- Brake Line Help!
- Passenger seat creaks...
- Rotor and Caliper Weight
- '00 plenum
- S-afc Install, Someone, Please Help!!!
- engine cover emblem
- CE Light always on??
- Color spray paint used on turn signals......
- Installing new fuel filter cause check engine light to come on?
- LED's in Gauges...again
- How do I remove my seatbelts?
- sleeve cylinder
- MaX TuNiNg LiP
- 19", difficulty balancing
- Running Light Rewire - Anyone Done It?
- childseat ***hor covers
- seat handle??
- Help with #!%@%^ tranny
- b-pipe question??
- aluminized warpspeed y pipe...
- Has anyone installed after market fogs?
- Car works strange after changing o2 sensor.
- Illuminas and H-Techs are finally on
- Help with O2 sensors
- Tint: Reflective, Black, Smoke
- about intake spacer will this idea work
- What size transmission cooler?
- Any member here have just stillen front and rear lip?
- Pics of 5th gen with Konig Absolutes?
- question on indigo door sills
- Is 5th gen engine, etc... reliable??
- 5th gen carpeting?....
- Check engine light question......
- Vias Help
- Help w/ new fog light install
- Sawblades
- tune up blues$$$$. i mean... help
- Projector question.... Not the usual question (more advanced).
- front clear markers
- Ignition Coil Issues
- HS Headers Installed!!!
- Levoc shift knob
- Replacing key and keyless remotes.....
- Is an Alignment Kit needed with Tein S Springs?
- auto shifter problem
- Where does this vacuum line connect to?
- What is the real fix for front brakes on 2000 Max SE? Getting frustrated
- Clutch halfway to floor.....help anyone!!
- Hot Shot
- how much would a camber kit....
- Please help it sounds like a screw is in my engine
- question on oem body kit
- Whats the deal w/ RedLineMax.com
- D2S vs D2R in Stock 02-03 Headlights
- do i need illuminas for H&R springs or will KYB GR2 work?
- Uninstall HIDS and Install Halogen...
- New Pics of my Maxima on 19" rims (plus pics of 2 bent 18's)
- Automatic transmission Fcking up
- How the heck does this button work?
- CV boot questions, mine ripped
- broken axle bracket
- Interior Lighting problem
- Batteries for the remotes
- A/C Problem?!?
- Can a 2002 non-bose radio work in a 2000?
- Hey whats the part number for KYB frount strut mounts
- My speedomer needle is stuck on 70: what can I do?
- grinding the clutch
- At start up...
- What tire size for 18x8 350z rims?
- Steering wheel shakes when braking - not rotors
- heatwrap on exhaust
- Not That Impressed
- Dynamat Under Hood and Sound Deadening
- Where to find Passcetter STS
- Static shocks from a maxima everytime?
- 2003 kelvin temp?
- Is it possible???
- Does your auto tranny do this?
- Walbro fuel pump??
- 2000/2001 : GXE vs SE ????
- Leather 01 Gle Kits?????
- I think I'm coming bacckkkkkkkkk
- High octane (100-105) fuel found in SLC
- Yellow fog lights...
- Update on Lexan Fog light replacements
- What's quieter, Cattman or Frankencar?
- Where can i buy oem side skirts
- Power window cable snapped
- Anybody been successful putting 00/01 fogs on a 02/03?
- Question about our 3 cat. converters
- How to Remove Rear Brake...
- weird burning smell when flooring/reving up
- Brake gurus, need some guidance
- has anyone added auto up/down feature to rest of windows?
- Stolen headlight replaced...looks different from stock
- hp mods= tranny cooler needed?
- Websites for Tokico shocks and struts
- Helpppppp!!!!!
- Where is the orginal LED write up?
- Triple Gauge Pod for Passenger Side Pillar???
- Maf options?
- adjustable tint
- overhead console
- 5SPD tranny shot!!!
- Brake pros!!! I need your help!
- knock sensor
- Rear Strut, is this bad?
- Wiring Amp ?s
- What bushings in suspension do i have to change after time?
- Anybody having problems of noise when turning right or left after just starting car?
- $3000 to spend; what would you do?
- PIX of Octane Side skirts...
- couple of ?'s
- best non-HID headlights
- 2 quick questions
- New ECU
- I need 2 Maxima.org decals for my car......
- Sarona Side Skirts
- New owner - what color do I have?
- Good news on my transmission
- Eng/Tranny gurus. Can you please help diagnose this problem?
- forums.maxima.org down?
- Anyone have feedback on camber kits?
- 1157 AE corners
- 2000 gxe shock problem
- New Grill, Tires, Rims, Stereo
- brake grind noise with Brembo blank rotors
- 2002 side skirts
- where can i find octane sideskirts for cheap?
- Are Eibach springs a lot stiffer than H&R?
- Help with headers
- Front Lips
- Anyone have over 150k miles?
- Transponder Programming
- Random SES Light, Code P0455 - EVAP Control System Gross Leak
- Changing to illuminas/h&r. Any additional parts needed with these?
- What Would You Do?
- LED Window/Lock Switches Help?
- clutch
- Whine from top of motor??
- Problem loading pages on this site?
- How much longer do i have
- I need some major help!
- ABS, TCS Off, Slip Lights - No Codes Pulled
- opion's on clear/smoked corners
- Maxspeed and Illuminas going in today
- Imitation Stillen Rear fittment?
- Only when listening to cds? Anyone else get this?
- R34 Rear Conversion
- Hard choice!!!!!
- dust cover boots
- Anyone Who Knows How To Do Timing...help!!!
- How to open up the valve in the heater core to do a coolant flush
- quickie for all the experts
- 2k3 hood question
- Air Bag
- H-Tech's & Illumina's coming. A FEW ?'s though
- anyone know how to change the key ignition beeping sound thingy
- Is anyone using an AEM adjustable fuel pressure regulator?
- clear corner question
- is there a how to on.....
- 2 Quick Questions
- Any pics or info on gram light 57s pros??
- Ran over trash!
- Auto shifter stiffness?
- Installing leather/Vinyl door panels. Anybody done this on there own?
- VQ35s with knock/misfire/ping
- The NEW,aimable masterswitch LED HOW-TO; no soldeing to the OEM circutboard required!
- want to do the vb mod and get a tranny cooler
- Towing
- Aftermarket Cats
- Figured out what is wrong with new struts, now how do I fix it?
- Anyone ever use 94+ octane?
- Hids in 00/01 Housing
- Friction Band??
- Unorthodox UDPs for $95
- Got Suspension???
- Flashing OD light???
- Oil Light on start up.....
- Battery light comes on.
- clip of my exhaust
- What is it really worth
- Nissan Survey
- Starting problems - help please :-)
- Car not moving???
- 2k I30 gauges in a 2k Maxima
- Installing Splash Guards...
- Coasting In Neutral To Save Gas
- Has Anyone Tried This Intake
- Can you turn slotted rotors?
- Eibach and H-Techs, Whos got them with 18"?
- New struts and top bushings. Now a loud clunk over bumps???
- Carfax?
- 5 gen engine coil replacement
- Review: Active Tuning Custom Engine Grounding Kit
- Non-bose stereo question
- Clearence lights a b*tch...
- Battle of the 3.0 vs. 3.5 (autocross)
- Progress vs. H&R: I need your help!
- Has anyone found a bra for the AE?
- Right Bose speakers clipping
- door trim peeling off
- Engine Coil Problems 2x, need suggestions
- auto-dimming mirror rattle
- A/C problems
- Assistance Please!!
- Anyone ever heard of SS Auto Chrome HEADERS for 5th Gen??
- Dont forget about this!
- MPG Gas test
- clear corners question
- 2k maxima w/ bose door speakers....
- Vq35, TS extended rev limiter = safe?
- 2k1 AE vs. 2k1 330Ci Drag Race Outcome
- Buyer/Seller Rating?
- Michelin Pilot Sport A/S Balancing Issues
- 5.5 Gens With 6 -Speed Conversions(Step In)
- How do I adjust my Stillen RSB and how does it affect handling?
- Glovebox R&I on a 2k2....
- Wrecked the Max
- HID theft has hit Nome, Alaska
- Need Quick Help : Install Side Markers
- HID theft has hit Miami Kendall
- Rattling under the car?
- Altima SE-R exhaust?
- Splitfire DIS system adaptable to our needs?
- Walbro Fuel Pump
- 2000 GLE private party pricing?
- 2k gxe radio trim....
- Tuneup at 54k What I found
- Anyone wear out brake pads?
- turn signals on mirrors
- AVON Tech R Tires
- AT Grounding kit Install??
- 2K2 shift boot and console in a 2000
- Rear Axle
- Bank 1 Sensor 2 O2 Replacement
- Wrong size batter in my car!
- Your opinions on clear taillights...
- so i snapped the belt tensioner, but belt is still tight? help please...
- Mille Miglia EVO 5 19 x 8.5 help please
- Tranny cold shifting
- Illegal Y-pipes in NJ?!
- Another HID retro
- APEXi S-AFC II Installation
- Factory Service Manual
- Wheel locks
- Update on TB Cleaning & CEL
- Anyone running ssr gt3 rims???
- Any 5th gens hit 200K yet?
