View Full Version : 5th Generation Maxima (2000-2003)
  1. High Flow Cat Converter From E-BAY Questions
  2. Tokico HP blues and Tokico Illuminas
  3. 2k3 seats in a 2k1?
  4. Berk Intake Installed
  5. Brake pads and dust...
  6. Which Piaa H3 bulbs do you all get?
  7. grinding from the front brakes... what's wrong?
  8. Fuel Filter
  9. Those with progress lowering springs
  10. By Inches
  11. Projector Headlights Beam Pattern
  12. need recommendation for spark plugs and air filter
  13. MAF - How to tell
  14. Ground wire for O2 Sensor
  15. tint removal question/concern
  16. Struts need replacement?
  17. P1320- How do I fix this?
  18. Floatiness of Springs
  19. Berk intake in.
  20. Let's See Your Headunits!
  21. Who has a cracked fog light housing
  22. How many #74 bulbs are behind '01 SE gauges ??
  23. ae door sills
  24. Re-Wire, DRL (day running lights) to Fogs.
  25. Need helps!! Just bought the HKS Twin Power but how to install it??
  26. Is it OK to lower on stock shocks?
  27. Installed high flow cat/ test pipe today
  28. Oil Filter Magnet....
  29. What is the best way to clean the oil?
  30. AC lights keep going off
  31. Why...
  32. axis hiro pics on 5.5 max?
  33. You might be a 5th gen owner if...
  34. super charger or turbo??
  35. DRL Removal/Stand-Alone Fogs
  36. Idol System Malfunction
  37. NEED HELP- fiberglassing the eurethane touring lip
  38. have aftermarket head unit w/bose speakers?? step inside
  39. questions about warranty
  40. jealous
  41. O2 Sensor malfunction Damaging?
  42. Sound clip of new muffler
  43. SES light on...ECU not communicating with code reader?
  44. rear side marker bulb
  45. illuminas + eibach = BOMB DIGGITY
  46. 02 03 maximas with o2 simulator
  47. 5th gen w/o Side air. Can that be changed?
  48. bolt pattern
  49. Power Socket Rewire
  50. Spring Break
  51. Tell me this....
  52. All SE Owners and Aftermarket Struts
  53. 2000 GLE exhaust help please
  54. Crap. Expensive lunch hour. Suggestions?
  55. Need HELP with bucking 2000 GXE!!!
  56. Video of new muffler...host please
  57. Removing Limiters
  58. still getting codes
  59. Question
  60. Alarm?
  61. Quick ? about fog bulb install
  62. Window problem
  63. LSD for the Maxima
  64. VIAS Question?
  65. Pilar Gauge Pics
  66. got free leather seats;;;; but
  67. Are overhead consoles interchangeable?
  68. question on power numbers?
  69. Necessary Services ?
  70. when replacing ou 2k-2k1 clutches...
  71. Are all FSTBs the same??
  72. custom 02 03 taillights tinted all red
  73. Eibach Prokit! or Tokico Illumina users!! enter!
  74. Kyb GR2
  75. Need Pics of optima Yellow in 5th gen
  76. 90,000 mile service?
  77. 90,000 mile service?
  78. Lightning Audio Maxima on TLC
  79. Black Outed 2k2/2k3 taillights
  80. not another HESITATION thread!!!
  81. Looking into Frankencar intake and catback exhaust..
  82. Anything about projector fog lights?
  83. Progress Springs on Stock Struts
  84. 5.5 Mudguards on 5?
  85. Got the new muffler installed!!!
  86. Replacing tail/brake lights
  87. Maxima Seized by sheriff !!!
  88. Engine Trouble----What Now?
  89. Superchargers
  90. she lives again
  91. ECU Reset doesn't last for too long
  92. 4th gen needs a 5th gen answer
  93. video of a max...crazy
  94. Power Passenger Seat Swap
  95. How to Fix/reset Sunroof motor
  96. HELP! New Black glove compartment needed!
  97. 02 max OEM hood and taillights for sale!!!!
  98. installing MAF
  99. Willing to pay for VIAS fix!!!
  100. Fog lights
  101. Would a grounding kit get rid of purple DDE rings
  102. clunky sound in right rear
  103. Anyone with Axis Ne-os rims?? Pics??
  104. Write up for Rear Trailing Arm Bushings?
  105. sound during clutch travel
  106. Low end HP missing?
  107. whistling noise?
  108. Wear and Tear - Struts Replacement
  109. what is MAF code
  110. 2004 max rims whats the best coilovers w/ h-teins
  111. 350z muffler on a 5.5 gen
  112. Messed my Baby UP
  113. FYI - Parting out max
  114. Free Carfax Report, Hurry up before it expires
  115. Full leather interior for $350 :-)
  116. differences between 5.5 gen max and 350z intake manifold?
  117. Homemade CAI
  118. torque clutch cellanoid
  119. List of Nissan Part numbers???
  120. How much am I looking at to get this painted
  121. Ebay Projector lenses HID retro? (pics... if you have dial-up twiddle your thumbs)
  122. has anyone done this yet ????
  123. Serious DDE Problem...
  124. 300zx brake upgrade
  125. white 5.5 Gen with Axis Supermesh
  126. Full tank Average mileage
  127. Question about DTC P0740
  128. To all the Moderators and Members of the Org
  129. 2001 Fan Resistor
  130. Just bought Rhino Ramps they are pretty cool
  131. Anyone used Seafoam Trans Tune?
  132. UR Pulley:What Size Belts.....?
  133. Just Brought My Berk
  134. GPS mounting bracket
  135. basslink keeps blowing fuse
  136. HID Write Up?
  137. Federal law...WTF?
  138. Air bag light blinking ....... warranty?
  139. HID Trouble Shooting
  140. How long did your PIAA Fog Bulbs last?
  141. 01 SE stalls out after high rpm's
  142. bad down stream O2 sessor.
  143. High Mileage - need your opinions
  144. Probably a repost but... (Ignition Coil Question for 2000)
  145. Some pics after months of bad weather II
  146. cracked fogs
  147. ? about Clear Side Markers
  148. noise from center air vents
  149. question for the HID guys
  150. Cai Runs Like Crap
  151. Rear-end repair question... (MA)
  152. Dash lights on again...'TCS off', SLIP, and 'ABS'
  153. HLSD Maintenance needed?
  154. Headlight housing black or gunmetal grey?
  155. is this possible & worth it??
  156. Emblems - Glue Residue
  157. VIAS help, please
  158. K&N filter
  159. camber kit poll
  160. Compass/Temperature rearview mirror
  161. whos car is this??????????
  162. Painting Rims
  163. 00 maxima se
  164. Weird cold acceleration?
  165. Rotten Egg Smell
  166. G35 rims on maxima
  167. Cheap, Do-It-Yourself performance upgrades
  168. Bung the headers instead of extending wires?
  169. Power Loss at 3500 RPM
  170. What exhaust
  171. Airbag Light reset procedure
  172. suspension done, smoooooth....er
  173. ...wow
  174. Silverstar vs. PIAA Super Plasma (fogs)
  175. HERE ARE ALL MATCHING PAINTS (sidemarkers, etc)
  176. window goes up then back down
  177. headers and y pipe on ebay
  178. Periodic whine/click/hiss noise in front left of car
  179. Ebay clears: Good or Bad?
  180. DDE's INSTALLED!!!!!!!!! pics
  181. 01 Service Engine Light Keeps on Comming On
  182. O2/Fuse question
  183. Stock Exhaust Concern
  184. Can you buy the plastic part of the 02-03 headlights?
  185. car running while filling up?
  186. Tranny slipping; how much will cost to fix?
  187. Hypothesis: bad MAF, bad rear O2
  188. Rear Bumper Question
  189. Does this guy know what he's talkin bout
  190. fuel filter pics
  191. Exhaust Video
  192. Engine trouble!
  193. How much cable for DIY grounding kits?
  194. Dropped Bulb in Tail Light
  195. Where to buy header and ecu for 2000 Maxima SE (searched)
  196. Rear Seat Belts LOCKED UP!!!
  197. ebrake adjustment?
  198. Portable GPS
  199. Question on body kit painting and install prices
  200. Best place to buy..
  201. black on Merlot PICSS
  202. SES CODE P0171 bank 1, PLEASE HELP
  203. Spoiler Paint Question
  204. Is it just me? ROAD NOISE
  205. need help asap....front suspension....
  206. any 5th gens w/ adr kasai 18"
  207. Interior lighting...blue changed to red...
  208. i have some questions about struts
  209. Can shimmy be caused by warped rear rotors?
  210. The ultimate suspension!!
  211. restricter behind tb
  212. 5th Gen Wheels on customenterprise.com
  213. rsb/brakes and more...
  214. projector headlight
  215. s-tech springs
  216. Sluggish, funny idle, performance is so-so...
  217. exhaust system removal problems
  218. VIAS problems??
  219. POST PICs of ur Anniversary Knob
  220. Blew another 2k3 MAF!
  221. 2000 se pulling to right
  222. Flaking Emblem
  223. Yay! I got Maxima back, YAY!!!
  224. People With Edfc Step Right In Please!!
  225. OMG, the JBWeld VIAS fix rocks!!!!!
  226. >>3:00AM Maxima with SSR's at OU Mini-Photoshoot 300D (13 PICS!)<<
  227. White grill or Black grill
  228. trunk lid
  229. need help asap....front suspension....
  230. greddy and cattman catback sound clips
  231. Why hasn't anybody attempted this?
  232. Pics of Lower Control Arm ES bushing install
  233. Does anyone make a brake upgrade kit that fits stock 17" rims?
  234. Optima battery sale
  235. What size red top fits best?
  236. Question on Cattman Cat Back Exhaust System
  237. ignition problem, confused.
  238. Fog Light Question - Can't Search - Must Ask
  239. Door Panel Clips
  240. jack for Maxima....
  241. Is it possible to change a higher intensity bulb on a stock 02 headlight?
  242. tint removal
  243. Knock Sensor Replacement
  244. GReddy Evo2 owners please
  245. how do u know if a sensor is bad
  246. Need help with lower control arm install
  247. about tranny
  248. Sport max racing
  249. Newbie here!! Whats up guys?
  250. Wtf?!
