View Full Version : 5th Generation Maxima (2000-2003)
  1. AT CONVERSION TO A 5SPD OR 6SPD
  2. Clank, Tick tick tick, Blue Smoke. 2002 Maxima..What the...
  3. If you have FLICKERING Lights, How Many Miles do You Have?
  4. New Alt...SQUEAK SQUEAK DAMN SQUEAK
  5. Megan racing springs
  6. sift kit install, help
  7. Infinity Valve cover
  8. Help me with my radiator..
  9. 6th gen BBK query
  10. HID goes out- What to do?
  11. Is there any advantage to getting cross drilled and slotted rotors?
  12. stillen muffler on a 5th gen
  13. where can i buy H&R springs for only the front?
  14. Sputtering
  15. Bouncy Idle between 1500-2000 RPM
  16. Rotors and Pads question????
  17. p0138/p0325 questions? 125,000 miles
  18. Tinting question
  19. Best place to buy rotors and pads for my 2003 Maxipad?
  20. R.I.P. My 03
  21. Tokico ABS line issue
  22. Windows Switch for GLE
  23. Lug nut torque...
  24. Brakes: Do it yourself or pay to have them done?
  25. Car sounds like crap! Help!
  26. mcguard tuner lugs not fitting? wat the...
  27. Best place to buy an alternator???
  28. 2000 nissan maxima GLE exhaust
  29. pilot bushing on an 02 auto max engine
  30. Anyone with tint over 20%?
  31. just your opinion...
  32. Best Upgrade for under $500
  33. 02 I35 tranny slippage update..feedback needed..
  34. Anyone Know where I can find this Part?
  35. Chrome Nissan Emblem on 2k Steering Wheel?
  36. ABS, SLIP, and TCS OFF light are all on
  37. vq35 swap into a 2k maxima
  38. Rear Beam install + ES Trailing Arm Bushings mini review and pics
  39. ABS light- should i get this checked out?
  40. Found engine starting issue
  41. HELP NO CRUISE CONTROL
  42. Snorkel
  43. !!crash course in vafc2 tuning!!
  44. Backed into =/
  45. What is the % of tint in maxima factory glass
  46. P0300 code, Please help
  47. Washer Fluid Issue
  48. 5th Gen Fender Rolling?
  49. battery post & fuse?? delete
  50. Replacing 4 strut boots, tie rod boot and fuel pump...
  51. Vibration starting out in first and 2nd
  52. 6th gen bbk brake line question
  53. another exhaust option
  54. WATER FROM UNDER THE DASH
  55. what your insurance cost.
  56. 02 maxima se rotor or pad noise
  57. H&R Wheel Spacer help?
  58. My experience with Amsoil GL-4 75w-90 gear oil
  59. 2002 Maxima SE MAF question
  60. 2003 off to a rough start
  61. I've been a member a while, need advice on this 2k2
  62. can someone help me out?
  63. Help locating clutch interlock relay
  64. Vacuum Bleeder Question
  65. Replace Headlights
  66. O2 Sensor Extending
  67. both 5gens hard start this morn !?!?
  68. We Know of Yellow Fogs -- But What About Amber?
  69. hack job amp install
  70. Clear spoiler light?
  71. Weapon R Intake
  72. 5.5 Dyno day @ mainstream
  73. Stillen High Capacity Oil Pan
  74. clicking noise when i turn right what is it?????
  75. Safc help
  76. how do i tell if my seats have ADP?
  77. Where is fog light fuse in fuse box?
  78. 01 Maxima Vs. 05 Acura TL will i win????
  79. Engine and transmission weight
  80. Using SeaFoam
  81. Calling all 4AT > 6MT 5.5-gen swaps
  82. EVAP - "Large Leak" - What to replace?
  83. 2001 Maxima Y-pipe Cali/Fed spec question
  84. was this cheap
  85. Maxima saved my life!
  86. Replaced o2 Sensor - still have code/SEL?
  87. foglight bulbs 03 max se
  88. were to findd intake...also question on front lip
  89. Microgreen MG201?
  90. o2 sensor spacer
  91. Need help P0507
  92. i need some help please!
  93. dustboots.. autozone.. advanced
  94. Making some much needed changes (G35 wheel restoration included)
  95. Need Help ASAP: Car doesnt start
  96. Which stock intake pieces will I need for pop charger or Stillen?
  97. 3.5 swaped 20th AE???????????????
  98. Transmission Problems
  99. DROP RESISTOR MOD? 5.5GEN..
  100. AT Trans. Parts
  101. Having problems wiring aftermarket headlights with halos
  102. Help: General info on windhsield wiper motors
  103. Show me your Flaps
  104. Clutch/trans issue
  105. ES or OEM Engine Mount?
  106. Megan test pipe too long
  107. Replacing front and rear mounts -- labor, is this right?
  108. JIC fla-1s front dampers blown again..
  109. New bearing--still have wheel play
  110. brightest bulbs for 03 maxima headlights + foglights
  111. Cattman B-pipe resonator took a dump on me
  112. Many thanks to everyone for your assistance!!!
  113. More 5.5 power loss, running out of things to check
  114. OEM Shocks Struts and HTEIN Springs ride is Garbage?
  115. Steering Issues
  116. plastic foglights for 03 maxima?
  117. Steering Wheel Mods, if you have done them...(no matter how small)
  118. NEW MOD!!! "Beehive Mod" 5th GEN ORIGINAL!
  119. vias delete question
  120. AC Issue!
  121. Cracked mirror
  122. CV Joint/Boots?
  123. HELP Keep losing Overdrive
  124. Ebay exhaust
  125. No dyno fail but seems to be acceleration fail
  126. Should i be worried about these numbers - cylinder compression test....
  127. Headlight Removal..With Data Dots.HELP.
  128. FOUND!>!>!>!>!>! NISMO SE-R MAXIMA.....
  129. BG coilovers made by BC??? any info
  130. Are these the TE rims?
  131. gutted cat?
  132. Billet Grille on a 2003 GLE?
  133. Wrong exhaust?
  134. 5.5 Gen dyno FAIL!
  135. and another one....... issue that is.....
  136. Sitting on the side of the road.
  137. VIN Check
  138. VIN Check
  139. exhaust input
  140. Just plugs..
  141. Warm start issue
  142. slight popping sound when turning
  143. Starting problems when hot
  144. How to reset the garage door opener?
  145. anti spark plug foulers to remove ses light
  146. New Fuel Filter
  147. 18in wheels with +45 offset fitment on a 03 max?
  148. Is this a rare car?
  149. Wheel Question
  150. Interior LED Conversion (PICS)
  151. Tie Rods, Bearings, Control Arms & Sway Bar Links..Isn't it all about the Bushings?
  152. 200,000 mile service ideas
  153. Installed Exedy stage 1 & Fidanza
  154. Stumble During Cold Acceleration
  155. UTEC Plug and Play harness for the 5.5 !!!!
  156. exhaust done the cheap way
  157. Birds under my hood?
  158. What are YOUR recomendations for LED bulbs for clear corners and interior?
  159. Maxima with Swagga
  160. worst luck with wheels/tires/life
  161. exhaust rattle!!!!!
  162. Maxspeed front, H-tech rear
  163. Transition from 50 series to 35 series tires
  164. Torsion Beam Bushing Leaking
  165. Settling Springs / Progress
  166. Embroidered Trunk Carpet
  167. anyone rebuilt their 4 piston AP Racing calipers?
  168. High Idle:
  169. Opinions on my repair.
  170. Free STS - Improved version. Perfect parts list.
  171. New suspension.....new noise
  172. Grille
  173. Crazy squeal
  174. outside ambiant temperature display
  175. Water Sound when giving gas... Need Help
  176. 2K-2K3 Maxima Courtesy PDF Database
  177. Rear Spoiler Removal? How To
  178. URGENT HELP NEEDED: RSB Install how do you get around the brake lines? PLZ!
  179. Trying to find speed sensor, HELP!
  180. ramdom video!!!!
  181. Quick Q on brakes
  182. Blower motor
  183. Steering Wheel Control Lights?
  184. house hold paint on my car
  185. H&R Wheel Spacer Problems
  186. 2003 maxima w/ 09 19in wheels?
  187. HOOD SWITCH
  188. Pick my poison...
  189. idle low tranny funny exhaust rattles .. HELP
  190. suspension tread
  191. Manual Trans Fluid
  192. Where do i go to rent a transmission jack?
  193. My accident back in the beginning of March...
  194. Parts Diagram Request for 5th & 5.5 Gen Headlights
  195. Anyone SUCESSFULLY removed the running light lens on 5.5gen Headlights?
  196. TURBOCHARGER on my CAR ?!?!
  197. Blacking out chrome window trim
  198. Rough Idle...Motor mount??
  199. Check this maxima out...wow 5th gen
  200. 4th gen front turn signal harness same as 5th gen??
  201. Ordered HLSD Diff, Need immediate advice
  202. Ordered HLSD Diff, Need immediate advice
  203. Looking for stock headlight harnesses
  204. Gear Box feels Rough-Advise?
  205. How Can i tell which Alloy Rim type do i have?
  206. annoying hood shake. any thoughts?
  207. Wheel Bearing/Hub Assembly? Or something else?
  208. Just bought a New clutch master cylinder, and slave cylinder
  209. Changing out my shocks
  210. audio help
  211. Sound Proofing
  212. 2000 SE Mirrors...Will they fit?
  213. Any Feedback on OEM Shocks & Struts with H-Tech Tein Springs
  214. Prolumen HID Kit
  215. timing chain tensioner
  216. Tranny swap question
  217. Need help on 6MT clutch repair SLC UT
  218. Timing advance important question ?!?!
  219. Help with Umnitza HID fog install
  220. need help
  221. question on 5.5 belt replacement
  222. Important Question about struts/springs !?!? NEED ADVICE!
  223. Short Ram Intake or Cold Air Intake ?!? Maxima 03
  224. 9003 Lightbulb question
  225. Problem ??? Axle? cv Joints? something else?
  226. Restoring a 2003 Maxima SE
  227. tranny question
  228. Anyone have paint matching problems?
  229. Anyone try these out?
  230. exhaust question
  231. Steering Wheel controls added??
  232. Steering Whaal controls added??
  233. What are good exotic mods for a maxima 5.5 gen ?!?!
  234. Pre-wired for Navi?
  235. SoFlo Accident 4-7-09
  236. New CD player...no audio...
  237. Any writeups on replacing 5.5 gen clutch?
  238. Starting issue
  239. What bulbs to buy?
  240. "SE" font to replace emblem
  241. Strut and Spring advice
  242. walbro fuel pump installation questions
  243. Took out The Resonator. Oh yessssss!!
  244. 350z Clutch
  245. 01 vs 03 = 01 getting owned?
  246. Need suspension advise
  247. Repair Fog Light / Remove glass
  248. new motor,clutch,headers and more...
  249. RSB installed thoughts & question
  250. Help with ABS, SLIP, TCS lights.
