- Window Tint Question?
- Best Prices for Brembo Blanks? Maybe?
- Why no supercharger on the 5.5 gen?
- intake set up will it work?
- LT1+T56+RWD+5th gen Maxima....
- Wheel Question?
- door sill question
- H4 Hi/Low 5000K HID Kit Help!!!
- corrosion warranty question
- question on injen cai
- New Wheels on the Max! Dubs lol
- Internal Lights rather dim
- can anyone help me install HIDs in stock maxima?
- Reset Ses
- Is it bad to always park and set parking brake?
- Power and Torque Gains from CAI and Y-Pipe/Catback
- Help- P0139/P1147
- 105 octane?
- Coming up on 50K miles....What maintenance would you perform?
- Everyone Check this out, you think its worth a try?
- Window washer not working, any suggestions?
- New Horns
- Brake line damage from rsb?
- Oxygen Sensors
- how to aim fogs in a 2k
- DRivers seat stuck
- Question about Stillen Classic Lip
- New Plugs
- MAF question
- Merlot paint, any idea how much it costs for quart or 2?
- Reference pics 01 gle with modest h&r drop and illuminas.
- 02 altima same engine as 02 max?
- After braking hard, tranny slips.
- Parts Prices
- Finally Completed My Retrofit
- say it isnt so..tranny woes????
- anyone with a retrofit?
- Help! How do I remove piston rod nut without piston turning on shock?
- Liquid oozing on my bumper
- SSBC Brakes
- is there an audible difference when your VIAS secondaries kick in?
- Is the strut spacer really important?
- PIC - 00-01 versus 02-03 bump stops.
- Water condensation??
- Selling 5th Gen Berk Intake!
- Rear passenger window question
- Upgrading standerd stereo and CC to Navigation
- Battery Dying, Alternator for 2001,
- Alternator weird pitch noise
- Motor Mounts????
- Will 2k SE cluster fit on 2k1 GXE?
- Difficult or at least for me.
- !---ABS light is ON---!
- Trunk Latch Loose - Rattling
- Few Questions on buying a 02 SE & HLSD
- How in HELL do you take this bolt out
- delay headlamps 00-01 "open door switches"?????
- anyone ever dyno a WSP Y???
- Thought You Guys Might Like To See This!
- Cooling Fluid
- Need High Quality side profile pics of H-Tech springs
- Gas Cap, Check Engine Light, 4th Time!!!!!!!!!
- 5th gen on LaughatRice.com
- Question about a new PIAA bulb
- Resale value question!
- DIY for 02 SE Radiator Fluid flush
- Tinted or autodim sideview mirrors?
- HID kit with projector headlights
- 02 loses AC
- ECU reset a sick joke?
- Finally bought a CAI
- KYB AGX for 5th gens
- SES light/No pressure in gas tank
- Wheel Bearing???? (rear caliper part 2)
- Theft Recovery 02 SE Project car for the summer
- Grounding Points again
- corner color issue on 01 headlights
- Has anyone had....
- Powerslot/Hawk HPS Combo...Just Installed
- metalmax's LED is possible!
- Getting a new engine
- Helpppp!!!!!!!!
- WTB: Throttle Body 2000 Maxima
- RPM jump at idle
- Apexi WS2 muffler?
- Rear caliper question????
- to fix exhaust leak
- My VIAS and ME!!!
- Check out these wheels please And let me know what you think!
- Can anyone confirm that hyperground kits work?
- coil problems on 3.5(5.5gen)
- Are the KYB strut/shock mounts same quality as nissan mounts?
- Pic request of aftermarket head units and install kits....
- Sprint Springs on the 5th gen
- '02 HID Headlamp burned out already.
- Turn signal side marker add-on
- Wheel Bearing Preload?
- Screeching Noise At Start Up
- ECU-to-main harness connector pics?
- Question about stock SE springs from 2002 on 2000 Maxima
- Slight vibration on the highway what is it?
- check engine light after cleaning throttle body
- short shifter problem
- i35 front end conversion
- Body Control Module (BCM). What is it and what does it do?
- 2000 max fog lights
- Front strut bar install??
- Rain in the radio
- MOMO Stealth Pedals *Installed*
- 03 Alternater----looks tight to replace???
- clear corner lighting
- Difference between 00-01 from 02-03 fogs
- New MAF.... let's see how good it is.
- WTF is going on?
- I Hate Stupid People
- Rear Rotor
- Warning!!!!!!!!
- any body bought the silver corner lights for 00-01
- New Brake kit found.
- HID bulb question
- To Weld or Bolt on Exhaust
- Ingalls Camber kit?
- Any tips on removing shifter trim to get to stereo?
- Want to see S-Tech/Illuminas on stock 17's
- threw a code need help?
- weekend forum
- Exhaust Question Greddy Magnaflow
- Do 5th gens (2k) come with a factory Alarm?
- motion sensor
- borla exhaust
- center bore hub diameter
- Is it possible to have a bad MAF, but no "Check Engine" light?
- Pic of nissan emblem on steering wheel on 2001.
- Hitched?
- Aftermarket headlights...
- The DEFINITIVE Maxspeed vs. H&R Thread
- Finally done with the modded stock spoiler *pics*
- anyone upgrade to digital climate control?
- Where do I get bumpstops/dust boots for my illuminas?
- Ignition Coil Replacements
- clear corners question
- A'PEXi S-AFC II install and tuning questions.
- 04 max bose w/screen in 03 max?
- All Red Tails 5.5gen
- Front Strut Brace on 03 with HLSD?
- Your update on CE rear smoked sidemarkers
- how to turn off airbag light?
- front lip
- 350z Rims, Everyone Said It Woundt Work, It Did
- 04 rotors interchangable ?
- Front, passenger side axle.
- quicky coil question
- Where to buy...
- burning my tires
- Comments please on H&R springs.
- How do I know if my car has the sport Package?
- Curious
- Sterling Mist with Smoked 5.5 gen headlights...
- Does ECU store info a/t mileage?
- Budget bpipe= teh ghey
- the rarest 2k2-2k3 color out there?
- avatar
- 5gen owner with aftermarket wheels, where to buy hubcentric rings?
- bought a hks rear section today
- 3M clear tape, where to buy ?
- Cracked Windshield from Heat
- replacing evap canister
- should i buy a car that's been in an accident?
- Another stupid headlight question...
- clunking or knocking sound
- Help with loud CREAKING noise.
- Front passenger shock noise
- Back deck sub question
- Helios H3 micro fog kit
- 2k2 clicking sensation in steering
- yikes...
- Rotor Stud replacement
- Factory Fogs
- Squeaking clutch pedal...
- Fogs keep blowing fuse URRRRR
- Hard Drive for music in 03 Max with Navi?
- Nissan extended warranty..anyone got it?
- ••ü•• Tutorial/Lighting FAQ
- Quick Flashin Blinker??
- Post Pics of your Custom Trunk Setup (not commentary)
- 5spd tranny ratios?
- newbee need help install rear spoiler
- good deal / fair price?
- Brake pedal drill
- how can i fix/rig this???
- 02 auto tranny question
- Nifty camera mount for autocross....
- Painted EyeLids and CutDownShifter pics
- Just installed the Rear sway bar and
- ABS Rear Lip Fitment *PICS*
- Radar hardwire to sunroof switches??
- Which tires for 2001 Maxima?
- Towing with a maxima??!?!?! possible? or na?
- What fog lights????
- More brake woes....
- Looking for the HID write up
- can we have a sticky that summarizes all good mods for both auto/man for 5gen/5.5gen?
- Help! Need advice w/ Lighting setup for my '03
- Left Rear Tire Angled IN, any suggestions?
- Rattle--possibly timing chain
- Brakes squeaking when not engaged?
- Muffler?
- new pics of my ride!!!
- 2002 Antenna Hook up help needed.....
- Headlight question
- Drive by Wire
- climate control
- Anyone out there with KYB-GR2's with stock springs?
- robbing a dealership?
- Power Windows and Moonroof Problem HELP NEEDED
- Where do you have your car inspected?
- 5th gen tranny stronger?
- Dyno numbers with Cattman Headers!!!!!
- 2001 fuse link and fuse off of positive terminal
- Rotors: Brembo vs. Frozen
- Replacing 2002 Non-Bose Headunit options....
- What do they do when thet rebuild trannys?
- Help w/ repairing 03 Titanium Edition Dash
- Transmission flushes and fill
- With new MAF is reprogramming necessarily needed?
- How much money do you have in your max
- Do they still sell PIAA Super Plasma's anywhere?
- What do you recommend
- ipod connectivity
- Energy Suspension Engine Mounts
- Headlight issues.
- Need "How-to" for HP Autoworks STS...
- Bose Head Unit
- Bad camber adjustment?
- the new car
- TCM reset procedure for 5.0th gen?
- heard chunks fall off of car
- Where to get HID Kits??
- Resetting the CPU???
- software
- 18X9 wheels?
- Safc?????
- Can you help me figure out if these are authentic titanium rims?
- More info than you ever thought you needed to know about Oxygen Sensors
- Brake part pricing info
- oil catch can and 3.5 ping / knock
- RSB Installed On Lowered Max
- Which aftermarket shocks best for stock struts, while still maintaining a good drop?
- 2000 coil pack removal
- water in headlights?
