- o2 sensor simulators?
- upgraded ignition ??'s
- body kits....be constructive!!!
- Supercharge my Max or get new car?
- 5th gen Chrome Engine Dress Up Kit
- full exhaust questions
- loud click when turning...
- 5th gen in wa?
- Loud ticking...
- Brembo blanks/ Hawk HPS, Question???
- FS: frankencar intake
- i want grandma brakes !!!
- anyone gone back to stock exhaust?
- Flowmaster 50 vs. Greddy Muffler
- Car starts poorly, any solutions?
- Ouch - road projectile!
- **best place to order brake pads??
- 2002 trans oil change
- Curb rash repair...(Help)
- Clutch???
- Niteshades question
- $1.99 ebay FSB!!!
- Replacing CV boots...Anyone done this?
- just got my FSTB
- Best PSI for Yokohama Avid V4S?
- kicking in the VIAS sooner
- question about headlights
- I have to show this pic
- Ever felt the steering wandering??
- Speedometer problems help!
- Posting and you...
- 01 faulty wheel bearing with jics?
- V6Performance.net Ride of the Month nomination!
- Side molding all scrathed and gouged??
- POLL: Coilover Setups - Happy or Unhappy
- Frankencar catback
- Help Changing brakes Cylinder wont compress!!!
- question about warning lights??...help
- Need quick help on rear brake sliding pins
- hardwiring passport x50
- Buying a 5.5, which should i get...?
- Is this a good deal for a 5.5
- Hotshot Headers are in!
- 2k1 door panel removal
- Reverse-brake-*clunk*
- 00 Maxima - Amp. Remote Wire Color
- Otto Racing FSTB
- Quote for bumper, hood repaint?
- Boing? Rear Solid to Independent suspension conversion
- Blinkers dont work. could it be.......
- LSD in a an auto?
- Will 2004 rotors fit with modification?
- Spark Plug Wires
- XM Installs
- pics of nht tail light tint on the SE tail light wanted
- 2001 AC drain and Refill procedues and tools needed
- Who wants honey?!
- Someone Needs To Make A Camber Plate!
- running the 1/4
- Anyone with Cattman Catback whole exhaust???
- HID headlight got fogged up. *HELP*
- ***MAD*** My driver's side AE side skirt won't stay on
- Blown Strut...NEED HELP FAST!
- I need a new drive belt...which to buy?
- HomeDepot: PCV Blowby Oil Catch Reservoir
- Those with 2002 maximas step in
- 3.5 in a 2k
- Place Racing Template
- Rim Question...19's
- Magnaflow Tips
- 2k2 Auto Max is stalling and dropping revs
- Injen Heatshield Gains
- STILLEN FRONT BIG BRAKE KIT post pics please
- Someone will get ripped off...
- AE Headlight Mod, problem...
- Rusting already :mad:
- intake?
- 2K2 02 Sensor Installation
- b pipe woes...
- Techies Please Help!
- A question about the rear shock piston rod nut.
- where can i get exterior door handles?
- What key is used to open the backseats to trunk?
- Replace intake gasket w/ spark plug change?
- PIAA wipers
- NEW PRODUCT- Samco hoses
- New Stainless Muffler Tip Opinions Needed
- How much lower w/ Stillen Rear Lip?
- side graphic
- adjustable camber plates
- What size are the lug nuts and what thead?
- What's up with this Computer Chip Upgrade
- HID Projectors as fog lights
- Major Evap Leak
- 2000 Fuse panel
- How to get ECU Codes on 2000
- Canadian Maxima Headlight Wiring Codes
- Why???
- help with dealer service invoice.
- Same old coil problem
- RSTB Or Rear Sway Bar???
- Cluster Illumination Lights go out
- what do u guys think?
- ppl with PR cai installed ... Question
- 02-03 Body Kit Opinions/Suggestions
- 5th Genners names' in urban dictionary.
- 3.5L Maxima HP question
- $700 for lips install/paint?
- Heard a bang while accelerating
- Have You Guys Heard Of This?
- how long are the brake lines???
- Dealer Discounts
- Maxima Fuel Injector Cleaning
- What actually makes a diffrence ????
- Put 20th AE pedals on other Nissans?
- What Do you think? Alive or Not? that is the Question
- Surprisingly Good Inspection in NJ
- "Idle Position Sensor"...same as "Throttle Position Sensor"?
- tire sizing question for my 01
- Thoughts about rear-windshield spoilers?
- anybody do their own tint job?
- Maf gone
- Does brand matter when it comes to wheel spacers?
- Tranny Fluid Change = BIG difference
- car trouble
- ambient air sensor in '00 and '01
- Some 5th gen (and 3rd gen) autocross pics
- Anyone replace Strut mounts with new struts?
- Show of hands...MAF issues once intake installed?
- Squeaky brakes after a month?
- Throttle body noise?
- ABS Light on what can it be??
- Broken wheel-stud.
- Bad bad day. How much for a new windsheild?
- Question about intake midpipes...(breather tubes)
- few mod quetions
- $1,000 to swap cars?
- Headlight Bulb Replacement
- Removing trim inside rear glass....
- Hmm, can't contact about rotors...
- Illumina Horror Story
- Loud noise coming from the front of the car
- Ignition Coils Question
- e-brake "brake light"
- Rough Idling... Not Ignition coils
- Today i almost divorced my Maxima...
- Flowmaster 50 Which One to Order Help!
- Installed the FC intake, but having one problem
- TCS & ABS & SLIP lights all on, anyone has any idea why ?
- Magnaflow Mufflers?
- Dash Kit Question
- Holy crap 3 New Nissans in the family in 1 week!!
- dimensions and weight for 5&6 spoke rims
- NJ Max Meet 2k5!
- Pic's of 350z Rims with tires
- Quiet Muffler for a 2002 Maxima
- wat mods for an '01 to put on for $1.5k
- pothole killed my rim; questions
- Alternative Foglights for 02/03
- 02-03 Ebay Headlights??
- tried my VIAS JB Weld fix, FAILED
- could this throw the code????
- Berk Technology Intake owners, come on down!
- hlsd tranny swap
- KP Technologies windows up module installed...
- Black rims on Sterling Mist
- Tein EDFC Install
- can anybody tell me how to remove this
- Does the inside/outside temp come standard?
- How can I get better MPG? 03 3.5L
- 2k maxima SE es sway bar bushings
- Metal to metal noise left front wheel.Helo.
- three tires in 6 months.
- Throwing Codes Out All Over the Place Help!
- lookin for a little more bump
- Apexi WS2 rear section installed
- Car sitting weird
- 2000 Fog Light Install
- Where to get clear sidemarkers.
- Need the Shift boot plastic trim piece on a 2k2 SE 6spd...
- Machinned Rotors, clanking noise??
- 2000 -2003 Maxima production numbers
- Anyone install a stillen classic lip where it can be removed for winter?
- Service Manual for 2002 Maxima
- question on AE lip kit
- what if i f**kup my O2 sensor??
- P1615 what is a NATS Malfunction?
- question on installing rear.....
- Anyone Have 5th Gen and 5.5 Gen Sales Numbers?
- quick question
- Any cool grill inserts for the 2k3?
- Possible to have killed MAF?
- Best foglight bulb replacements?
- What bulbs go in front side markers?
- hard to shift into reverse sometimes
- Anyone know how to do this?
- I think I F&*%ed up...
- What is this fin looking piece called?
- Rapidly blinking tail-light 2K1
- Do-It-Yourself Maxima Wiki (encyclopedia for how-to information on repair/tuning)
- How To
- Car Stalling
- drove a 5th gen for first time
- please help me decide on a rotor and pad combo
- Nissan Key
- 2002-03 Foglight bulb
- Confirm SES reset instructions.
- 2k2 SE NAVIGATION CD-ROM QUESTION-BACKUP NEEDED
- How to check which Ignition Coil(s) needs replacement?
- IAC Valve Cleaning For Smooth Idle
- new to this site. some ?'s
- HIDTech Yellow foglight capsules
- Buying maxima stuff on Ebay
- Finally got my 02 Maxima back from the body shop after 31 days!
- Grille Tech install on 2k2??
- ebay black projectors??????
- 2K3 Maxima - Clutch not releasing? WTF?
- 00/01's with HIDs answer this please...
- Battery and Brake light came on while car was driving
- Plz Help clunking noise
- 2001 Nissan Maxima Coolant Bleeder Valve Location
- Rear Break Pad Question, HELP ASAP
- DDE's + tinted headlights
- Quick question on use of steering wheel controls with aftermarket HU...
- brakes cleaned..
- Keyring Color change write-up?
- New clutch @ 43k!!!!!
- im not sure, is this correct
- Redlinemax.com- New front bumper available soon!!!
- Radar Detector Mounting 02 Max
- What Illumina settings are best for city driving?
- LOL...check out the bargain of the century for spring installation
- Need help with O2 sim install.
- Feel bad, like I'm beatin on my car
- Rear Rotor Min Thickness (Odd Wear Issues)
- 2002-2003 Bose Headunit Repair?
- Its Been awhile
- New pics of wheels, what u guys think?
- How to PROPERLY install a FSB?
- Tokico Blues installed today *pics*
- Auto Climate Not Regulating
- Aftermarket cams
- highest 2k2 mileage?
- Rotor Rust
- P0455 Evap System Gross Leak (not a question thread)
- 2002-2003 Headlight Disassembly
- Automatic "One Touch" Window Roll-up
- 2002 Maxima Aftermarket Suspension
- Problem with steering wheel controls!!
- quick fitment questions...
