- Need your opinionon my fiberglass project...QUICK!!!!!
- Ebay Headers and Y-Pipe Advice Needed
- ignition coil question
- i need a new trunk lid
- Wow...I actually have mods!
- steering wheel removal
- how hard is it to fix halo leds
- ahh, already a problem
- Need Help. Tail light problem
- where to buy a new MAFs
- 2 year report- chopped Eibachs
- Auto tranny concerns
- MPG guage
- somethings wrong with my brakes!!!
- quick clearance question...
- Door Pillars
- Grille-Tech Valance Grille Question
- Putting leather from GLE into SE
- **Confused**
- JUST PUT ON THE 20s
- How to/ Instructions section...
- "How to's" on brakes?
- Suspension install gone to hell. Suggestions needed asap.
- Leather ripping
- Calling all 5-SPEED owners...
- Will a 01-up steering wheel fit a 2000?
- The famus P0507 code!
- Those with sarona skirts...
- wheel spacers/exhaust installed
- my trans is on crack
- 2000 Cali specs...favor please???
- installing my illuminas soon..whats the best setting?
- Weird Idling Issue/Condition...
- Short Throw Shifter
- LED'S question????????
- Stupid DDE's Ballast
- tried to get timing advance
- Sweet new project...yellow HID projector foglights.
- which autolite gauge...
- What do you think about this Y-pipe??
- Need one 02-03 for FREE prototype in Northern VA THIS WEEKEND
- new lip problems
- How to carefully remove corner lights?
- Shifter knob thread pattern
- I can't use my horn! :(
- ABS self-diag mode.. anyone tried?
- just timed my 0-60 and 50-70
- Driving a Manual
- o2 simulator question
- Spark Plug Change
- 2000-2001 Projector Headlights
- 2 Questions
- A good buy?
- P0455 and P1448 Answers
- Grounding Kits??
- HID Bulb
- Chroming automotive parts
- Advantage of UDP w/o other major engine mods?
- Electrical problem...Plz help..
- mileage vs years
- damn!!!!
- A/C not blowing cold enough...What to do?
- 57K miles- lots of work needed
- Windows open and close slowly and noisy, help.
- JUST POSTED PICS AND DYNO. ALSO TAKING .02's..
- retorfit problem
- 100+ k mile 5.5gen
- Calling Dr. Roy
- Anyone have sounclips oh headers or exaust
- No performance mods!
- Cleaning Our Engines
- Pls Help with fuses and dash board lights
- Guess What?
- steering wheel vibrates
- getting hs headers whatelse should i get for the exhaust
- Where can i get carbon fiber mirrors or mirror shells
- PO153 Rear bank, 1st sensor????
- Who was it that measured engine bay temp while parked/moving?
- P0456(Very small evap leak)
- need a new alternator
- StreetScenes or GrilleTech Grille????
- Vinegar smell when A/C on
- staggered rim setup
- how often do i need a tune up?
- Clicking Clutch.....
- ABS and Slip problem.
- Murano rims on 2k3 - take a look *PICS*
- Fast Cat and Cattman catback Installed
- Can I upgrade the Alternator on my 5th gen!
- 480 Miles On Tank Of Gas
- ok guys wich do i dyno headers or timing advance
- Anyone trade their 03 Titanium@Niello Infiniti...
- Zero Rust, POR-15, Rust Bullet Products
- new 5.5gen vent visors?????????
- Just stopping by
- Headers and Y-Pipe Questions
- i need window help! please
- Car feels slower with A/C on.
- CF style tail lights on Sterling silver 5th gen?
- ECU and Reverse Wire
- rear ABS sensors from 00 work on 02-03 just fine
- Sorry for the Projector Repost but...
- Need your help....
- Tokiko Blues and Tokiko Alluminas.
- Anyone ever fix their coils?
- Stock exhaust reliability
- Almost 100 Deg no AC PLEASE HELP
- Totalled the max early Monday morning.
- Painted nissan hamberger...
- replacement wheel studs
- Timing Advance
- Intake Manifold Question
- Help me decide on what to get for my next mod!
- strut torque specs
- Time delay switch-off control on 2k1 GXE?
- Hid Stock Lamps
- Fog Lamp question
- UPDATE- 2k3 losing OIL
- maxima/i30 body
- Straight/Race pipe owners step in
- newbie gas q
- Help with EVAP
- smooth idle rough acceleration
- Wheres the Fuel Filter on a 5th GEN?
- iPOD adapter appears to have RCA in jacks
- pinging pos!
- removing cross member under ypipe/cat?
- Nissan Caliper Stickers *pics*
- Catalytic Converter
- Just bought 02 max se
- need tech help, rear spring install
- Strut Tower Bars & Strength
- quick coilovers question
- Greghome 5.5 Sparkplug Change
- How to adjust ambient temperature reading?
- Cross Drilled rotor failure
- Need Help - (Loosing Clutch Fluid)
- Maxima 2000 Automatic and Kenwood Navigation Unit Speed Sensor Wire and Reverse Light
- Timing Advance In Schaumburg IL
- Broken Key in 5.5 Gen Driver side
- 5.5 gen v.s. 04 350Z Rims
- which tranny to get?(opinions needed)
- problem with my 01 SE HELP
- Replacement Headliner??
- Replacing stock catalytic converter and question about ECU codes
- Crank Shaft Position Sensor problem in a 5.5 gen
- 19s on a 2k, what suspension is best?
- PowerTech 1012
- turnin radis question
- question bout intake
- Lightweight wheel effects on wheelhop
- ABS problems???
- Aftermarket (or Walmart) fog lights for 5.5 Gen?
- Wtf I Found A Spacer Below My Pedal!
- Survey: 1 thing u like most, dislike most about max
- Installed Eibachs/Illuminas HUGE difference
- The Great Picture Thread.....
- misfiring help! e55amg2, blackbird?
- Opinions on Shocks/Struts
- Weird idle.....................
- Vertical Sun roof
- All 5th gen members, Mandatory Read!!
- Sunroof
- Finally i chose what rims i want !
- Pics of rear window spoiler?
- Rattle under the hood, after acceletation...
- question about dte/trip guages
- radio question
- test drove a max today...howd they do this??
- fluid dripping by tranny and axle......
- Spent so much on gas :(
- tire size change and speedo calibration
- general questions...
- Question about HID
- 1 Sourceautowarranty - Extended Warranty
- Intermittent wipers on a 2000
- fog light rewirin
- Taming a 6-Spd Need Advice
- Crank, No Start Condition. Help Please
- Help! Service engine light is on again.
- OK, I'm Confused...
- symptoms of slipping tranny?
- 2000-2001 Maxima OEM 17" Wheels/Rims on ebay
- A quick wash and wax... what do you guys think?
- pics of my 02 max se
- maxspeeds on
- Why are wheel spacers so expensive?
- Tint on 2000 max - back window?
- Custom Exhaust bending
- bottoming out/harsh ride with Progress/Tokico HP's
- 13 inch cobra's on a 5th gen!
- Curious About Frankencar Performance Service Hours
- please help. how to remove driver side door panel?
- Help...Please!!!
- Reprogram ECU now or later
- car lights for inside
- What are some real good brake pads?
- Do X-Drilled rotors have certain direction they need to turn around?
- Grill-Tech Grille
- Need an How to for installing 2k4 rotor/caliper.
- Need brake rotor knowledge
- The condition of your Cattman Products?
- where to find haynes manuel for 02 max???
- Way to program key????????
- out on my maxspeeds got one question
- Blue LED gauge mode question!!!1
- Tokico Illumina front only with Maxspeeds
- Vibration Vibration Vibration
- Custom two-tone interior project! ***TEASER PICS***
- Need Opinion supercharger or 5.5 gen
- 2k maxima with ticking noise
- 2k2 foglight rewire????????????????
- Leather Ripping?
- Front suspension noise fixed
- new clutch issues
- window up/down button
- Ran over curved metal tube on highway
- Rubber Dust Boots for front suspension
- anyone know how to change pvc valve
- Outside Temp. Display
- What should i offer
- Ugly hole....any ideas how to cover?
- Center Caps....Black or Silver??
- Need a carfax report
- performance between flywheels
- Cattman muffler on, wooohoooo.
- looking for abs dynamics rear lip for 5th gen..who sells them?
- Rear brake pad?
- P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
- Are Monroe Sensa-Track Struts OK for a daily driver?
- 3 Things
- Got my VIS CF hood today
- CAI UDP Dyno Results
- Painting the motor cover......???
- Can I buy Langka at auto stores?
- Eibach/Illumina-cut bumpstops?
- Advance Timing
- Eibach Pro-kit and Factory Struts
- My 5.5gen GXE and friend's Prelude at OU (8 Pictures)
- Which a better combo?
- new springs :)
- g2 paint suggestions, how long to wait?
- question on oil change
- Basic brake parts...
- Yakima Roof Rack measurements
- Bushings replacement important after 80k??
- Intake problems
- my MPG says 15.0 MPG????
- 5.5 gen lips(both of them) Please post pics
- Curbed!!!!!
