View Full Version : 5th Generation Maxima (2000-2003)
  1. Ping sound after installing B pipe
  2. Help - Front left tire shakes
  3. To lip or not to lip ????? Well I lipped. (pics inside)
  4. Helios 6000k HID Video
  5. Plenum Spacers anyone?
  6. rims on H-techs
  7. Radiator Flush Procedures Needed Immediately
  8. Headlight adjustment
  9. Where to buy used stock NAV system?
  10. adding amps to bose
  11. budget y pipe
  12. who as nich inch wide rims???
  13. Tockio Illuminas w/Tein S-Techs
  14. Difference between trims?
  15. does anyone have repair manual for 01
  16. Need Help Replacing Fog Lite Bulbs
  17. Front clip
  18. SwitchBlade Keys for the max
  19. Radio Code
  20. ss brake lines warning
  21. ATF change question not asked before
  22. 02/03 maxima grill
  23. winter wheel question
  24. for people w/dash kits
  25. multi problems
  26. Stock Alarm Sensativity Adjustment.
  27. How to install 1970's style steering wheel
  28. Invader Type 6 carbon fiber hood...
  29. Anyone have a very very dim check engine light at certain times>
  30. another suspension problem, need help
  31. 2000 Max CLUSTER SWAB
  32. brakes pads question need help!!!!!!!!!!!
  33. high mileage questions....
  34. Had bumpstops trimmed today...(well...they actually trimmed themselves)
  35. Few Questions on switching radio receiver
  36. Best Rubber Exhaust Hangers for Cattman Cat-Back?
  37. What about if remove P/S and A/C ?
  38. Pics Please
  39. AT Fluid change - need answer ASAP!!!
  40. Need help from a owner of ......!!!
  41. engine question..sort of
  42. how to remove seat?
  43. Wtf!!!!
  44. Replacing MAF tool? WTF
  45. back of the car improvements...
  46. Are these Progress Spring...wtf
  47. removing aftermarket wood trim
  48. Quick Question
  49. Some general questions about 5th gens.
  50. Sterling Mist with same color grill? Pics?
  51. Lsd????
  52. Are my headlights (HID) normal??
  53. A/C blower motor replacement??
  54. Stock Exhaust Leak on Front Bank of engine
  55. When do you need to replace suspension?
  56. Does Eibach not make a pro damper kit and anti-roll bar...
  57. Rigging Remote Starter on a 6spd
  58. Class Action Lawsuite (headlight Theft Issue)
  59. what u guys think of this deal
  60. does anyone have the ebay grill on a 2000 pearl
  61. DDE remote on??
  62. Jdubs Kit Here!
  63. need so brake rotos advice
  64. Please Help ASAP! Taking off Rear Rotor
  65. Few Questions about the Cattman 3.5 Y-Pipe.
  66. Brake Light On
  67. How much Brake Fluid?
  68. AC Vent cleaning?
  69. will 4th gen and 5th gen coiover swap over
  70. Which Exhaust Gaskekts Needed for.......
  71. Someone Trashed my Car
  72. NEW Brakes (advise) SERIOUS PPL ONLY!!
  73. Bronze Caliper Paint
  74. 6sp MT, shifting into reverse
  75. "Thunking" noise
  76. Inlet size for stock 5.5 gen muffler?
  77. Brake pads Q's
  78. Impression on the D2 after 6 months ride...
  79. eibach and tociko blues work or will blow the shoks? or oem spings with blues?
  80. O2 Sim Problem? Help
  81. Need a bit of information from 02-03 owners
  82. What did your VQ3.5 timing chain rattle soudn like?
  83. 5th gen standard features
  84. Climate Control Lights burned out
  85. Am i using too much fuel?
  86. Front Strut Dust Boots Torn Off
  87. Custom Performance Engineering/MAFci System
  88. HID Replacement
  89. Help angel eyes
  90. carfax
  91. Frankencar Intake
  92. OD not engaging properly
  93. Weird noise coming from exhaust area?
  94. anyone with a greddy emanage ultimate?
  95. Can a stock 5th gen air box fit a 4th gen?
  96. headlight problem
  97. Tokico Illumina questions??
  98. Photoshop request
  99. 02'-03' Grill Fit 00-01'
  100. ignition bulb
  101. ABS on/off switch
  102. top pro 1
  103. problem with clutch
  104. Whining noise from clutch
  105. New wheels and tires
  106. Need source for ball joint
  107. Personal Web sites for maxima
  108. Max with HID Headlights and Yellow Fogs Pics??
  109. Installing Headlight bulbs
  110. Rookie MAF questions
  111. !!! I brought my MAF back to life!!!
  112. fog lights
  113. Wireing diagram guro's step in
  114. 4th gear pops out when normal shifting
  115. ding ding ding.... (COMPUTER BEEPING)
  116. Double Din Hu
  117. Totalled my baby..i cant find the words to describe it
  118. Modded Injen...
  119. no one talks about Stillen Y pipe...
  120. Busted VIAS? Torque Converter? Dammit...what's wrong with my car?
  121. Cleanup 5th gen FAQ
  122. clusterlights dont work when headlights are turned on !??!!
  123. dyno horse power problems with my 2k
  124. have you put heated seats in a non-heated seat max?
  125. How are the new Cattman Headers?
  126. Downshifting in auto = bad, right? Clear this up for me then...
  127. MAF Replacement, pictures anyone?
  128. headlight wiring diagram
  129. oil leak
  130. This is wired
  131. Need Help - Brake & Battery Warning Lights
  132. AutoMeter Pro Shift Lite: Help Needed
  133. Strange Noise when turning wheel to the left, Any Idea?
  134. Annoying sounds - Rattles
  135. cabin filter
  136. Alternator belt ?
  137. exhaust tips for 5.5 gen
  138. GLE vs. SE Suspension - Struts and Springs
  139. RT Cat Opinion??
  140. IAT Resistor. Does It Work?
  141. lower grill pics?
  142. Jet Game 09-25-05
  143. Helios 5000K HID kits
  144. lightly oil leak/drip, will "stop leak" work????
  145. Tools needed for a rotor and brake pad change
  146. Meeting with a drunk driver
  147. Helios Hi/Lo Hid Kit
  148. strut/shock boots ripped up, do u really need them?
  149. Foglights dont turn on or Gauge light?
  150. engine mount problems........ again
  151. eBay aluminum dash kits and retail dash kits. What's the difference?
  152. interior of new max?
  153. Camber Adjustment Slot Struts...?????
  154. Shaking of the Steering wheel at 70mph+
  155. anyone here have a roll cage?
  156. exhaust pics
  157. Valve Body ordering Site
  158. Stock Struts worn out, what to replace them with?
  159. LEDs in Turn Signal Housing?
  160. Anyone make a Torsen diff. for the 5.5 gen?
  161. my leather seats are all beat up
  162. auto shift knob
  163. Is this a good price? [Tokico]
  164. sqeaking noise and burning oil
  165. Chrome trim around windows
  166. 00-01 Foglight Bulb Replacement How-To? (Link broken)
  167. Stealership bendin me over?
  168. And now an electrical problem
  169. Strut Mount / Streat Bearing
  170. Street Scenes/Stillen grill painted black?
  171. Customizing Big Brakes
  172. Injen CAI vs. Fram Air Hog
  173. H3 Bulbs for Fogs that match 6000K HID kit?
  174. Looking for Info:Control Arm Bushing Replacement
  175. Couple of questions about my new 3.5L ('02 I35)
  176. 00-01 Blinker Bulb Recommedation for Hyper White?
  177. Yet another strange sound
  178. stiff springs....minimal lowering
  179. please help! repair questions
  180. "Reflashing" the computer?
  181. HID conversion for 2k-2k1
  182. intake vs. header
  183. Moonroof fuse
  184. Is it normal for the gas mileage display to be too high?
  185. 0302 & 1320 How do I fix this? ? ? ? ? ? ? ?
  186. y pipe
  187. Check engine, SLIP, and TCS light...
  188. This Sucked but I think I got Lucky
  189. Product to remove scratch from windshield
  190. something funky with rpm's or maybe its just me
  191. oxygen sensor part number
  192. 20" wheels and lowered?
  193. 2k2 Clutch
  194. Just installed my MAF and guess what ??
  195. 2K3 - Oil consumption SOLVED!! Finally!!
  196. Got new Cattman rear muffler section *pics*
  197. Manual tranny….oil…
  198. ECU Update/Rev Issue
  199. sign of a blown strut?
  200. Damn VIS
  201. 5.5 Gen + Mobil 1 = Low Oil in 1000 miles
  202. steering wheel shakes and turns when braking
  203. stupid in dash LED'S
  204. Exterior/Interior Lighting Recommendations for White Color
  205. 2000 SE cold air intake
  206. Bank 1 Sensor 2 Where is it?
  207. Off roading in the max(sort of)
  208. way to improve radio signal strength in aftermarket HU?
  209. Frankencar cai
  210. Manual to Auto climate control
  211. removing muffler w/ rusted bolts
  212. 5-Speed LEAKING CRAP IM SCREWED....
  213. tweeters/midbass in the rear
  214. Yet another HID question
  215. SLIP light keeps turning on
  216. Please help me out
  217. It's official! No more payments!!!
  218. Stock muffler or after market with headers?
  219. i have never ever known this..
  220. Y-pipe trouble.....
  221. SES light not going off
  222. Broken into ... again
  223. Coil help please!!
  224. metal on metal rubbing sound from front wheels...please give input!
  225. I'm getting an annoying noise....
  226. web hosting...
  227. sick and tired of freaking coils
  228. front markers installation instructions needed
  229. Getting sick of the drone from my exhuast....
  230. Shifter bushings
  231. Helios 6000k H4 Hi/Lo Pics
  232. 3.5L in the snow(good/bad)?
  233. CV Joints?????
  234. Lexus IS350
  235. New Battery?
  236. DDE Problems
  237. LSD and TCS info
  238. has this ever happened to anyone before?
  239. My Airbag light is blinking. What do I do?
  240. need to tune up and replace parts need help
  241. Fender Bender Maxima Accident
  242. rust on rotors
  243. Has anyone though of adding a radiator cooling cover?
  244. help.....socket stuck in spark plug hole....any ideas?
  245. HID Ballasts mounting?
  246. Redlinemax.com-5th gen final pics inside
  247. brake pads..will these work??
  248. Corrosion deposits on battery bracket. How to prevent?
  249. Muffler install questions? ASAP!
  250. BBK for 5.5 gen max
