6 17x8 ET35 20lbs each, but...
- Need help locating Idle Air Control Valve
- DBA's Rotors
- Steering wheel controls... Help
- Strange problem with Auto
- Knock sensors from 4th, 5th, 6th gen's.
- Grind down the intake manifold for a Stillen FSTB?
- Great Website for Nissan Part Numbers
- Caliper Question
- Spark plugs
- Security key lockout...
- Whining noise after cleaning the throttle body...clueless.. help please..
- SES P0464 fuel level sensor intermittent
- Desperately need swaybar endlink help...
- Did a few things to the max over the last week. PICS
- Car not starting .. clicking noise from relay HELP
- Loud whistle/squeak during sharp right turn
- its not the timing chain?
- Help replacing ABS speed sensor Snapped off
- will headers and y pipe for a 95-99 maxima fit a 2001 maxima?
- Aftermarket Hood fitment
- Carbon fiber trunk alignment.
- Nissan Radio swap??
- 5th gen lugnut thread pattern question
- Testing 03 Auto @ Houston Raceway Park
- Quick ? regarding 00-01 taillights...
- oxygen sensors?
- Car keeps shutting off randomly..HELP.
- 2002 tranny codes any help would be great
- Maybe a hole in exhaust?
- 00 se bose help! no sound after pothole!
- Need a Hamburger :( Anyone?
- 02 maxima high idle...
- with Illuminas & ss lines, steering pulls, clunky noises
- time for a spring refresh...
- Distinguish a 22680-AM600 MAF from a 22680-6N201
- Sorry to do this but where can I get replacement clear corners?
- Just got my tranny rebuilt
- Bad accretion at high RPM Problem HELP!!!
- is tis exhaust setup good?
- 17" 03 TE Rims on my 01 GLE is Rubbing?
- Stillen intake
- OBX Headers and NWP Spacers....
- What?? More leaks??
- WTF is this noise? Video
- R.I.P. 2001 GLE :(
- Pre Cat ???
- Manual tranny for 2000 maxima
- Do you have a squeaky/rattling front end? Read this.
- Headlight Restoration Kit?
- So how would I go about to fix this
- ABS Noise and Light
- JWT intake and HKS Sport rear section question
- Poor acceleration ONLY after warming up (2003 Maxima)
- Long Term Ownership Assesment
- 2 alarms..
- Keyless Entry / Interior light issue.
- o2's gone, need help locating
- Muffler/B-Pipe Flange
- Power Door locks stopped working
- Dropped off the car today (Header and Spacer Install)
- Grounding kit problem
- Weird Knocking Sound
- *Need Advice* Sick of Coilover --- WANT A SMOOTH RIDE AGAIN!!
- Strut boots and mounts with new suspension...
- Cold Start Grinding Noise
- are there any relay's for te cruise control if so where?
- Weird sound on passenger side suspension
- Rear Brakes
- Anniversary Edition passenger CV Axle
- Check engine light on = gas cap loose or massive leak HELP car smells like gas
- Muffler Removal help!
- hole in the exhause or .........
- Wiring VAFC on 5.5gen
- 13" Wilwood BBK, need 5 to commit
- 4th gen brakes= fifth gen?
- 00 Max shuts off while car is in park.
- tokico illuminas vs Teins coilovers
- how to get new alarm remote to work with car
- To reprogram, or not to Reprogram? O2 P0138 Question
- DTC 31 (P0100) issues...
- AE engine cover
- Replaced control lights and now blows hot air
- 100,000 Club
- P0506 .. need help please.. on a 02 SE auto maxima
- euro tails
- Noise during start up
- Engine pinging is getting worse!! Why?
- Car shuts off while driving? tps??
- navi headunit Help
- P0327 low input knock sensor
- Do I need a new TCM?
- Car now feeling slugish
- Where is the best place to buy these tailights?
- Project Max finished
- new maxima issues
- Info on changing rear ABS/Wheel Sensor on 01 please
- Different front/back Tire size?
- Catalytic converter question
- Auto tranny swap question.
- I Rear ended someone.
- Barely squeaked by on my yearly emission test
- Oil leak from valve cover
- Apexi Neo - Where is its place?
- Opinions Needed
- Can't seem to find stage 2 clutch for 5.5 gen
- '00 Tranny swap - stock exhaust: What's gonna break in the swap?
- Headlight Disassembly - Oven or Heat Gun?
- cel PO174
- How would I find out who has my old car?
- Lets See Those 00-03 Maxima Pics w/Carbon Fiber Hoods
- Power Windows
- HELP - failed emissions
- Spare Tire and Accessories
- High Beam Issue
- The last time Navi ashtray mod. (Clear pictures)
- Need Inner Tie Rod Tool - Richmond VA
- How wide can we go? (tires)
- Will a 2000 Y-pipe fit a 2002 Maxima?
- Help finding Navi Headunit
- Need ES Inserts Fast! - Where from??
- Foglights....
- P0430 code aka CAT needs to be replaced
- To those with a tune...look what the MN tuners said..
- How to get started with the code searches?
- I guess I have to drive more than 55 miles after an ECU reset to pass emissions
- Something that made me smile
- OE Speedometer calibration question
- Tranny replacement quote (NY)
- Rusty bolts on power steering?
- Aftermarket Bump Stops ((H-tech/Tokico HP))
- Squeaking sound when shifting in cold day
- o2 sensor question
- Got new set of wheels
- 01 transmission flaring (vids)
- P2138 code
- skipping....someone help
- Is there any truth to this?
- I want a OEM Navi
- Front Suspension Noise *Creak*
- Tranny repair shop
- Funny Liquid sound... Help
- Everything you ever wanted to know about spark plugs, and maybe more...
- Strange creaking noise from the front
- Online Source for Part Numbers?
- Est. how many tenths with a TS ECU reflash
- p0403 from ecu swap
- has anyone swapped out their dash/climate control lights to LED's?
- Idle'ing issues and CEL light after changin valve cover
- Good looking DIN radio install kit??
- 2002 SE missing bad - help
- Can I get a honk?
- A few control lights out, ideas on how to fix
- P0300 misfire code. All the usual suspects check out OK...
- What's considered "highly modded" for a 5th/5.5 gen?
- Still bad mpg...im out of ideas
- Could these spark plugs be bad???
- You know gas prices are too high when...
- Does anyone have/know where I can get sidemarker clips?
- erased code never came back...nothing wrong?
- Replacing Lower Oil Pan on 5.5 gen.....Anyone?
- Brake squealing/hissing halfway to work :(
- P0171 from bad gass, is it possible?
- If I upgrade to '02 side skirts can I keep the rear Mudguards '01?
- Epic tie bar fail......
- Vaccum Leak???
- to those with s techs springs
- Trunk light out
- Strange mechanical beeping noise when turning off car
- Eibachs + Tokicos = Loud Noises at Full Lock
- broke front left A-Pillar. what is part number? where to buy?
- power steering pressure hose leak
- I'm Back!!!
- No start...towed
- Stillen header question
- 2000 electronic motor mounts
- WTB fog lights 2k2
- End link question?
- 2000 SE - 160K Impressions
- bad motor mount = hard getting into gear?
- Is my radio going out????
- i need help
- 03 rocker panels, 4 mud guards, & front badge= 900?!!
- BIG Install comming soon!! Need some help with finding the right things!
- Coils and Plugs not the problem....??
- VQ35 falls on its face.
- REPLACED BRAKE PADS!!! HELP!!!!
- WTB 2000-01 Front bumber
- Raybestos pads/rotors
- strut mount question.. i know its been beat to death
- anyone know where to get an 03 titanium edition ghost chrome wheel?
- Will the 2001 mudguard fit on an '03??
- gap between headlights/bumper 2002
- Automatic Engine Mounts
- At 123k miles on an '02 Max, is it a good idea to...
- Need Fuse Help
- Two part question re: p0138/139 and Federal Emissions or Cali
- Please help..Need help indetifiying a part
- Which rims should I choose?
- Squeak, Squeak (Another Suspension Noise)
- '00 Two new dings on fresh painted (tri-coat pearl white) hood!!!! Crap-ola!!
- Solder, crimp or caps?
- 5.5gen auto leather boot
- Need Help: EGI Harness?????????????????
- Custom Magnaflow 3" Exhaust INSTALLED With Pics and Video
- oil drain plug washer?
