- Unorthodox Racing Pulley
- How stiff
- wheel shimmer and noise
- Installed NGK Iridiums
- Timing chain rattle?
- Question ABS 2000 owners?
- Bumper damage
- yellow dot on 02' MAF??
- CRAZY method to get into your car if you lock your keys inside...NO TAMPERING REQ.!!!
- question on door sills
- Cleared HID's today.....WHEW, finally!!
- AT : Hard to shift from park
- little problem with a check engine light HELP!!
- curb rash, any suggestions
- Anyone have these springs?
- Cheap cat-back for 2k, new car in Jan.
- Anyone have a Bi-Xenon kit on the Stock 00,01 headlighs?
- Low RPM's and power
- Front motor mount stays on and makes noise
- OBD II cable and laptop??
- Anyone know who's max this is? NO 56K
- window tinting
- Street Scene Grille??
- Keep the center caps or no?
- 02 3.5 Custom "B" pipe questions
- Headlight Poll
- HotShot Owners Step In
- '03 Owners....need Advice
- '00-'01 Diamond black headlamps??
- Back Of Seat Coming Apart
- New in-car computer for 5th gen....
- HOW TO: Remove after market dash kit????
- Leaky spark plug O-seal...
- 2003 Brake Job How-to?
- Locked my keys inside... HELP
- i hate the transmission ratio on my 5spd
- Nissan complaint center
- 2 questions thats been bugging me
- Interior redo
- 350Z Exaust on an 02 max????
- Please help diagnose suspension noise.
- Brake Pads and Rotors are so necessary.
- 03 maxima price question
- new clutch installed
- Buying an 02 6MT with 104k miles ($12k)
- 5th gen battery power wire
- grinds into reverse
- 5/32nds in only 9k?
- State Lighting Laws...?
- Rear Smoked Sidemarkers From CE, "Interest Thread"
- Car got backed into ... trunk damage
- Looking for info on plastic nose covers
- Random Insane SR20 thought
- Nokya Headlight Bulbs
- oem exhaust parts needed
- Want HIDs on my 2001 Max
- gettin' back into the max game
- Steering Wheel leather replacement
- Climate Control... What do you think?
- frankencar exhaust problem
- New maf, smooth accelaration!
- How long till new Cattman Headers???
- 6spd 350z tranny in a 2000 maxima se??
- auto headlights reaction time change
- Full Service Manuals 1994-2004
- High RPM...
- Magna flow exhaust tips
- What to buy
- buying ebay piaa's....these really them??
- Can defective coils be returned?
- DDE's Dead
- 430 Error Code
- Yet Another PowerSlot thread(new install impressions)
- Gas tank needle goes up while driving...why?
- What do you think about this for a 5 gen Maxima?
- Door, map, visor, trunk lights & key fob not working...wtf, how do I fix?
- Cat failure (why and how to not have it happen to you)
- Bought me some rims!
- Went to get an oil change....came out confused about oil filter
- LED Tails - Question.
- hot shot clearance issues.
- Repainted Maxima
- Where to buy KYB bump stop/ dust boot?
- i didnt drive my max for 6 weeks
- carbonfiber hood
- Broken side skirt...help
- z rims
- which hid kit in the GD section is better?
- spark plugs
- AC leaking excessive amount of water?
- 02 gets some new shoes
- when does the radiator fan come on? can it ba damaged?
- here comes another week without my car....
- Bridgestone recall
- Oil in one of my spark plug cavitys...
- header install/motor mount/bad idle?
- Only one tip on the exhaust is releasing..
- help. Problems w/ ABS,traction control
- Lease is coming up, What car should I get
- Car got scratched!
- repairs at dealership
- Left front speaker off with cd only
- Seats are too thin?
- Steering shakes under braking, new brakes.
- help needed....steerin wheel shakin
- Bosch MAFs
- Replacing O2 sensors HELP please
- ugly header heat shield, dont need it?
- Does the 02 GLE have side airbags?
- Is the interior of the Maxima stock?
- Flywheel recommendations anyone?
- What fuel grade do you run in your 5th gen Maxima?
- getting a bit frustrated!
- putting 02 tails in a 00
- Springs
- Strange starting noise
- Rockauto.com coupon expires Aug 30th
- Maxima Experts, Please Step Inside
- an e46 bixenon retro...done
- 2000 GLE Charcoal Grey-Window Tint
- Will it fit
- question about i30/i35 and the maxima
- How to reset airbag light? Help please
- 02 MAF Adapter -
- Driver seat motor
- Ran 1/2 tank on regular...
- Maximas off but making noise!!! HELP PLEASE!!!
- No More Push Starting!!!
- 5.5 Gen that are Currently Running Axxis Ultimate pads(Step in)
- Xtec Fog Light Owners - Similar Problems?
- Dying motor
- foul sulfur smell gets inside cabin.
- whos hap[y with their magnaflow?
- Best air intake
- Gutting Cali Front Pre-Cat
- need brakes
- Catalytic Convertor
- injen intake for 2k2 max
- Pulling intake to change spark plugs, where to disconnect from airbox side?
- cattman muffler
- 2002 guys with sunroof switch please step in..
- withdraw pains
- upgrading from a 97 to an 02
- when clearing headlights???
- P0139 & P1147 - ORG gurus please help!
- 2000 Gxe vs. 1998 Se
- window tint
- 2002 SE Valve seals bad
- Rattling when I let off the gas...
- Weird issue with '00VI.
- SES Light - Code 1380?
- Anyone have Tein EDFC Electronic Damping Kit?
- P1456 Code
- Turning over issue.
- Installed Tokico HP w/stock springs
- switching to regular gas?
- Tokico Illumina Suspension Kit
- Spark Plug/ Coil Pack problem
- omg i want these!!!
- Cali spec or Federal
- Best place to mount ballast
- 5.5gen HORN idea!
- Paint Code Front Grille
- P0135 - Location/How to Access 02 Sensor for Replacement?
- 00VI/VIAS Mystery Problem
- Left Headlight Out!
- 02-03 OEM HID stock wattage?
- Need A Response... Fast!!!
- engine surges when braking
- VQ35DE oil burjning issue - step inside
- CT Stuff for Sale-local pick up
- Getting a 5th Gen - What do I need to look out for?
- rear suspention pain...help
- P0011 and P0021
- For 5.5gen guys(vq35)
- Apexi Air Filter
- Wierd Problem with Foglight Rewire
- Weird Steering Issue
- A Question about vq35 injectors
- If You're Thinking of Going Aftermarket Navi w/ SIRIUS *PICS*
- A/C is not cold anymore....
- Need test-fit car for 1st set of new Cattman headers
- a/c problems! help!
- wats a good oil filter?
- weird sound comin from right front brake
- tranny fluid choices?
- installing STS
- aftermarket intake information clarification
- Did the 2001 GXE and SE come with different manual transmissions?
- problem after tune up
- 00-01 Maximas with P1320, step inside.
- cali spec y pipe
- Color Shift
- Nismo CAI
- P0430 and will under 90day 3000 mile lemon law
- Where to buy Raybestos QS?
- Painting headlights
- where is the plug for ODBII scan?
- Get 15 more horses power for $50 seriously.
- can i do this? "intake"
- question on brake kits
- how to remove front door panels?
- Cattman ypipe -bolt size
- oil-fouled spark plug
- What'a up w/Umnitza's predator lights?
- SOMEONE ELSE please make SFC's for 5th gen!!!
- Having problems installing clear corners...
- Another rim thread(opinions please)
- Is Warpspeed the only company that makes subframe connectors?
- 20th Anniversary Edition engine/valve cover
- clearing headlights today! [scared]
- Window Motor dieing?
- new tires, sloppy handling????
- BBK owners?
- Opinions!!!
- Opinions!!!!
- BEWARE of Throttle Body Issues!!!
- AC Controls doesn't iluminate any more
- Finally Fixed High Idle
- Looking for a 2000 manual swap part list...
- OMG LED's are great!
- Does ANYONE here have Philips Ultinons?
- GAB low-end concerns
- Stupid Question RSB
- Need Some Advice Cant Find In Search Car Hesitated!
- Popular settings for the Illumina struts and everyday driving.
- H4 glare shield
- Oil + Filter Change for VQ35DE engine
- Feels Like I Am Towing Something
- is 5th gen clutch soft or do i need a new one?
- help - unusually low idle
- 2k2 headlight conversion problem
- I need to balance my sound...
- Trailering/Towing Max
- How to adjust e-brake
- Carbon Hood vs Stock Hood
- where has warpspeed been?
- Maf 22680-am600 Is Weak!!!
- Exhaust flow... 2000 Auto GLE
- clicking noise from clutch & throtle...
- Rear section swap/install...no lift...good times
- read before commenting Need a link for replacing spark plugs
- Intake Hose Connection...
- 2001 O2 Sensors
- need some help....
- Umnitsa HID FOGs installed...WOW
- Headers, Install, ???
- These Error Codes...
- Axxis/PBR Metal Masters vs. Hawk HPS
- Too good to be true 5th gen for sale?
