View Full Version : 5th Generation Maxima (2000-2003)
  1. Help!! Bought MAF without realizing the ECM needed upgrading
  2. 6 Disc CD changer
  3. how hard to replace the water pump ?
  4. Electrical Problem
  5. A/C problem?
  6. LED reverse light
  7. Brake upgrades for 5.5gens need spacer
  8. Steering Wheel Radio Controls
  9. Help: Need to replace motor mounts
  10. Cold Air Intake Problems
  11. Weird water in trunk problem!!
  12. New MAF new car WOW
  13. HELP!!!! Received Damaged Umnitza DDE's
  14. Clicking/whistling from wheel area after installing rims NEED HELP ASAP!!!
  15. Window Motor
  16. BERK Intake vs. FC Intake
  17. Sorry To bring up old thread about the VIAS Mod
  18. Camber kits
  19. Michelin brake dust repellant. GREAT STUFF!!!
  20. car start question
  21. Reverse lockout
  22. cargo net
  23. Hawk Brake Pads: HPS or Ceramic?
  24. P0140 o2 problem and reprogramming
  25. Production Date Mystery
  26. ethonol gas
  27. help 2001 AE 5 SPEED owners
  28. Car start to vibrate at 50+mph since tire rotation
  29. Frankencar Cat Back
  30. Took this picture tonight...
  31. serius problem, maf, tranny? hellp
  32. Everyone Dropped On Progress Or Stech On Stock Rims Please Come In
  33. Window motor going out?
  34. Exhaust Noise Drone
  35. Fenders
  36. So is it bad to have A/C on?
  37. Seafoam deep creep for throtle body
  38. Technosquare ECu
  39. Cattman Headers ?
  40. Light stalk for 02 backwards compatible for 01?
  41. Attention Alignment Gurus...
  42. 00-01 Projector Headlights from Custommaxima.com
  43. Last Time
  44. Where did you install you ballast/ignitor.
  45. O2 Sensor question
  46. Questions on 2000 SE before purchase...
  47. Cleaning MAF Sensor
  48. Need a quick answer
  49. Blown strut/shock sound?
  50. New pads/rotors in the front only? Recommended?
  51. Since when is it illegal to have an aftermarket exhaust on your car.
  52. Need Akebono pads ... any help?
  53. Eyelids finally?? check it out
  54. Top windshield molding off
  55. Face Lift?
  56. New rotors need new pads, how about new pads need new rotors???
  57. transmission VB Part number
  58. Towing your car across state??
  59. Cattman/SAFC II dyno graph. with a Baseline graph
  60. Best Short Throw for the 2k Max?
  61. 3.5L ebay headers, first impressions
  62. Cleaning rust off grille-tech inserts
  63. Fog light bulb
  64. quick 5 speed question
  65. Lazy 1-2 shift...lil grind.
  66. Hid Theft Has Hit Orlando!
  67. car got broken into last night
  68. Pinstriping removal...
  69. Stillen Grounding Kit. Pix Anyone?
  70. lower bumper grill painted?
  71. Ignition coil part #
  72. Installing Maxspeed and Illuminas during weekend.
  73. Thermostat question
  74. Frankencar exhasut installed but problems...
  75. Which bushings wear out the most?
  76. Replacing the Bank 2 pre-cat on a 2k CALI
  77. Saying Goodbye to My Fart Can
  78. I hate my door....
  79. Installation of clutch pedal assembly...
  80. beep noise
  81. Would a 4th gen rsb fit a 5th gen?
  82. wheel spacers *pics*
  83. Matt Blehm Grounding Kit vs . . .
  84. Evap Canister
  85. Helios 6000K HID Kit
  86. Are belts covered by 60k/Powertrain warranty? (Please help with issue)
  87. Checked everything.. and still not working
  88. brakes
  89. 4th Gen H&R Springs in a 5th Gen?
  90. AE headlights how to?
  91. Problem with Starter Removal *PICS*
  92. 3/4" rear wheel spacers help!!!
  93. I feel stupid.
  94. Lookie lookie whose selling their max
  95. The worst maxima ever?
  96. Headlight aiming
  97. PIAA's and Xenon bulbs melting wires?
  98. Grille-Tech - Diamond or Race style on Sheer Silver?
  99. 2k light stalk in a 4th gen
  100. What Maxima Years alternator will fit a 2k maxima???
  101. CF hood washer nozzle hole size
  102. Quieting down the car
  103. Anyone Else With A 2k2 Kill A Throttle Body?
  104. Timing chain replacement
  105. tungsten blue eye candy (pics)
  106. Injen RD intake filter options
  107. Electric Clips w/ Green Button - how?
  108. VIS carbon fiber hood fitting...
  109. What does this P1130 Mean.. and how?
  110. Muffler clanging erynow and then ...
  111. Harm in replacing stock crankcase breather?
  112. Cooling and a/c problem
  113. ebay HID w/ philips?
  114. Those with Grille-Tech lower grilles
  115. Those with Goodridge SS Lines
  116. New Powerslots / Calipers! *PICS INSIDE*
  117. carbon fiber door pillars
  118. Suspension rant...
  119. Cheap struts on ebay
  120. Vias?
  121. Replace 2k MAF at 100k? Maintainence item?
  122. Im the Bob Ross of car paint
  123. 2 hot new HID projector retrofits
  124. blacking out chrome window trim
  125. header question.
  126. What the hell is up with premature locks?
  127. what's going on
  128. My Max just got rear ended!!
  129. dirty stockheadlites??
  130. Another VB Mod thread...
  131. What is the tread size for 5spd shift knob?
  132. SOO WEIRD!!! BRAKE PROBLEM AT 35k MILES ALREADY!!!!@$&@&
  133. Whipping sound..
  134. Kakimoto Exhaust
  135. Where is the Amp?
  136. moisture in projectors
  137. Stupid Engine Light Again TB Cleaning Ugh!
  138. battery and brake lights come on...
  139. Anyone seen these Nissan 18" Rims?
  140. My next car a 2002 M5....
  141. [B]2002 Headlamp Housings[/B]
  142. How much does it cost for a Muffler
  143. Damaged Bumper
  144. Whining sound
  145. rusty metal divider on windows
  146. Yet Another Blown MAF, I think ??
  147. UDP and starting problems
  148. If I remove the OEM HID bulbs...whats the highest in K can I go to replace theM???
  149. Trans shifts hard dealer says Valve Body
  150. white smoke
  151. Steering wheel audio control
  152. SES Light Indicates P0138
  153. cut 1 coil on H&R or S techs
  154. O2 sensor ECU reset HELP!!!
  155. Overheating in gridlock after 3 hrs driving w/AC on?
  156. Buzzing sound from tranny??
  157. Your Maxima SE suspension; height?
  158. Heated Oxygen Sensor???
  159. How's my shift knob come off???
  160. brakes shot in 5k
  161. Jack points....
  162. Did I do what I think I did? (rotor issue)
  163. ??? for those with bot RSB and FSTB
  164. corroborate information - Advanced Timing
  165. Custommaxima.com?????
  166. Just did a few mods, have some feedback for you.
  167. 2001 Front Bumper Removal
  168. 5th Gen Exhaust Clips and Pictures
  169. RSTB custom boxes in your trunks
  170. Navigation Cd MCA9
  171. Acceleration...i have none
  172. question on brake light housing
  173. Awkward buzzing sound when driving cold car.
  174. Stillen Vs Fidanza Flywheel
  175. Cattman Catback
  176. Odd Pinging.
  177. Electrical Gods....
  178. Car starts poorly, time for new starter?
  179. Automatic Transmission Test??
  180. 3 questions about brakes
  181. Need Help with fuses or relay??
  182. Those with Brembo blanks....
  183. Headlamp Sealant
  184. Painted Splash Guards to Match factory Paint
  185. What Parts Can You Swap On a VQ35DE to fit on a VQ30DE
  186. When Reversing my car it makes a EERRRUP noise, from the back?
  187. Stillen Y pipe Recent?
  188. Fold down rear seats
  189. pics of my max
  190. engine makes dieseling sound on start up
  191. can u identify this engine part 4 me
  192. 6 spd riderz here!!
  193. (Another) SES, 02 GLE
  194. Leather or vinyl?
  195. Service Engine Soon
  196. Still searching
  197. Another way to open headlight
  198. Horrible gas mileage...trying to find out whats wrong
  199. Power Steering leak?
  200. Spark Plug Part #
  201. Another Headlight Victim...but this is kinda weird
  202. Pics of SAFC Install...Hidden spot.
  203. Bored +digi cam + parking garage with city skyline = new pics! no 56K
  204. Stillen WAI on '96 fit '01?
  205. got raped at the dealer today!!
  206. Brake line prob.
  207. Touch-up paint, FLEX or NON-FLEX? Any experience anyone?
  208. GAS Tank Door
  209. Modded Stock Spoiler
  210. SES: 171 and 174
  211. 5.5 Gen to 5th gen gauge cluster swap
  212. SAFC II Setup..Sensor Type
  213. funny smell from the air conditioner
  214. clutch questions....
  215. Clear LED spoiler lamp mod....(**PICS**)
  216. To the all knowing brake members...
  217. aftermarket y-pipe with PRECATs, but higher-flow
  218. Limp mode!!!! NOOO!!!!!
  219. clarification on lighting...
  220. Power Loss After Y Pipe Installed
  221. Brembo G35 calipers...Can it be done???
  222. Will this work ???
  223. PICS and VIDEO of Kenwood KVT-815DVD, KNA-DV4100, and Kenwwod Music Keg
  224. Inline Fuel Filter - anyone done it?
  225. Infiniti M
  226. Custom pain job
  227. Change LED color in Radar Detector?
  228. window bug(?) deflectors
  229. Free Wind Deflector!!!!!
  230. SES wont reset or flash
  231. Fog Light Rewire????
  232. where to find corner light re wire
  233. When do you need to replace the in cabin filter and where can I get one cheap
  234. Any 5gen owner have 18'' 350Z wheels?
  235. Got a new exhaust....
  236. street scene side skirts
  237. strut question
  238. MAF ?'s..........
  239. Is there a site to order all these bulbs from at once???
  240. Lower Valence Grille, Irish style....pics
  241. **help install headers**
  242. new pics, sitting pretty
  243. To those who in stalled the Energy Suspension shifter bushings...
  244. Installed the STS.......got a question or two.....
  245. Need Help with 02 Max High Idle,
  246. SES Light
  247. Jus bougth a 00 max need help mech 116k
  248. noise when turning
  249. Spare Tire Space
  250. Park Neutral Switch Problem
