- tociko blues w/ drop?
- Thule rack install issue/question
- VIAS Delete
- Cat back exhaust?. Your help :)
- Camshaft sensor
- WTB Tsudo Or BBP exhaust
- Oil leak - am I in trouble based on these pics?
- Slow decline in power over last 6 months...thoughts????
- 2K AT Substitute MT Motor Mounts?
- best performace spark plugs to use
- Removing My AE Lip
- y pipe flex section replacement?
- HELP, with window problom
- Cattman y pipe installation on a 03
- whats going on???
- Yet another dyno graph Thread...
- instead of gutting pre cats...
- will this motor mount fit my 02
- Exedy Stage 1 Racing Clutch
- Seeking long term assessment on NWP Spacers
- 00-01 se tails
- nwp spacer ?
- Pics of painted rims on 5.5
- Please don't be maf...
- q45 brakes will they work on the max
- How accurate is your speedometer/odometer
- Got the new brakes in but holy crap ARE THEY HOT! Too hot???
- ABS LIGHT?
- Best red tail light bulbs
- Dealership Quote, "We do not sell fuel filters, its lifetime."
- What could it be?
- Rust free rotors
- Navigation bypass while in motion
- Will I scrape?
- Ideas for Knock Sensor Removal?
- Opinions on OEM spoiler or no spoiler
- Tranny
- Dealing with noises from right front
- SRS Control Unit?
- 6mt randomly getting hard to get in gear??
- Something is wrong with my transmission...
- S/R deflector, to remove or keep?
- Fog Light Replacement. Need Help/Advice
- Where can I get a CF - VC cover ?
- Muffler/Exhaust question
- Will front motor mount from 1995-99 fit on my 5.5 ?
- 350z Spacer
- best price on tokico illuminas?
- In car lap top mount
- Need Help Finding The Airbag Module?
- Lights on climate control
- G35 seats to fit in 5th gen?
- Is there a tutorial out there on how to change brakes?
- New IACV equals new ECU??
- Centercap Help :)
- Is this maxima worth getting repaired?
- Price and best place to buy ignition coils?
- Headlight Question?
- 5.5gen....oil...
- wierd thumping sound at low speeds
- Wiper Problems
- Oil lead near rear subframe = rear valve cover gasket leaking?
- New axle is in and I can feel the car enaging the axles at different tiimes
- Strut bearing acting up?
- rx8 vs 01 maxima
- Just picked up a max and... no base?
- Changing the wheel bearings on a 2003
- Differential and input bearing part numbers
- Need a picture of this...please
- Need pic of black stock rims 17" SE
- will 4th gen crank pulley work on 5.5 gen
- Starter Question...real quick and easy one
- P0228- Throttle Positioning Sensor Code
- Where can I find this little part?
- Has anyone redone the rings in thier VQ35?
- Odd starting problem.
- Suspension Noises
- What do you guys think? (Wheel Opinions)
- PAINFULLY slow 03 se te... its agonizing
- Borg Warner coil
- Which Intake?
- Did the 02 and 03 Maximas come standard with xenon headlights?
- How much and how long to bleed brakes?
- UR Crank Pulley Underdrive
- is an alignment needed when changing Sway bar end links
- No Tint On Sunroof??.. What is this about?
- P1320 and P0300
- How to install O2 SideSkirts on a 2k?.
- Seat Covers..
- The NWP Engineering Engine Torque Link - Interest Thread
- VQ35 5th Gen Maxima a good first car?
- Which way do I turn the socket to change the oil?
- 2002 weak accel.
- vac leak?? pics
- Damn exhaust rattle is driving me crazy!
- Mystery rattle on 5.5 gen
- Transverse recall ??
- STEERING COLUMN NOISE
- What strut boot to use
- Blose 6cd changer
- Installing Headers this weekend!!!
- Dave B?????
- Replacing Wiper Pivot Assy?!?
- Whining sound coming from one of my tires
- Gut tells me I'm getting ripped on brakes....
- I am going to get flamed like hell for this one, maaco does a good paint job if...
- Cannot remember for the life of me!
- key ring light help....
- Need some ideas..
- CODES AGAIN..ADVISE PLEASE..
- Alternative To Ebay Foglights?
- Safe fix for headlight condensation?
- *New Release* Nitto NT850 Premium Touring Tire
- Power loss issue.... vias maybe???
- 3.0 to 3.5 engine swap
- Changing out Power Steering Hose
- Exhaust
- Need AE Rear Bumper
- Is a tune required for intake spacers and VIAS plate?
- Racingline Battery Tie Down
- 2002 SE Wheel Center Caps
- Time to buy me some springs. But first...
- Girl rear ended me a couple days ago :(
- very strange noise.....walkman on FF??
- ordered a keyfob and its not working??? possible solution found
- Rear Driver side Door help.
- Anyone know the 0-60 time for the 02s and 03s?
- 01-Anniversary lip on 02 Max
- Spark Plug change without removing upper plenum
- My car dies while idling in drive due to low rpm's
- What maintenance should I do at 85k before a long trip?
- catback question
- How many quarts for this refill?
- 5th Gen Gauges
- I think my tranny might be toast...
- So I'm AEing my '00 headlights but have a question
- Rattle noise and the solution.
- busted extended wheel stud
- Odd power issue
- Replaced both O2 Sensors,and codes are back, Please advice.
- some misc. questions
- 2005 s2000 vs 2003 maxima ???
- Reconditioned the headlights today... looks so much better
- p1572 and p0021....just came on today
- WTF! Why is the car doing this?!?!
- clutch fluid leaking faster now.
- Saved the I35 motor from immenent oil consumption......
- Anybody has one?
- $60 intake setup
- E3 spark plug review for 00 Max
- Rear Seatbelt LOCKUP
- Does this tie rod end look right to you?
- Locked out of 02 max- actuators?
- ??? Re: Factory Alarm System
- Sound comparison - Apexi/K&N/AEM PopChargers vs. GAB
- Problems with accleration HELP!!
- Anyone tried LED headlight bulbs?
- cold start issues. 2000 se
- Issue completing drive cycle
- Exhaust cut-out location?
- Just put in Tranny, now Tachometer doesnt work!
- strange glove box problem
- E3 Spark Plugs
- Sourcing new OEM replacement HID ballast
- 06 HLSD 6spd spun bearing?
- Complete OBX Headers/Y-pipe Installation Writeup
- Car repair checklist, @115k and need advice
- 5th Gen Fog Lights
- Anyone ever mount G35 sedan seats in a Max?
- ES Motor Mounts!
- how to test ballas and HID
- brake help
- Clutch Hose Removal
- Problems with idle, loss of power accelerating
- Clutch related advice .. aftermarket or no?
- Car overheats in traffic but cools down when moving
- Best Rotors and pads for 6th gen Calipers
- Double Din dash kit for bose on 5th gen HELP
- Engine swap align flyweel w.crank sensor
- Would a 2000 ECU work in an '01?
- Problem after taking my rear passenger wheel off to change ABS sensor
- START-UP ISSUES - MECHANIC THINKS FLYWHEEL. THOUGHTS?
- Radiator fan issues
- Whats the best way to paint the Chrome window trim?
- Intake and coil over
- Paintin' the grille...need suggestions.
- Bose Headunits..
- need help with my a/c
- A/C problem
- E brake handle to complement Greddy shift knob
- Fuel cleaner, codes?
- Problem After Installing o2 Simulator
- is it okay to drive with vacuum leak?
- When it rains it pours!
- air conditioning
- The P0340/Camshaft Recall Nissan Saga/Ordeal
- drivers side oil leak... what to check for?
- P0505-Help!
- ABS Light
- Misfiring after Headers install??
- Need help with turbo timer.
- Whats wrong with my brakes?
- O2 Sensors... Anyone have a clue???
- Strange noise!!!???? help..
- Transmission Leak because of clutch????
- I need a short Block
- NWP VQ30DEK intake manifold spacer REVIEW.....
- cold air intake problems
- Need to order brakes please suggest where to buy!
- Can new MAF sensor be put into old MAF tube?
- Just a general RANT and RAVE...
- Rattle over bumps and at engine shut off
- Major issure with brakes - ABS light on, Odd sounds, Brake failures
- Clutch replacement question
- Seafoam?
- Cattman needs 5th gen Max in SoCal for parts development
- Disposing Antifreeze
- How should I Break-In new rotors and pads??
- Clutch Pedal fell half way to the floor
- 02 - 03 maxima ANGEL EYE
- Maxima indicator light problems
- Battery..
- In the process of replacing alternator today...but I'm stuck
- Front end noise
- Stock Diameter Pulley - Advantages?
- Question for owners with B&M Auxiliary Tranny SuperCooler
- Fiamm Highway Blaster Horns
- strange electrical problem. unlike anything i have read about.
- Vent Shades for 2001 Maxima GLE
- S.O.S. noise under acceleration
- 02 Max hesitation
- Lights Out!!!
- PAC SWI-X Write...do we have one here?
- QUIK help with my belt squeel!!!
- someone help me out!
- LED tail light resisters 2 green wires which one?
- Lights went out
- Just had my clutch changed
- ? about spacer thickness
- Urgent: What the he11 is wrong with my HID wiring???
- How to remove stock grill?
- Flasher/Blinker Unit?
- GM Synchromesh trans fluid for the 6-speed?
- squeaky sound when turning from steering wheel area help!!
- Need LED brake light bulbs for clear tails, i finally got pulled
- fog light glare gaurd removal? lexus fog mods
- Is there a write up?
- Not liking maxima anymore..
- Humming noise comming out of the engine
- New Axle, new vibration...any input?
