View Full Version : 5th Generation Maxima (2000-2003)
  1. Secret Weapon Intake??? Anyone?
  2. Benefits of Oil and Tranny cooler
  3. tokico illumina shock and strut new boots
  4. Airbag system on a 5th gen?!
  5. ebay projector headlights for 02-03 folks got a few questions
  6. FrankenCar Cold Air Intake System
  7. add this to the quick reference...
  8. good read on oil.
  9. Need Brake Pads and rotors,any Suggestion?
  10. 00 Cali EGR
  11. Timing Advance
  12. HID Head Light Adjustments
  13. help help help.
  14. New TWM 2nd Gen Maxima Shift Adapter
  15. Redlinemax.com-5th gen bumper, So Flexible
  16. People with Momo Ebrakes, Come in pls.
  17. A Present From Me To You
  18. Did some test drives...still love my Max!!
  19. Where to buy OEM Splash Guards for Maxima?
  20. What will happen if...?
  21. Header fitment
  22. HVAC bulbs ?
  23. Brakes viberate in reverse
  24. The Dealer Can Bite Me New TB
  25. Considering buying a 2k2 SE...but it has a couple problems
  26. P1320-Ignition Signal, what would be the cause
  27. JET V MOdule verses SAFC2
  28. where can I get a key and key fob for cheap?
  29. Cattman Y-Pipe News
  30. Wtf: Brake Failure Obo-74,000
  31. ECU Update...?
  32. squeeky windows
  33. Updated pics (56k, just get DSL already!)
  34. Brembo distributors
  35. 2001 Headlights
  36. 2001 Wind Noise TSB confusion
  37. Leather covers!
  38. Anyone w/exp on tranny coolers???
  39. Weird smell coming from the a/c
  40. black leather/vinyl match for 02-03??
  41. Stock OEM rotor?
  42. Does anyone know what kind of steering fluid 5.5 gens use?
  43. Slipping clutch.
  44. To keep or not to keep?
  45. Problem with AC
  46. shifter bushing heaven
  47. Help with HID bulb replacement
  48. Apexi SAFC
  49. Started Getting Some Buzzing......
  50. ported intake manifold
  51. For you guys who haven't auto-x'd your 5th gen...
  52. Nismo Front Brake Pads
  53. Some Help
  54. P1065-ECM Power Supply Circuit...help needed
  55. $155 for custom piping ??
  56. polarg dome bulb?
  57. addition of headers??????
  58. Torque Steer or Bad Motor Mount
  59. HELP ME PLZ!!! ...Slipping 2000 Tranny...
  60. JWT Filter-does it hook up right?
  61. Brembo Crossed drilled & slotted rotor's
  62. Headers/Catback or Coilovers First?
  63. synthetic Brushed Aluminum verus real aluminum dash kits
  64. White Headlight Housing??
  65. quick vias question
  66. Any 5gen have just Stillen front and rear lip?
  67. Own a light colored Max? Step inside please...
  68. Battery Leakage Causing Rusting
  69. g35 sedan muffler on a maxima?
  70. my car wants to stall
  71. MAF Sensor Instructions...?
  72. Replace MonsterFlow Air Filter?
  73. How to replace MAF sensor
  74. Alignment Question
  75. Stillen intake?
  76. P0171 - How do I fix this??
  77. 03 Brakes?
  78. Would these wheels look good
  79. Custom Fit Car Cover!
  80. Thought You Guys Might Enjoy
  81. TSX Projectors, Done! Some pics...
  82. Trunk mat question
  83. Steering wheels shakes above 80mph.
  84. How to install spark plugs?
  85. Door rigger wire color?
  86. Changed Filter now get Bee's in the Can Noise
  87. 5th gen owns 3rd gen and I30 (NOT street racing)
  88. Cold Cathode under dash Lighting Pics!
  89. Check Engine Light is alway on
  90. parting ways with my 01
  91. opinions on buyin a 2k3
  92. anyone tried "baking" the ebay/cm tail-lights?
  93. Sticky for Newbs
  94. Tein Springs
  95. RPMs drop and car turns off...
  96. Reverse Glow/Indiglo Gauge Install
  97. Need Help!!! Leaking OIL!!!
  98. Two exhaust options
  99. Must read for HID upgrade/info
  100. 350Z track wheels
  101. I need help from 2k3 titanium edition owner
  102. Help troubleshooting flasher relay? Have searched..
  103. Air Filter Replacement
  104. Questions on software update/reprogram of ECU
  105. How many LBS of Torque for RSB?
  106. atf change help
  107. how to flush the cooling system
  108. H&R springs
  109. O2... help... (FAQ read)...
  110. instrument cluster too dim?
  111. State inspection
  112. Jim Wolf Technologies flywheel
  113. Kamikaze Body Kit
  114. LTB Clearance pics....for those who asked
  115. So i did the home depot lower grille...
  116. hello all
  117. Ignition Light Ring
  118. ebay lip spoiler
  119. those that have had bumpers repainted...
  120. What does the transverse link look like?
  121. Just another thread thanking DaveB for his help.
  122. Engine rumbles at 2000-2500 rpm
  123. question about transmission..
  124. CV joint replacement or worse?
  125. smithhaven mall meet
  126. Custom grille?
  127. Evo Body Kit
  128. Deal on a new Cat???
  129. My car...
  130. Best UDP for 01 Max?
  131. quick help needed!!! shifter bushing install
  132. Flowmaster 50 Review
  133. Idle Air C0ntrol Valve For 02 Help!
  134. For those with Tein H-Techs / Tokico Blues Combos...
  135. All components that connect strut and shock to car
  136. ES bushings for LTB II
  137. I hate my pink clears
  138. Is this an emergency?!(inst panel lights)
  139. I35's with electric rear sunshade...step in..
  140. I35 sport side skirts on 01 max?
  141. Motorola Bluetooth Phone Kit HF850 Installed Pics
  142. brake lights don't work
  143. weird block on the clutch line
  144. hood fitment
  145. Ign. Coil problem solved...
  146. O2/ Knock sensor problem.. Neeed some help..
  147. is this poor gas milage? what could be the cause?
  148. Quick question
  149. PIAAs blew.
  150. Brake Pads BOSCH PADS?
  151. bad alternator at 32k
  152. Budget y/b pipe opionions plz
  153. Funny Maxima sale someone will get stiffed
  154. Windsheild Replacement
  155. side graphic... opinions
  156. need to know how to change xenon bulb! ASAP
  157. brake problems
  158. triple gauge pod mounting Q???
  159. Will rims that fit on a 99 Chevy Xtreme Blazer fit a 5th gen Max?
  160. Quote on repairing 17" 2k3 rims?
  161. Maxima rattling below 2000 rpm
  162. e-brake light on - sensor?
  163. The controller on the steering wheel
  164. Removed ugly wood...
  165. Bosch Xenon Projector Retro (56k ...prolly not)
  166. 02 Sensor Location Diagram (00-01 Cali Spec)
  167. Bad auto tranny?
  168. 00 Engine questions
  169. TB High Idle Fix - Jump In Here
  170. Suspension Question: Bounce - struts or spring?
  171. anyone ever try yellow ion halogens?
  172. AE Auto Shifter
  173. Paint Jobs?Need help guys.
  174. Why do fellow maxima drivers hate sooo much????
  175. Need confirmation of timing advance in Canadian 02max
  176. Best Place to buy G35 18"s
  177. JDUBS kit is now available... full kit or bumper
  178. Exhaust Leak?? Input needed.
  179. HELP.....please post your thoughts
  180. rear clear marker install
  181. Syndicate Kustomz eyelids painted & installed (56k, nobody likes you)
  182. Will standard h3 HID bulbs fit 02-03 Fogs?
  183. help please! need a new catalytic converter
  184. Hot weather + easy driving =
  185. A/C for 2002 Maxima
  186. Phantom Grip
  187. Dashboard clock rattle
  188. Tanny questions
  189. Climate Control lights to be changed
  190. 02-03 Grille fit on '01?
  191. Basic Suspension Package from Cattman review
  192. So I took apart my Umnitza DDE Ballast
  193. Tranny issue, just went away?!?
  194. New discovery- brake pads
  195. Anyone take out leather seats from a junkyard car and use them?
  196. Another MAF.....
  197. Tips on installing Stillen Classic kit
  198. Idle Sensor Question
  199. Lexus Fogs on my 5.5 Gen - PICS -
  200. maxima emblem?????
  201. Clutch options for 5.5 gen
  202. Word of Caution for 5.5 gen KYB GR2 owners
  203. Lowering Brace Under Y-pipe-How Low?
  204. P0135 Code...02 Sensor...Nissan vs. AutoZone
  205. Im going to smash my console
  206. car back from paint shop and the hid fog light will not work now
  207. changing bulbs in an 01
  208. Valve body and torque converter?
  209. Replaced coils/plugs. Still have P1320??
  210. 2001's (ONLY) with in-dash monitor
  211. SE emblem
  212. brake rotor/pad help
  213. Tv Headrests With/without Tvs
  214. transmission cooler
  215. Sticky? Fog Light/Headlight Comparison Thread
  216. Can anyone help me out?
  217. Finally Got a 5th Gen
  218. How to install the AE Kit?
  219. how to remove the rear parcel deck completly?
  220. Replacement Injen Filter & Brake Rotors
  221. More power when engine is cold?
  222. is this a joke???
  223. 02/03 headlight Q
  224. Need new tires and rims soon. Any suggestions?
  225. Piaa Fog Lights
  226. Need help removing rear license plate holder
  227. Starting Max From cold start it jerks untill engine is warm
  228. Videos of my newly installed WigWags/Rear Flashers
  229. home depot grill
  230. Has anyone put in a 5sp auto tranny?
  231. Can somebody measure the height and length of the 5.5 grille?
  232. installed new oil catch can
  233. Bosch Platinu,4 vs NGK Platinum
  234. Car is stalling..
  235. Installation Instructions for MattBlemcho Grouding kit?
  236. Broken Bolt
  237. Computer Tuning?
  238. Cleared Hid and Hid Fog Pics
  239. Stock horns...ground wire?
  240. Another source of "lost oil"
  241. Carbon fiber eyelids
  242. Stumped!
  243. WANTED: Those whom have had their 60,000 mile maintinence done...
  244. Warpspeed Y-pipes
  245. Going for new paint & graphics
  246. What size optima are you running
  247. Exhaust Banging Need Advice Please Help
  248. auto rpm shift points
  249. 02-03 maxima vs. 00-01
  250. valve cover...
