View Full Version : 5th Generation Maxima (2000-2003)
  1. Codes P0171 and P0174..help..
  2. looking for maxima 2000 wireing diagrams
  3. what year was my car made
  4. Removing the Wind Deflector (your thoughts)
  5. 03 bose HU ipod hook up
  6. Tire size
  7. Does it play CD-RW
  8. ned help deciding on a clutch
  9. cant rev past 2400, blown maf?
  10. Is alignment needed after wheel bearings
  11. best place for used parts
  12. Polarg Bulbs for reverse lights?
  13. Messed up my instrument cluster
  14. Jerking Car
  15. Tein H-Tech (4th Gen same as 5th Gen????)
  16. 04-05 Center rims cap fits G35 rims
  17. wat intakes.....
  18. 2K2 HotShot Header/Y-Pipe Recommendations?
  19. question about Nissan AE kit's sideskirt
  20. I know, enough about brake pads already...
  21. should a CAI be removed in the winter
  22. Just got my Illuminas, but one is broken??!?!!
  23. Squeak when closing door
  24. Axxis/PBR ultimates review
  25. chattering wipers
  26. Where to cut and program new transponder key?
  27. Does Anyone have 255/35/19 ?? getting New Tires
  28. Question: Climate control lights are out
  29. Transmission Swap
  30. why there is there is a 2-3 sec delay? and how to overcome
  31. FLAT tire :-(
  32. Frosty Returns?! And other VQ oddities..
  33. Wassup with these inexpensive coilovers on ebay?
  34. How to check for frozen calipers?
  35. Tips/Tricks on Umnitza DDES?? PLEASE
  36. Remote FOB program instructions???
  37. High Idle..
  38. My Hotshot header install experience (20 pictures, 4.38mb)
  39. hawks vs Axxis Ultimate brake pads.
  40. belt problem
  41. VIAS working??
  42. 02-03 pulley is it worth getting? please help.
  43. Is it me or do the factory rotors just suck?
  44. What are your past issues that carry from car to car.
  45. Best mod ever if your at the track
  46. What about this brake kit?????
  47. o2 sensor part number issues....
  48. anyone else have this???
  49. need HELP with Umnitza DDE's!!!
  50. whats the best setting on illuminas?
  51. Sunroof Button
  52. SES Light Codes P0455 & P1448
  53. Re: Help ( Transmission Problem )
  54. 2002 Maxima - P1448 and P0447
  55. 02 front bumper on a 00 car???
  56. Never doubt the org
  57. VIAS Fix - Anyone willing to help me that lives in the Boston area?
  58. altima lsd fit?
  59. Air Bag Suspension
  60. 00 Ebay Projectors Install
  61. Transmission Swap 6SPD VQ35de
  62. drop only the front side?
  63. Finally! Problem figured out and fixed!
  64. correct part number for....
  65. LEDs in stock tailight?
  66. FS: '01 front heated '01 sensor-CHEAP!
  67. suspension trashed...need advice/thoughts
  68. How to change calipers?
  69. 2K2 MAF Fix/Replace Options
  70. 2000 Maxima ground strap under the car?
  71. 00 Reverse Glow Gauges
  72. i have a custom turbo for sale in the for sale section
  73. Ebay bumper cover??
  74. 5th gen CV Axles
  75. slippage between 4th and 5th gear (manual tranny)
  76. Installed Fidanza flywheel and...
  77. reading ABS error code again
  78. I got H&R's right now...whats the ride comparision of the Teins Htech and Stech?
  79. Oxygen Sensors and you Maxima
  80. bad day... help... anyway to fix?(pic inside)
  81. Need help with wierd MAF issue
  82. Just lamn-x'd my tail lights....
  83. k & N allows more dirt in
  84. idle air control valve? clean it or get a new one?
  85. squakes and rattles, what is happeing.
  86. cheaper answer to coil problom
  87. Re: Transmission filter change
  88. How often do you shift w/o clutch???
  89. Gas/Exhaust smell in the car.
  90. Throttlebody Cleaning instructions
  91. Catalyst below efficiency level
  92. Alternator job
  93. Yes another MAF question But could someone Help confirm my problem!
  94. y- pipe
  95. front lip time, but which one
  96. pop tabs to fix rear deck rattle
  97. Solid Pedal Feel, But Brakes arent biting.
  98. Creating a 3.3 with 3.5 parts on a 3.0
  99. So after test driving teh crap out of a VQ35...I want one
  100. PICS REQUEST....if possible..anyone??
  101. Question for anyone who has removed heated sterring wheel
  102. Bose HU Aux in?
  103. car won't turn over, help!
  104. foglight options
  105. Brake shudder
  106. Problem with fogs
  107. Car Problem - Thunking Noise in Reverse
  108. 2002 se tail lights
  109. Can 2k2 springs fit on 2k?
  110. Brake Upgrade, feedback after 1000+ miles
  111. final verdict......blue LED window switches
  112. Anyone know this car? JN1DA31D72T433739
  113. 2k2 3.5L -- Did an oil change last night, this morning car made an awful rattling.
  114. white 5th gens.. 20% vs 35% tint.. pics please?
  115. How do I push in the left axle
  116. rpm's go up, car not so much
  117. DDE remote on...HELP!!!!!
  118. Cluster Question
  119. HELP - O2 Sensor Connector Issue
  120. 01 rear stud length size?
  121. 2003 GLE Bumper Skins
  122. how do I remove climate control unit and radio?
  123. Questions about carpet replacement...
  124. bump stops
  125. Bone Stock Dyno Run?
  126. Power valve actuator
  127. 2001 Nissan Maxima GXE - Drag Racing Videos
  128. Aftermarket Rear Bumper
  129. Clutch engine noises?
  130. bad luck today
  131. 2k - 2k1 steering wheel swap?
  132. Problem with power seat.. driver
  133. Nissan's warranties and what they cover. (Need list of Nissan's standard warranties)
  134. DDE's...WHATS SUPPOSED TO BE IN THE BOX??
  135. HELP!! A/C Related
  136. Help, need some dignostics...
  137. What's the name of that part?
  138. Greddy Exhaust with Silencer...way a maxima should sound
  139. fixing exhaust leak
  140. Headlights....please help
  141. HELP - put in new shoks...now crazy squeeks
  142. Quick Photoshop Request
  143. Quick 2k2 rear susp. question
  144. how do I make my climate control, clock, and bose display blue?
  145. Anyone have the 5th gen repair manual in pdf format?
  146. changing fog light bulbs
  147. Metal scraping on metal sound coming from wheels..
  148. My foot is off the gas yet my engine still revs..
  149. Stillen Headers
  150. Any alternative to 2k1 Intake manifold...
  151. headlights dont work HELP!!
  152. rain issues need help bad!!!
  153. what size axle nut socket for 02 auto
  154. Greddy Exhaust rusted to no end.. needs replacement. What should I get?
  155. help with belts please
  156. help grease around cv boot, is it leaking?
  157. My 2k Has a Flacid Clutch
  158. Changed my tranny fluid today (5spd)
  159. help - to all break guys
  160. Prolumen HID Fog Kit Install help
  161. 2k1 technosquare ecu?
  162. Choices choices... help me decide...
  163. bad morning - $850 bill at stealership
  164. P0171 - Maf?
  165. Air Filter Heat Shield
  166. Best Mod Ever!!!!!
  167. Hissing noise-engine stalling
  168. Hard-Wired OBD ???
  169. g35 brakes
  170. ATTN : chris'max
  171. QUICK question on e-brake on 2K
  172. Well there goes my drivers headlight....(do g35 ballast or morano fit max light?)
  173. H&R Wheel Spacers
  174. where to get rear strut bar?
  175. How to install 02-03 Headlights in an 00-01
  176. I have the CEL on with a P0138 code...is this a warranty repair or not?
  177. What a way to start the day....with a ?
  178. Help with brake issues.. Caliper problems?
  179. Just had the stillen y installed....
  180. warranty question (your opinion)
  181. will these foglight bulbs fit my maxi?
  182. New Maxima owner, 2k2 SE
  183. ??? Difference in chrome wheels ???
  184. Stuck In Park
  185. Check Engine Light...
  186. Those of you with H4 Hi/Low HID's.....
  187. 3.5 engine sound pretty good
  188. Progress Springs w/ Tockio Illuminas
  189. Someone Busted Out My Windows
  190. Idle puley in 3.0
  191. replaced alternator
  192. 2000-2001 Ignition Coils??
  193. Buying '01 AE this weekend, few questions
  194. S-Techs w/Illuminas
  195. Buying G35 rims on Saturday..which lugnuts should I buy...
  196. interior lights
  197. Passenger Side Power Seat
  198. Damn. The Y-Pipe is a pain to install....
  199. bad engine mounts?
  200. Help..... A.s.a.p
  201. Possible solution to rattling sound under low RPM's
  202. dash removal tips
  203. Need 2k2 wiring diagram for HID's
  204. Exhaust Problem/Question/Advice needed
  205. Car Trouble Help!!!
  206. Throttle body service problems
  207. Computer Drive Cycle
  208. Known 2K2 Issues
  209. What to Have Nissan Test For Possible Failed Converter/Burning Oil
  210. Your opinions
  211. headlamps don't work and fogs too
  212. Spon J Neous - Supercalifragilistic Music Video Featuring 5th Gen
  213. Blower Motor Resistor Help plz
  214. Q: Will '00 stillen classic body kit fit an '02?
  215. Pics of removed black plastic from b pillar
  216. NEED to buy Car cover
  217. Brakes are screeching !
  218. Having Steering/Shimmy Issues...
  219. Auto Climate Control Fan Speed Problem
  220. Okay Light in dash came on..
  221. Top Speed Y Pipe
  222. Door Trim Question
  223. should alignment be done w/driver in the car?
  224. quick question on the frankencar website..
  225. Clutch adjustment?
  226. Race/ Test Pipe
  227. replacing 2k2 hid headlight with 20th aniversary headlights
  228. NEED HELP WITH umnitza dde's
  229. I'm quickly starting to hate my car more...(Electric issues)
  230. Read the stalling threads.....followed, but more problems!
  231. Need help with engine codes!!!
  232. my car is shaking
  233. Help installing y-pipe
  234. rattling..
  235. ABS and/or Brake Related Issue
  236. Chances of a bad alternator ???
  237. Car Got Broken into, Help Needed
  238. Need help with under drive pulley.
  239. Spoiler
  240. Bose System.....Warranty or TSB?
  241. the pcv valve replacement
  242. Need help plz
  243. rotors advice 300zx caliper
  244. how-to 4 rsb doesnt work...post link?
  245. Vid: dyno run
  246. Help with a DIY mod (HID) ...
  247. Looking To buy a 5th gen
  248. huh? 5.5 se grill and 5.5 gxe grill
  249. A33 Series 2000-2001 APEXi S-AFC II Pin Location On ECM
  250. Squealing sound when I turn the wheel to the right
