- New pics just for the hell of it....
- Removing EBrake Handle
- I finally de-recied my car, tell me what you think
- What kind of brake pads...
- Frying 5.5gen Bose Amp with Aftermarket Headunit????
- Throttle Body
- removing the burger
- color?
- low speed, wide right, damn grating sound
- B-pipe with OEM rear section? Step in...
- Warpspeed's Y-Pipe
- New Mod Pics
- Do rear brakes wear out faster-all brake gurus come in
- Where to Order A VB mod and a Trans. Cooler
- Tried the sidemarker re-wire BUT DIDN'T WORK
- What Drop and Struts Do You Have and How is the ride comfort.
- What's this?
- My 01 SE 5 sp. needs a trans help?????
- Rotor and and brake in....
- Huge Problem. Car keeps dying.
- Stillen Classic lip installed - PICS!!!
- Weird But True...
- 02 Maxima Burning Oil
- titanium center console
- ANYONE with an apexi SAFC-II...please help
- help! limp mode problem?
- Stillen touring kit w/ sarona sides pics!!!!!
- red climate control pix
- what's under your clear sidemarkers?
- just did the coat hanger GAB...thoughts inside
- I need help with my engine!
- New Stillen Kit and '02 Sides ***PICS***
- 5.5 Gen rear ended
- Evap canister and vent control valve
- Inspection with o2 Sensor??
- code P1491 "manufacturer auxiliary emission control" what is this?
- Mixing exhaust parts?
- help me fast
- when you cut the bumpstops, what are you actually cutting?
- Front passenger power window is Dying out on me! What to do?
- Amping front door speakers
- Throttle Sticking Problem
- stock altenator?
- PBR/Axxis brake pads?
- HIDs wont fit... broken clip, new one, still won't fit
- Frankencar, Cattmann or other?
- Isnt this the AT STS?
- error code p1126 - Cant find anything on it...
- WTF is this...
- My Max with 350z Rims - Photoshopped
- Installed SilverStars you be the judge(56K warning)
- BlehmoCo BBK with 04 Slotted IRotors - 5,000 miles later
- Will these struts work in my 2000?
- 3 quick questions for the experts...
- How would this look?
- Audio file of pinging and knocking
- "winding sound"
- ok guys i got a problem
- Its official...I've had my car two years today. 84,6xx and counting!!
- Just installed frankencar 2.5 catback....looks great...sounds stock
- Help with my brakes please..
- 2001 Maxima GLE TOP SPEED?
- Painting brake pads..
- Need help to put my brakes back together
- write up
- Yet another head unit for me.
- Something wrong w/ my exhaust??
- Chroming the mirror covers??
- Timing Advanced at Infiniti Dealership?
- Anyone's Leather Steerig wheel peeling?
- Frequent Ingnition Lockup
- fixed and repainted my rims w/pics
- Write up on ae headlights
- MAF covered under powertrain warranty?
- Exhaust mods
- Power Chip?
- clear 3rd brake light
- Floor Bar?
- irotors or brembos
- clear corners?
- 2003 Se
- God my Max probably hates me. . .
- Muffler Needed - which is best to get?
- TS ECU or Hotshot headers for 2k3
- I Need Help.
- Question on option of heated steering wheel
- 30+ pics of what I did today. take a look. (putty/fiberglassing)-- 56k beware..
- [urgent] HELP dealership is charging me for transmission fluid
- Remote Question
- parking light bulb removal
- 97 M3 or 03 Max?
- Need Help Asap!!!
- Unreal!!!
- AE automatic shift lever
- housecor fog mod??
- A/c and Heater bulb or led where to buy ?????
- ebay projector picts
- Check out my new rims
- I need instructions how to install my front struts PLEASE
- JUST Batt light coming on w/ low volt
- Just my Max--all stock
- Frankencar intake owners(Step In)
- Suspension Question
- Coilovers or spring/strut set up
- Performance Question!?
- Question About WarpSpeed B-Pipe
- New pics of my max
- Replacing 02 sensor question
- Coil Testing?
- stupid shift knob and some other small mods..
- Free Sts........
- What do you guys think of my max? (pics.. 56k beware)
- New Spring Without Struts?
- Noise coming from right rear wheel??
- Moonroof won't open after dealer service
- Need Sterling Mist Bumper
- My car sittin' on 19's ROJA 19x8 formula 7
- Storage for a year - What do I do for Max?
- Changing Spring Yourself
- My stock intake owns ALL of you. :grin:
- Pocket on top or bottom??
- wheelwell falling apart
- springs and 20's?
- frankencar exhaust question....
- update ecu when changing o2 sensor?
- Stock spring mod? possible?
- ses came on 0138, 0139 O2 sensors...have a question
- Canadians with advanced timming
- How much better are coilovers than springs/shocks?
- p1147 what should i do?
- 2 Bent Titanium Rims on 2003 SE
- oil pan seal change
- VIAS question
- motormount inserts
- Installatio HELP!!!
- Car is dying while slowing down....what's broken?
- Sunroof on a 2K GLE
- Car stalled out of no where??
- Modding and saving money?
- new tails, need some input
- Want custom grill for 00-01 GLE
- navagation question
- 5th gen trunk pin wire
- Anyone use 245/45r17 fr and 225/50r17 rear?
- sunroof problem
- System got stolen... sad story...
- Angel eyes + Data Dots
- have you seen these headers before?
- Muffler bearings worn out... replacement?
- Help with brakes pls
- Whats the Fitment of Rearview Camaras?
- hp racing hp r5's
- Common Mods
- Starting problem
- NEED HELP - Rotor/Pad Swap = GRINDING SOUND??!
- All those who replaced their Bose HU
- Springs?!?
- installing rear sway
- Bank 1 Sensor 2
- in dash dvd set up...step inside
- changing shoks ?
- Ya'll said no to gold, but I did anyway... look.
- 5.5 gen ANGEL EYES HELP
- HELP ASAP rear sway bar installation
- hissing noise???
- Touch Up Paint
- Best Exhaust Mods???????
- anyone with pics of their Max with 17"
- Did you install your own leatherseats.com/katzkin seats?
- silver centercaps
- Throttle Body Spacer
- Only had the rims for 2 weeks, and I already hit something :mad:
- Need to see pics before putting them on
- Seafoam with Oil
- Wheel alignment.
- Another Maxima
- What are my options to change my headlights?
- another HID projector retro (E46's)
- 02 Repeated Battery Failure
- Chips that increase horse power
- What to look out for 00-01?
- Hit 100k Today
- mirror prob?
- stock gauge bulbs #???????
- These Headers any good
- no blinkers or hazard lights...
- 2001 AC Drain and refill Recharge
- Any ill-effects with wider rear tires?
- RSB without FTSB?
- Mass Air Flow meter for $89.50??
- Yet another ghetto intake!
- dome light not working but bulb is fine
- Size of 5th gen lower valence opening
- some pics for my 5th gen friends....
- free flow vs. frankencar
- question about getting gps on my pionner headunit
- Airbag light flashes
- 2000-2001 Se Rims
- Fog light question?
- H1 into H3
- This is the GXE Dash Kit and my new toy!!!
- Service engine light
- Pipes and Chips
- Updated PICs of my Car (Polished Titanium)
- Putting a navigation system in a non-nav car?
- Illumina rear adjustments - Easy method?
- valence grill on AE
- Transaxle bearing covered under Powertrain or Bumper Warranty
- Who was the one who re-located the digital climate control?
- Optima or Di hard battery?
- Cleaning fuel injectors
- Help/tips for changing rear o2 sensors
- First Oil Change for my 2k
- To those with the Grille-Tech lower grille insert...
- Front bumper
- Is there a difference between Grey lustre on 00-01 and 02-03?
- Muffler for 01 SE AE
- Thanks to DAVEB
- Check out this website.
- 8 sec skyline video
- Spoiler
- rotors, is this ok?
- Slotted/Cross Drilled Rotors w/ Painted Calipers **PICS**
- 02-03 highbeam bulbs
- ••ü•• This Weekend Only - Maxima DDE - $149 special price
- ••ü•• ProLumen Explanation
- AUTO'S>>>How do u do your best LAUNCH??
- how do i deal with my dealer?
- Aftermarket E-Brake
- The benifits of a intercooler?
- Throttle body
- any1 got pics of a aftermarket 5.5 gen auto shift knob
- OEM part number
- convert Berk to CAI?
- Wagner ThermoQuiet or Performance Friction Brake Pads
- My Tranny Dying?
- 2k4 Rotor Upgrade
- need to get a scratch out....
- Sunroof Motor Replacement Procedure on 2000 Maxima
- rewiring how-to's...sorry
- 350z/g35 intake on 2k2
- Anyone dyno'd the Hotshot headers vs. the Cattman's?
- Servicing the Car
- maxspeed springs?
- serious prob with stillen kit color match,help
- Front wheel vibration over 65. Any ideas?
- obd2-headers-emissions
- 2k's only~blown manifold w/ intake
- Putting in New Front Wheel Bearings Today, help!
