- Newbie here!! Whats up guys?
- Wtf?!
- Urgent Recall Notice!!!!
- rear deck rattle/ easiest fix
- question on stillen intake
- Engine surge with cruise control.
- Some pics after what seems like months of bad weather.
- why a grounding kit?
- End of warranty check-up?
- Keyless remote
- Burned out bulbs in dash?
- Max is comming back home today
- I was nominated for Ride of the Month on V6Performance.net
- injen heat/splash shield
- Your Max: New or Used?
- P0420 code.
- Berk Intake came yesterday!!
- 20in Riders Come in !!!
- Annoying Noise!! Plllease Help
- tune up recommendations
- Where to buy Cattman exhaust ?
- cluster lights?
- Up And Comming Event
- Cheap Clear corners?
- hood shake anyone?
- Shocks and Struts
- Any One Ever Ordered a Pully From Ebay????
- Anyone done a RED LED swap
- Camber kits for 5th gens!!!
- Tranny problem
- BOSE problem...
- Front End Whine
- Anyone have/know of a 00-01 being parted out?
- Strut/spring combo...a must?
- Ignition Coils
- basslink knob
- For those who have had the warped rotor problem
- P0505 - Idle Air Control Valve
- Recomendation-4-modification 01max
- P0171....How do I fix this? for a 2k
- 00 struts
- VIAS and Mag-Lite Mod Today
- Canadian AE - no body kit?
- remove headliner
- Projector Write-up
- Am I going to have a problem?
- Remote Start
- Illumina settings?
- Need recomendation on brake pads
- WTH is going on with my mileage?
- po217 code
- For those of you thinking of going cheap on body kit installations......THINK TWICE!
- New PICS of NY's ghetto Max (side skirts finally!) 56k DIE!
- intakes please help
- Who do I Message? (02-03 HID install)
- Just got my Hella Supertone.....now how do i install these?
- SSB Brake Kit
- Anyone with yellow laminate flim on thier fogs?? Pics??
- Reprograming of the ecu reschedule
- aftermarket exhaust people step in
- drops and camber
- CAI Help
- Porterfield pads - reply to rear fitment issues
- Hella - Triple tone Air horn kit
- Spare key for cars with remote start installed
- climate control?
- 5 th gen wheel weight?
- 2002 Nissan Maxima SE Lips
- Lowering ?
- Help please...
- OEM Bose radio warranty
- NE1 retrofit '04 HID projectors or projector foglights?
- 2000 Stillen Bumper
- Question about changing brakes
- Driving impressions of 17in 350z rim
- Service Engine Soon light came on my 2k...Please help?
- Need suggestion fast!!!
- Help identify this starting problem
- 2003 Interior Colors... 3 or ???
- Labor cost questions
- Handful of 5th Gen ???
- how to for installing hella horns
- Oxygen sensors again...
- VIS Kombat kit vs. Custom Enterprise RAZOR
- New MAF equals new car
- WIERD LOW-END power loss 2002 3.5L
- Programming New Remotes
- OBX headers???
- 1st 5th Gen CF Trunk Installed Pictures
- Knock Sensor??
- Noise Noise Noise...WTF
- foglights + yellow capsuls + 5000K HID bulbs ...Pics
- Those Nissan Ladies..
- Rotten egg smell... MAF??
- warpspeed y pipe
- Lady Bug in my light...
- code P0420
- Yellow film covers foglight lens?? does that exisist?
- nite shades
- Is this the right way..... Powerslots
- New Question? Jet Chips
- Spec Clutch/Flywheel
- '00 Maxima has hicup when cold. Help!
- Brightest WHITE sidemarker & conerlight bulbs?? Brand? Type? Help?
- need exhaust
- Do you have one of those days when...
- Infiniti Key For 2000 Maxima
- Strange smell from ventilation system (2001 GLE)
- Strut Prices?
- Size bulbs lights up gauges for 01 AE??
- LED Mirrors HELP!!!!!!
- push button start
- Wheel Weight
- Need a sound clip please.
- Consruction begining soon
- unstable cornering
- aftermarket hood
- EBC brake pads
- Slow clutch release
- A mod question for all you maxima gurus.
- 2K - 2K1 Short shifter thread
- VIS Hoods don't like hoodpins
- Driving on repaired tire...
- 5th Gen coil overs into a 4th Gen
- 2000-2001 White 5th Gen GLE or GXE
- basslink qeustions
- Decals near stereo are rubbing off
- Dreaded 1-2 shift slip..Questions inside
- Difficulty removing time clock pod to change to blue display. HELP
- Want to lower my 02' Max
- Injen CAI with battery removal
- Stillen Kit **PICS***
- Projector Headlights from eBay?
- Stock Intake Whistle
- Hood Adjustment
- rear deck rattles like poo
- Coil Pack Purchase?
- what size is our HID bulb?
- Photoshop
- iridium or platinum plugs
- Goodbye torque, power valve removed again, for good
- Tokico Reseller with great prices??
- foglights
- Question about salvage/totaled vehicle
- P0420 Code SOLUTIONS ARE HERE!
- AC/Stereo/TimeClock disply in blue?? Help...
- having trouble switching to first..help guys
- purge valve stuck open (p1440)
- Another headlight question
- All with DDE's please enter
- Quiet exhaust
- Angel Eyes for 2001
- 2002 keyless entry remote program
- location of bank one sensor 2 clarification
- starting problems
- just installed a pair of PIAA Super Plasma GTX and....
- 0-30 engine noise
- 2002 Maxima Oxygen Sensors
- Aftermarket speaker brackets? for 2k1
- dumb question, but is there any trick to take the coils out?
- Those with dealership experience...
- Bought a High Flow cat today.
- Splash Plate/cover Hanging
- intake install .. car is slow please HELP
- '03 Warranty Work - Wheel Bearing?
- 2k dash plastic melting??
- LSD vs. Locker
- ok guys,ideas for new muffler
- blacking out tailights
- Transmission whine. Help.
- Auto Window Roll Up Problem~
- VIN Decoder. List of what each digit in your VIN stands for...
- Brightest Ion Yellow Foglights?
- Eiback ProKit or Sportline?? '01s
- MAF on Ebay?
- Wiper Blade not sitting on glass correctly
- Energy Suspension Question
- So how's your stock wheelgap? Uneven? The 5th Gen stock wheel gap discussion
- car wont start
- Crank Seal Problems 02 Max
- rim weight???
- Has anyone gutted thier cat with an aftermarket exhaust?
- HLSD - How much do i need it?
- OD Light Bilinking at startup
- Merlot Riders!!
- Do you run your cat with your y-pipe for emissions?
- Unordthodox 3 Piece Pulley Sets
- Intake or y pipe???
- Cutting Into The Maxima For Switches... Help!
- cali vs. fed emissions???
- idle air control valve
- 2k auto tranny issues
- car automatically locks?
- 2000 Intake Exhaust good, y pipe lost power
- 5.5 or 6 gen?
- question on the way my car sits...
- Struts Install
- Driver seat motor TSB question
- STILLEN Y-PIPE vs WARPSPEED Y-PIPE
- Cruise control surge problem?
- Brake Lights Out... Got pulled over?
- Who needs leather seats?
- 2003 Maxima Question
- might buy a 5th gen. looking for opinions and advice
- headers+y-pipe ne good?
- P0430 ???
- AE Sills
- Rear Window Switch
- Few HS header/Greddy EVO videos
- Headers and emissions
- TWM short shifter
- Lower temp. Thermostat
- CF trunk... not installed yet Pics
- 3M bra
- How to- HS headers 01 Maxima.
- engine cover
- will this work with our max?
- It finally happened...
- nub o d day
- help! center nut loose
- Wont go past 110 - VIAS?????
- Extended warranty, where to get? Is it worth it?
- So who has gotten their tranny flushed?
- air filter...?
- Affordable/Simple Performance Improvements
- where did it go???
- Reliability question
- DEI Cryogenic Intake System?!?!?!?!?
- Break Fluid/Lines Replacement write-up?
- Unorthodox Racing pulley....
- NE1 paint my rims gold? (photochop)
- My transmition just died on me
- Gas Gauge promblema
- PINGING & timing advance?
- Random pix from today w/ irish44j
- how do i order these yellow capsules?!
- about cel
- **Rear Valence Won't Fit**
- Reflectors flip light upside down, correct?
- O2 sensor bad?
- 2002 GLE side skirt question
- Cleared sidemarker question
- I hate the center console.
- Whining Noise at cold Start
- Interior lightbulbs?
- Leaking Valve Cover Gasket... =(
- LED Tail lights
- Lost in snow
- thinking about switching from 00 to an 02 max
- What needs to be modded on 5.5 gen headlights to fit 5.0gen?
